[GRASS-SVN] r51106 - in grass/trunk: include/vect lib/vector/Vlib
lib/vector/diglib
svn_grass at osgeo.org
Sun Mar 18 08:59:01 EDT 2012
Author: martinl
Date: 2012-03-18 05:59:01 -0700 (Sun, 18 Mar 2012)
New Revision: 51106
grass/trunk/include/vect/dig_structs.h
grass/trunk/lib/vector/Vlib/build_sfa.c
grass/trunk/lib/vector/Vlib/close_pg.c
grass/trunk/lib/vector/Vlib/open_pg.c
grass/trunk/lib/vector/diglib/frmt.c
vlib(pg): support schemas
Modified: grass/trunk/include/vect/dig_structs.h
--- grass/trunk/include/vect/dig_structs.h 2012-03-18 12:50:21 UTC (rev 51105)
+++ grass/trunk/include/vect/dig_structs.h 2012-03-18 12:59:01 UTC (rev 51106)
@@ -590,6 +590,10 @@
char *db_name;
+ \brief Schema name
+ char *schema_name;
\brief Table name
char *table_name;
Modified: grass/trunk/lib/vector/Vlib/build_sfa.c
--- grass/trunk/lib/vector/Vlib/build_sfa.c 2012-03-18 12:50:21 UTC (rev 51105)
+++ grass/trunk/lib/vector/Vlib/build_sfa.c 2012-03-18 12:59:01 UTC (rev 51106)
@@ -330,13 +330,14 @@
G_zero(&fparts, sizeof(struct feat_parts));
/* get records */
- sprintf(stmt, "SELECT %s,%s FROM %s",
+ sprintf(stmt, "SELECT %s,%s FROM %s.%s",
pg_info->fid_column,
- pg_info->geom_column, pg_info->table_name);
+ pg_info->geom_column, pg_info->schema_name, pg_info->table_name);
G_debug(2, "SQL: %s", stmt);
pg_info->res = PQexec(pg_info->conn, stmt);
if (!pg_info->res || PQresultStatus(pg_info->res) != PGRES_TUPLES_OK) {
PQclear(pg_info->res);
+ pg_info->res = NULL;
G_warning(_("Unable to get features:\n%s"),
PQerrorMessage(pg_info->conn));
return; /* reading failed */
Modified: grass/trunk/lib/vector/Vlib/close_pg.c
--- grass/trunk/lib/vector/Vlib/close_pg.c 2012-03-18 12:50:21 UTC (rev 51105)
+++ grass/trunk/lib/vector/Vlib/close_pg.c 2012-03-18 12:59:01 UTC (rev 51106)
@@ -69,13 +69,12 @@
if (pg_info->cache.lines)
G_free(pg_info->cache.lines);
- if (pg_info->db_name)
- G_free(pg_info->db_name);
- if (pg_info->geom_column)
- G_free(pg_info->geom_column);
- if (pg_info->fid_column)
- G_free(pg_info->fid_column);
+ G_free(pg_info->db_name);
+ G_free(pg_info->schema_name);
+ G_free(pg_info->geom_column);
+ G_free(pg_info->fid_column);
return 0;
#else
G_fatal_error(_("GRASS is not compiled with PostgreSQL support"));
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c 2012-03-18 12:50:21 UTC (rev 51105)
+++ grass/trunk/lib/vector/Vlib/open_pg.c 2012-03-18 12:59:01 UTC (rev 51106)
@@ -140,8 +140,8 @@
/* get fid and geometry column */
- db_set_string(&stmt, "SELECT f_table_name, f_geometry_column,"
- "coord_dimension,srid,type "
+ db_set_string(&stmt, "SELECT f_table_schema, f_table_name, f_geometry_column,"
+ "coord_dimension, srid, type "
"FROM geometry_columns");
G_debug(2, "SQL: %s", db_get_string(&stmt));
@@ -154,19 +154,27 @@
G_debug(3, "\tnrows = %d", ntables);
found = FALSE;
for (i = 0; i < ntables; i++) {
- if (strcmp(PQgetvalue(res, i, 0), pg_info->table_name) == 0) {
+ if ((pg_info->schema_name && /* schema defined */
+ strcmp(PQgetvalue(res, i, 0), pg_info->schema_name) == 0 &&
+ strcmp(PQgetvalue(res, i, 1), pg_info->table_name) == 0) ||
+ (!pg_info->schema_name && /* schema not defined, get first match */
+ strcmp(PQgetvalue(res, i, 1), pg_info->table_name) == 0)) {
+ /* schema name */
+ if (!pg_info->schema_name) {
+ pg_info->schema_name = G_store(PQgetvalue(res, i, 0));
/* geometry column */
- pg_info->geom_column = G_store(PQgetvalue(res, i, 1));
+ pg_info->geom_column = G_store(PQgetvalue(res, i, 2));
G_debug(3, "\t-> table = %s column = %s", pg_info->table_name,
/* fid column */
pg_info->fid_column = get_key_column(pg_info);
/* coordinates dimension */
- pg_info->coor_dim = atoi(PQgetvalue(res, i, 2));
+ pg_info->coor_dim = atoi(PQgetvalue(res, i, 3));
/* SRS ID */
- pg_info->srid = atoi(PQgetvalue(res, i, 3));
+ pg_info->srid = atoi(PQgetvalue(res, i, 4));
/* feature type */
- pg_info->feature_type = ftype_from_string(PQgetvalue(res, i, 4));
+ pg_info->feature_type = ftype_from_string(PQgetvalue(res, i, 5));
found = TRUE;
break;
@@ -180,7 +188,8 @@
db_free_string(&stmt);
if (!found) {
- G_warning(_("Feature table <%s> not found in 'geometry_columns'"));
+ G_warning(_("Feature table <%s> not found in 'geometry_columns'"),
+ pg_info->table_name);
return -1;
Modified: grass/trunk/lib/vector/diglib/frmt.c
--- grass/trunk/lib/vector/diglib/frmt.c 2012-03-18 12:50:21 UTC (rev 51105)
+++ grass/trunk/lib/vector/diglib/frmt.c 2012-03-18 12:59:01 UTC (rev 51106)
@@ -117,6 +117,8 @@
if (frmt == GV_FORMAT_POSTGIS) {
if (strcmp(buf1, "CONNINFO") == 0)
finfo->pg.conninfo = G_store(ptr);
+ if (strcmp(buf1, "SCHEMA") == 0)
+ finfo->pg.schema_name = G_store(ptr);
if (strcmp(buf1, "TABLE") == 0)
finfo->pg.table_name = G_store(ptr);
