[GRASS-SVN] r51036 - grass/branches/develbranch_6
svn_grass at osgeo.org
Sun Mar 11 15:51:37 EDT 2012
Author: neteler
Date: 2012-03-11 12:51:37 -0700 (Sun, 11 Mar 2012)
New Revision: 51036
grass/branches/develbranch_6/configure
grass/branches/develbranch_6/configure.in
jpeg refs removed
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure 2012-03-11 19:50:23 UTC (rev 51035)
+++ grass/branches/develbranch_6/configure 2012-03-11 19:51:37 UTC (rev 51036)
@@ -33,8 +33,6 @@
--with-macosx-sdk[=path/sdk]
compile with a system SDK on MacOSX. (default: no)"
ac_help="$ac_help
- --with-jpeg support JPEG functionality (default: yes)"
-ac_help="$ac_help
--with-tiff support TIFF functionality (default: yes)"
ac_help="$ac_help
--with-png support PNG functionality (default: yes)"
@@ -112,11 +110,6 @@
--with-readline-libs=DIRS
Readline library files are in DIRS"
ac_help="$ac_help
- --with-jpeg-includes=DIRS
- JPEG include files are in DIRS"
-ac_help="$ac_help
- --with-jpeg-libs=DIRS JPEG library files are in DIRS"
-ac_help="$ac_help
--with-tiff-includes=DIRS
TIFF include files are in DIRS"
ac_help="$ac_help
@@ -755,7 +748,7 @@
fi
echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:759: checking host system type" >&5
+echo "configure:752: checking host system type" >&5
host_alias=$host
case "$host_alias" in
@@ -778,7 +771,7 @@
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:782: checking for $ac_word" >&5
+echo "configure:775: checking for $ac_word" >&5
if test -n "$CC"; then
ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -805,7 +798,7 @@
# Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
-echo "configure:809: checking for $ac_word" >&5
+echo "configure:802: checking for $ac_word" >&5
@@ -853,7 +846,7 @@
# Extract the first word of "cl", so it can be a program name with args.
set dummy cl; ac_word=$2
-echo "configure:857: checking for $ac_word" >&5
+echo "configure:850: checking for $ac_word" >&5
@@ -882,7 +875,7 @@
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:886: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:879: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
ac_ext=c
# CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -893,12 +886,12 @@
cat > conftest.$ac_ext << EOF
-#line 897 "configure"
+#line 890 "configure"
#include "confdefs.h"
main(){return(0);}
EOF
-if { (eval echo configure:902: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cc_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -924,19 +917,19 @@
{ echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:928: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:921: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
cross_compiling=$ac_cv_prog_cc_cross
echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:933: checking whether we are using GNU C" >&5
+echo "configure:926: checking whether we are using GNU C" >&5
cat > conftest.c <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:940: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:933: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gcc=yes
else
ac_cv_prog_gcc=no
@@ -954,7 +947,7 @@
ac_save_CFLAGS="$CFLAGS"
CFLAGS=
echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:958: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:951: checking whether ${CC-cc} accepts -g" >&5
echo 'void f(){}' > conftest.c
if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -983,10 +976,10 @@
fi
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:987: checking for Cygwin environment" >&5
+echo "configure:980: checking for Cygwin environment" >&5
cat > conftest.$ac_ext <<EOF
-#line 990 "configure"
+#line 983 "configure"
int main() {
@@ -997,7 +990,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:1001: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:994: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -1013,17 +1006,17 @@
CYGWIN=
test "$ac_cv_cygwin" = yes && CYGWIN=yes
echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:1017: checking for mingw32 environment" >&5
+echo "configure:1010: checking for mingw32 environment" >&5
-#line 1020 "configure"
+#line 1013 "configure"
int main() {
return __MINGW32__;
; return 0; }
EOF
-if { (eval echo configure:1027: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1020: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_mingw32=yes
else
@@ -1041,7 +1034,7 @@
echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1045: checking for executable suffix" >&5
+echo "configure:1038: checking for executable suffix" >&5
if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
ac_cv_exeext=.exe
@@ -1060,23 +1053,23 @@
IEEEFLAG=
echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1064: checking for full floating-point support" >&5
+echo "configure:1057: checking for full floating-point support" >&5
if test "$cross_compiling" = yes; then
echo "$ac_t""unknown (cross-compiling)" 1>&6
echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1069: checking whether "cc -mieee" works" >&5
+echo "configure:1062: checking whether "cc -mieee" works" >&5
ac_save_cflags=${CFLAGS}
CFLAGS="$CFLAGS -mieee"
-#line 1073 "configure"
+#line 1066 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:1080: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1073: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
IEEEFLAG="-mieee"
@@ -1092,7 +1085,7 @@
else
-#line 1096 "configure"
+#line 1089 "configure"
#include <float.h>
@@ -1106,7 +1099,7 @@
EOF
-if { (eval echo configure:1110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
@@ -1119,14 +1112,14 @@
CFLAGS=-mieee
echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1123: checking for full floating-point support with -mieee" >&5
+echo "configure:1116: checking for full floating-point support with -mieee" >&5
{ echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
else
-#line 1130 "configure"
+#line 1123 "configure"
#include <float.h>
@@ -1140,7 +1133,7 @@
EOF
-if { (eval echo configure:1144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
IEEEFLAG="-mieee"
@@ -1177,7 +1170,7 @@
# Extract the first word of "pwd", so it can be a program name with args.
set dummy pwd; ac_word=$2
-echo "configure:1181: checking for $ac_word" >&5
+echo "configure:1174: checking for $ac_word" >&5
case "$pwd" in
@@ -1215,7 +1208,7 @@
fi
echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1219: checking for source directory" >&5
+echo "configure:1212: checking for source directory" >&5
if test -z "$srcdir" ; then
SRCDIR=`$pwd`
@@ -1226,7 +1219,7 @@
echo "$ac_t"""$SRCDIR"" 1>&6
echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1230: checking for build directory" >&5
+echo "configure:1223: checking for build directory" >&5
DSTDIR=`$pwd`
WINDSTDIR=`$winpwd`
@@ -1294,7 +1287,7 @@
# Extract the first word of "svnversion", so it can be a program name with args.
set dummy svnversion; ac_word=$2
-echo "configure:1298: checking for $ac_word" >&5
+echo "configure:1291: checking for $ac_word" >&5
case "$SVN_VERSION" in
@@ -1353,7 +1346,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1357: checking for MacOSX App" >&5
+echo "configure:1350: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1365,7 +1358,7 @@
# Check for MacOSX archs
echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1369: checking for MacOSX architectures" >&5
+echo "configure:1362: checking for MacOSX architectures" >&5
MACOSX_ARCHS=
@@ -1394,7 +1387,7 @@
# Check for MacOSX SDK
echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1398: checking for MacOSX SDK" >&5
+echo "configure:1391: checking for MacOSX SDK" >&5
MACOSX_SDK=
@@ -1404,7 +1397,7 @@
ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1408: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1401: checking for $with_macosx_sdk/SDKSettings.plist" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1448,7 +1441,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1452: checking how to build libraries" >&5
+echo "configure:1445: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -1491,7 +1484,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:1495: checking for $ac_word" >&5
+echo "configure:1488: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1516,7 +1509,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1520: checking how to run the C preprocessor" >&5
+echo "configure:1513: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -1529,13 +1522,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 1533 "configure"
+#line 1526 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1539: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1532: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -1546,13 +1539,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 1550 "configure"
+#line 1543 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1556: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1549: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1563,13 +1556,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 1567 "configure"
+#line 1560 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:1573: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1566: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1597,7 +1590,7 @@
# Step 0.a: Enable 64 bit support?
echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1601: checking if 64bit support is requested" >&5
+echo "configure:1594: checking if 64bit support is requested" >&5
# Check whether --enable-64bit or --disable-64bit was given.
if test "${enable_64bit+set}" = set; then
enableval="$enable_64bit"
@@ -1617,7 +1610,7 @@
# Step 0.b: Enable Solaris 64 bit VIS support?
echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1621: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1614: checking if 64bit Sparc VIS support is requested" >&5
# Check whether --enable-64bit-vis or --disable-64bit-vis was given.
if test "${enable_64bit_vis+set}" = set; then
enableval="$enable_64bit_vis"
@@ -1641,7 +1634,7 @@
# there are a few systems, like Next, where this doesn't work.
echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1645: checking system version (for dynamic loading)" >&5
+echo "configure:1638: checking system version (for dynamic loading)" >&5
if test -f /usr/lib/NextStep/software_version; then
system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
else
@@ -1667,13 +1660,13 @@
# Linux can use either -ldl or -ldld for dynamic loading.
echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1671: checking for dlopen in -ldl" >&5
+echo "configure:1664: checking for dlopen in -ldl" >&5
ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-ldl $LIBS"
-#line 1677 "configure"
+#line 1670 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -1684,7 +1677,7 @@
dlopen()
; return 0; }
EOF
-if { (eval echo configure:1688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -1731,7 +1724,7 @@
# Extract the first word of "ar", so it can be a program name with args.
set dummy ar; ac_word=$2
-echo "configure:1735: checking for $ac_word" >&5
+echo "configure:1728: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1860,13 +1853,13 @@
# known GMT value.
echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1864: checking for gettimeofday in -lbsd" >&5
+echo "configure:1857: checking for gettimeofday in -lbsd" >&5
ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 1870 "configure"
+#line 1863 "configure"
@@ -1877,7 +1870,7 @@
gettimeofday()
; return 0; }
EOF
-if { (eval echo configure:1881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1918,13 +1911,13 @@
# is always linked to, for compatibility.
echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1922: checking for inet_ntoa in -lbind" >&5
+echo "configure:1915: checking for inet_ntoa in -lbind" >&5
ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-lbind $LIBS"
-#line 1928 "configure"
+#line 1921 "configure"
@@ -1935,7 +1928,7 @@
inet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:1939: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1996,13 +1989,13 @@
SHLIB_SUFFIX=".sl"
echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:2000: checking for shl_load in -ldld" >&5
+echo "configure:1993: checking for shl_load in -ldld" >&5
ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
LIBS="-ldld $LIBS"
-#line 2006 "configure"
+#line 1999 "configure"
@@ -2013,7 +2006,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:2017: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -2078,13 +2071,13 @@
HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
SHLIB_SUFFIX=".sl"
-echo "configure:2082: checking for shl_load in -ldld" >&5
+echo "configure:2075: checking for shl_load in -ldld" >&5
LIBS="-ldld $LIBS"
-#line 2088 "configure"
+#line 2081 "configure"
@@ -2095,7 +2088,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:2099: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -2217,15 +2210,15 @@
else
ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2221: checking for dld.h" >&5
+echo "configure:2214: checking for dld.h" >&5
-#line 2224 "configure"
+#line 2217 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2229: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2222: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2285,15 +2278,15 @@
else
-echo "configure:2289: checking for dld.h" >&5
+echo "configure:2282: checking for dld.h" >&5
-#line 2292 "configure"
+#line 2285 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2297: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2290: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2390,9 +2383,9 @@
CC_SEARCH_FLAGS=""
LD_SEARCH_FLAGS=""
echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2394: checking for ELF" >&5
+echo "configure:2387: checking for ELF" >&5
-#line 2396 "configure"
+#line 2389 "configure"
#ifdef __ELF__
@@ -2422,15 +2415,15 @@
# Not available on all versions: check for include file.
ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2426: checking for dlfcn.h" >&5
+echo "configure:2419: checking for dlfcn.h" >&5
-#line 2429 "configure"
+#line 2422 "configure"
#include <dlfcn.h>
EOF
-{ (eval echo configure:2434: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2427: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2454,9 +2447,9 @@
CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2458: checking for ELF" >&5
+echo "configure:2451: checking for ELF" >&5
-#line 2460 "configure"
+#line 2453 "configure"
#ifdef __ELF__
@@ -2780,17 +2773,17 @@
# that don't grok the -Bexport option. Test that it does.
hold_ldflags=$LDFLAGS
echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2784: checking for ld accepts -Bexport flag" >&5
+echo "configure:2777: checking for ld accepts -Bexport flag" >&5
LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2787 "configure"
+#line 2780 "configure"
int main() {
int i;
; return 0; }
EOF
-if { (eval echo configure:2794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2787: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
found=yes
else
@@ -2946,16 +2939,6 @@
fi
-# Check whether --with-jpeg or --without-jpeg was given.
-if test "${with_jpeg+set}" = set; then
- withval="$with_jpeg"
-else
- with_jpeg=yes
-fi
# Check whether --with-tiff or --without-tiff was given.
if test "${with_tiff+set}" = set; then
withval="$with_tiff"
@@ -3251,23 +3234,6 @@
-# Check whether --with-jpeg-includes or --without-jpeg-includes was given.
-if test "${with_jpeg_includes+set}" = set; then
- withval="$with_jpeg_includes"
-fi
-# Check whether --with-jpeg-libs or --without-jpeg-libs was given.
-if test "${with_jpeg_libs+set}" = set; then
- withval="$with_jpeg_libs"
-fi
# Check whether --with-tiff-includes or --without-tiff-includes was given.
if test "${with_tiff_includes+set}" = set; then
withval="$with_tiff_includes"
@@ -3615,7 +3581,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3619: checking for additional include dirs" >&5
+echo "configure:3585: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3638,7 +3604,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3642: checking for additional library dirs" >&5
+echo "configure:3608: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3672,7 +3638,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3676: checking for a BSD compatible install" >&5
+echo "configure:3642: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -3725,7 +3691,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:3729: checking for $ac_word" >&5
+echo "configure:3695: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3756,13 +3722,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3760: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3726: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
LIBS="-l$ac_lib $LIBS"
-#line 3766 "configure"
+#line 3732 "configure"
@@ -3773,7 +3739,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:3777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3798,7 +3764,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:3802: checking for $ac_word" >&5
+echo "configure:3768: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -3838,7 +3804,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:3842: checking for $ac_word" >&5
+echo "configure:3808: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3869,7 +3835,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:3873: checking for $ac_word" >&5
+echo "configure:3839: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -3907,7 +3873,7 @@
-echo "configure:3911: checking for $ac_word" >&5
+echo "configure:3877: checking for $ac_word" >&5
@@ -3936,7 +3902,7 @@
-echo "configure:3940: checking for $ac_word" >&5
+echo "configure:3906: checking for $ac_word" >&5
@@ -3967,7 +3933,7 @@
-echo "configure:3971: checking for $ac_word" >&5
+echo "configure:3937: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3996,7 +3962,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:4000: checking for $ac_word" >&5
+echo "configure:3966: checking for $ac_word" >&5
case "$PERL" in
@@ -4027,10 +3993,10 @@
fi
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:4031: checking for ANSI C header files" >&5
+echo "configure:3997: checking for ANSI C header files" >&5
-#line 4034 "configure"
+#line 4000 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -4038,7 +4004,7 @@
#include <float.h>
EOF
-{ (eval echo configure:4042: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4008: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4055,7 +4021,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 4059 "configure"
+#line 4025 "configure"
#include <string.h>
EOF
@@ -4073,7 +4039,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 4077 "configure"
+#line 4043 "configure"
#include <stdlib.h>
EOF
@@ -4094,7 +4060,7 @@
else
-#line 4098 "configure"
+#line 4064 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -4105,7 +4071,7 @@
exit (0); }
EOF
-if { (eval echo configure:4109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -4132,15 +4098,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:4136: checking for $ac_hdr" >&5
+echo "configure:4102: checking for $ac_hdr" >&5
-#line 4139 "configure"
+#line 4105 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4144: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4110: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4169,15 +4135,15 @@
do
-echo "configure:4173: checking for $ac_hdr" >&5
+echo "configure:4139: checking for $ac_hdr" >&5
-#line 4176 "configure"
+#line 4142 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4181: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4147: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4206,15 +4172,15 @@
do
-echo "configure:4210: checking for $ac_hdr" >&5
+echo "configure:4176: checking for $ac_hdr" >&5
-#line 4213 "configure"
+#line 4179 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4218: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4184: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4243,15 +4209,15 @@
do
-echo "configure:4247: checking for $ac_hdr" >&5
+echo "configure:4213: checking for $ac_hdr" >&5
-#line 4250 "configure"
+#line 4216 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4255: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4221: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4280,15 +4246,15 @@
do
-echo "configure:4284: checking for $ac_hdr" >&5
+echo "configure:4250: checking for $ac_hdr" >&5
-#line 4287 "configure"
+#line 4253 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4292: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4258: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4314,10 +4280,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4318: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4284: checking whether time.h and sys/time.h may both be included" >&5
-#line 4321 "configure"
+#line 4287 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -4326,7 +4292,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:4330: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4296: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -4346,10 +4312,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4350: checking for off_t" >&5
+echo "configure:4316: checking for off_t" >&5
-#line 4353 "configure"
+#line 4319 "configure"
#if STDC_HEADERS
@@ -4376,10 +4342,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4380: checking for uid_t in sys/types.h" >&5
+echo "configure:4346: checking for uid_t in sys/types.h" >&5
-#line 4383 "configure"
+#line 4349 "configure"
EOF
@@ -4407,10 +4373,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4411: checking return type of signal handlers" >&5
+echo "configure:4377: checking return type of signal handlers" >&5
-#line 4414 "configure"
+#line 4380 "configure"
#include <signal.h>
@@ -4427,7 +4393,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:4431: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4397: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -4445,10 +4411,10 @@
-echo "configure:4449: checking for Cygwin environment" >&5
+echo "configure:4415: checking for Cygwin environment" >&5
-#line 4452 "configure"
+#line 4418 "configure"
int main() {
@@ -4459,7 +4425,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:4463: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4429: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -4477,10 +4443,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4481: checking for $ac_func" >&5
+echo "configure:4447: checking for $ac_func" >&5
-#line 4484 "configure"
+#line 4450 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -4503,7 +4469,7 @@
; return 0; }
EOF
-if { (eval echo configure:4507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -4529,10 +4495,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:4533: checking for $ac_func" >&5
+echo "configure:4499: checking for $ac_func" >&5
-#line 4536 "configure"
+#line 4502 "configure"
@@ -4555,7 +4521,7 @@
; return 0; }
EOF
-if { (eval echo configure:4559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4581,10 +4547,10 @@
for ac_func in drand48
do
-echo "configure:4585: checking for $ac_func" >&5
+echo "configure:4551: checking for $ac_func" >&5
-#line 4588 "configure"
+#line 4554 "configure"
@@ -4607,7 +4573,7 @@
; return 0; }
EOF
-if { (eval echo configure:4611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4633,10 +4599,10 @@
for ac_func in putenv setenv
do
-echo "configure:4637: checking for $ac_func" >&5
+echo "configure:4603: checking for $ac_func" >&5
-#line 4640 "configure"
+#line 4606 "configure"
@@ -4659,7 +4625,7 @@
; return 0; }
EOF
-if { (eval echo configure:4663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4685,10 +4651,10 @@
for ac_func in nanosleep
do
-echo "configure:4689: checking for $ac_func" >&5
+echo "configure:4655: checking for $ac_func" >&5
-#line 4692 "configure"
+#line 4658 "configure"
@@ -4711,7 +4677,7 @@
; return 0; }
EOF
-if { (eval echo configure:4715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4736,13 +4702,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4740: checking whether setpgrp takes no argument" >&5
+echo "configure:4706: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 4746 "configure"
+#line 4712 "configure"
#ifdef HAVE_UNISTD_H
@@ -4762,7 +4728,7 @@
EOF
-if { (eval echo configure:4766: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -4790,16 +4756,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4794: checking for long long int" >&5
+echo "configure:4760: checking for long long int" >&5
-#line 4796 "configure"
+#line 4762 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:4803: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4769: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
@@ -4819,7 +4785,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4823: checking for W11" >&5
+echo "configure:4789: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -4847,7 +4813,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4851: checking for X" >&5
+echo "configure:4817: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -4907,12 +4873,12 @@
# First, try using that file with no special directory specified.
-#line 4911 "configure"
+#line 4877 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:4916: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4882: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4981,14 +4947,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 4985 "configure"
+#line 4951 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:4992: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -5093,17 +5059,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:5097: checking whether -R must be followed by a space" >&5
+echo "configure:5063: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 5100 "configure"
+#line 5066 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:5107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -5119,14 +5085,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 5123 "configure"
+#line 5089 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:5130: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -5158,13 +5124,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:5162: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:5128: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 5168 "configure"
+#line 5134 "configure"
@@ -5175,7 +5141,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:5179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5196,13 +5162,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5200: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5166: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 5206 "configure"
+#line 5172 "configure"
@@ -5213,7 +5179,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:5217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5241,10 +5207,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5245: checking for gethostbyname" >&5
+echo "configure:5211: checking for gethostbyname" >&5
-#line 5248 "configure"
+#line 5214 "configure"
which can conflict with char gethostbyname(); below. */
@@ -5267,7 +5233,7 @@
; return 0; }
EOF
-if { (eval echo configure:5271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -5287,13 +5253,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5291: checking for gethostbyname in -lnsl" >&5
+echo "configure:5257: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5297 "configure"
+#line 5263 "configure"
@@ -5304,7 +5270,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:5308: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5274: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5333,10 +5299,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5337: checking for connect" >&5
+echo "configure:5303: checking for connect" >&5
-#line 5340 "configure"
+#line 5306 "configure"
which can conflict with char connect(); below. */
@@ -5359,7 +5325,7 @@
; return 0; }
EOF
-if { (eval echo configure:5363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -5379,13 +5345,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5383: checking for connect in -lsocket" >&5
+echo "configure:5349: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5389 "configure"
+#line 5355 "configure"
@@ -5396,7 +5362,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:5400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5419,10 +5385,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5423: checking for remove" >&5
+echo "configure:5389: checking for remove" >&5
-#line 5426 "configure"
+#line 5392 "configure"
which can conflict with char remove(); below. */
@@ -5445,7 +5411,7 @@
; return 0; }
EOF
-if { (eval echo configure:5449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -5465,13 +5431,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5469: checking for remove in -lposix" >&5
+echo "configure:5435: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 5475 "configure"
+#line 5441 "configure"
@@ -5482,7 +5448,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:5486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5505,10 +5471,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5509: checking for shmat" >&5
+echo "configure:5475: checking for shmat" >&5
-#line 5512 "configure"
+#line 5478 "configure"
which can conflict with char shmat(); below. */
@@ -5531,7 +5497,7 @@
; return 0; }
EOF
-if { (eval echo configure:5535: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -5551,13 +5517,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5555: checking for shmat in -lipc" >&5
+echo "configure:5521: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 5561 "configure"
+#line 5527 "configure"
@@ -5568,7 +5534,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:5572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5600,13 +5566,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5604: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5570: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5610 "configure"
+#line 5576 "configure"
@@ -5617,7 +5583,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:5621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5655,7 +5621,7 @@
echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5659: checking whether to use Curses" >&5
+echo "configure:5625: checking whether to use Curses" >&5
echo "$ac_t"""$with_curses"" 1>&6
case "$with_curses" in
"no") USE_CURSES= ;;
@@ -5674,15 +5640,15 @@
do
-echo "configure:5678: checking for $ac_hdr" >&5
+echo "configure:5644: checking for $ac_hdr" >&5
-#line 5681 "configure"
+#line 5647 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5686: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5652: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5713,10 +5679,10 @@
echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5717: checking curses.h WINDOW structure component" >&5
+echo "configure:5683: checking curses.h WINDOW structure component" >&5
CURSES_MAXY=NONE
-#line 5720 "configure"
+#line 5686 "configure"
#include <curses.h>
@@ -5725,7 +5691,7 @@
WINDOW w; w.maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5729: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5695: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=maxy
else
@@ -5734,7 +5700,7 @@
fi
rm -f conftest*
-#line 5738 "configure"
+#line 5704 "configure"
#include <curses.h>
@@ -5743,7 +5709,7 @@
WINDOW w; w._maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5747: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5713: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=_maxy
else
@@ -5759,13 +5725,13 @@
echo "$ac_t""$CURSES_MAXY" 1>&6
echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5763: checking for initscr in -lncurses" >&5
+echo "configure:5729: checking for initscr in -lncurses" >&5
ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lncurses $LIBS"
-#line 5769 "configure"
+#line 5735 "configure"
@@ -5776,7 +5742,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5795,13 +5761,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5799: checking for initscr in -lcurses" >&5
+echo "configure:5765: checking for initscr in -lcurses" >&5
ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lcurses $LIBS"
-#line 5805 "configure"
+#line 5771 "configure"
@@ -5812,7 +5778,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5841,13 +5807,13 @@
echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5845: checking for keypad in -lncurses" >&5
+echo "configure:5811: checking for keypad in -lncurses" >&5
ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5851 "configure"
+#line 5817 "configure"
@@ -5858,7 +5824,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5880,13 +5846,13 @@
echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5884: checking for keypad in -lcurses" >&5
+echo "configure:5850: checking for keypad in -lcurses" >&5
ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5890 "configure"
+#line 5856 "configure"
@@ -5897,7 +5863,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5927,13 +5893,13 @@
fi # $USE_CURSES
echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5931: checking for gtty in -lcompat" >&5
+echo "configure:5897: checking for gtty in -lcompat" >&5
ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lcompat $LIBS"
-#line 5937 "configure"
+#line 5903 "configure"
@@ -5944,7 +5910,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5963,13 +5929,13 @@
echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5967: checking for gtty in -lbsd-compat" >&5
+echo "configure:5933: checking for gtty in -lbsd-compat" >&5
ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd-compat $LIBS"
-#line 5973 "configure"
+#line 5939 "configure"
@@ -5980,7 +5946,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5999,13 +5965,13 @@
echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:6003: checking for gtty in -lbsd" >&5
+echo "configure:5969: checking for gtty in -lbsd" >&5
ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 6009 "configure"
+#line 5975 "configure"
@@ -6016,7 +5982,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:6020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6050,12 +6016,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:6054: checking for library containing cuserid" >&5
+echo "configure:6020: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 6059 "configure"
+#line 6025 "configure"
@@ -6066,7 +6032,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:6070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -6077,7 +6043,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 6081 "configure"
+#line 6047 "configure"
@@ -6088,7 +6054,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:6092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -6114,10 +6080,10 @@
# Note: -lxdr -liberty -lws2_32 is for MinGW
echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:6118: checking for xdrmem_create" >&5
+echo "configure:6084: checking for xdrmem_create" >&5
-#line 6121 "configure"
+#line 6087 "configure"
which can conflict with char xdrmem_create(); below. */
@@ -6140,7 +6106,7 @@
; return 0; }
EOF
-if { (eval echo configure:6144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_xdrmem_create=yes"
else
@@ -6158,13 +6124,13 @@
echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:6162: checking for xdrmem_create in -lsun" >&5
+echo "configure:6128: checking for xdrmem_create in -lsun" >&5
ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lsun $LIBS"
-#line 6168 "configure"
+#line 6134 "configure"
@@ -6175,7 +6141,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6194,13 +6160,13 @@
echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:6198: checking for xdrmem_create in -lnsl" >&5
+echo "configure:6164: checking for xdrmem_create in -lnsl" >&5
ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 6204 "configure"
+#line 6170 "configure"
@@ -6211,7 +6177,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6215: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6230,13 +6196,13 @@
echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:6234: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:6200: checking for xdrmem_create in -lrpclib" >&5
ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lrpclib $LIBS"
-#line 6240 "configure"
+#line 6206 "configure"
@@ -6247,7 +6213,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6266,13 +6232,13 @@
echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6270: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6236: checking for xdrmem_create in -lxdr" >&5
ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lxdr -liberty -lws2_32 $LIBS"
-#line 6276 "configure"
+#line 6242 "configure"
@@ -6283,7 +6249,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6317,10 +6283,10 @@
for ac_func in asprintf
do
-echo "configure:6321: checking for $ac_func" >&5
+echo "configure:6287: checking for $ac_func" >&5
-#line 6324 "configure"
+#line 6290 "configure"
@@ -6343,7 +6309,7 @@
; return 0; }
EOF
-if { (eval echo configure:6347: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6370,10 +6336,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6374: checking for atan" >&5
+echo "configure:6340: checking for atan" >&5
-#line 6377 "configure"
+#line 6343 "configure"
which can conflict with char atan(); below. */
@@ -6396,7 +6362,7 @@
; return 0; }
EOF
-if { (eval echo configure:6400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -6414,13 +6380,13 @@
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6418: checking for atan in -lm" >&5
+echo "configure:6384: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 6424 "configure"
+#line 6390 "configure"
@@ -6431,7 +6397,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:6435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6458,10 +6424,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6462: checking for dlsym" >&5
+echo "configure:6428: checking for dlsym" >&5
-#line 6465 "configure"
+#line 6431 "configure"
which can conflict with char dlsym(); below. */
@@ -6484,7 +6450,7 @@
; return 0; }
EOF
-if { (eval echo configure:6488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -6502,13 +6468,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6506: checking for dlsym in -ldl" >&5
+echo "configure:6472: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 6512 "configure"
+#line 6478 "configure"
@@ -6519,7 +6485,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:6523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6489: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6546,10 +6512,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6550: checking for iconv" >&5
+echo "configure:6516: checking for iconv" >&5
-#line 6553 "configure"
+#line 6519 "configure"
which can conflict with char iconv(); below. */
@@ -6572,7 +6538,7 @@
; return 0; }
EOF
-if { (eval echo configure:6576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -6590,13 +6556,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6594: checking for iconv in -liconv" >&5
+echo "configure:6560: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 6600 "configure"
+#line 6566 "configure"
@@ -6607,7 +6573,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6626,13 +6592,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6630: checking for iconv in -lgiconv" >&5
+echo "configure:6596: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 6636 "configure"
+#line 6602 "configure"
@@ -6643,7 +6609,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6647: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6662,10 +6628,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6666: checking for libiconv" >&5
+echo "configure:6632: checking for libiconv" >&5
-#line 6669 "configure"
+#line 6635 "configure"
which can conflict with char libiconv(); below. */
@@ -6688,7 +6654,7 @@
; return 0; }
EOF
-if { (eval echo configure:6692: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6658: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -6706,13 +6672,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6710: checking for libiconv in -liconv" >&5
+echo "configure:6676: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6716 "configure"
+#line 6682 "configure"
@@ -6723,7 +6689,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6742,13 +6708,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6746: checking for libiconv in -lgiconv" >&5
+echo "configure:6712: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6752 "configure"
+#line 6718 "configure"
@@ -6759,7 +6725,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6796,10 +6762,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6800: checking for socket" >&5
+echo "configure:6766: checking for socket" >&5
-#line 6803 "configure"
+#line 6769 "configure"
which can conflict with char socket(); below. */
@@ -6822,7 +6788,7 @@
; return 0; }
EOF
-if { (eval echo configure:6826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -6840,13 +6806,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6844: checking for socket in -lsocket" >&5
+echo "configure:6810: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 6850 "configure"
+#line 6816 "configure"
@@ -6857,7 +6823,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:6861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6905,7 +6871,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6909: checking for location of zlib includes" >&5
+echo "configure:6875: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6931,15 +6897,15 @@
do
-echo "configure:6935: checking for $ac_hdr" >&5
+echo "configure:6901: checking for $ac_hdr" >&5
-#line 6938 "configure"
+#line 6904 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6943: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6909: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6973,7 +6939,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6977: checking for location of zlib library" >&5
+echo "configure:6943: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6998,13 +6964,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:7002: checking for deflate in -lz" >&5
+echo "configure:6968: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 7008 "configure"
+#line 6974 "configure"
@@ -7015,7 +6981,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:7019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7063,7 +7029,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:7067: checking for location of External PROJ.4 includes" >&5
+echo "configure:7033: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -7089,15 +7055,15 @@
do
-echo "configure:7093: checking for $ac_hdr" >&5
+echo "configure:7059: checking for $ac_hdr" >&5
-#line 7096 "configure"
+#line 7062 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7101: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7067: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7134,7 +7100,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:7138: checking External PROJ.4 version" >&5
+echo "configure:7104: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -7142,7 +7108,7 @@
else
cat > conftest.$ac_ext <<EOF
-#line 7146 "configure"
+#line 7112 "configure"
#include <stdio.h>
@@ -7154,7 +7120,7 @@
EOF
-if { (eval echo configure:7158: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:7124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -7179,7 +7145,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:7183: checking for location of External PROJ.4 library" >&5
+echo "configure:7149: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -7204,13 +7170,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:7208: checking for pj_get_def in -lproj" >&5
+echo "configure:7174: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 7214 "configure"
+#line 7180 "configure"
@@ -7221,7 +7187,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:7225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7255,7 +7221,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7259: checking for location of External PROJ.4 data files" >&5
+echo "configure:7225: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7279,14 +7245,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7283: checking for epsg" >&5
+echo "configure:7249: checking for epsg" >&5
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7290: checking for $PROJSHARE/epsg" >&5
+echo "configure:7256: checking for $PROJSHARE/epsg" >&5
if test "$cross_compiling" = yes; then
@@ -7318,7 +7284,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7322: checking for $ac_word" >&5
+echo "configure:7288: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -7358,7 +7324,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:7362: checking whether to use regex" >&5
+echo "configure:7328: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -7378,7 +7344,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:7382: checking for location of regex includes" >&5
+echo "configure:7348: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -7404,15 +7370,15 @@
do
-echo "configure:7408: checking for $ac_hdr" >&5
+echo "configure:7374: checking for $ac_hdr" >&5
-#line 7411 "configure"
+#line 7377 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7416: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7382: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7446,7 +7412,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:7450: checking for location of regex library" >&5
+echo "configure:7416: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -7471,10 +7437,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:7475: checking for regcomp" >&5
+echo "configure:7441: checking for regcomp" >&5
-#line 7478 "configure"
+#line 7444 "configure"
which can conflict with char regcomp(); below. */
@@ -7497,7 +7463,7 @@
; return 0; }
EOF
-if { (eval echo configure:7501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -7524,13 +7490,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:7528: checking for regcomp in -lregex" >&5
+echo "configure:7494: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 7534 "configure"
+#line 7500 "configure"
@@ -7541,7 +7507,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:7545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7591,7 +7557,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7595: checking whether to use Readline" >&5
+echo "configure:7561: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -7612,7 +7578,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7616: checking for location of Readline includes" >&5
+echo "configure:7582: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7638,15 +7604,15 @@
do
-echo "configure:7642: checking for $ac_hdr" >&5
+echo "configure:7608: checking for $ac_hdr" >&5
-#line 7645 "configure"
+#line 7611 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7650: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7616: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7682,15 +7648,15 @@
do
-echo "configure:7686: checking for $ac_hdr" >&5
+echo "configure:7652: checking for $ac_hdr" >&5
-#line 7689 "configure"
+#line 7655 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7694: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7660: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7724,7 +7690,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7728: checking for location of Readline library" >&5
+echo "configure:7694: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7749,13 +7715,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7753: checking for readline in -lreadline" >&5
+echo "configure:7719: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 7759 "configure"
+#line 7725 "configure"
@@ -7766,7 +7732,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:7770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7801,13 +7767,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7805: checking for add_history in -lhistory" >&5
+echo "configure:7771: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 7811 "configure"
+#line 7777 "configure"
@@ -7818,7 +7784,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:7822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7857,228 +7823,10 @@
# Done checking Readline
-# Enable JPEG option
-echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:7865: checking whether to use JPEG" >&5
-echo "$ac_t"""$with_jpeg"" 1>&6
-case "$with_jpeg" in
- "no") USE_JPEG= ;;
- "yes") USE_JPEG="1" ;;
- *) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
-esac
-JPEGINCPATH=
-JPEGLIBPATH=
-JPEGLIB=
-if test -n "$USE_JPEG"; then
-# With JPEG includes directory
-echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:7885: checking for location of JPEG includes" >&5
-case "$with_jpeg_includes" in
-y | ye | yes | n | no)
- { echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
-esac
-echo "$ac_t""$with_jpeg_includes" 1>&6
-if test -n "$with_jpeg_includes" ; then
- for dir in $with_jpeg_includes; do
- if test -d "$dir"; then
- JPEGINCPATH="$JPEGINCPATH -I$dir"
- else
- { echo "configure: error: *** JPEG includes directory $dir does not exist." 1>&2; exit 1; }
- fi
- done
-fi
-ac_save_cppflags="$CPPFLAGS"
-CPPFLAGS="$JPEGINCPATH $CPPFLAGS"
-for ac_hdr in jpeglib.h
-do
-ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
-echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:7911: checking for $ac_hdr" >&5
-cat > conftest.$ac_ext <<EOF
-#line 7914 "configure"
-#include "confdefs.h"
-#include <$ac_hdr>
-EOF
-ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7919: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
-if test -z "$ac_err"; then
- rm -rf conftest*
- eval "ac_cv_header_$ac_safe=yes"
-else
- echo "$ac_err" >&5
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -rf conftest*
- eval "ac_cv_header_$ac_safe=no"
-fi
-rm -f conftest*
-if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
- echo "$ac_t""yes" 1>&6
- ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
- cat >> confdefs.h <<EOF
-#define $ac_tr_hdr 1
-EOF
-else
- echo "$ac_t""no" 1>&6
-{ echo "configure: error: *** Unable to locate JPEG includes." 1>&2; exit 1; }
-fi
-done
-CPPFLAGS=$ac_save_cppflags
-# With JPEG library directory
-echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:7953: checking for location of JPEG library" >&5
-case "$with_jpeg_libs" in
- { echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
-esac
-echo "$ac_t""$with_jpeg_libs" 1>&6
-if test -n "$with_jpeg_libs"; then
- for dir in $with_jpeg_libs; do
- JPEGLIBPATH="$JPEGLIBPATH -L$dir"
- else
- { echo "configure: error: *** JPEG library directory $dir does not exist." 1>&2; exit 1; }
- fi
- done
-fi
-ac_save_ldflags="$LDFLAGS"
-LDFLAGS="$JPEGLIBPATH $LDFLAGS"
-echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:7980: checking for jpeg_start_compress in -ljpeg" >&5
-ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
-ac_save_LIBS="$LIBS"
-LIBS="-ljpeg $LIBS"
-#line 7986 "configure"
-/* Override any gcc2 internal prototype to avoid an error. */
-/* We use char because int might match the return type of a gcc2
- builtin and then its argument prototype would still apply. */
-char jpeg_start_compress();
-int main() {
-jpeg_start_compress()
-; return 0; }
-EOF
-if { (eval echo configure:7997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
- eval "ac_cv_lib_$ac_lib_var=yes"
-else
- rm -rf conftest*
- eval "ac_cv_lib_$ac_lib_var=no"
-fi
-rm -f conftest*
-LIBS="$ac_save_LIBS"
-if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
- JPEGLIB="$JPEGLIB -ljpeg "
-else
-echo "configure:8016: checking for jpeg_start_compress in -ljpeg" >&5
-LIBS="-ljpeg $ZLIB $LIBS"
-#line 8022 "configure"
-int main() {
-; return 0; }
-EOF
-if { (eval echo configure:8033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
- rm -rf conftest*
-else
- rm -rf conftest*
-fi
-rm -f conftest*
- JPEGLIB="$JPEGLIB -ljpeg $ZLIB"
-else
-LDFLAGS=${ac_save_ldflags}
- { echo "configure: error: *** Unable to locate JPEG library." 1>&2; exit 1; }
-fi
-fi
-fi # $USE_JPEG
-# Done checking JPEG
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:8082: checking whether to use GDAL" >&5
+echo "configure:7830: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -8096,7 +7844,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:8100: checking for $ac_word" >&5
+echo "configure:7848: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -8151,14 +7899,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 8155 "configure"
+#line 7903 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:8162: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -8167,14 +7915,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 8171 "configure"
+#line 7919 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:8178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -8206,7 +7954,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:8210: checking whether to use GEOS" >&5
+echo "configure:7958: checking whether to use GEOS" >&5
GEOS_LIBS=
GGEOS_CFLAGS=
@@ -8224,7 +7972,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:8228: checking for $ac_word" >&5
+echo "configure:7976: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -8272,15 +8020,15 @@
do
-echo "configure:8276: checking for $ac_hdr" >&5
+echo "configure:8024: checking for $ac_hdr" >&5
-#line 8279 "configure"
+#line 8027 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8284: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8032: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8316,13 +8064,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c_i""... $ac_c" 1>&6
-echo "configure:8320: checking for initGEOS in -lgeos_c_i" >&5
+echo "configure:8068: checking for initGEOS in -lgeos_c_i" >&5
ac_lib_var=`echo geos_c_i'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c_i $LIBS"
-#line 8326 "configure"
+#line 8074 "configure"
@@ -8333,7 +8081,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:8337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8085: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8369,13 +8117,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:8373: checking for initGEOS in -lgeos_c" >&5
+echo "configure:8121: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 8379 "configure"
+#line 8127 "configure"
@@ -8386,7 +8134,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:8390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8430,7 +8178,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:8434: checking whether to use TIFF" >&5
+echo "configure:8182: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -8450,7 +8198,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:8454: checking for location of TIFF includes" >&5
+echo "configure:8202: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -8476,15 +8224,15 @@
do
-echo "configure:8480: checking for $ac_hdr" >&5
+echo "configure:8228: checking for $ac_hdr" >&5
-#line 8483 "configure"
+#line 8231 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8488: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8236: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8518,7 +8266,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8522: checking for location of TIFF library" >&5
+echo "configure:8270: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8549,13 +8297,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8553: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8301: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 8559 "configure"
+#line 8307 "configure"
@@ -8566,7 +8314,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8585,13 +8333,13 @@
-echo "configure:8589: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8337: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 8595 "configure"
+#line 8343 "configure"
@@ -8602,7 +8350,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8354: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8621,13 +8369,13 @@
-echo "configure:8625: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8373: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 8631 "configure"
+#line 8379 "configure"
@@ -8638,7 +8386,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8642: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8657,13 +8405,13 @@
-echo "configure:8661: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8409: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8667 "configure"
+#line 8415 "configure"
@@ -8674,7 +8422,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8693,13 +8441,13 @@
-echo "configure:8697: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8445: checking for TIFFOpen in -ltiff" >&5
-LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
+LIBS="-ltiff -ljpeg $LIBS"
-#line 8703 "configure"
+#line 8451 "configure"
@@ -8710,7 +8458,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8462: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8724,18 +8472,18 @@
- TIFFLIB="$TIFFLIB -ltiff $JPEGLIBPATH $JPEGLIB"
+ TIFFLIB="$TIFFLIB -ltiff -ljpeg"
else
-echo "configure:8733: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8481: checking for TIFFOpen in -ltiff" >&5
-LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
+LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 8739 "configure"
+#line 8487 "configure"
@@ -8746,7 +8494,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8760,18 +8508,18 @@
- TIFFLIB="$TIFFLIB -ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB"
+ TIFFLIB="$TIFFLIB -ltiff -ljpeg $MATHLIB"
else
-echo "configure:8769: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8517: checking for TIFFOpen in -ltiff" >&5
-LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
+LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 8775 "configure"
+#line 8523 "configure"
@@ -8782,7 +8530,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8796,18 +8544,18 @@
- TIFFLIB="$TIFFLIB -ltiff $JPEGLIBPATH $JPEGLIB $ZLIB"
+ TIFFLIB="$TIFFLIB -ltiff -ljpeg $ZLIB"
else
-echo "configure:8805: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8553: checking for TIFFOpen in -ltiff" >&5
-LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
+LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 8811 "configure"
+#line 8559 "configure"
@@ -8818,7 +8566,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8832,7 +8580,7 @@
- TIFFLIB="$TIFFLIB -ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB"
+ TIFFLIB="$TIFFLIB -ltiff -ljpeg $ZLIB $MATHLIB"
else
@@ -8916,7 +8664,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8920: checking whether to use PNG" >&5
+echo "configure:8668: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -8935,7 +8683,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8939: checking for location of PNG includes" >&5
+echo "configure:8687: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8961,15 +8709,15 @@
do
-echo "configure:8965: checking for $ac_hdr" >&5
+echo "configure:8713: checking for $ac_hdr" >&5
-#line 8968 "configure"
+#line 8716 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8973: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8721: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9003,7 +8751,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:9007: checking for location of PNG library" >&5
+echo "configure:8755: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -9028,13 +8776,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:9032: checking for png_read_image in -lpng" >&5
+echo "configure:8780: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 9038 "configure"
+#line 8786 "configure"
@@ -9045,7 +8793,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:9049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9087,7 +8835,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:9091: checking whether to use PostgreSQL" >&5
+echo "configure:8839: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -9114,7 +8862,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:9118: checking for location of PostgreSQL includes" >&5
+echo "configure:8866: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -9140,15 +8888,15 @@
do
-echo "configure:9144: checking for $ac_hdr" >&5
+echo "configure:8892: checking for $ac_hdr" >&5
-#line 9147 "configure"
+#line 8895 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9152: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8900: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9186,7 +8934,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:9190: checking for location of PostgreSQL library" >&5
+echo "configure:8938: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -9215,13 +8963,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:9219: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8967: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9225 "configure"
+#line 8973 "configure"
@@ -9232,7 +8980,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9236: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9251,13 +8999,13 @@
-echo "configure:9255: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9003: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9261 "configure"
+#line 9009 "configure"
@@ -9268,7 +9016,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9272: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9287,13 +9035,13 @@
-echo "configure:9291: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9039: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 9297 "configure"
+#line 9045 "configure"
@@ -9304,7 +9052,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9308: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9323,13 +9071,13 @@
-echo "configure:9327: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9075: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9333 "configure"
+#line 9081 "configure"
@@ -9340,7 +9088,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9397,13 +9145,13 @@
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9401: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9149: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9407 "configure"
+#line 9155 "configure"
@@ -9414,7 +9162,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9166: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9436,13 +9184,13 @@
-echo "configure:9440: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9188: checking for PQcmdTuples in -lpq" >&5
-#line 9446 "configure"
+#line 9194 "configure"
@@ -9453,7 +9201,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9457: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9496,7 +9244,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9500: checking whether to use MySQL" >&5
+echo "configure:9248: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9516,7 +9264,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9520: checking for location of MySQL includes" >&5
+echo "configure:9268: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9542,15 +9290,15 @@
do
-echo "configure:9546: checking for $ac_hdr" >&5
+echo "configure:9294: checking for $ac_hdr" >&5
-#line 9549 "configure"
+#line 9297 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9554: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9302: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9587,7 +9335,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9591: checking for location of MySQL library" >&5
+echo "configure:9339: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9618,13 +9366,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9622: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9370: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9628 "configure"
+#line 9376 "configure"
@@ -9635,7 +9383,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9387: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9654,13 +9402,13 @@
-echo "configure:9658: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9406: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9664 "configure"
+#line 9412 "configure"
@@ -9671,7 +9419,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9423: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9690,13 +9438,13 @@
-echo "configure:9694: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9442: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9700 "configure"
+#line 9448 "configure"
@@ -9707,7 +9455,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9726,13 +9474,13 @@
-echo "configure:9730: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9478: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9736 "configure"
+#line 9484 "configure"
@@ -9743,7 +9491,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9762,13 +9510,13 @@
-echo "configure:9766: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9514: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9772 "configure"
+#line 9520 "configure"
@@ -9779,7 +9527,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9798,13 +9546,13 @@
-echo "configure:9802: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9550: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9808 "configure"
+#line 9556 "configure"
@@ -9815,7 +9563,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9567: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9834,13 +9582,13 @@
-echo "configure:9838: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9586: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9844 "configure"
+#line 9592 "configure"
@@ -9851,7 +9599,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9855: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9603: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9870,13 +9618,13 @@
-echo "configure:9874: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9622: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9880 "configure"
+#line 9628 "configure"
@@ -9887,7 +9635,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9977,7 +9725,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:9981: checking for $ac_word" >&5
+echo "configure:9729: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -10018,10 +9766,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:10022: checking for mysql_server_init" >&5
+echo "configure:9770: checking for mysql_server_init" >&5
-#line 10025 "configure"
+#line 9773 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -10044,7 +9792,7 @@
; return 0; }
EOF
-if { (eval echo configure:10048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -10082,7 +9830,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:10086: checking whether to use SQLite" >&5
+echo "configure:9834: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -10102,7 +9850,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:10106: checking for location of SQLite includes" >&5
+echo "configure:9854: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -10128,15 +9876,15 @@
do
-echo "configure:10132: checking for $ac_hdr" >&5
+echo "configure:9880: checking for $ac_hdr" >&5
-#line 10135 "configure"
+#line 9883 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10140: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9888: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10179,7 +9927,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:10183: checking for location of SQLite library" >&5
+echo "configure:9931: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -10208,13 +9956,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:10212: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9960: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 10218 "configure"
+#line 9966 "configure"
@@ -10225,7 +9973,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10244,13 +9992,13 @@
-echo "configure:10248: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9996: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 10254 "configure"
+#line 10002 "configure"
@@ -10261,7 +10009,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10280,13 +10028,13 @@
-echo "configure:10284: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10032: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 10290 "configure"
+#line 10038 "configure"
@@ -10297,7 +10045,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10316,13 +10064,13 @@
-echo "configure:10320: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10068: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 10326 "configure"
+#line 10074 "configure"
@@ -10333,7 +10081,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10085: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10402,7 +10150,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10406: checking whether to use FFMPEG" >&5
+echo "configure:10154: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10422,7 +10170,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10426: checking for location of FFMPEG includes" >&5
+echo "configure:10174: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10448,15 +10196,15 @@
do
-echo "configure:10452: checking for $ac_hdr" >&5
+echo "configure:10200: checking for $ac_hdr" >&5
-#line 10455 "configure"
+#line 10203 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10460: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10208: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10492,15 +10240,15 @@
do
-echo "configure:10496: checking for $ac_hdr" >&5
+echo "configure:10244: checking for $ac_hdr" >&5
-#line 10499 "configure"
+#line 10247 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10504: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10536,15 +10284,15 @@
do
-echo "configure:10540: checking for $ac_hdr" >&5
+echo "configure:10288: checking for $ac_hdr" >&5
-#line 10543 "configure"
+#line 10291 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10548: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10296: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10587,7 +10335,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10591: checking for location of FFMPEG library" >&5
+echo "configure:10339: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10614,13 +10362,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10618: checking for av_free in -lavutil" >&5
+echo "configure:10366: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 10624 "configure"
+#line 10372 "configure"
@@ -10631,7 +10379,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10650,13 +10398,13 @@
-echo "configure:10654: checking for av_free in -lavutil" >&5
+echo "configure:10402: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 10660 "configure"
+#line 10408 "configure"
@@ -10667,7 +10415,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10671: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10419: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10712,13 +10460,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10716: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10464: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 10722 "configure"
+#line 10470 "configure"
@@ -10729,7 +10477,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10733: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10748,13 +10496,13 @@
-echo "configure:10752: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10500: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10758 "configure"
+#line 10506 "configure"
@@ -10765,7 +10513,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:10769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10810,13 +10558,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10814: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10562: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 10820 "configure"
+#line 10568 "configure"
@@ -10827,7 +10575,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10846,13 +10594,13 @@
-echo "configure:10850: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10598: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10856 "configure"
+#line 10604 "configure"
@@ -10863,7 +10611,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:10867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10615: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10922,7 +10670,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10926: checking whether to use OpenGL" >&5
+echo "configure:10674: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -10956,7 +10704,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10960: checking for location of OpenGL includes" >&5
+echo "configure:10708: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10982,15 +10730,15 @@
do
-echo "configure:10986: checking for $ac_hdr" >&5
+echo "configure:10734: checking for $ac_hdr" >&5
-#line 10989 "configure"
+#line 10737 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10994: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10742: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11024,7 +10772,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:11028: checking for location of OpenGL library" >&5
+echo "configure:10776: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -11053,13 +10801,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:11057: checking for glBegin in -lGL" >&5
+echo "configure:10805: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11063 "configure"
+#line 10811 "configure"
@@ -11070,7 +10818,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11089,13 +10837,13 @@
-echo "configure:11093: checking for glBegin in -lGL" >&5
+echo "configure:10841: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 11099 "configure"
+#line 10847 "configure"
@@ -11106,7 +10854,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11125,13 +10873,13 @@
-echo "configure:11129: checking for glBegin in -lGL" >&5
+echo "configure:10877: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 11135 "configure"
+#line 10883 "configure"
@@ -11142,7 +10890,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11146: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11161,13 +10909,13 @@
-echo "configure:11165: checking for glBegin in -lGL" >&5
+echo "configure:10913: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 11171 "configure"
+#line 10919 "configure"
@@ -11178,7 +10926,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:11182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11240,13 +10988,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11244: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10992: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11250 "configure"
+#line 10998 "configure"
@@ -11257,7 +11005,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11276,13 +11024,13 @@
-echo "configure:11280: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11028: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11286 "configure"
+#line 11034 "configure"
@@ -11293,7 +11041,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11337,10 +11085,10 @@
LDFLAGS="$LDFLAGS $OPENGLLIB"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11341: checking for glXCreatePbuffer" >&5
+echo "configure:11089: checking for glXCreatePbuffer" >&5
-#line 11344 "configure"
+#line 11092 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11363,7 +11111,7 @@
; return 0; }
EOF
-if { (eval echo configure:11367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11385,10 +11133,10 @@
fi
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11389: checking for glXCreateGLXPixmap" >&5
+echo "configure:11137: checking for glXCreateGLXPixmap" >&5
-#line 11392 "configure"
+#line 11140 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11411,7 +11159,7 @@
; return 0; }
EOF
-if { (eval echo configure:11415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11163: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11450,7 +11198,7 @@
-echo "configure:11454: checking for location of OpenGL includes" >&5
+echo "configure:11202: checking for location of OpenGL includes" >&5
@@ -11476,15 +11224,15 @@
do
-echo "configure:11480: checking for $ac_hdr" >&5
+echo "configure:11228: checking for $ac_hdr" >&5
-#line 11483 "configure"
+#line 11231 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11488: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11236: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11519,10 +11267,10 @@
LDFLAGS="$with_opengl_libs $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11523: checking for glBegin" >&5
+echo "configure:11271: checking for glBegin" >&5
-#line 11526 "configure"
+#line 11274 "configure"
which can conflict with char glBegin(); below. */
@@ -11545,7 +11293,7 @@
; return 0; }
EOF
-if { (eval echo configure:11549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11560,10 +11308,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11564: checking for gluBeginCurve" >&5
+echo "configure:11312: checking for gluBeginCurve" >&5
-#line 11567 "configure"
+#line 11315 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11586,7 +11334,7 @@
; return 0; }
EOF
-if { (eval echo configure:11590: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11338: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11630,7 +11378,7 @@
-echo "configure:11634: checking for location of OpenGL includes" >&5
+echo "configure:11382: checking for location of OpenGL includes" >&5
@@ -11656,15 +11404,15 @@
do
-echo "configure:11660: checking for $ac_hdr" >&5
+echo "configure:11408: checking for $ac_hdr" >&5
-#line 11663 "configure"
+#line 11411 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11668: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11416: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11698,7 +11446,7 @@
-echo "configure:11702: checking for location of OpenGL library" >&5
+echo "configure:11450: checking for location of OpenGL library" >&5
@@ -11723,18 +11471,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11727: checking for OpenGL library" >&5
+echo "configure:11475: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 11731 "configure"
+#line 11479 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -11758,18 +11506,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11762: checking for GLU library" >&5
+echo "configure:11510: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 11766 "configure"
+#line 11514 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11818,7 +11566,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11822: checking whether to use Tcl/Tk" >&5
+echo "configure:11570: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -11838,7 +11586,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11842: checking for location of Tcl/Tk includes" >&5
+echo "configure:11590: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11864,15 +11612,15 @@
do
-echo "configure:11868: checking for $ac_hdr" >&5
+echo "configure:11616: checking for $ac_hdr" >&5
-#line 11871 "configure"
+#line 11619 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11876: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11624: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11909,15 +11657,15 @@
do
-echo "configure:11913: checking for $ac_hdr" >&5
+echo "configure:11661: checking for $ac_hdr" >&5
-#line 11916 "configure"
+#line 11664 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11921: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11669: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11950,7 +11698,7 @@
# Tcl/Tk version checks
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11954: checking Tcl version" >&5
+echo "configure:11702: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
@@ -11958,7 +11706,7 @@
else
-#line 11962 "configure"
+#line 11710 "configure"
#include <stdio.h>
@@ -11970,7 +11718,7 @@
EOF
-if { (eval echo configure:11974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11722: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -11988,7 +11736,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11992: checking Tk version" >&5
+echo "configure:11740: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11996,7 +11744,7 @@
else
-#line 12000 "configure"
+#line 11748 "configure"
#include <stdio.h>
@@ -12008,7 +11756,7 @@
EOF
-if { (eval echo configure:12012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -12039,7 +11787,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:12043: checking for location of Tcl/Tk library" >&5
+echo "configure:11791: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -12079,13 +11827,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:12083: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11831: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 12089 "configure"
+#line 11837 "configure"
@@ -12096,7 +11844,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11848: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12115,13 +11863,13 @@
-echo "configure:12119: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11867: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 12125 "configure"
+#line 11873 "configure"
@@ -12132,7 +11880,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12159,13 +11907,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12163: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11911: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 12169 "configure"
+#line 11917 "configure"
@@ -12176,7 +11924,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12195,13 +11943,13 @@
-echo "configure:12199: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11947: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 12205 "configure"
+#line 11953 "configure"
@@ -12212,7 +11960,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12239,13 +11987,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12243: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:11991: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 12249 "configure"
+#line 11997 "configure"
@@ -12256,7 +12004,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12260: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12275,13 +12023,13 @@
-echo "configure:12279: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12027: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 12285 "configure"
+#line 12033 "configure"
@@ -12292,7 +12040,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12296: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12370,13 +12118,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:12374: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12122: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 12380 "configure"
+#line 12128 "configure"
@@ -12387,7 +12135,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12406,13 +12154,13 @@
-echo "configure:12410: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12158: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12416 "configure"
+#line 12164 "configure"
@@ -12423,7 +12171,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12450,13 +12198,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12454: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12202: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 12460 "configure"
+#line 12208 "configure"
@@ -12467,7 +12215,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12486,13 +12234,13 @@
-echo "configure:12490: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12238: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12496 "configure"
+#line 12244 "configure"
@@ -12503,7 +12251,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12530,13 +12278,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12534: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12282: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12540 "configure"
+#line 12288 "configure"
@@ -12547,7 +12295,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12551: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12299: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12566,13 +12314,13 @@
-echo "configure:12570: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12318: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12576 "configure"
+#line 12324 "configure"
@@ -12583,7 +12331,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12673,13 +12421,13 @@
do
# add only if in MACOSX_ARCHS
echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:12677: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:12425: checking for Tcl_Init in -l$tlib" >&5
ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 12683 "configure"
+#line 12431 "configure"
@@ -12690,7 +12438,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12442: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12739,7 +12487,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12743: checking whether to use ODBC" >&5
+echo "configure:12491: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -12758,7 +12506,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12762: checking for location of ODBC includes" >&5
+echo "configure:12510: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12784,15 +12532,15 @@
do
-echo "configure:12788: checking for $ac_hdr" >&5
+echo "configure:12536: checking for $ac_hdr" >&5
-#line 12791 "configure"
+#line 12539 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12796: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12544: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12826,7 +12574,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12830: checking for location of ODBC library" >&5
+echo "configure:12578: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12851,13 +12599,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12855: checking for SQLConnect in -lodbc" >&5
+echo "configure:12603: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 12861 "configure"
+#line 12609 "configure"
@@ -12868,7 +12616,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12893,13 +12641,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12897: checking for SQLConnect in -liodbc" >&5
+echo "configure:12645: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 12903 "configure"
+#line 12651 "configure"
#include "confdefs.h"
@@ -12910,7 +12658,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12662: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12935,11 +12683,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12939: checking for ODBC library" >&5
+echo "configure:12687: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 12943 "configure"
+#line 12691 "configure"
#include <windows.h>
#include <sql.h>
@@ -12947,7 +12695,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:12951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12699: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12996,7 +12744,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:13000: checking whether to use FFTW" >&5
+echo "configure:12748: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -13015,7 +12763,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:13019: checking for location of FFTW includes" >&5
+echo "configure:12767: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -13041,15 +12789,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13045: checking for $ac_hdr" >&5
+echo "configure:12793: checking for $ac_hdr" >&5
-#line 13048 "configure"
+#line 12796 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13053: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12801: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13077,15 +12825,15 @@
do
-echo "configure:13081: checking for $ac_hdr" >&5
+echo "configure:12829: checking for $ac_hdr" >&5
-#line 13084 "configure"
+#line 12832 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13089: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12837: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13113,15 +12861,15 @@
do
-echo "configure:13117: checking for $ac_hdr" >&5
+echo "configure:12865: checking for $ac_hdr" >&5
-#line 13120 "configure"
+#line 12868 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13125: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12873: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13167,7 +12915,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:13171: checking for location of FFTW library" >&5
+echo "configure:12919: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -13192,13 +12940,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:13196: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12944: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 13202 "configure"
+#line 12950 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -13209,7 +12957,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:13213: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -13234,13 +12982,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:13238: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12986: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 13244 "configure"
+#line 12992 "configure"
@@ -13251,7 +12999,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13276,13 +13024,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:13280: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:13028: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 13286 "configure"
+#line 13034 "configure"
@@ -13293,7 +13041,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13350,7 +13098,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:13354: checking whether to use BLAS" >&5
+echo "configure:13102: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -13371,7 +13119,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:13375: checking for location of BLAS includes" >&5
+echo "configure:13123: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -13391,7 +13139,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:13395: checking for location of BLAS library" >&5
+echo "configure:13143: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -13417,15 +13165,15 @@
do
-echo "configure:13421: checking for $ac_hdr" >&5
+echo "configure:13169: checking for $ac_hdr" >&5
-#line 13424 "configure"
+#line 13172 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13429: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13177: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13460,13 +13208,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:13464: checking for dnrm2_ in -lblas" >&5
+echo "configure:13212: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 13470 "configure"
+#line 13218 "configure"
@@ -13477,7 +13225,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13496,13 +13244,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:13500: checking for dnrm2_ in -lblas" >&5
+echo "configure:13248: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13506 "configure"
+#line 13254 "configure"
@@ -13513,7 +13261,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13557,13 +13305,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13561: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13309: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 13567 "configure"
+#line 13315 "configure"
@@ -13574,7 +13322,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:13578: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13589,13 +13337,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13593: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13341: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 13599 "configure"
+#line 13347 "configure"
@@ -13606,7 +13354,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13358: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13621,13 +13369,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13625: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13373: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13631 "configure"
+#line 13379 "configure"
@@ -13638,7 +13386,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:13642: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13684,16 +13432,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13688: checking for sgemm in $vlib_flags" >&5
+echo "configure:13436: checking for sgemm in $vlib_flags" >&5
-#line 13690 "configure"
+#line 13438 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:13697: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -13711,13 +13459,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13715: checking for sgemm_ in -lblas" >&5
+echo "configure:13463: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 13721 "configure"
+#line 13469 "configure"
@@ -13728,7 +13476,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13480: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13743,13 +13491,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13747: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13495: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 13753 "configure"
+#line 13501 "configure"
@@ -13760,7 +13508,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:13764: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13775,13 +13523,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13779: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13527: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 13785 "configure"
+#line 13533 "configure"
@@ -13792,7 +13540,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13826,13 +13574,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13830: checking for acosp in -lsunmath" >&5
+echo "configure:13578: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 13836 "configure"
+#line 13584 "configure"
@@ -13843,7 +13591,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:13847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13858,13 +13606,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13862: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13610: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 13868 "configure"
+#line 13616 "configure"
@@ -13875,7 +13623,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13627: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13905,13 +13653,13 @@
# Generic BLAS library
-echo "configure:13909: checking for sgemm_ in -lblas" >&5
+echo "configure:13657: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 13915 "configure"
+#line 13663 "configure"
@@ -13922,7 +13670,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13674: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13961,7 +13709,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13965: checking whether to use LAPACK" >&5
+echo "configure:13713: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13986,7 +13734,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13990: checking for location of LAPACK includes" >&5
+echo "configure:13738: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -14006,7 +13754,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:14010: checking for location of LAPACK library" >&5
+echo "configure:13758: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -14032,15 +13780,15 @@
do
-echo "configure:14036: checking for $ac_hdr" >&5
+echo "configure:13784: checking for $ac_hdr" >&5
-#line 14039 "configure"
+#line 13787 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14044: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13792: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14072,10 +13820,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:14076: checking for dsegv_" >&5
+echo "configure:13824: checking for dsegv_" >&5
-#line 14079 "configure"
+#line 13827 "configure"
which can conflict with char dsegv_(); below. */
@@ -14098,7 +13846,7 @@
; return 0; }
EOF
-if { (eval echo configure:14102: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13850: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -14125,13 +13873,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:14129: checking for desgv_ in -llapack" >&5
+echo "configure:13877: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 14135 "configure"
+#line 13883 "configure"
@@ -14142,7 +13890,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:14146: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14174,13 +13922,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:14178: checking for dgesv_ in -llapack" >&5
+echo "configure:13926: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 14184 "configure"
+#line 13932 "configure"
@@ -14191,7 +13939,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:14195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14210,13 +13958,13 @@
-echo "configure:14214: checking for dgesv_ in -llapack" >&5
+echo "configure:13962: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 14220 "configure"
+#line 13968 "configure"
@@ -14227,7 +13975,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:14231: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14283,7 +14031,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:14287: checking whether to use Motif" >&5
+echo "configure:14035: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -14302,7 +14050,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:14306: checking for location of Motif includes" >&5
+echo "configure:14054: checking for location of Motif includes" >&5
case "$with_motif_includes" in
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -14328,15 +14076,15 @@
do
-echo "configure:14332: checking for $ac_hdr" >&5
+echo "configure:14080: checking for $ac_hdr" >&5
-#line 14335 "configure"
+#line 14083 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14340: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14088: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14370,7 +14118,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:14374: checking for location of Motif library" >&5
+echo "configure:14122: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -14395,13 +14143,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:14399: checking for XmStringCreate in -lXm" >&5
+echo "configure:14147: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 14405 "configure"
+#line 14153 "configure"
@@ -14412,7 +14160,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:14416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14453,7 +14201,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:14457: checking whether to use Cairo" >&5
+echo "configure:14205: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -14485,7 +14233,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14489: checking for location of cairo includes" >&5
+echo "configure:14237: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14511,15 +14259,15 @@
do
-echo "configure:14515: checking for $ac_hdr" >&5
+echo "configure:14263: checking for $ac_hdr" >&5
-#line 14518 "configure"
+#line 14266 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14523: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14271: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14555,7 +14303,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14559: checking for location of cairo library" >&5
+echo "configure:14307: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14575,7 +14323,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14579: checking for cairo linking flags" >&5
+echo "configure:14327: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14591,10 +14339,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14595: checking for cairo_create" >&5
+echo "configure:14343: checking for cairo_create" >&5
-#line 14598 "configure"
+#line 14346 "configure"
which can conflict with char cairo_create(); below. */
@@ -14617,7 +14365,7 @@
; return 0; }
EOF
-if { (eval echo configure:14621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -14651,10 +14399,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14655: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14403: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14658 "configure"
+#line 14406 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -14677,7 +14425,7 @@
; return 0; }
EOF
-if { (eval echo configure:14681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -14710,10 +14458,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:14714: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:14462: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 14717 "configure"
+#line 14465 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -14736,7 +14484,7 @@
; return 0; }
EOF
-if { (eval echo configure:14740: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -14778,7 +14526,7 @@
echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14782: checking whether to use GLw" >&5
+echo "configure:14530: checking whether to use GLw" >&5
echo "$ac_t"""$with_glw"" 1>&6
case "$with_glw" in
"no") USE_GLW= ;;
@@ -14797,7 +14545,7 @@
echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14801: checking for location of GLw includes" >&5
+echo "configure:14549: checking for location of GLw includes" >&5
case "$with_glw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14823,15 +14571,15 @@
do
-echo "configure:14827: checking for $ac_hdr" >&5
+echo "configure:14575: checking for $ac_hdr" >&5
-#line 14830 "configure"
+#line 14578 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14835: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14583: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14859,15 +14607,15 @@
do
-echo "configure:14863: checking for $ac_hdr" >&5
+echo "configure:14611: checking for $ac_hdr" >&5
-#line 14866 "configure"
+#line 14614 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14871: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14619: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14907,7 +14655,7 @@
echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14911: checking for location of GLw library" >&5
+echo "configure:14659: checking for location of GLw library" >&5
case "$with_glw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14932,13 +14680,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14936: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14684: checking for GLwCreateMDrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14942 "configure"
+#line 14690 "configure"
@@ -14949,7 +14697,7 @@
GLwCreateMDrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14974,13 +14722,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14978: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14726: checking for GLwCreateM1DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14984 "configure"
+#line 14732 "configure"
@@ -14991,7 +14739,7 @@
GLwCreateM1DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15016,13 +14764,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:15020: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14768: checking for GLwCreateM2DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 15026 "configure"
+#line 14774 "configure"
@@ -15033,7 +14781,7 @@
GLwCreateM2DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:15037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15058,13 +14806,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:15062: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14810: checking for GLwCreateMDrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 15068 "configure"
+#line 14816 "configure"
@@ -15075,7 +14823,7 @@
; return 0; }
EOF
-if { (eval echo configure:15079: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15100,13 +14848,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:15104: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14852: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 15110 "configure"
+#line 14858 "configure"
@@ -15117,7 +14865,7 @@
; return 0; }
EOF
-if { (eval echo configure:15121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14869: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15142,13 +14890,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:15146: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14894: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 15152 "configure"
+#line 14900 "configure"
@@ -15159,7 +14907,7 @@
; return 0; }
EOF
-if { (eval echo configure:15163: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15186,13 +14934,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:15190: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14938: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 15196 "configure"
+#line 14944 "configure"
@@ -15203,7 +14951,7 @@
; return 0; }
EOF
-if { (eval echo configure:15207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15222,13 +14970,13 @@
-echo "configure:15226: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14974: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15232 "configure"
+#line 14980 "configure"
@@ -15239,7 +14987,7 @@
; return 0; }
EOF
-if { (eval echo configure:15243: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15266,13 +15014,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:15270: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15018: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 15276 "configure"
+#line 15024 "configure"
@@ -15283,7 +15031,7 @@
; return 0; }
EOF
-if { (eval echo configure:15287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15302,13 +15050,13 @@
-echo "configure:15306: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15054: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15312 "configure"
+#line 15060 "configure"
@@ -15319,7 +15067,7 @@
; return 0; }
EOF
-if { (eval echo configure:15323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15432,7 +15180,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:15436: checking whether to use FreeType" >&5
+echo "configure:15184: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -15451,7 +15199,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:15455: checking for location of FreeType includes" >&5
+echo "configure:15203: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -15477,15 +15225,15 @@
do
-echo "configure:15481: checking for $ac_hdr" >&5
+echo "configure:15229: checking for $ac_hdr" >&5
-#line 15484 "configure"
+#line 15232 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15489: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15237: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15519,7 +15267,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15523: checking for location of FreeType library" >&5
+echo "configure:15271: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15544,13 +15292,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15548: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15296: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 15554 "configure"
+#line 15302 "configure"
@@ -15561,7 +15309,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:15565: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15602,7 +15350,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15606: checking whether to use NLS" >&5
+echo "configure:15354: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -15622,10 +15370,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15626: checking for gettext" >&5
+echo "configure:15374: checking for gettext" >&5
-#line 15629 "configure"
+#line 15377 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char gettext(); below. */
@@ -15648,7 +15396,7 @@
; return 0; }
EOF
-if { (eval echo configure:15652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -15666,13 +15414,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15670: checking for gettext in -lintl" >&5
+echo "configure:15418: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 15676 "configure"
+#line 15424 "configure"
@@ -15683,7 +15431,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:15687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15718,7 +15466,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15722: checking whether to use C++" >&5
+echo "configure:15470: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -15734,7 +15482,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15738: checking for $ac_word" >&5
+echo "configure:15486: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15763,7 +15511,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15767: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15515: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15774,12 +15522,12 @@
cat > conftest.$ac_ext << EOF
-#line 15778 "configure"
+#line 15526 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:15783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -15805,19 +15553,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15809: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15557: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15814: checking whether we are using GNU C++" >&5
+echo "configure:15562: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15821: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15569: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -15835,7 +15583,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15839: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15587: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15863,7 +15611,58 @@
fi
fi
+for ac_declaration in \
+ '#include <stdlib.h>' \
+ 'extern "C" void std::exit (int) throw (); using std::exit;' \
+ 'extern "C" void std::exit (int); using std::exit;' \
+ 'extern "C" void exit (int) throw ();' \
+ 'extern "C" void exit (int);' \
+ 'void exit (int);'
+do
+ cat > conftest.$ac_ext <<EOF
+#line 15625 "configure"
+#include "confdefs.h"
+#include <stdlib.h>
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:15633: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -rf conftest*
+ continue
+fi
+rm -f conftest*
+#line 15643 "configure"
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:15650: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+ rm -rf conftest*
+ break
+else
+fi
+rm -f conftest*
+done
+if test -n "$ac_declaration"; then
+ echo '#ifdef __cplusplus' >>confdefs.h
+ echo $ac_declaration >>confdefs.h
+ echo '#endif' >>confdefs.h
+fi
+else
CXX=
CXXFLAGS=
@@ -15876,7 +15675,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15880: checking whether to use openDWG" >&5
+echo "configure:15679: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -15896,7 +15695,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15900: checking for location of openDGW includes" >&5
+echo "configure:15699: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15922,15 +15721,15 @@
do
-echo "configure:15926: checking for $ac_hdr" >&5
+echo "configure:15725: checking for $ac_hdr" >&5
-#line 15929 "configure"
+#line 15728 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15934: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15733: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15964,7 +15763,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15968: checking for location of openDWG library" >&5
+echo "configure:15767: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -16011,7 +15810,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:16015: checking for special C compiler options needed for large files" >&5
+echo "configure:15814: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -16019,7 +15818,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 16023 "configure"
+#line 15822 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -16035,7 +15834,7 @@
; return 0; }
EOF
-if { (eval echo configure:16039: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15838: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -16044,7 +15843,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 16048 "configure"
+#line 15847 "configure"
@@ -16060,7 +15859,7 @@
; return 0; }
EOF
-if { (eval echo configure:16064: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15863: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -16080,11 +15879,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:16084: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15883: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 16088 "configure"
+#line 15887 "configure"
@@ -16100,14 +15899,14 @@
; return 0; }
EOF
-if { (eval echo configure:16104: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15903: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 16111 "configure"
+#line 15910 "configure"
#define _FILE_OFFSET_BITS 64
@@ -16125,7 +15924,7 @@
; return 0; }
EOF
-if { (eval echo configure:16129: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15928: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -16144,11 +15943,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:16148: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15947: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 16152 "configure"
+#line 15951 "configure"
@@ -16164,14 +15963,14 @@
; return 0; }
EOF
-if { (eval echo configure:16168: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15967: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 16175 "configure"
+#line 15974 "configure"
#define _LARGE_FILES 1
@@ -16189,7 +15988,7 @@
; return 0; }
EOF
-if { (eval echo configure:16193: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15992: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -16208,25 +16007,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:16212: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:16011: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 16216 "configure"
+#line 16015 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:16223: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16022: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 16230 "configure"
+#line 16029 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -16235,7 +16034,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:16239: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16038: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -16256,10 +16055,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:16260: checking if system supports Large Files at all" >&5
+echo "configure:16059: checking if system supports Large Files at all" >&5
-#line 16263 "configure"
+#line 16062 "configure"
#include <stdio.h>
@@ -16291,7 +16090,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:16295: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16094: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -16320,7 +16119,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16324: checking whether to use Python" >&5
+echo "configure:16123: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -16340,7 +16139,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:16344: checking for $ac_word" >&5
+echo "configure:16143: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -16382,15 +16181,15 @@
do
-echo "configure:16386: checking for $ac_hdr" >&5
+echo "configure:16185: checking for $ac_hdr" >&5
-#line 16389 "configure"
+#line 16188 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16394: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16193: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -16460,7 +16259,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16464: checking whether to use wxWidgets" >&5
+echo "configure:16263: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -16481,7 +16280,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:16485: checking for $ac_word" >&5
+echo "configure:16284: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -16529,7 +16328,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16533: checking wxWidgets version" >&5
+echo "configure:16332: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -16552,15 +16351,15 @@
do
-echo "configure:16556: checking for $ac_hdr" >&5
+echo "configure:16355: checking for $ac_hdr" >&5
-#line 16559 "configure"
+#line 16358 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16564: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16363: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -16827,9 +16626,6 @@
s%@READLINELIBPATH@%$READLINELIBPATH%g
s%@READLINELIB@%$READLINELIB%g
s%@HISTORYLIB@%$HISTORYLIB%g
-s%@JPEGINCPATH@%$JPEGINCPATH%g
-s%@JPEGLIBPATH@%$JPEGLIBPATH%g
-s%@JPEGLIB@%$JPEGLIB%g
s%@GDAL_CONFIG@%$GDAL_CONFIG%g
s%@GDAL_LIBS@%$GDAL_LIBS%g
s%@GDAL_CFLAGS@%$GDAL_CFLAGS%g
@@ -17228,8 +17024,6 @@
echo " GLw support: `if test -n "${USE_GLW}" ; then echo yes ; else echo no ; fi`"
-echo " JPEG support: `if test -n "${USE_JPEG}" ; then echo yes ; else echo no ; fi`"
echo " LAPACK support: `if test -n "${USE_LAPACK}" ; then echo yes ; else echo no ; fi`"
echo " Large File support (LFS): `if test -n "${USE_LARGEFILES}" ; then echo yes ; else echo no ; fi`"
Modified: grass/branches/develbranch_6/configure.in
--- grass/branches/develbranch_6/configure.in 2012-03-11 19:50:23 UTC (rev 51035)
+++ grass/branches/develbranch_6/configure.in 2012-03-11 19:51:37 UTC (rev 51036)
@@ -244,7 +244,6 @@
AC_ARG_WITH(macosx-sdk,
[ --with-macosx-sdk[=path/sdk]
compile with a system SDK on MacOSX. (default: no)],, with_macosx_sdk="no")
-LOC_ARG_WITH(jpeg, JPEG)
LOC_ARG_WITH(tiff, TIFF)
LOC_ARG_WITH(png, PNG)
LOC_ARG_WITH(tcltk, Tcl/Tk)
@@ -305,9 +304,6 @@
LOC_ARG_WITH_INC(readline, Readline)
LOC_ARG_WITH_LIB(readline, Readline)
-LOC_ARG_WITH_INC(jpeg, JPEG)
-LOC_ARG_WITH_LIB(jpeg, JPEG)
LOC_ARG_WITH_INC(tiff, TIFF)
LOC_ARG_WITH_LIB(tiff, TIFF)
@@ -768,36 +764,6 @@
# Done checking Readline
-# Enable JPEG option
-LOC_CHECK_USE(jpeg,JPEG,USE_JPEG)
-JPEGINCPATH=
-JPEGLIBPATH=
-JPEGLIB=
-if test -n "$USE_JPEG"; then
-# With JPEG includes directory
-LOC_CHECK_INC_PATH(jpeg,JPEG,JPEGINCPATH)
-LOC_CHECK_INCLUDES(jpeglib.h,JPEG,$JPEGINCPATH)
-# With JPEG library directory
-LOC_CHECK_LIB_PATH(jpeg,JPEG,JPEGLIBPATH)
-LOC_CHECK_LIBS(jpeg,jpeg_start_compress,JPEG,$JPEGLIBPATH,JPEGLIB,,,,$ZLIB)
-fi # $USE_JPEG
-AC_SUBST(JPEGINCPATH)
-AC_SUBST(JPEGLIBPATH)
-AC_SUBST(JPEGLIB)
-# Done checking JPEG
# GDAL option
AC_MSG_CHECKING(whether to use GDAL)
@@ -916,7 +882,7 @@
LOC_CHECK_LIB_PATH(tiff,TIFF,TIFF_LIBRARY_DIRS)
-LOC_CHECK_LIBS(tiff,TIFFOpen,TIFF,$TIFF_LIBRARY_DIRS,TIFFLIB,,,,$JPEGLIBPATH $JPEGLIB,$ZLIB,$MATHLIB)
+LOC_CHECK_LIBS(tiff,TIFFOpen,TIFF,$TIFF_LIBRARY_DIRS,TIFFLIB,,,,-ljpeg,$ZLIB,$MATHLIB)
fi # $USE_TIFF
@@ -2060,7 +2026,6 @@
LOC_MSG_USE(GDAL support,USE_GDAL)
LOC_MSG_USE(GEOS support,USE_GEOS)
LOC_MSG_USE(GLw support,USE_GLW)
-LOC_MSG_USE(JPEG support,USE_JPEG)
LOC_MSG_USE(LAPACK support,USE_LAPACK)
LOC_MSG_USE(Large File support (LFS), USE_LARGEFILES)
LOC_MSG_USE(Motif support,USE_MOTIF)
