[GRASS-SVN] r51105 - grass/trunk/vector/v.external
svn_grass at osgeo.org
Sun Mar 18 08:50:21 EDT 2012
Author: martinl
Date: 2012-03-18 05:50:21 -0700 (Sun, 18 Mar 2012)
New Revision: 51105
grass/trunk/vector/v.external/list.c
grass/trunk/vector/v.external/local_proto.h
grass/trunk/vector/v.external/main.c
v.external: support schema info for postgis links
Modified: grass/trunk/vector/v.external/list.c
--- grass/trunk/vector/v.external/list.c 2012-03-18 12:16:45 UTC (rev 51104)
+++ grass/trunk/vector/v.external/list.c 2012-03-18 12:50:21 UTC (rev 51105)
@@ -53,11 +53,29 @@
return -1;
+void get_table_name(const char *table, char **table_name, char **schema_name)
+ char **tokens;
+ tokens = G_tokenize(table, ".");
+ if (G_number_of_tokens(tokens) > 1) {
+ *schema_name = G_store(tokens[0]);
+ *table_name = G_store(tokens[1]);
+ else {
+ *schema_name = NULL;
+ *table_name = G_store(tokens[0]);
+ G_free_tokens(tokens);
+#ifdef HAVE_POSTGRES
int list_layers_pg(FILE *fd, const char *conninfo, const char *table, int print_types, int *is3D)
-#ifdef HAVE_POSTGRES
int row, ntables, ret, print_schema;
- char *value;
+ char *value, *schema_name, *table_name;
PGconn *conn;
PGresult *res;
@@ -80,20 +98,27 @@
if (PQresultStatus(res) != PGRES_TUPLES_OK)
G_fatal_error("%s\n%s", _("No feature tables found in database."),
PQresultErrorMessage(res));
+ /* get schema & table_name */
+ table_name = schema_name = NULL;
+ if (table)
+ get_table_name(table, &table_name, &schema_name);
ntables = PQntuples(res);
G_debug(3, " nrows = %d", ntables);
if (fd)
G_message(_("PostGIS database <%s> contains %d feature table(s):"),
PQdb(conn), ntables);
/* report also schemas */
print_schema = FALSE;
- for (row = 0; row < ntables; row++) {
- value = PQgetvalue(res, row, 0);
- if (strcmp(value, "public") != 0) {
- print_schema = TRUE;
- break;
+ if (fd) {
+ for (row = 0; row < ntables; row++) {
+ value = PQgetvalue(res, row, 0);
+ if (strcmp(value, "public") != 0) {
+ print_schema = TRUE;
+ break;
@@ -116,21 +141,24 @@
fprintf(fd, "%s\n", value);
- if (table && strcmp(value, table) == 0) {
+ if (table_name && strcmp(value, table_name) == 0) {
ret = row;
*is3D = WITHOUT_Z;
+ if (table_name)
+ G_free(table_name);
+ if (schema_name)
+ G_free(schema_name);
PQclear(res);
PQfinish(conn);
G_debug(1, "PQfinish()");
return ret;
-#else
- G_fatal_error(_("GRASS not compiled with PostgreSQL/PostGIS support"));
-#endif
+#endif /* HAVE_POSTGRES */
#ifdef HAVE_OGR
int list_layers_ogr(FILE *fd, const char *dsn, const char *layer, int print_types, int *is3D)
Modified: grass/trunk/vector/v.external/local_proto.h
--- grass/trunk/vector/v.external/local_proto.h 2012-03-18 12:16:45 UTC (rev 51104)
+++ grass/trunk/vector/v.external/local_proto.h 2012-03-18 12:50:21 UTC (rev 51105)
@@ -16,5 +16,6 @@
/* list.c */
void list_formats(FILE *);
int list_layers(FILE *, const char *, const char *, int, int, int *);
+void get_table_name(const char *, char **, char **);
#endif
Modified: grass/trunk/vector/v.external/main.c
--- grass/trunk/vector/v.external/main.c 2012-03-18 12:16:45 UTC (rev 51104)
+++ grass/trunk/vector/v.external/main.c 2012-03-18 12:50:21 UTC (rev 51105)
@@ -142,9 +142,18 @@
if (flags.postgis->answer) {
+ char *table_name, *schema_name;
+ get_table_name(options.layer->answer, &table_name, &schema_name);
fprintf(fd, "FORMAT: postgis\n");
fprintf(fd, "CONNINFO: %s\n", dsn);
- fprintf(fd, "TABLE: %s\n", options.layer->answer);
+ if (schema_name)
+ fprintf(fd, "SCHEMA: %s\n", schema_name);
+ fprintf(fd, "TABLE: %s\n", table_name);
else {
fprintf(fd, "FORMAT: ogr\n");
