[GRASS-SVN] r51634 - in grass/trunk: . include/Make raster3d raster3d/r3.out.netcdf raster3d/r3.out.netcdf/test_suite
Wed May 16 17:31:40 EDT 2012
Author: huhabla
Date: 2012-05-16 14:31:40 -0700 (Wed, 16 May 2012)
New Revision: 51634
   grass/trunk/configure
   grass/trunk/configure.in
   grass/trunk/include/Make/Platform.make.in
   grass/trunk/raster3d/Makefile
   grass/trunk/raster3d/r3.out.netcdf/Makefile
   grass/trunk/raster3d/r3.out.netcdf/main.c
   grass/trunk/raster3d/r3.out.netcdf/test_suite/test.r3.out.netcdf.sh
NetCDF library support integrated in configuration.
Projection specific metadata generation implemented in r3.out.netcdf.
Added r3.out.netcdf to 3D raster Makefile.
Modified: grass/trunk/configure
--- grass/trunk/configure	2012-05-16 19:51:41 UTC (rev 51633)
+++ grass/trunk/configure	2012-05-16 21:31:40 UTC (rev 51634)
@@ -83,6 +83,11 @@
                           e.g. '--with-wxwidgets=/usr/local/bin/wx-config',
                           default: no)"
 ac_help="$ac_help
+  --with-netcdf[=path/nc-config]
+                          enable NetCDF support (nc-config with path,
+                          e.g. '--with-nc=/usr/local/bin/nc-config',
+                          default: no)"
+ac_help="$ac_help
   --with-geos[=path/geos-config]
                           enable GEOS support (geos-config with path,
                           e.g. '--with-geos=/usr/local/bin/geos-config',
@@ -745,7 +750,7 @@
 fi
 echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:749: checking host system type" >&5
+echo "configure:754: checking host system type" >&5
 host_alias=$host
 case "$host_alias" in
@@ -768,7 +773,7 @@
 # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:772: checking for $ac_word" >&5
+echo "configure:777: checking for $ac_word" >&5
 if test -n "$CC"; then
   ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -795,7 +800,7 @@
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
-echo "configure:799: checking for $ac_word" >&5
+echo "configure:804: checking for $ac_word" >&5
@@ -843,7 +848,7 @@
       # Extract the first word of "cl", so it can be a program name with args.
 set dummy cl; ac_word=$2
-echo "configure:847: checking for $ac_word" >&5
+echo "configure:852: checking for $ac_word" >&5
@@ -872,7 +877,7 @@
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:876: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:881: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
 ac_ext=c
 # CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -883,12 +888,12 @@
 cat > conftest.$ac_ext << EOF
-#line 887 "configure"
+#line 892 "configure"
 #include "confdefs.h"
 main(){return(0);}
 EOF
-if { (eval echo configure:892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cc_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -914,19 +919,19 @@
   { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:918: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:923: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
 cross_compiling=$ac_cv_prog_cc_cross
 echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:923: checking whether we are using GNU C" >&5
+echo "configure:928: checking whether we are using GNU C" >&5
 cat > conftest.c <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:930: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:935: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gcc=yes
 else
   ac_cv_prog_gcc=no
@@ -944,7 +949,7 @@
 ac_save_CFLAGS="$CFLAGS"
 CFLAGS=
 echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:948: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:953: checking whether ${CC-cc} accepts -g" >&5
 echo 'void f(){}' > conftest.c
 if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -973,10 +978,10 @@
 fi
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:977: checking for Cygwin environment" >&5
+echo "configure:982: checking for Cygwin environment" >&5
 cat > conftest.$ac_ext <<EOF
-#line 980 "configure"
+#line 985 "configure"
 int main() {
@@ -987,7 +992,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:991: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:996: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -1003,17 +1008,17 @@
 CYGWIN=
 test "$ac_cv_cygwin" = yes && CYGWIN=yes
 echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:1007: checking for mingw32 environment" >&5
+echo "configure:1012: checking for mingw32 environment" >&5
-#line 1010 "configure"
+#line 1015 "configure"
 int main() {
 return __MINGW32__;
 ; return 0; }
 EOF
-if { (eval echo configure:1017: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1022: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_mingw32=yes
 else
@@ -1031,7 +1036,7 @@
 echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1035: checking for executable suffix" >&5
+echo "configure:1040: checking for executable suffix" >&5
 if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
   ac_cv_exeext=.exe
@@ -1050,23 +1055,23 @@
 IEEEFLAG=
 echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1054: checking for full floating-point support" >&5
+echo "configure:1059: checking for full floating-point support" >&5
 if test "$cross_compiling" = yes; then
      echo "$ac_t""unknown (cross-compiling)" 1>&6
 echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1059: checking whether "cc -mieee" works" >&5
+echo "configure:1064: checking whether "cc -mieee" works" >&5
 ac_save_cflags=${CFLAGS}
 CFLAGS="$CFLAGS -mieee"
-#line 1063 "configure"
+#line 1068 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:1070: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1075: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
      echo "$ac_t""yes" 1>&6
         IEEEFLAG="-mieee"
@@ -1082,7 +1087,7 @@
 else
-#line 1086 "configure"
+#line 1091 "configure"
 #include <float.h>
@@ -1096,7 +1101,7 @@
 EOF
-if { (eval echo configure:1100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
@@ -1109,14 +1114,14 @@
   CFLAGS=-mieee
 echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1113: checking for full floating-point support with -mieee" >&5
+echo "configure:1118: checking for full floating-point support with -mieee" >&5
     { echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
 else
-#line 1120 "configure"
+#line 1125 "configure"
 #include <float.h>
@@ -1130,7 +1135,7 @@
 EOF
-if { (eval echo configure:1134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
     IEEEFLAG="-mieee"
@@ -1167,7 +1172,7 @@
 # Extract the first word of "pwd", so it can be a program name with args.
 set dummy pwd; ac_word=$2
-echo "configure:1171: checking for $ac_word" >&5
+echo "configure:1176: checking for $ac_word" >&5
 case "$pwd" in
@@ -1205,7 +1210,7 @@
 fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1209: checking for source directory" >&5
+echo "configure:1214: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1216,7 +1221,7 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1220: checking for build directory" >&5
+echo "configure:1225: checking for build directory" >&5
 DSTDIR=`$pwd`
 WINDSTDIR=`$winpwd`
@@ -1284,7 +1289,7 @@
 # Extract the first word of "svnversion", so it can be a program name with args.
 set dummy svnversion; ac_word=$2
-echo "configure:1288: checking for $ac_word" >&5
+echo "configure:1293: checking for $ac_word" >&5
 case "$SVN_VERSION" in
@@ -1343,7 +1348,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1347: checking for MacOSX App" >&5
+echo "configure:1352: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1355,7 +1360,7 @@
 # Check for MacOSX archs
 echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1359: checking for MacOSX architectures" >&5
+echo "configure:1364: checking for MacOSX architectures" >&5
 MACOSX_ARCHS=
@@ -1384,7 +1389,7 @@
 # Check for MacOSX SDK
 echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1388: checking for MacOSX SDK" >&5
+echo "configure:1393: checking for MacOSX SDK" >&5
 MACOSX_SDK=
@@ -1394,7 +1399,7 @@
 ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1398: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1403: checking for $with_macosx_sdk/SDKSettings.plist" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1438,7 +1443,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1442: checking how to build libraries" >&5
+echo "configure:1447: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1835,6 +1840,15 @@
 fi
+# Check whether --with-netcdf or --without-netcdf was given.
+if test "${with_netcdf+set}" = set; then
+  withval="$with_netcdf"
+else
+  with_netcdf="no"
+fi
 # With includes and libs options
 # Check whether --with-geos or --without-geos was given.
@@ -2250,7 +2264,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2254: checking for additional include dirs" >&5
+echo "configure:2268: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2273,7 +2287,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2277: checking for additional library dirs" >&5
+echo "configure:2291: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2307,7 +2321,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2311: checking for a BSD compatible install" >&5
+echo "configure:2325: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -2360,7 +2374,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:2364: checking for $ac_word" >&5
+echo "configure:2378: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2391,13 +2405,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2395: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2409: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-l$ac_lib  $LIBS"
-#line 2401 "configure"
+#line 2415 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -2408,7 +2422,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:2412: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -2433,7 +2447,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:2437: checking for $ac_word" >&5
+echo "configure:2451: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -2473,7 +2487,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:2477: checking for $ac_word" >&5
+echo "configure:2491: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2504,7 +2518,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:2508: checking for $ac_word" >&5
+echo "configure:2522: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -2542,7 +2556,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:2546: checking for $ac_word" >&5
+echo "configure:2560: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2571,7 +2585,7 @@
-echo "configure:2575: checking for $ac_word" >&5
+echo "configure:2589: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2602,7 +2616,7 @@
-echo "configure:2606: checking for $ac_word" >&5
+echo "configure:2620: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2631,7 +2645,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:2635: checking for $ac_word" >&5
+echo "configure:2649: checking for $ac_word" >&5
 case "$PERL" in
@@ -2662,7 +2676,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2666: checking how to run the C preprocessor" >&5
+echo "configure:2680: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -2675,13 +2689,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 2679 "configure"
+#line 2693 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2685: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2699: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -2692,13 +2706,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 2696 "configure"
+#line 2710 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:2702: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2716: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2709,13 +2723,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 2713 "configure"
+#line 2727 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:2719: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2733: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2739,10 +2753,10 @@
 echo "$ac_t""$CPP" 1>&6
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2743: checking for ANSI C header files" >&5
+echo "configure:2757: checking for ANSI C header files" >&5
-#line 2746 "configure"
+#line 2760 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -2750,7 +2764,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:2754: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2768: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2767,7 +2781,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2771 "configure"
+#line 2785 "configure"
 #include <string.h>
 EOF
@@ -2785,7 +2799,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2789 "configure"
+#line 2803 "configure"
 #include <stdlib.h>
 EOF
@@ -2806,7 +2820,7 @@
 else
-#line 2810 "configure"
+#line 2824 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2817,7 +2831,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:2821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -2844,15 +2858,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2848: checking for $ac_hdr" >&5
+echo "configure:2862: checking for $ac_hdr" >&5
-#line 2851 "configure"
+#line 2865 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2856: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2870: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2881,15 +2895,15 @@
 do
-echo "configure:2885: checking for $ac_hdr" >&5
+echo "configure:2899: checking for $ac_hdr" >&5
-#line 2888 "configure"
+#line 2902 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2893: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2907: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2918,15 +2932,15 @@
 do
-echo "configure:2922: checking for $ac_hdr" >&5
+echo "configure:2936: checking for $ac_hdr" >&5
-#line 2925 "configure"
+#line 2939 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2930: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2944: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2955,15 +2969,15 @@
 do
-echo "configure:2959: checking for $ac_hdr" >&5
+echo "configure:2973: checking for $ac_hdr" >&5
-#line 2962 "configure"
+#line 2976 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2967: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2981: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2992,15 +3006,15 @@
 do
-echo "configure:2996: checking for $ac_hdr" >&5
+echo "configure:3010: checking for $ac_hdr" >&5
-#line 2999 "configure"
+#line 3013 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3004: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3018: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3026,10 +3040,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3030: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3044: checking whether time.h and sys/time.h may both be included" >&5
-#line 3033 "configure"
+#line 3047 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -3038,7 +3052,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:3042: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3056: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -3058,10 +3072,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3062: checking for off_t" >&5
+echo "configure:3076: checking for off_t" >&5
-#line 3065 "configure"
+#line 3079 "configure"
 #if STDC_HEADERS
@@ -3088,10 +3102,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3092: checking for uid_t in sys/types.h" >&5
+echo "configure:3106: checking for uid_t in sys/types.h" >&5
-#line 3095 "configure"
+#line 3109 "configure"
 EOF
@@ -3119,10 +3133,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3123: checking return type of signal handlers" >&5
+echo "configure:3137: checking return type of signal handlers" >&5
-#line 3126 "configure"
+#line 3140 "configure"
 #include <signal.h>
@@ -3139,7 +3153,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:3143: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3157: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -3157,10 +3171,10 @@
-echo "configure:3161: checking for Cygwin environment" >&5
+echo "configure:3175: checking for Cygwin environment" >&5
-#line 3164 "configure"
+#line 3178 "configure"
 int main() {
@@ -3171,7 +3185,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:3175: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3189: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -3189,10 +3203,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3193: checking for $ac_func" >&5
+echo "configure:3207: checking for $ac_func" >&5
-#line 3196 "configure"
+#line 3210 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -3215,7 +3229,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -3241,10 +3255,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:3245: checking for $ac_func" >&5
+echo "configure:3259: checking for $ac_func" >&5
-#line 3248 "configure"
+#line 3262 "configure"
@@ -3267,7 +3281,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3293,10 +3307,10 @@
 for ac_func in drand48
 do
-echo "configure:3297: checking for $ac_func" >&5
+echo "configure:3311: checking for $ac_func" >&5
-#line 3300 "configure"
+#line 3314 "configure"
@@ -3319,7 +3333,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3345,10 +3359,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:3349: checking for $ac_func" >&5
+echo "configure:3363: checking for $ac_func" >&5
-#line 3352 "configure"
+#line 3366 "configure"
@@ -3371,7 +3385,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3397,10 +3411,10 @@
 for ac_func in nanosleep
 do
-echo "configure:3401: checking for $ac_func" >&5
+echo "configure:3415: checking for $ac_func" >&5
-#line 3404 "configure"
+#line 3418 "configure"
@@ -3423,7 +3437,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3448,13 +3462,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3452: checking whether setpgrp takes no argument" >&5
+echo "configure:3466: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 3458 "configure"
+#line 3472 "configure"
 #ifdef HAVE_UNISTD_H
@@ -3474,7 +3488,7 @@
 EOF
-if { (eval echo configure:3478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -3502,16 +3516,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3506: checking for long long int" >&5
+echo "configure:3520: checking for long long int" >&5
-#line 3508 "configure"
+#line 3522 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:3515: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3529: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -3531,7 +3545,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3535: checking for W11" >&5
+echo "configure:3549: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -3559,7 +3573,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3563: checking for X" >&5
+echo "configure:3577: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -3619,12 +3633,12 @@
   # First, try using that file with no special directory specified.
-#line 3623 "configure"
+#line 3637 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:3628: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3642: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3693,14 +3707,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 3697 "configure"
+#line 3711 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:3704: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3718: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -3805,17 +3819,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3809: checking whether -R must be followed by a space" >&5
+echo "configure:3823: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3812 "configure"
+#line 3826 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3833: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -3831,14 +3845,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3835 "configure"
+#line 3849 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3856: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -3870,13 +3884,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3874: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3888: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 3880 "configure"
+#line 3894 "configure"
@@ -3887,7 +3901,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:3891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3905: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3908,13 +3922,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3912: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3926: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 3918 "configure"
+#line 3932 "configure"
@@ -3925,7 +3939,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:3929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3953,10 +3967,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:3957: checking for gethostbyname" >&5
+echo "configure:3971: checking for gethostbyname" >&5
-#line 3960 "configure"
+#line 3974 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -3979,7 +3993,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -3999,13 +4013,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4003: checking for gethostbyname in -lnsl" >&5
+echo "configure:4017: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 4009 "configure"
+#line 4023 "configure"
@@ -4016,7 +4030,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:4020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4045,10 +4059,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4049: checking for connect" >&5
+echo "configure:4063: checking for connect" >&5
-#line 4052 "configure"
+#line 4066 "configure"
     which can conflict with char connect(); below.  */
@@ -4071,7 +4085,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -4091,13 +4105,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4095: checking for connect in -lsocket" >&5
+echo "configure:4109: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4101 "configure"
+#line 4115 "configure"
@@ -4108,7 +4122,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:4112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4131,10 +4145,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4135: checking for remove" >&5
+echo "configure:4149: checking for remove" >&5
-#line 4138 "configure"
+#line 4152 "configure"
     which can conflict with char remove(); below.  */
@@ -4157,7 +4171,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -4177,13 +4191,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4181: checking for remove in -lposix" >&5
+echo "configure:4195: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 4187 "configure"
+#line 4201 "configure"
@@ -4194,7 +4208,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:4198: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4212: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4217,10 +4231,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4221: checking for shmat" >&5
+echo "configure:4235: checking for shmat" >&5
-#line 4224 "configure"
+#line 4238 "configure"
     which can conflict with char shmat(); below.  */
@@ -4243,7 +4257,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -4263,13 +4277,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4267: checking for shmat in -lipc" >&5
+echo "configure:4281: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 4273 "configure"
+#line 4287 "configure"
@@ -4280,7 +4294,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:4284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4312,13 +4326,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4316: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4330: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4322 "configure"
+#line 4336 "configure"
@@ -4329,7 +4343,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:4333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4347: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4369,12 +4383,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4373: checking for library containing cuserid" >&5
+echo "configure:4387: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 4378 "configure"
+#line 4392 "configure"
@@ -4385,7 +4399,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -4396,7 +4410,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 4400 "configure"
+#line 4414 "configure"
@@ -4407,7 +4421,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4411: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -4433,10 +4447,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:4437: checking for xdrmem_create" >&5
+echo "configure:4451: checking for xdrmem_create" >&5
-#line 4440 "configure"
+#line 4454 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -4459,7 +4473,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -4477,13 +4491,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:4481: checking for xdrmem_create in -lsun" >&5
+echo "configure:4495: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 4487 "configure"
+#line 4501 "configure"
@@ -4494,7 +4508,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:4498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4513,13 +4527,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:4517: checking for xdrmem_create in -lnsl" >&5
+echo "configure:4531: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 4523 "configure"
+#line 4537 "configure"
@@ -4530,7 +4544,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:4534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4549,13 +4563,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:4553: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:4567: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 4559 "configure"
+#line 4573 "configure"
@@ -4566,7 +4580,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:4570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4585,13 +4599,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:4589: checking for xdrmem_create in -lxdr" >&5
+echo "configure:4603: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 4595 "configure"
+#line 4609 "configure"
@@ -4602,7 +4616,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:4606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4636,10 +4650,10 @@
 for ac_func in asprintf
 do
-echo "configure:4640: checking for $ac_func" >&5
+echo "configure:4654: checking for $ac_func" >&5
-#line 4643 "configure"
+#line 4657 "configure"
@@ -4662,7 +4676,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4666: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4689,10 +4703,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4693: checking for atan" >&5
+echo "configure:4707: checking for atan" >&5
-#line 4696 "configure"
+#line 4710 "configure"
     which can conflict with char atan(); below.  */
@@ -4715,7 +4729,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4719: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4733: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -4733,13 +4747,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4737: checking for atan in -lm" >&5
+echo "configure:4751: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 4743 "configure"
+#line 4757 "configure"
@@ -4750,7 +4764,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:4754: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4768: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4777,10 +4791,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4781: checking for dlsym" >&5
+echo "configure:4795: checking for dlsym" >&5
-#line 4784 "configure"
+#line 4798 "configure"
     which can conflict with char dlsym(); below.  */
@@ -4803,7 +4817,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -4821,13 +4835,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4825: checking for dlsym in -ldl" >&5
+echo "configure:4839: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 4831 "configure"
+#line 4845 "configure"
@@ -4838,7 +4852,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:4842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4856: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4865,10 +4879,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4869: checking for iconv" >&5
+echo "configure:4883: checking for iconv" >&5
-#line 4872 "configure"
+#line 4886 "configure"
     which can conflict with char iconv(); below.  */
@@ -4891,7 +4905,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -4909,13 +4923,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4913: checking for iconv in -liconv" >&5
+echo "configure:4927: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 4919 "configure"
+#line 4933 "configure"
@@ -4926,7 +4940,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4944: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4945,13 +4959,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4949: checking for iconv in -lgiconv" >&5
+echo "configure:4963: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 4955 "configure"
+#line 4969 "configure"
@@ -4962,7 +4976,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4981,10 +4995,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4985: checking for libiconv" >&5
+echo "configure:4999: checking for libiconv" >&5
-#line 4988 "configure"
+#line 5002 "configure"
     which can conflict with char libiconv(); below.  */
@@ -5007,7 +5021,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -5025,13 +5039,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:5029: checking for libiconv in -liconv" >&5
+echo "configure:5043: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 5035 "configure"
+#line 5049 "configure"
@@ -5042,7 +5056,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:5046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5061,13 +5075,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:5065: checking for libiconv in -lgiconv" >&5
+echo "configure:5079: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 5071 "configure"
+#line 5085 "configure"
@@ -5078,7 +5092,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:5082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5115,10 +5129,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:5119: checking for socket" >&5
+echo "configure:5133: checking for socket" >&5
-#line 5122 "configure"
+#line 5136 "configure"
     which can conflict with char socket(); below.  */
@@ -5141,7 +5155,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -5159,13 +5173,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5163: checking for socket in -lsocket" >&5
+echo "configure:5177: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 5169 "configure"
+#line 5183 "configure"
@@ -5176,7 +5190,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:5180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5224,7 +5238,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5228: checking for location of zlib includes" >&5
+echo "configure:5242: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5250,15 +5264,15 @@
 do
-echo "configure:5254: checking for $ac_hdr" >&5
+echo "configure:5268: checking for $ac_hdr" >&5
-#line 5257 "configure"
+#line 5271 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5262: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5276: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5292,7 +5306,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5296: checking for location of zlib library" >&5
+echo "configure:5310: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5317,13 +5331,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5321: checking for deflate in -lz" >&5
+echo "configure:5335: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 5327 "configure"
+#line 5341 "configure"
@@ -5334,7 +5348,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:5338: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5382,7 +5396,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5386: checking for location of External PROJ.4 includes" >&5
+echo "configure:5400: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5408,15 +5422,15 @@
 do
-echo "configure:5412: checking for $ac_hdr" >&5
+echo "configure:5426: checking for $ac_hdr" >&5
-#line 5415 "configure"
+#line 5429 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5420: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5434: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5453,7 +5467,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5457: checking External PROJ.4 version" >&5
+echo "configure:5471: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5461,7 +5475,7 @@
 else
-#line 5465 "configure"
+#line 5479 "configure"
 #include <stdio.h>
@@ -5473,7 +5487,7 @@
 EOF
-if { (eval echo configure:5477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -5498,7 +5512,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5502: checking for location of External PROJ.4 library" >&5
+echo "configure:5516: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5523,13 +5537,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5527: checking for pj_get_def in -lproj" >&5
+echo "configure:5541: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 5533 "configure"
+#line 5547 "configure"
@@ -5540,7 +5554,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:5544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5574,7 +5588,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5578: checking for location of External PROJ.4 data files" >&5
+echo "configure:5592: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5598,14 +5612,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5602: checking for epsg" >&5
+echo "configure:5616: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5609: checking for $PROJSHARE/epsg" >&5
+echo "configure:5623: checking for $PROJSHARE/epsg" >&5
@@ -5637,7 +5651,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
-echo "configure:5641: checking for $ac_word" >&5
+echo "configure:5655: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -5677,7 +5691,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5681: checking whether to use regex" >&5
+echo "configure:5695: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -5697,7 +5711,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5701: checking for location of regex includes" >&5
+echo "configure:5715: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5723,15 +5737,15 @@
 do
-echo "configure:5727: checking for $ac_hdr" >&5
+echo "configure:5741: checking for $ac_hdr" >&5
-#line 5730 "configure"
+#line 5744 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5735: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5749: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5765,7 +5779,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5769: checking for location of regex library" >&5
+echo "configure:5783: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5790,10 +5804,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5794: checking for regcomp" >&5
+echo "configure:5808: checking for regcomp" >&5
-#line 5797 "configure"
+#line 5811 "configure"
     which can conflict with char regcomp(); below.  */
@@ -5816,7 +5830,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -5843,13 +5857,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5847: checking for regcomp in -lregex" >&5
+echo "configure:5861: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 5853 "configure"
+#line 5867 "configure"
@@ -5860,7 +5874,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:5864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5910,7 +5924,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5914: checking whether to use Readline" >&5
+echo "configure:5928: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -5931,7 +5945,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5935: checking for location of Readline includes" >&5
+echo "configure:5949: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5957,15 +5971,15 @@
 do
-echo "configure:5961: checking for $ac_hdr" >&5
+echo "configure:5975: checking for $ac_hdr" >&5
-#line 5964 "configure"
+#line 5978 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5969: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5983: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6001,15 +6015,15 @@
 do
-echo "configure:6005: checking for $ac_hdr" >&5
+echo "configure:6019: checking for $ac_hdr" >&5
-#line 6008 "configure"
+#line 6022 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6013: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6027: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6043,7 +6057,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:6047: checking for location of Readline library" >&5
+echo "configure:6061: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -6068,13 +6082,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:6072: checking for readline in -lreadline" >&5
+echo "configure:6086: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 6078 "configure"
+#line 6092 "configure"
@@ -6085,7 +6099,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:6089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6103: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6120,13 +6134,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6124: checking for add_history in -lhistory" >&5
+echo "configure:6138: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 6130 "configure"
+#line 6144 "configure"
@@ -6137,7 +6151,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:6141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6179,7 +6193,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6183: checking whether to use GDAL" >&5
+echo "configure:6197: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -6197,7 +6211,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:6201: checking for $ac_word" >&5
+echo "configure:6215: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -6252,14 +6266,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6256 "configure"
+#line 6270 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:6263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -6268,14 +6282,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6272 "configure"
+#line 6286 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -6307,7 +6321,7 @@
 # libLAS option
 echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6311: checking whether to use libLAS" >&5
+echo "configure:6325: checking whether to use libLAS" >&5
 LIBLAS_LIBS=
 LIBLAS_CFLAGS=
@@ -6324,7 +6338,7 @@
   # Extract the first word of "liblas-config", so it can be a program name with args.
 set dummy liblas-config; ac_word=$2
-echo "configure:6328: checking for $ac_word" >&5
+echo "configure:6342: checking for $ac_word" >&5
 case "$LIBLAS_CONFIG" in
@@ -6372,14 +6386,14 @@
   LIBS="$LIBS $LIBLAS_LIBS"
   CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
-#line 6376 "configure"
+#line 6390 "configure"
 #include <liblas/capi/liblas.h>
 int main() {
 LASReader_Create("foo");
 ; return 0; }
 EOF
-if { (eval echo configure:6383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6387,14 +6401,14 @@
   rm -rf conftest*
-#line 6391 "configure"
+#line 6405 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6398: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6412: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LAS_LIBS="$LAS_LIBS"
 else
@@ -6423,13 +6437,130 @@
+# NetCDF option
+echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
+echo "configure:6444: checking whether to use NetCDF" >&5
+NETCDF_LIBS=
+NETCDF_CFLAGS=
+USE_NETCDF=
+if test "`basename xx/$with_netcdf`" = "nc-config" ; then
+  NETCDF_CONFIG="$with_netcdf"
+fi
+if test "$with_netcdf" = "no" ; then
+  echo "$ac_t""no" 1>&6
+else
+  echo "$ac_t""yes" 1>&6
+  # Extract the first word of "nc-config", so it can be a program name with args.
+set dummy nc-config; ac_word=$2
+echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
+echo "configure:6461: checking for $ac_word" >&5
+case "$NETCDF_CONFIG" in
+  ac_cv_path_NETCDF_CONFIG="$NETCDF_CONFIG" # Let the user override the test with a path.
+  ac_cv_path_NETCDF_CONFIG="$NETCDF_CONFIG" # Let the user override the test with a dos path.
+  IFS="${IFS= 	}"; ac_save_ifs="$IFS"; IFS=":"
+  ac_dummy="$PATH"
+  for ac_dir in $ac_dummy; do
+    test -z "$ac_dir" && ac_dir=.
+    if test -f $ac_dir/$ac_word; then
+      ac_cv_path_NETCDF_CONFIG="$ac_dir/$ac_word"
+      break
+    fi
+  done
+  IFS="$ac_save_ifs"
+  test -z "$ac_cv_path_NETCDF_CONFIG" && ac_cv_path_NETCDF_CONFIG="no"
+esac
+NETCDF_CONFIG="$ac_cv_path_NETCDF_CONFIG"
+if test -n "$NETCDF_CONFIG"; then
+  echo "$ac_t""$NETCDF_CONFIG" 1>&6
+else
+fi
+  if test "$NETCDF_CONFIG" = "no" ; then
+    { echo "configure: error: *** couldn't find nc-config" 1>&2; exit 1; }
+  fi
+  if test "$NETCDF_CONFIG" != "" ; then
+    NETCDF_LIBS=`"$NETCDF_CONFIG" --libs`
+    NETCDF_CFLAGS=`"$NETCDF_CONFIG" --cflags`
+    USE_NETCDF=1
+  fi
+  NETCDF=
+  ac_save_libs="$LIBS"
+  ac_save_cflags="$CFLAGS"
+  LIBS="$LIBS $NETCDF_LIBS"
+  CFLAGS="$CFLAGS $NETCDF_CFLAGS"
+  cat > conftest.$ac_ext <<EOF
+#line 6508 "configure"
+#include "confdefs.h"
+#include <netcdf.h>
+int main() {
+nc_create("foo", NC_CLOBBER, NULL);
+; return 0; }
+EOF
+if { (eval echo configure:6515: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+#line 6523 "configure"
+int main() {
+; return 0; }
+EOF
+if { (eval echo configure:6530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+  NETCDF_LIBS="$NETCDF_LIBS"
+else
+  rm -rf conftest*
+  { echo "configure: error: *** Unable to locate NetCDF library." 1>&2; exit 1; }
+fi
+rm -f conftest*
+fi
+rm -f conftest*
+  LIBS=${ac_save_libs}
+  CFLAGS=${ac_save_cflags}
+  cat >> confdefs.h <<\EOF
+#define HAVE_NETCDF 1
+EOF
+fi
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6430: checking whether to use GEOS" >&5
+echo "configure:6561: checking whether to use GEOS" >&5
 GEOS_LIBS=
-GGEOS_CFLAGS=
+GEOS_CFLAGS=
 USE_GEOS=
 # FIXME: "quote" $with_geos ?
@@ -6444,7 +6575,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:6448: checking for $ac_word" >&5
+echo "configure:6579: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -6492,15 +6623,15 @@
 do
-echo "configure:6496: checking for $ac_hdr" >&5
+echo "configure:6627: checking for $ac_hdr" >&5
-#line 6499 "configure"
+#line 6630 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6504: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6635: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6536,13 +6667,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c_i""... $ac_c" 1>&6
-echo "configure:6540: checking for initGEOS in -lgeos_c_i" >&5
+echo "configure:6671: checking for initGEOS in -lgeos_c_i" >&5
 ac_lib_var=`echo geos_c_i'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c_i  $LIBS"
-#line 6546 "configure"
+#line 6677 "configure"
@@ -6553,7 +6684,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:6557: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6589,13 +6720,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6593: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6724: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c  $LIBS"
-#line 6599 "configure"
+#line 6730 "configure"
@@ -6606,7 +6737,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:6610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6650,7 +6781,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6654: checking whether to use TIFF" >&5
+echo "configure:6785: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -6670,7 +6801,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6674: checking for location of TIFF includes" >&5
+echo "configure:6805: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6696,15 +6827,15 @@
 do
-echo "configure:6700: checking for $ac_hdr" >&5
+echo "configure:6831: checking for $ac_hdr" >&5
-#line 6703 "configure"
+#line 6834 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6708: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6839: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6738,7 +6869,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6742: checking for location of TIFF library" >&5
+echo "configure:6873: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6769,13 +6900,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6773: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6904: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 6779 "configure"
+#line 6910 "configure"
@@ -6786,7 +6917,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6805,13 +6936,13 @@
-echo "configure:6809: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6940: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 6815 "configure"
+#line 6946 "configure"
@@ -6822,7 +6953,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6841,13 +6972,13 @@
-echo "configure:6845: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6976: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 6851 "configure"
+#line 6982 "configure"
@@ -6858,7 +6989,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6877,13 +7008,13 @@
-echo "configure:6881: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7012: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 6887 "configure"
+#line 7018 "configure"
@@ -6894,7 +7025,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6913,13 +7044,13 @@
-echo "configure:6917: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7048: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $LIBS"
-#line 6923 "configure"
+#line 7054 "configure"
@@ -6930,7 +7061,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6949,13 +7080,13 @@
-echo "configure:6953: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7084: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 6959 "configure"
+#line 7090 "configure"
@@ -6966,7 +7097,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6985,13 +7116,13 @@
-echo "configure:6989: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7120: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 6995 "configure"
+#line 7126 "configure"
@@ -7002,7 +7133,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7021,13 +7152,13 @@
-echo "configure:7025: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7156: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 7031 "configure"
+#line 7162 "configure"
@@ -7038,7 +7169,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7136,7 +7267,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7140: checking whether to use PNG" >&5
+echo "configure:7271: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -7155,7 +7286,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7159: checking for location of PNG includes" >&5
+echo "configure:7290: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7181,15 +7312,15 @@
 do
-echo "configure:7185: checking for $ac_hdr" >&5
+echo "configure:7316: checking for $ac_hdr" >&5
-#line 7188 "configure"
+#line 7319 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7193: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7324: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7223,7 +7354,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7227: checking for location of PNG library" >&5
+echo "configure:7358: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7248,13 +7379,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7252: checking for png_read_image in -lpng" >&5
+echo "configure:7383: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7258 "configure"
+#line 7389 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7265,7 +7396,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:7269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7307,7 +7438,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7311: checking whether to use PostgreSQL" >&5
+echo "configure:7442: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -7334,7 +7465,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7338: checking for location of PostgreSQL includes" >&5
+echo "configure:7469: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7360,15 +7491,15 @@
 do
-echo "configure:7364: checking for $ac_hdr" >&5
+echo "configure:7495: checking for $ac_hdr" >&5
-#line 7367 "configure"
+#line 7498 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7372: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7503: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -7406,7 +7537,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7410: checking for location of PostgreSQL library" >&5
+echo "configure:7541: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7435,13 +7566,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7439: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7570: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7445 "configure"
+#line 7576 "configure"
@@ -7452,7 +7583,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7471,13 +7602,13 @@
-echo "configure:7475: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7606: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7481 "configure"
+#line 7612 "configure"
@@ -7488,7 +7619,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7623: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7507,13 +7638,13 @@
-echo "configure:7511: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7642: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 7517 "configure"
+#line 7648 "configure"
@@ -7524,7 +7655,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7543,13 +7674,13 @@
-echo "configure:7547: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7678: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7553 "configure"
+#line 7684 "configure"
@@ -7560,7 +7691,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7617,13 +7748,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7621: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7752: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7627 "configure"
+#line 7758 "configure"
@@ -7634,7 +7765,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7638: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7656,13 +7787,13 @@
-echo "configure:7660: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7791: checking for PQcmdTuples in -lpq" >&5
-#line 7666 "configure"
+#line 7797 "configure"
@@ -7673,7 +7804,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7677: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7716,7 +7847,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7720: checking whether to use MySQL" >&5
+echo "configure:7851: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -7736,7 +7867,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7740: checking for location of MySQL includes" >&5
+echo "configure:7871: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7762,15 +7893,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:7766: checking for $ac_hdr" >&5
+echo "configure:7897: checking for $ac_hdr" >&5
-#line 7769 "configure"
+#line 7900 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7774: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7905: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7807,7 +7938,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7811: checking for location of MySQL library" >&5
+echo "configure:7942: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7838,13 +7969,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7842: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7973: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 7848 "configure"
+#line 7979 "configure"
@@ -7855,7 +7986,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7874,13 +8005,13 @@
-echo "configure:7878: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8009: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7884 "configure"
+#line 8015 "configure"
@@ -7891,7 +8022,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7910,13 +8041,13 @@
-echo "configure:7914: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8045: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 7920 "configure"
+#line 8051 "configure"
@@ -7927,7 +8058,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8062: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7946,13 +8077,13 @@
-echo "configure:7950: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8081: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 7956 "configure"
+#line 8087 "configure"
@@ -7963,7 +8094,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7982,13 +8113,13 @@
-echo "configure:7986: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8117: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 7992 "configure"
+#line 8123 "configure"
@@ -7999,7 +8130,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8018,13 +8149,13 @@
-echo "configure:8022: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8153: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 8028 "configure"
+#line 8159 "configure"
@@ -8035,7 +8166,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8170: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8054,13 +8185,13 @@
-echo "configure:8058: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8189: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8064 "configure"
+#line 8195 "configure"
@@ -8071,7 +8202,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8090,13 +8221,13 @@
-echo "configure:8094: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8225: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8100 "configure"
+#line 8231 "configure"
@@ -8107,7 +8238,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8242: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8197,7 +8328,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:8201: checking for $ac_word" >&5
+echo "configure:8332: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -8246,10 +8377,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8250: checking for mysql_server_init" >&5
+echo "configure:8381: checking for mysql_server_init" >&5
-#line 8253 "configure"
+#line 8384 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -8275,7 +8406,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:8279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -8327,7 +8458,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8331: checking whether to use SQLite" >&5
+echo "configure:8462: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -8347,7 +8478,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8351: checking for location of SQLite includes" >&5
+echo "configure:8482: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8373,15 +8504,15 @@
 do
-echo "configure:8377: checking for $ac_hdr" >&5
+echo "configure:8508: checking for $ac_hdr" >&5
-#line 8380 "configure"
+#line 8511 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8385: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8516: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8424,7 +8555,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8428: checking for location of SQLite library" >&5
+echo "configure:8559: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8453,13 +8584,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8457: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8588: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 8463 "configure"
+#line 8594 "configure"
@@ -8470,7 +8601,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8474: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8489,13 +8620,13 @@
-echo "configure:8493: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8624: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8499 "configure"
+#line 8630 "configure"
@@ -8506,7 +8637,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8525,13 +8656,13 @@
-echo "configure:8529: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8660: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8535 "configure"
+#line 8666 "configure"
@@ -8542,7 +8673,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8677: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8561,13 +8692,13 @@
-echo "configure:8565: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8696: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8571 "configure"
+#line 8702 "configure"
@@ -8578,7 +8709,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8713: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8647,7 +8778,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8651: checking whether to use FFMPEG" >&5
+echo "configure:8782: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -8667,7 +8798,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8671: checking for location of FFMPEG includes" >&5
+echo "configure:8802: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8693,15 +8824,15 @@
 do
-echo "configure:8697: checking for $ac_hdr" >&5
+echo "configure:8828: checking for $ac_hdr" >&5
-#line 8700 "configure"
+#line 8831 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8705: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8836: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8737,15 +8868,15 @@
 do
-echo "configure:8741: checking for $ac_hdr" >&5
+echo "configure:8872: checking for $ac_hdr" >&5
-#line 8744 "configure"
+#line 8875 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8749: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8880: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8781,15 +8912,15 @@
 do
-echo "configure:8785: checking for $ac_hdr" >&5
+echo "configure:8916: checking for $ac_hdr" >&5
-#line 8788 "configure"
+#line 8919 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8793: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8924: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8832,7 +8963,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8836: checking for location of FFMPEG library" >&5
+echo "configure:8967: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -8859,13 +8990,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8863: checking for av_free in -lavutil" >&5
+echo "configure:8994: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 8869 "configure"
+#line 9000 "configure"
@@ -8876,7 +9007,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:8880: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8895,13 +9026,13 @@
-echo "configure:8899: checking for av_free in -lavutil" >&5
+echo "configure:9030: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 8905 "configure"
+#line 9036 "configure"
@@ -8912,7 +9043,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:8916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9047: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8957,13 +9088,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:8961: checking for avcodec_init in -lavcodec" >&5
+echo "configure:9092: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 8967 "configure"
+#line 9098 "configure"
@@ -8974,7 +9105,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:8978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9109: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8993,13 +9124,13 @@
-echo "configure:8997: checking for avcodec_init in -lavcodec" >&5
+echo "configure:9128: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 9003 "configure"
+#line 9134 "configure"
@@ -9010,7 +9141,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:9014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9055,13 +9186,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:9059: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9190: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 9065 "configure"
+#line 9196 "configure"
@@ -9072,7 +9203,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:9076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9091,13 +9222,13 @@
-echo "configure:9095: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9226: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9101 "configure"
+#line 9232 "configure"
@@ -9108,7 +9239,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:9112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9243: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9167,7 +9298,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9171: checking whether to use OpenGL" >&5
+echo "configure:9302: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -9201,7 +9332,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9205: checking for location of OpenGL includes" >&5
+echo "configure:9336: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9227,15 +9358,15 @@
 do
-echo "configure:9231: checking for $ac_hdr" >&5
+echo "configure:9362: checking for $ac_hdr" >&5
-#line 9234 "configure"
+#line 9365 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9239: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9370: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9269,7 +9400,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9273: checking for location of OpenGL library" >&5
+echo "configure:9404: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9298,13 +9429,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9302: checking for glBegin in -lGL" >&5
+echo "configure:9433: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9308 "configure"
+#line 9439 "configure"
@@ -9315,7 +9446,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9450: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9334,13 +9465,13 @@
-echo "configure:9338: checking for glBegin in -lGL" >&5
+echo "configure:9469: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9344 "configure"
+#line 9475 "configure"
@@ -9351,7 +9482,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9370,13 +9501,13 @@
-echo "configure:9374: checking for glBegin in -lGL" >&5
+echo "configure:9505: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9380 "configure"
+#line 9511 "configure"
@@ -9387,7 +9518,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9406,13 +9537,13 @@
-echo "configure:9410: checking for glBegin in -lGL" >&5
+echo "configure:9541: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9416 "configure"
+#line 9547 "configure"
@@ -9423,7 +9554,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9485,13 +9616,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9489: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9620: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9495 "configure"
+#line 9626 "configure"
@@ -9502,7 +9633,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9506: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9521,13 +9652,13 @@
-echo "configure:9525: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9656: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9531 "configure"
+#line 9662 "configure"
@@ -9538,7 +9669,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9585,10 +9716,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9589: checking for glXCreatePbuffer" >&5
+echo "configure:9720: checking for glXCreatePbuffer" >&5
-#line 9592 "configure"
+#line 9723 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -9611,7 +9742,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9615: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -9648,10 +9779,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9652: checking for glXCreateGLXPixmap" >&5
+echo "configure:9783: checking for glXCreateGLXPixmap" >&5
-#line 9655 "configure"
+#line 9786 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -9674,7 +9805,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -9717,7 +9848,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9721: checking for location of OpenGL framework" >&5
+echo "configure:9852: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9741,15 +9872,15 @@
 do
-echo "configure:9745: checking for $ac_hdr" >&5
+echo "configure:9876: checking for $ac_hdr" >&5
-#line 9748 "configure"
+#line 9879 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9753: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9884: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9785,10 +9916,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9789: checking for glBegin" >&5
+echo "configure:9920: checking for glBegin" >&5
-#line 9792 "configure"
+#line 9923 "configure"
     which can conflict with char glBegin(); below.  */
@@ -9811,7 +9942,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9815: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -9848,10 +9979,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9852: checking for gluBeginCurve" >&5
+echo "configure:9983: checking for gluBeginCurve" >&5
-#line 9855 "configure"
+#line 9986 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -9874,7 +10005,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -9922,7 +10053,7 @@
-echo "configure:9926: checking for location of OpenGL includes" >&5
+echo "configure:10057: checking for location of OpenGL includes" >&5
@@ -9948,15 +10079,15 @@
 do
-echo "configure:9952: checking for $ac_hdr" >&5
+echo "configure:10083: checking for $ac_hdr" >&5
-#line 9955 "configure"
+#line 10086 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9960: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10091: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9990,7 +10121,7 @@
-echo "configure:9994: checking for location of OpenGL library" >&5
+echo "configure:10125: checking for location of OpenGL library" >&5
@@ -10015,18 +10146,18 @@
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:10019: checking for OpenGL library" >&5
+echo "configure:10150: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 10023 "configure"
+#line 10154 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:10030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -10050,18 +10181,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:10054: checking for GLU library" >&5
+echo "configure:10185: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 10058 "configure"
+#line 10189 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:10065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10196: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -10110,7 +10241,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:10114: checking whether to use Tcl/Tk" >&5
+echo "configure:10245: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -10130,7 +10261,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:10134: checking for location of Tcl/Tk includes" >&5
+echo "configure:10265: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -10156,15 +10287,15 @@
 do
-echo "configure:10160: checking for $ac_hdr" >&5
+echo "configure:10291: checking for $ac_hdr" >&5
-#line 10163 "configure"
+#line 10294 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10168: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10299: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10201,15 +10332,15 @@
 do
-echo "configure:10205: checking for $ac_hdr" >&5
+echo "configure:10336: checking for $ac_hdr" >&5
-#line 10208 "configure"
+#line 10339 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10213: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10344: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10243,7 +10374,7 @@
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:10247: checking Tcl version" >&5
+echo "configure:10378: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -10251,7 +10382,7 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 10255 "configure"
+#line 10386 "configure"
 #include <stdio.h>
@@ -10263,7 +10394,7 @@
 EOF
-if { (eval echo configure:10267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10398: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -10281,7 +10412,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:10285: checking Tk version" >&5
+echo "configure:10416: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -10289,7 +10420,7 @@
 else
-#line 10293 "configure"
+#line 10424 "configure"
 #include <stdio.h>
@@ -10301,7 +10432,7 @@
 EOF
-if { (eval echo configure:10305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10436: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -10330,7 +10461,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:10334: checking for location of Tcl/Tk library" >&5
+echo "configure:10465: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -10370,13 +10501,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:10374: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10505: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 10380 "configure"
+#line 10511 "configure"
@@ -10387,7 +10518,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10406,13 +10537,13 @@
-echo "configure:10410: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10541: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 10416 "configure"
+#line 10547 "configure"
@@ -10423,7 +10554,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10450,13 +10581,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10454: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10585: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 10460 "configure"
+#line 10591 "configure"
@@ -10467,7 +10598,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10486,13 +10617,13 @@
-echo "configure:10490: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10621: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 10496 "configure"
+#line 10627 "configure"
@@ -10503,7 +10634,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10507: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10638: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10530,13 +10661,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:10534: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10665: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 10540 "configure"
+#line 10671 "configure"
@@ -10547,7 +10678,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10551: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10566,13 +10697,13 @@
-echo "configure:10570: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10701: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 10576 "configure"
+#line 10707 "configure"
@@ -10583,7 +10714,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10718: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10661,13 +10792,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:10665: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10796: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 10671 "configure"
+#line 10802 "configure"
@@ -10678,7 +10809,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10697,13 +10828,13 @@
-echo "configure:10701: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10832: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10707 "configure"
+#line 10838 "configure"
@@ -10714,7 +10845,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10718: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10741,13 +10872,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10745: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:10876: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 10751 "configure"
+#line 10882 "configure"
@@ -10758,7 +10889,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10762: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10777,13 +10908,13 @@
-echo "configure:10781: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:10912: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10787 "configure"
+#line 10918 "configure"
@@ -10794,7 +10925,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10798: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10821,13 +10952,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:10825: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:10956: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 10831 "configure"
+#line 10962 "configure"
@@ -10838,7 +10969,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10857,13 +10988,13 @@
-echo "configure:10861: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:10992: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10867 "configure"
+#line 10998 "configure"
@@ -10874,7 +11005,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:10878: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10964,13 +11095,13 @@
   do
     # add only if in MACOSX_ARCHS
     echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:10968: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:11099: checking for Tcl_Init in -l$tlib" >&5
 ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 10974 "configure"
+#line 11105 "configure"
@@ -10981,7 +11112,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:10985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11031,7 +11162,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11035: checking whether to use ODBC" >&5
+echo "configure:11166: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -11050,7 +11181,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11054: checking for location of ODBC includes" >&5
+echo "configure:11185: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11076,15 +11207,15 @@
 do
-echo "configure:11080: checking for $ac_hdr" >&5
+echo "configure:11211: checking for $ac_hdr" >&5
-#line 11083 "configure"
+#line 11214 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11088: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11219: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11118,7 +11249,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11122: checking for location of ODBC library" >&5
+echo "configure:11253: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11143,13 +11274,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11147: checking for SQLConnect in -lodbc" >&5
+echo "configure:11278: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 11153 "configure"
+#line 11284 "configure"
@@ -11160,7 +11291,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11185,13 +11316,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11189: checking for SQLConnect in -liodbc" >&5
+echo "configure:11320: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 11195 "configure"
+#line 11326 "configure"
@@ -11202,7 +11333,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:11206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11227,11 +11358,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:11231: checking for ODBC library" >&5
+echo "configure:11362: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 11235 "configure"
+#line 11366 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -11239,7 +11370,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:11243: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11288,7 +11419,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:11292: checking whether to use FFTW" >&5
+echo "configure:11423: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -11307,7 +11438,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:11311: checking for location of FFTW includes" >&5
+echo "configure:11442: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -11333,15 +11464,15 @@
 do
-echo "configure:11337: checking for $ac_hdr" >&5
+echo "configure:11468: checking for $ac_hdr" >&5
-#line 11340 "configure"
+#line 11471 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11345: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11476: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11369,15 +11500,15 @@
 do
-echo "configure:11373: checking for $ac_hdr" >&5
+echo "configure:11504: checking for $ac_hdr" >&5
-#line 11376 "configure"
+#line 11507 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11381: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11512: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11405,15 +11536,15 @@
 do
-echo "configure:11409: checking for $ac_hdr" >&5
+echo "configure:11540: checking for $ac_hdr" >&5
-#line 11412 "configure"
+#line 11543 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11417: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11548: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11459,7 +11590,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:11463: checking for location of FFTW library" >&5
+echo "configure:11594: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -11484,13 +11615,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:11488: checking for fftw_execute in -lfftw3" >&5
+echo "configure:11619: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 11494 "configure"
+#line 11625 "configure"
@@ -11501,7 +11632,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:11505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11526,13 +11657,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:11530: checking for fftwnd_one in -lfftw" >&5
+echo "configure:11661: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 11536 "configure"
+#line 11667 "configure"
 #include "confdefs.h"
@@ -11543,7 +11674,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:11547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11568,13 +11699,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:11572: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:11703: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 11578 "configure"
+#line 11709 "configure"
@@ -11585,7 +11716,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:11589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11720: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11642,7 +11773,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:11646: checking whether to use BLAS" >&5
+echo "configure:11777: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -11663,7 +11794,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:11667: checking for location of BLAS includes" >&5
+echo "configure:11798: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -11683,7 +11814,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:11687: checking for location of BLAS library" >&5
+echo "configure:11818: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -11709,15 +11840,15 @@
 do
-echo "configure:11713: checking for $ac_hdr" >&5
+echo "configure:11844: checking for $ac_hdr" >&5
-#line 11716 "configure"
+#line 11847 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11721: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11852: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11752,13 +11883,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:11756: checking for dnrm2_ in -lblas" >&5
+echo "configure:11887: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 11762 "configure"
+#line 11893 "configure"
@@ -11769,7 +11900,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:11773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11788,13 +11919,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:11792: checking for dnrm2_ in -lblas" >&5
+echo "configure:11923: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 11798 "configure"
+#line 11929 "configure"
@@ -11805,7 +11936,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:11809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11849,13 +11980,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:11853: checking for ATL_xerbla in -latlas" >&5
+echo "configure:11984: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 11859 "configure"
+#line 11990 "configure"
@@ -11866,7 +11997,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:11870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11881,13 +12012,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:11885: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12016: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 11891 "configure"
+#line 12022 "configure"
@@ -11898,7 +12029,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11902: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11913,13 +12044,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:11917: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12048: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 11923 "configure"
+#line 12054 "configure"
@@ -11930,7 +12061,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:11934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11976,16 +12107,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:11980: checking for sgemm in $vlib_flags" >&5
+echo "configure:12111: checking for sgemm in $vlib_flags" >&5
-#line 11982 "configure"
+#line 12113 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:11989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -12003,13 +12134,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12007: checking for sgemm_ in -lblas" >&5
+echo "configure:12138: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 12013 "configure"
+#line 12144 "configure"
@@ -12020,7 +12151,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12035,13 +12166,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12039: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12170: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 12045 "configure"
+#line 12176 "configure"
@@ -12052,7 +12183,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12067,13 +12198,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12071: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12202: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 12077 "configure"
+#line 12208 "configure"
@@ -12084,7 +12215,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12118,13 +12249,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12122: checking for acosp in -lsunmath" >&5
+echo "configure:12253: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 12128 "configure"
+#line 12259 "configure"
@@ -12135,7 +12266,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:12139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12270: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12150,13 +12281,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12154: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12285: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 12160 "configure"
+#line 12291 "configure"
@@ -12167,7 +12298,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12171: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12302: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12197,13 +12328,13 @@
 # Generic BLAS library
-echo "configure:12201: checking for sgemm_ in -lblas" >&5
+echo "configure:12332: checking for sgemm_ in -lblas" >&5
 ac_save_LIBS="$LIBS"
 LIBS="-lblas  $LIBS"
-#line 12207 "configure"
+#line 12338 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12214,7 +12345,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:12218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12349: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12253,7 +12384,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12257: checking whether to use LAPACK" >&5
+echo "configure:12388: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -12278,7 +12409,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:12282: checking for location of LAPACK includes" >&5
+echo "configure:12413: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -12298,7 +12429,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:12302: checking for location of LAPACK library" >&5
+echo "configure:12433: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -12324,15 +12455,15 @@
 do
-echo "configure:12328: checking for $ac_hdr" >&5
+echo "configure:12459: checking for $ac_hdr" >&5
-#line 12331 "configure"
+#line 12462 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12336: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12467: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -12364,10 +12495,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:12368: checking for dsegv_" >&5
+echo "configure:12499: checking for dsegv_" >&5
-#line 12371 "configure"
+#line 12502 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -12390,7 +12521,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12394: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -12417,13 +12548,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12421: checking for desgv_ in -llapack" >&5
+echo "configure:12552: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 12427 "configure"
+#line 12558 "configure"
@@ -12434,7 +12565,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:12438: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12466,13 +12597,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12470: checking for dgesv_ in -llapack" >&5
+echo "configure:12601: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 12476 "configure"
+#line 12607 "configure"
@@ -12483,7 +12614,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:12487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12502,13 +12633,13 @@
-echo "configure:12506: checking for dgesv_ in -llapack" >&5
+echo "configure:12637: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 12512 "configure"
+#line 12643 "configure"
@@ -12519,7 +12650,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:12523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12654: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12575,7 +12706,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:12579: checking whether to use Cairo" >&5
+echo "configure:12710: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -12607,7 +12738,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:12611: checking for location of cairo includes" >&5
+echo "configure:12742: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -12633,15 +12764,15 @@
 do
-echo "configure:12637: checking for $ac_hdr" >&5
+echo "configure:12768: checking for $ac_hdr" >&5
-#line 12640 "configure"
+#line 12771 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12645: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12776: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12677,7 +12808,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:12681: checking for location of cairo library" >&5
+echo "configure:12812: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -12697,7 +12828,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:12701: checking for cairo linking flags" >&5
+echo "configure:12832: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -12713,10 +12844,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:12717: checking for cairo_create" >&5
+echo "configure:12848: checking for cairo_create" >&5
-#line 12720 "configure"
+#line 12851 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -12739,7 +12870,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -12773,10 +12904,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:12777: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:12908: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 12780 "configure"
+#line 12911 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -12799,7 +12930,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -12832,10 +12963,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:12836: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:12967: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 12839 "configure"
+#line 12970 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -12858,7 +12989,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -12900,7 +13031,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:12904: checking whether to use FreeType" >&5
+echo "configure:13035: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -12919,7 +13050,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:12923: checking for location of FreeType includes" >&5
+echo "configure:13054: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -12945,15 +13076,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:12949: checking for $ac_hdr" >&5
+echo "configure:13080: checking for $ac_hdr" >&5
-#line 12952 "configure"
+#line 13083 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12957: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13088: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12987,7 +13118,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:12991: checking for location of FreeType library" >&5
+echo "configure:13122: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13012,13 +13143,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13016: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13147: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 13022 "configure"
+#line 13153 "configure"
@@ -13029,7 +13160,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:13033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13070,7 +13201,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13074: checking whether to use NLS" >&5
+echo "configure:13205: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -13090,10 +13221,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13094: checking for gettext" >&5
+echo "configure:13225: checking for gettext" >&5
-#line 13097 "configure"
+#line 13228 "configure"
     which can conflict with char gettext(); below.  */
@@ -13116,7 +13247,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -13134,13 +13265,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13138: checking for gettext in -lintl" >&5
+echo "configure:13269: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 13144 "configure"
+#line 13275 "configure"
@@ -13151,7 +13282,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:13155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13286: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13186,7 +13317,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:13190: checking whether to use C++" >&5
+echo "configure:13321: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -13202,7 +13333,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13206: checking for $ac_word" >&5
+echo "configure:13337: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -13231,7 +13362,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:13235: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:13366: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -13242,12 +13373,12 @@
 cat > conftest.$ac_ext << EOF
-#line 13246 "configure"
+#line 13377 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:13251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -13273,19 +13404,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:13277: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:13408: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:13282: checking whether we are using GNU C++" >&5
+echo "configure:13413: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13289: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13420: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -13303,7 +13434,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:13307: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:13438: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -13331,58 +13462,7 @@
   fi
 fi
-for ac_declaration in \
-   '#include <stdlib.h>' \
-   'extern "C" void std::exit (int) throw (); using std::exit;' \
-   'extern "C" void std::exit (int); using std::exit;' \
-   'extern "C" void exit (int) throw ();' \
-   'extern "C" void exit (int);' \
-   'void exit (int);'
-do
-  cat > conftest.$ac_ext <<EOF
-#line 13345 "configure"
-#include "confdefs.h"
-#include <stdlib.h>
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:13353: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
-  echo "configure: failed program was:" >&5
-  cat conftest.$ac_ext >&5
-  rm -rf conftest*
-  continue
-fi
-rm -f conftest*
-#line 13363 "configure"
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:13370: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
-  rm -rf conftest*
-  break
-else
-fi
-rm -f conftest*
-done
-if test -n "$ac_declaration"; then
-  echo '#ifdef __cplusplus' >>confdefs.h
-  echo $ac_declaration      >>confdefs.h
-  echo '#endif'             >>confdefs.h
-fi
-else
 	CXX=
 	CXXFLAGS=
@@ -13395,7 +13475,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:13399: checking whether to use openDWG" >&5
+echo "configure:13479: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -13415,7 +13495,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:13419: checking for location of openDGW includes" >&5
+echo "configure:13499: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -13441,15 +13521,15 @@
 do
-echo "configure:13445: checking for $ac_hdr" >&5
+echo "configure:13525: checking for $ac_hdr" >&5
-#line 13448 "configure"
+#line 13528 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13453: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13533: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13483,7 +13563,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:13487: checking for location of openDWG library" >&5
+echo "configure:13567: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -13524,7 +13604,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:13528: checking whether to use POSIX threads" >&5
+echo "configure:13608: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -13544,7 +13624,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:13548: checking for location of POSIX threads includes" >&5
+echo "configure:13628: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -13570,15 +13650,15 @@
 do
-echo "configure:13574: checking for $ac_hdr" >&5
+echo "configure:13654: checking for $ac_hdr" >&5
-#line 13577 "configure"
+#line 13657 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13582: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13662: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13612,7 +13692,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:13616: checking for location of POSIX threads library" >&5
+echo "configure:13696: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -13637,10 +13717,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:13641: checking for pthread_create" >&5
+echo "configure:13721: checking for pthread_create" >&5
-#line 13644 "configure"
+#line 13724 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char pthread_create(); below.  */
@@ -13663,7 +13743,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13667: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -13690,13 +13770,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:13694: checking for pthread_create in -lpthread" >&5
+echo "configure:13774: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 13700 "configure"
+#line 13780 "configure"
@@ -13707,7 +13787,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:13711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13791: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13757,7 +13837,7 @@
 echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:13761: checking whether to use OpenMP" >&5
+echo "configure:13841: checking whether to use OpenMP" >&5
 echo "$ac_t"""$with_openmp"" 1>&6
 case "$with_openmp" in
 	"no")	USE_OPENMP=	;;
@@ -13778,7 +13858,7 @@
 echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:13782: checking for location of OpenMP includes" >&5
+echo "configure:13862: checking for location of OpenMP includes" >&5
 case "$with_openmp_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -13804,15 +13884,15 @@
 do
-echo "configure:13808: checking for $ac_hdr" >&5
+echo "configure:13888: checking for $ac_hdr" >&5
-#line 13811 "configure"
+#line 13891 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13816: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13896: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13850,7 +13930,7 @@
 echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:13854: checking for location of OpenMP library" >&5
+echo "configure:13934: checking for location of OpenMP library" >&5
 case "$with_gomp_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-gomp-libs." 1>&2; exit 1; }
@@ -13875,10 +13955,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:13879: checking for GOMP_parallel_start" >&5
+echo "configure:13959: checking for GOMP_parallel_start" >&5
-#line 13882 "configure"
+#line 13962 "configure"
     which can conflict with char GOMP_parallel_start(); below.  */
@@ -13901,7 +13981,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13905: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GOMP_parallel_start=yes"
 else
@@ -13928,13 +14008,13 @@
 echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:13932: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:14012: checking for GOMP_parallel_start in -lgomp" >&5
 ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
 LIBS="-lgomp  $LIBS"
-#line 13938 "configure"
+#line 14018 "configure"
@@ -13945,7 +14025,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13949: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14024,7 +14104,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14028: checking for special C compiler options needed for large files" >&5
+echo "configure:14108: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14032,7 +14112,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14036 "configure"
+#line 14116 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14048,7 +14128,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14052: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14132: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -14057,7 +14137,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14061 "configure"
+#line 14141 "configure"
@@ -14073,7 +14153,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14077: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14157: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -14093,11 +14173,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14097: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14177: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 14101 "configure"
+#line 14181 "configure"
@@ -14113,14 +14193,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14117: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14197: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14124 "configure"
+#line 14204 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -14138,7 +14218,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14142: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14222: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -14157,11 +14237,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14161: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14241: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 14165 "configure"
+#line 14245 "configure"
@@ -14177,14 +14257,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14181: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14261: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14188 "configure"
+#line 14268 "configure"
 #define _LARGE_FILES 1
@@ -14202,7 +14282,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14206: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14286: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -14221,25 +14301,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14225: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14305: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 14229 "configure"
+#line 14309 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14236: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14316: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14243 "configure"
+#line 14323 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -14248,7 +14328,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14252: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14332: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -14269,25 +14349,25 @@
    fi
-echo "configure:14273: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14353: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 14277 "configure"
+#line 14357 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14284: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14364: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14291 "configure"
+#line 14371 "configure"
 #include <stdio.h>
@@ -14296,7 +14376,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14300: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14380: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -14319,18 +14399,18 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:14323: checking for fseeko" >&5
+echo "configure:14403: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 14327 "configure"
+#line 14407 "configure"
 #include <stdio.h>
 int main() {
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:14334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14414: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -14347,10 +14427,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14351: checking if system supports Large Files at all" >&5
+echo "configure:14431: checking if system supports Large Files at all" >&5
-#line 14354 "configure"
+#line 14434 "configure"
 #include <stdio.h>
@@ -14382,7 +14462,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:14386: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14466: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -14411,7 +14491,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14415: checking whether to use wxWidgets" >&5
+echo "configure:14495: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -14432,7 +14512,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:14436: checking for $ac_word" >&5
+echo "configure:14516: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -14480,7 +14560,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14484: checking wxWidgets version" >&5
+echo "configure:14564: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -14503,15 +14583,15 @@
 do
-echo "configure:14507: checking for $ac_hdr" >&5
+echo "configure:14587: checking for $ac_hdr" >&5
-#line 14510 "configure"
+#line 14590 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14515: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14595: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14772,6 +14852,10 @@
 s%@LIBLAS_CFLAGS@%$LIBLAS_CFLAGS%g
 s%@LIBLAS_INC@%$LIBLAS_INC%g
 s%@USE_LIBLAS@%$USE_LIBLAS%g
+s%@NETCDF_CONFIG@%$NETCDF_CONFIG%g
+s%@NETCDF_LIBS@%$NETCDF_LIBS%g
+s%@NETCDF_CFLAGS@%$NETCDF_CFLAGS%g
+s%@USE_NETCDF@%$USE_NETCDF%g
 s%@GEOS_CONFIG@%$GEOS_CONFIG%g
 s%@GEOS_LIBS@%$GEOS_LIBS%g
 s%@GEOS_CFLAGS@%$GEOS_CFLAGS%g
@@ -15157,6 +15241,8 @@
 echo "  GDAL support:               `if test -n "${USE_GDAL}" ; then echo yes ; else echo no ; fi`"
+echo "  NETCDF support:             `if test -n "${USE_NETCDF}" ; then echo yes ; else echo no ; fi`"
 echo "  GEOS support:               `if test -n "${USE_GEOS}" ; then echo yes ; else echo no ; fi`"
 echo "  LAPACK support:             `if test -n "${USE_LAPACK}" ; then echo yes ; else echo no ; fi`"
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2012-05-16 19:51:41 UTC (rev 51633)
+++ grass/trunk/configure.in	2012-05-16 21:31:40 UTC (rev 51634)
@@ -282,6 +282,12 @@
                           e.g. '--with-wxwidgets=/usr/local/bin/wx-config',
                           default: no)],, with_wxwidgets="no")
+AC_ARG_WITH(netcdf,
+[  --with-netcdf[=path/nc-config]
+                          enable NetCDF support (nc-config with path,
+                          e.g. '--with-nc=/usr/local/bin/nc-config',
+                          default: no)],, with_netcdf="no")
 # With includes and libs options
 AC_ARG_WITH(geos,
@@ -826,12 +832,60 @@
 AC_SUBST(LIBLAS_INC)
 AC_SUBST(USE_LIBLAS)
+# NetCDF option
+AC_MSG_CHECKING(whether to use NetCDF)
+NETCDF_LIBS=
+NETCDF_CFLAGS=
+USE_NETCDF=
+if test "`basename xx/$with_netcdf`" = "nc-config" ; then
+  NETCDF_CONFIG="$with_netcdf"
+fi
+if test "$with_netcdf" = "no" ; then
+  AC_MSG_RESULT(no)
+else
+  AC_MSG_RESULT(yes)
+  AC_PATH_PROG(NETCDF_CONFIG, nc-config, no)
+  if test "$NETCDF_CONFIG" = "no" ; then
+    AC_MSG_ERROR([*** couldn't find nc-config])
+  fi
+  if test "$NETCDF_CONFIG" != "" ; then
+    NETCDF_LIBS=`"$NETCDF_CONFIG" --libs`
+    NETCDF_CFLAGS=`"$NETCDF_CONFIG" --cflags`
+    USE_NETCDF=1
+  fi
+  NETCDF=
+  ac_save_libs="$LIBS"
+  ac_save_cflags="$CFLAGS"
+  LIBS="$LIBS $NETCDF_LIBS"
+  CFLAGS="$CFLAGS $NETCDF_CFLAGS"
+  AC_TRY_LINK([#include <netcdf.h>],[nc_create("foo", NC_CLOBBER, NULL);],,[
+  AC_TRY_LINK([#include <netcdf.h>],[nc_create("foo", NC_CLOBBER, NULL);],NETCDF_LIBS="$NETCDF_LIBS",[
+  AC_MSG_ERROR([*** Unable to locate NetCDF library.])
+  LIBS=${ac_save_libs}
+  CFLAGS=${ac_save_cflags}
+  AC_DEFINE(HAVE_NETCDF)
+fi
+AC_SUBST(NETCDF_LIBS)
+AC_SUBST(NETCDF_CFLAGS)
+AC_SUBST(USE_NETCDF)
 # GEOS option
 AC_MSG_CHECKING(whether to use GEOS)
 GEOS_LIBS=
-GGEOS_CFLAGS=
+GEOS_CFLAGS=
 USE_GEOS=
 # FIXME: "quote" $with_geos ?
@@ -1975,6 +2029,7 @@
 LOC_MSG_USE(FFTW support,USE_FFTW)
 LOC_MSG_USE(FreeType support,USE_FREETYPE)
 LOC_MSG_USE(GDAL support,USE_GDAL)
+LOC_MSG_USE(NETCDF support,USE_NETCDF)
 LOC_MSG_USE(GEOS support,USE_GEOS)
 LOC_MSG_USE(LAPACK support,USE_LAPACK)
 LOC_MSG_USE(Large File support (LFS), USE_LARGEFILES)
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in	2012-05-16 19:51:41 UTC (rev 51633)
+++ grass/trunk/include/Make/Platform.make.in	2012-05-16 21:31:40 UTC (rev 51634)
@@ -183,6 +183,11 @@
 USE_GDAL            = @USE_GDAL@
 USE_OGR             = @USE_OGR@
+#NetCDF
+NETCDFLIBS           = @NETCDF_LIBS@
+NETCDFCFLAGS        = @NETCDF_CFLAGS@
+USE_NETCDF          = @USE_NETCDF@
 #LAS LiDAR through libLAS
 LASLIBS             = @LIBLAS_LIBS@
 LASCFLAGS           = @LIBLAS_CFLAGS@
Modified: grass/trunk/raster3d/Makefile
--- grass/trunk/raster3d/Makefile	2012-05-16 19:51:41 UTC (rev 51633)
+++ grass/trunk/raster3d/Makefile	2012-05-16 21:31:40 UTC (rev 51634)
@@ -10,6 +10,7 @@
 	r3.mkdspf \
 	r3.null \
 	r3.out.ascii \
+	r3.out.netcdf \
 	r3.out.v5d \
 	r3.out.vtk \
 	r3.retile \
Modified: grass/trunk/raster3d/r3.out.netcdf/Makefile
--- grass/trunk/raster3d/r3.out.netcdf/Makefile	2012-05-16 19:51:41 UTC (rev 51633)
+++ grass/trunk/raster3d/r3.out.netcdf/Makefile	2012-05-16 21:31:40 UTC (rev 51634)
@@ -2,13 +2,14 @@
 PGM=r3.out.netcdf
-LIBES = $(RASTER3DLIB) $(GISLIB) $(GPROJLIB)
-DEPENDENCIES = $(RASTER3DDEP) $(GISDEP) $(GPROJDEP)
+LIBES = $(RASTER3DLIB) $(GPROJLIB) $(GISLIB) $(GDALLIBS) $(NETCDFLIBS) $(PROJLIB) $(DATETIMELIB)
+DEPENDENCIES = $(RASTER3DDEP) $(GISDEP) $(GPROJDEP) $(DATETIMEDEP)
 EXTRA_INC = $(PROJINC)
+EXTRA_CFLAGS = $(NETCDF_CFLAGS)
-EXTRA_LIBS = -lnetcdf
 include $(MODULE_TOPDIR)/include/Make/Module.make
+ifneq ($(strip $(NETCDFLIBS)),)
 default: cmd
+endif
Modified: grass/trunk/raster3d/r3.out.netcdf/main.c
--- grass/trunk/raster3d/r3.out.netcdf/main.c	2012-05-16 19:51:41 UTC (rev 51633)
+++ grass/trunk/raster3d/r3.out.netcdf/main.c	2012-05-16 21:31:40 UTC (rev 51634)
@@ -14,16 +14,18 @@
  *   	    	for details.
  * TODO: Add time zone support to time variable
- * TODO: Implement support for coordinate reference system defined here:
+ * TODO: Implement better support for CF coordinate reference system defined here:
  *       http://cf-pcmdi.llnl.gov/documents/cf-conventions/1.6/cf-conventions.html#coordinate-system
  *       https://cf-pcmdi.llnl.gov/trac/wiki/Cf2CrsWkt
  *       http://trac.osgeo.org/gdal/wiki/NetCDF_ProjectionTestingStatus
 #include <stdio.h>
 #include <stdlib.h>
 #include <string.h>
 #include <netcdf.h>
+#include <grass/datetime.h>
 #include <grass/gis.h>
 #include <grass/raster3d.h>
 #include <grass/glocale.h>
@@ -45,6 +47,7 @@
 #define Y_STANDARD_NAME "projection_y_coordinate"
 #define Z_NAME "z"
 #define Z_LONG_NAME "z coordinate of projection"
+#define Z_STANDARD_NAME "projection_z_coordinate"
 #define UNITS "units"
 #define DEGREES_EAST "degrees_east"
 #define DEGREES_NORTH "degrees_north"
@@ -54,7 +57,8 @@
 #define ERR(e) {fatalError(nc_strerror(e));}
 /* structs */
-typedef struct {
+typedef struct
     struct Option *input, *output;
     struct Flag *mask;
 } paramType;
@@ -70,9 +74,9 @@
 static void fatalError(const char *errorMsg)
     if (map != NULL) {
-        /* should unopen map here! */
-        if (!Rast3d_close(map))
-            fatalError(_("Unable to close 3D raster map"));
+	/* should unopen map here! */
+	if (!Rast3d_close(map))
+	    G_fatal_error(_("Unable to close 3D raster map while catching error: %s"), errorMsg);
     G_fatal_error("%s", errorMsg);
@@ -83,22 +87,25 @@
 static void setParams()
-    param.input = G_define_standard_option(G_OPT_R3_INPUTS);
+    param.input = G_define_standard_option(G_OPT_R3_INPUT);
     param.output = G_define_standard_option(G_OPT_F_OUTPUT);
     param.output->key = "output";
     param.output->description = _("Name for netcdf output file");
     param.mask = G_define_flag();
     param.mask->key = 'm';
-    param.mask->description = _("Use 3D raster mask (if exists) with input map");
+    param.mask->description =
+	_("Use 3D raster mask (if exists) with input map");
-static void write_netcdf_header(int ncid, RASTER3D_Region *region, int *varid)
+static void write_netcdf_header(int ncid, RASTER3D_Region * region,
+				int *varid)
     int retval, typeIntern, time;
     size_t i;
     int is_time = 0;
+    int is_absolute_time = 0;
     float c;
     int lat_dimid = 0, lon_dimid = 0, time_dimid = 0;
     int lat_varid = 0, lon_varid = 0, time_varid = 0;
@@ -106,179 +113,353 @@
     struct Cell_head window;
     /* global attributes */
-    if ((retval = nc_put_att_text(ncid, NC_GLOBAL, "Conventions", strlen(CF_SUPPORT), CF_SUPPORT))) ERR(retval);
-    if ((retval = nc_put_att_text(ncid, NC_GLOBAL, "history", strlen(HISTORY_TEXT), HISTORY_TEXT))) ERR(retval);
+    if ((retval =
+	 nc_put_att_text(ncid, NC_GLOBAL, "Conventions", strlen(CF_SUPPORT),
+			 CF_SUPPORT)))
+	ERR(retval);
+    if ((retval =
+	 nc_put_att_text(ncid, NC_GLOBAL, "history", strlen(HISTORY_TEXT),
+			 HISTORY_TEXT)))
+	ERR(retval);
     G_get_window(&window);
     /* Projection parameter */
-    if(window.proj != PROJECTION_XY) {
-        struct Key_Value *pkv, *ukv;
-        struct pj_info pjinfo;
-        char *proj4, *proj4mod;
-        const char *unfact;
+    if (window.proj != PROJECTION_XY) {
+	struct Key_Value *pkv, *ukv;
+	struct pj_info pjinfo;
+	char *proj4, *proj4mod;
+	const char *unfact;
 	int crs_dimid = 0, crs_varid;
-        if ((retval = nc_def_var(ncid, "crs", NC_CHAR, 0, &crs_dimid, &crs_varid))) ERR(retval);
+	if ((retval =
+	     nc_def_var(ncid, "crs", NC_CHAR, 0, &crs_dimid, &crs_varid)))
+	    ERR(retval);
-     	pkv = G_get_projinfo();
-        ukv = G_get_projunits();
-        pj_get_kv(&pjinfo, pkv, ukv);
-        proj4 = pj_get_def(pjinfo.pj, 0);
-        pj_free(pjinfo.pj);
+	pkv = G_get_projinfo();
+	ukv = G_get_projunits();
+	pj_get_kv(&pjinfo, pkv, ukv);
+	proj4 = pj_get_def(pjinfo.pj, 0);
+	pj_free(pjinfo.pj);
 #ifdef HAVE_OGR
 	/* We support the CF suggestion crs_wkt and the gdal spatil_ref attribute */
-        if ((retval = nc_put_att_text(ncid, crs_varid, "crs_wkt", strlen(GPJ_grass_to_wkt(pkv, ukv, 0, 0)), GPJ_grass_to_wkt(pkv, ukv, 0, 0)))) ERR(retval);
-        if ((retval = nc_put_att_text(ncid, crs_varid, "spatial_ref", strlen(GPJ_grass_to_wkt(pkv, ukv, 0, 0)), GPJ_grass_to_wkt(pkv, ukv, 0, 0)))) ERR(retval);
+	if ((retval =
+	     nc_put_att_text(ncid, crs_varid, "crs_wkt",
+			     strlen(GPJ_grass_to_wkt(pkv, ukv, 0, 0)),
+			     GPJ_grass_to_wkt(pkv, ukv, 0, 0))))
+	    ERR(retval);
+	if ((retval =
+	     nc_put_att_text(ncid, crs_varid, "spatial_ref",
+	    ERR(retval);
 #endif
-        /* Code from g.proj:
-         * GRASS-style PROJ.4 strings don't include a unit factor as this is
-         * handled separately in GRASS - must include it here though */
-        unfact = G_find_key_value("meters", ukv);
-        if (unfact != NULL && (strcmp(pjinfo.proj, "ll") != 0))
-            G_asprintf(&proj4mod, "%s +to_meter=%s", proj4, unfact);
-        else
-            proj4mod = G_store(proj4);
-        pj_dalloc(proj4);
+	/* Code from g.proj:
+	 * GRASS-style PROJ.4 strings don't include a unit factor as this is
+	 * handled separately in GRASS - must include it here though */
+	unfact = G_find_key_value("meters", ukv);
+	if (unfact != NULL && (strcmp(pjinfo.proj, "ll") != 0))
+	    G_asprintf(&proj4mod, "%s +to_meter=%s", proj4, unfact);
+	else
+	    proj4mod = G_store(proj4);
+	pj_dalloc(proj4);
-        if ((retval = nc_put_att_text(ncid, crs_varid, "crs_proj4", strlen(proj4mod), proj4mod))) ERR(retval);
+	if ((retval =
+	     nc_put_att_text(ncid, crs_varid, "crs_proj4", strlen(proj4mod),
+			     proj4mod)))
+	    ERR(retval);
-        if(pkv)
-            G_free_key_value(pkv);
-        if(ukv)
-            G_free_key_value(ukv);
+	if (pkv)
+	    G_free_key_value(pkv);
+	if (ukv)
+	    G_free_key_value(ukv);
     typeIntern = Rast3d_tile_type_map(map);
     if (window.proj == PROJECTION_LL) {
-        if ((retval = nc_def_dim(ncid, LON_NAME, region->cols, &lon_dimid))) ERR(retval);
-        if ((retval = nc_def_dim(ncid, LAT_NAME, region->rows, &lat_dimid))) ERR(retval);
+        /* X-Axis */
+	if ((retval = nc_def_dim(ncid, LON_NAME, region->cols, &lon_dimid)))
+	    ERR(retval);
+	if ((retval =
+	     nc_def_var(ncid, LON_NAME, NC_FLOAT, 1, &lon_dimid, &lon_varid)))
+	    ERR(retval);
+	if ((retval =
+	     nc_put_att_text(ncid, lon_varid, UNITS, strlen(DEGREES_EAST),
+			     DEGREES_EAST)))
+	    ERR(retval);
+	if ((retval =
+	     nc_put_att_text(ncid, lon_varid, LONG_NAME,
+			     strlen(LON_LONG_NAME), LON_LONG_NAME)))
+	    ERR(retval);
+	if ((retval =
+	     nc_put_att_text(ncid, lon_varid, STANDARD_NAME, strlen(LON_NAME),
+			     LON_NAME)))
+	    ERR(retval);
-        if ((retval = nc_def_var(ncid, LON_NAME, NC_FLOAT, 1, &lon_dimid, &lon_varid))) ERR(retval);
-        if ((retval = nc_def_var(ncid, LAT_NAME, NC_FLOAT, 1, &lat_dimid, &lat_varid))) ERR(retval);
+        /* Y-Axis */
+	if ((retval = nc_def_dim(ncid, LAT_NAME, region->rows, &lat_dimid)))
+	    ERR(retval);
+	if ((retval =
+	     nc_def_var(ncid, LAT_NAME, NC_FLOAT, 1, &lat_dimid, &lat_varid)))
+	    ERR(retval);
+	if ((retval =
+	     nc_put_att_text(ncid, lat_varid, UNITS, strlen(DEGREES_NORTH),
+			     DEGREES_NORTH)))
+	    ERR(retval);
+	if ((retval =
+	     nc_put_att_text(ncid, lat_varid, LONG_NAME,
+			     strlen(LAT_LONG_NAME), LAT_LONG_NAME)))
+	    ERR(retval);
+	if ((retval =
+	     nc_put_att_text(ncid, lat_varid, STANDARD_NAME, strlen(LAT_NAME),
+			     LAT_NAME)))
+	    ERR(retval);
+    else {
+        /* X-Axis */
+	if ((retval = nc_def_dim(ncid, X_NAME, region->cols, &lon_dimid)))
+	    ERR(retval);
-        if ((retval = nc_put_att_text(ncid, lon_varid, UNITS, strlen(DEGREES_EAST), DEGREES_EAST))) ERR(retval);
-        if ((retval = nc_put_att_text(ncid, lon_varid, LONG_NAME, strlen(LON_LONG_NAME), LON_LONG_NAME))) ERR(retval);
-        if ((retval = nc_put_att_text(ncid, lon_varid, STANDARD_NAME, strlen(LON_NAME), LON_NAME))) ERR(retval);
-        if ((retval = nc_put_att_text(ncid, lat_varid, UNITS, strlen(DEGREES_NORTH), DEGREES_NORTH))) ERR(retval);
-        if ((retval = nc_put_att_text(ncid, lat_varid, LONG_NAME, strlen(LAT_LONG_NAME), LAT_LONG_NAME))) ERR(retval);
-        if ((retval = nc_put_att_text(ncid, lat_varid, STANDARD_NAME, strlen(LAT_NAME), LAT_NAME))) ERR(retval);
-    } else {
-        if ((retval = nc_def_dim(ncid, X_NAME, region->cols, &lon_dimid))) ERR(retval);
-        if ((retval = nc_def_dim(ncid, Y_NAME, region->rows, &lat_dimid))) ERR(retval);
+	if ((retval =
+	     nc_def_var(ncid, X_NAME, NC_FLOAT, 1, &lon_dimid, &lon_varid)))
+	    ERR(retval);
+	if ((retval =
+	     nc_put_att_text(ncid, lon_varid, UNITS, strlen("meter"),
+			     "meter")))
+	    ERR(retval);
+	if ((retval =
+	     nc_put_att_text(ncid, lon_varid, LONG_NAME, strlen(X_LONG_NAME),
+			     X_LONG_NAME)))
+	    ERR(retval);
+	if ((retval =
+			     strlen(X_STANDARD_NAME), X_STANDARD_NAME)))
+	    ERR(retval);
+        /* Y-Axis */
+	if ((retval = nc_def_dim(ncid, Y_NAME, region->rows, &lat_dimid)))
+	    ERR(retval);
-        if ((retval = nc_def_var(ncid, X_NAME, NC_FLOAT, 1, &lon_dimid, &lon_varid))) ERR(retval);
-        if ((retval = nc_def_var(ncid, Y_NAME, NC_FLOAT, 1, &lat_dimid, &lat_varid))) ERR(retval);
+	if ((retval =
+	     nc_def_var(ncid, Y_NAME, NC_FLOAT, 1, &lat_dimid, &lat_varid)))
+	    ERR(retval);
+	if ((retval =
+	     nc_put_att_text(ncid, lat_varid, UNITS, strlen("meter"),
+			     "meter")))
+	    ERR(retval);
+	if ((retval =
+	     nc_put_att_text(ncid, lat_varid, LONG_NAME, strlen(Y_LONG_NAME),
+			     Y_LONG_NAME)))
+	    ERR(retval);
+	if ((retval =
+			     strlen(Y_STANDARD_NAME), Y_STANDARD_NAME)))
+	    ERR(retval);
-        if ((retval = nc_put_att_text(ncid, lon_varid, UNITS, strlen("meter"), "meter"))) ERR(retval);
-        if ((retval = nc_put_att_text(ncid, lon_varid, LONG_NAME, strlen(X_LONG_NAME), X_LONG_NAME))) ERR(retval);
-        if ((retval = nc_put_att_text(ncid, lon_varid, STANDARD_NAME, strlen(X_STANDARD_NAME), X_STANDARD_NAME))) ERR(retval);
-        if ((retval = nc_put_att_text(ncid, lat_varid, UNITS, strlen("meter"), "meter"))) ERR(retval);
-        if ((retval = nc_put_att_text(ncid, lat_varid, LONG_NAME, strlen(Y_LONG_NAME), Y_LONG_NAME))) ERR(retval);
-        if ((retval = nc_put_att_text(ncid, lat_varid, STANDARD_NAME, strlen(Y_STANDARD_NAME), Y_STANDARD_NAME))) ERR(retval);
+    /* We set the vertical axis and its unit. Units can be spatial
+     * or temporal. Temporal can be absolute or relative.
+    is_time = 0;
+    is_absolute_time = 0;
+    if (Rast3d_get_vertical_unit(map) &&
+	G_strncasecmp(Rast3d_get_vertical_unit(map), "units", 5) != 0) {
+	/* Time handling */
+	if (G_is_units_type_temporal(Rast3d_get_vertical_unit2(map))) {
+	    is_time = 1;
+	    char long_name[1024];
+	    char time_unit[1024];
+	    G_snprintf(long_name, 1024, "Time in %s",
+		       Rast3d_get_vertical_unit(map));
+	    if ((retval =
+		 nc_def_dim(ncid, TIME_NAME, region->depths, &time_dimid)))
+		ERR(retval);
+	    if ((retval =
+		 nc_def_var(ncid, TIME_NAME, NC_INT, 1, &time_dimid,
+			    &time_varid)))
+		ERR(retval);
+	    /* Temporal unit */
+	    if (G_has_raster3d_timestamp(map->fileName, map->mapset)) {
+		struct TimeStamp ts;
+		G_read_raster3d_timestamp(map->fileName, map->mapset, &ts);
+                /* Days since datum in ISO norm*/
+		if (datetime_is_absolute(&ts.dt[0])) {
+		    is_absolute_time = 1;
+		    G_snprintf(time_unit, 1024,
+			       "%s since %d-%02d-%02d %02d:%02d:%02.0f",
+			       Rast3d_get_vertical_unit(map), ts.dt[0].year,
+			       ts.dt[0].month, ts.dt[0].day, ts.dt[0].hour,
+			       ts.dt[0].minute, ts.dt[0].second);
+		else {
+		    G_snprintf(time_unit, 1024, "%s",
+	    else {
+		G_snprintf(time_unit, 1024, "%s since %s",
+			   "1900-01-01 00:00:00");
+	    if ((retval =
+		 nc_put_att_text(ncid, time_varid, UNITS, strlen(time_unit),
+				 time_unit)))
+		ERR(retval);
+	    if ((retval =
+		 nc_put_att_text(ncid, time_varid, LONG_NAME,
+				 strlen(long_name), long_name)))
+		ERR(retval)
+		    if (is_absolute_time) {
+		    if ((retval =
+			 nc_put_att_text(ncid, time_varid, "calendar",
+					 strlen("gregorian"), "gregorian")))
+			ERR(retval);
+		else {
+		    if ((retval =
+					 strlen("none"), "none")))
+			ERR(retval);
+	else {
+	    if ((retval =
+		 nc_def_dim(ncid, Z_NAME, region->depths, &time_dimid)))
+		ERR(retval);;
+	    if ((retval =
+		 nc_def_var(ncid, Z_NAME, NC_FLOAT, 1, &time_dimid,
+			    &time_varid)))
+		ERR(retval);
+	    if ((retval =
+				 strlen(Rast3d_get_vertical_unit(map)),
+				 Rast3d_get_vertical_unit(map))))
+		ERR(retval);
+	    if ((retval =
+				 strlen(Z_LONG_NAME), Z_LONG_NAME)))
+		ERR(retval);
+	    if ((retval =
+		 nc_put_att_text(ncid, time_varid, STANDARD_NAME,
+				 strlen(Z_STANDARD_NAME), Z_STANDARD_NAME)))
+		ERR(retval);
-    is_time = 0;
+    else {
+	/* Default is z unit meter */
+	if ((retval = nc_def_dim(ncid, Z_NAME, region->depths, &time_dimid)))
+	    ERR(retval);
+	if ((retval =
+	     nc_def_var(ncid, Z_NAME, NC_FLOAT, 1, &time_dimid, &time_varid)))
+	    ERR(retval);
+	if ((retval =
+	     nc_put_att_text(ncid, time_varid, UNITS, strlen("meter"),
+			     "meter")))
+	    ERR(retval);
+	if ((retval =
+	     nc_put_att_text(ncid, time_varid, LONG_NAME, strlen(Z_LONG_NAME),
+			     Z_LONG_NAME)))
+	    ERR(retval);
+	if ((retval =
+	    ERR(retval);
-    if(Rast3d_get_vertical_unit(map) && G_strncasecmp(Rast3d_get_vertical_unit(map), "units", 5) != 0) {
-        /* Time handling */
-        if(G_is_units_type_temporal(Rast3d_get_vertical_unit2(map))) {
-            is_time = 1;
-            char long_name[1024];
-            char time_unit[1024];
-            G_snprintf(long_name, 1024, "Time in %s", Rast3d_get_vertical_unit(map));
-            if ((retval = nc_def_dim(ncid, TIME_NAME, region->depths, &time_dimid))) ERR(retval);
-            if ((retval = nc_def_var(ncid, TIME_NAME, NC_INT, 1, &time_dimid, &time_varid))) ERR(retval);
-            /* Temporal unit */
-            if(G_has_raster3d_timestamp(map->fileName, map->mapset)) {
-                struct TimeStamp ts;
-                G_read_raster3d_timestamp(map->fileName, map->mapset, &ts);
-                G_snprintf(time_unit, 1024, "%s since %d-%02d-%02d %02d:%02d:%02.0f",
-                           Rast3d_get_vertical_unit(map), ts.dt[0].year, ts.dt[0].month, ts.dt[0].day,
-                           ts.dt[0].hour,ts.dt[0].minute,ts.dt[0].second);
-            } else {
-                G_snprintf(time_unit, 1024, "%s since %s", Rast3d_get_vertical_unit(map), "1900-01-01 00:00:00");
-            if ((retval = nc_put_att_text(ncid, time_varid, UNITS, strlen(time_unit), time_unit))) ERR(retval);
-            if ((retval = nc_put_att_text(ncid, time_varid, LONG_NAME, strlen(long_name), long_name))) ERR(retval)
-            if ((retval = nc_put_att_text(ncid, time_varid, "calendar", strlen("gregorian"), "gregorian"))) ERR(retval);
-        } else {
-            if ((retval = nc_def_dim(ncid, Z_NAME, region->depths, &time_dimid))) ERR(retval);;
-            if ((retval = nc_def_var(ncid, Z_NAME, NC_FLOAT, 1, &time_dimid, &time_varid))) ERR(retval);
-            if ((retval = nc_put_att_text(ncid, time_varid, UNITS, strlen(Rast3d_get_vertical_unit(map)), Rast3d_get_vertical_unit(map)))) ERR(retval);
-            if ((retval = nc_put_att_text(ncid, time_varid, LONG_NAME, strlen(Z_LONG_NAME), Z_LONG_NAME))) ERR(retval);
-    }else {
-        if ((retval = nc_put_att_text(ncid, time_varid, UNITS, strlen("meter"), "meter"))) ERR(retval);
     /* z - axis orientation */
-    if ((retval = nc_put_att_text(ncid, time_varid, "positive", strlen("up"), "up"))) ERR(retval);
+    if ((retval =
+	 nc_put_att_text(ncid, time_varid, "positive", strlen("up"), "up")))
+	ERR(retval);
     /* Axis identifier attributes */
-    if ((retval = nc_put_att_text(ncid, lon_varid, "axis", 1, "X"))) ERR(retval);
-    if ((retval = nc_put_att_text(ncid, lat_varid, "axis", 1, "Y"))) ERR(retval);
-    if(is_time) {
-        if ((retval = nc_put_att_text(ncid, time_varid, "axis", 1, "T"))) ERR(retval);
-    } else {
-        if ((retval = nc_put_att_text(ncid, time_varid, "axis", 1, "Z"))) ERR(retval);
+    if ((retval = nc_put_att_text(ncid, lon_varid, "axis", 1, "X")))
+	ERR(retval);
+    if ((retval = nc_put_att_text(ncid, lat_varid, "axis", 1, "Y")))
+	ERR(retval);
+    if (is_time) {
+	if ((retval = nc_put_att_text(ncid, time_varid, "axis", 1, "T")))
+	    ERR(retval);
+    else {
+	if ((retval = nc_put_att_text(ncid, time_varid, "axis", 1, "Z")))
+	    ERR(retval);
     dimids[0] = time_dimid;
     dimids[1] = lat_dimid;
     dimids[2] = lon_dimid;
-    if(typeIntern == FCELL_TYPE) {
-        if ((retval = nc_def_var(ncid, param.input->answer, NC_FLOAT, NDIMS, dimids, varid))) ERR(retval);
-    } else {
-        if ((retval = nc_def_var(ncid, param.input->answer, NC_DOUBLE, NDIMS, dimids, varid))) ERR(retval);
+    if (typeIntern == FCELL_TYPE) {
+	if ((retval =
+	     nc_def_var(ncid, param.input->answer, NC_FLOAT, NDIMS, dimids,
+			varid)))
+	    ERR(retval);
-        if ((retval = nc_put_att_text(ncid, *varid, "grid_mapping", strlen("crs"), "crs"))) ERR(retval);
+    else {
+	if ((retval =
+	     nc_def_var(ncid, param.input->answer, NC_DOUBLE, NDIMS, dimids,
+			varid)))
+	    ERR(retval);
-   /* End define mode. */
-   if ((retval = nc_enddef(ncid))) ERR(retval);
+	if ((retval =
+	     nc_put_att_text(ncid, *varid, "grid_mapping", strlen("crs"),
+			     "crs")))
+	    ERR(retval);
+    /* End define mode. */
+    if ((retval = nc_enddef(ncid)))
+	ERR(retval);
      * Build coordinates, we need to use the cell center in case of spatial dimensions
-    for(i = 0; i < region->cols; i++) {
-        c = region->west + i*region->ew_res + 0.5*region->ew_res;
-        nc_put_var1_float(ncid, lon_varid, &i, &c);
+    for (i = 0; i < region->cols; i++) {
+	c = region->west + i * region->ew_res + 0.5 * region->ew_res;
+	nc_put_var1_float(ncid, lon_varid, &i, &c);
-    for(i = 0; i < region->rows; i++) {
-        c = region->south + i*region->ns_res + 0.5*region->ns_res;
-        nc_put_var1_float(ncid, lat_varid, &i, &c);
+    for (i = 0; i < region->rows; i++) {
+	//c = region->south + i * region->ns_res + 0.5 * region->ns_res;
+	c = region->north - i * region->ns_res - 0.5 * region->ns_res;
+	nc_put_var1_float(ncid, lat_varid, &i, &c);
-    for(i = 0; i < region->depths; i++) {
-        if(is_time) {
-            c = region->bottom + i*region->tb_res;
-            time = (int)c;
-            nc_put_var1_int(ncid, time_varid, &i, &time);
-	} else {
-            c = region->bottom + i*region->tb_res + 0.5*region->tb_res;
-            nc_put_var1_float(ncid, time_varid, &i, &c);
+    for (i = 0; i < region->depths; i++) {
+	if (is_time) {
+	    c = region->bottom + i * region->tb_res;
+	    time = (int)c;
+	    nc_put_var1_int(ncid, time_varid, &i, &time);
+	else {
+	    c = region->bottom + i * region->tb_res + 0.5 * region->tb_res;
+	    nc_put_var1_float(ncid, time_varid, &i, &c);
-static void write_netcdf_data(int ncid, RASTER3D_Region *region, int varid)
+static void write_netcdf_data(int ncid, RASTER3D_Region * region, int varid)
     DCELL dvalue;
     FCELL fvalue;
@@ -293,29 +474,30 @@
     for (z = 0; z < depths; z++) {
-        G_percent(z, depths, 1);
-        for (y = rows - 1; y >= 0; y--) { /* rows count from south to north */
-            for (x = 0; x < cols; x++) {
-                coords[0] = z;
-                coords[1] = y;
-                coords[2] = x;
-                 if (typeIntern == FCELL_TYPE) {
-                    Rast3d_get_value(map, x, y, z, &fvalue, FCELL_TYPE);
-                    if (!Rast3d_is_null_value_num(&fvalue, FCELL_TYPE)) {
-                        nc_put_var1_float(ncid, varid, coords, &fvalue);
-                } else {
-                    Rast3d_get_value(map, x, y, z, &dvalue, DCELL_TYPE);
-                    if (!Rast3d_is_null_value_num(&dvalue, DCELL_TYPE)) {
-                        nc_put_var1_double(ncid, varid, coords, &dvalue);
+	G_percent(z, depths, 1);
+	for (y = 0; y < rows; y++) {
+	    for (x = 0; x < cols; x++) {
+		coords[0] = z;
+		coords[1] = y;
+		coords[2] = x;
+		    Rast3d_get_value(map, x, y, z, &fvalue, FCELL_TYPE);
+		    if (!Rast3d_is_null_value_num(&fvalue, FCELL_TYPE)) {
+			nc_put_var1_float(ncid, varid, coords, &fvalue);
+		else {
+		    Rast3d_get_value(map, x, y, z, &dvalue, DCELL_TYPE);
+		    if (!Rast3d_is_null_value_num(&dvalue, DCELL_TYPE)) {
+			nc_put_var1_double(ncid, varid, coords, &dvalue);
     G_percent(1, 1, 1);
     G_percent_reset();
@@ -326,11 +508,11 @@
 int main(int argc, char *argv[])
     RASTER3D_Region region;
     int ncid;
     int retval;
     int varid;
     int changemask = 0;
     struct GModule *module;
@@ -340,18 +522,18 @@
     G_add_keyword(_("raster3d"));
     G_add_keyword(_("netcdf"));
     G_add_keyword(_("export"));
-    module->description =
-        _("Export a 3D raster map as netcdf file.");
+    module->description = _("Export a 3D raster map as netcdf file.");
     /* Get parameters from user */
     setParams();
     /* Have GRASS get inputs */
     if (G_parser(argc, argv))
-        exit(EXIT_FAILURE);
+	exit(EXIT_FAILURE);
     if (NULL == G_find_raster3d(param.input->answer, ""))
-        Rast3d_fatal_error(_("3D raster map <%s> not found"), param.input->answer);
+	Rast3d_fatal_error(_("3D raster map <%s> not found"),
+			   param.input->answer);
     /* Initiate the default settings */
     Rast3d_init_defaults();
@@ -360,43 +542,49 @@
     Rast3d_get_window(&region);
     /* Open the map and use XY cache mode */
-    map = Rast3d_open_cell_old(param.input->answer, G_find_raster3d(param.input->answer, ""), &region,
-                          RASTER3D_TILE_SAME_AS_FILE, RASTER3D_USE_CACHE_DEFAULT);
+    map =
+	Rast3d_open_cell_old(param.input->answer,
+			     G_find_raster3d(param.input->answer, ""),
+			     &region, RASTER3D_TILE_SAME_AS_FILE,
+			     RASTER3D_USE_CACHE_DEFAULT);
     if (map == NULL)
-        G_fatal_error(_("Error opening 3d raster map <%s>"), param.input->answer);
+	G_fatal_error(_("Error opening 3d raster map <%s>"),
     /* Create netcdf file */
-    if ((retval = nc_create(param.output->answer, NC_CLOBBER, &ncid))) ERR(retval);
+    if ((retval = nc_create(param.output->answer, NC_CLOBBER, &ncid)))
+	ERR(retval);
     write_netcdf_header(ncid, &region, &varid);
     /*if requested set the Mask on */
     if (param.mask->answer) {
-        if (Rast3d_mask_file_exists()) {
-            changemask = 0;
-            if (Rast3d_mask_is_off(map)) {
-                Rast3d_mask_on(map);
-                changemask = 1;
+	if (Rast3d_mask_file_exists()) {
+	    changemask = 0;
+	    if (Rast3d_mask_is_off(map)) {
+		Rast3d_mask_on(map);
+		changemask = 1;
     write_netcdf_data(ncid, &region, varid);
     /*We set the Mask off, if it was off bevor */
-            if (Rast3d_mask_is_on(map) && changemask)
-                Rast3d_mask_off(map);
+	    if (Rast3d_mask_is_on(map) && changemask)
+		Rast3d_mask_off(map);
     /* Close files and exit */
+	fatalError(_("Unable to close 3D raster map"));
     /* Close the netcdf file */
-    if ((retval = nc_close(ncid))) ERR(retval);
+    if ((retval = nc_close(ncid)))
+	ERR(retval);
     return 0;
Modified: grass/trunk/raster3d/r3.out.netcdf/test_suite/test.r3.out.netcdf.sh
--- grass/trunk/raster3d/r3.out.netcdf/test_suite/test.r3.out.netcdf.sh	2012-05-16 19:51:41 UTC (rev 51633)
+++ grass/trunk/raster3d/r3.out.netcdf/test_suite/test.r3.out.netcdf.sh	2012-05-16 21:31:40 UTC (rev 51634)
@@ -6,19 +6,28 @@
 # @preprocess step of this test. We generate
 # voxel data with r3.mapcalc. The region setting
 # should work for UTM and LL test locations
-g.region s=-40 n=40 w=-20 e=100 b=-25 t=25 res=10 res3=10 -p3
+g.region s=-90 n=90 w=-180 e=180 b=0 t=50 res=10 res3=10 -p3
 # We create several (float, double, null value) voxel map
 # with value = col + row + depth.
 r3.mapcalc --o expr="volume_float = float(col() + row() + depth())"
 r3.mapcalc --o expr="volume_double = double(col() + row() + depth())"
 r3.mapcalc --o expr="volume_time_double = double(col() + row() + depth())"
+r3.mapcalc --o expr="volume_time_float = float(col() + row() + depth())"
 r3.timestamp map=volume_time_double date='1 Jan 2001/5 Jan 2001'
 r3.support map=volume_time_double vunit="days"
+r3.timestamp map=volume_time_float date='5 seconds/10 seconds'
+r3.support map=volume_time_float vunit="seconds"
 # @test
 r3.out.netcdf --o input=volume_float output=test_float.nc
+#r3.info volume_float
+#ncdump -h test_float.nc
 r3.out.netcdf --o input=volume_double output=test_double.nc
+#r3.info volume_double
+#ncdump -h test_double.nc
 r3.out.netcdf --o input=volume_time_double output=test_time_double.nc
+#r3.info volume_time_double
+#ncdump -h test_time_double.nc
+r3.out.netcdf --o input=volume_time_float output=test_time_float.nc
+#r3.info volume_time_float
+#ncdump -h test_time_float.nc
-ncdump -h test_float.nc
-ncdump -h test_double.nc
-ncdump -h test_time_double.nc
\ No newline at end of file
