[GRASS-SVN] r51635 - grass/trunk/raster3d/r3.out.netcdf
svn_grass at osgeo.org
Wed May 16 17:36:09 EDT 2012
Author: huhabla
Date: 2012-05-16 14:36:09 -0700 (Wed, 16 May 2012)
New Revision: 51635
grass/trunk/raster3d/r3.out.netcdf/r3.out.netcdf.html
Added more documentation
Modified: grass/trunk/raster3d/r3.out.netcdf/r3.out.netcdf.html
--- grass/trunk/raster3d/r3.out.netcdf/r3.out.netcdf.html 2012-05-16 21:31:40 UTC (rev 51634)
+++ grass/trunk/raster3d/r3.out.netcdf/r3.out.netcdf.html 2012-05-16 21:36:09 UTC (rev 51635)
@@ -1,15 +1,235 @@
<h2>DESCRIPTION</h2>
-EXport a 3D raster map as netcdf file.
+The module <em>r3.out.netcdf</em> exports a 3D raster map as NetCDF file.
+Maps are valid 3D raster maps in the current mapset search path. The
+<em>output</em> parameter is the name of a NetCDF file that will be
+written in the current working directory. The module is sensitive
+to mapset region settings (set with <em>g.region</em>) and the vertical unit settings
+of the 3D raster map. The vertical unit can be set with <a href="r3.support.html">r3.support</a>.
+<h2>Note</h2>
+The resulting NetCDF file will have time as third dimension in case a temporal
+vertical unit is specified for the input map, otherwise the third dimension is assumed as spatial.
+If the 3D raster map has a time stamp with absolute time, the start time will be
+used as starting point for the NetCDF time series. If the absolute time stamp is missing
+the date "Jan. 01. 1900 00:00:00" will be used as default. In case of relative time stamp no start time
+is set in the NetCDF file. The number of depths of the 3D raster map are the number of time slices
+in the NetCDF file. You can use <em>t.rast.to.rast3</em> to convert a
+space time raster dataset into a 3D raster map representing a space time voxel
+cube, then export the raster time series as NetCDF file.
+<p>
+Spatial coordinates are exported as cell centered coordinates. The projection is stored
+in the metadata as <em>crs</em> attributes using a WKT parameter string.
+The export of projection parameters is suppressed when the XY-projection is set.
+The NetCDF projection metadata storage follows the spatial_ref GDAL/NetCDF suggestion
+<a href="http://www.gdal.org/frmt_netcdf.html">here</a>
+and the NetCDF CF 1.6 convention
+<a href="http://cf-pcmdi.llnl.gov/documents/cf-conventions/1.6/cf-conventions.html#coordinate-system">here</a>
+using WKT projection information. Additional a PROJ.4 string is
+stored in the <em>crs</em> attribute section.
+<p>
+The NetCDF library must be installed on the system and activated at configuration time to compile this module.
+<h2>Examples</h2>
+<h3>Using lat/lon projection without vertical unit specification</h3>
+<p>Lets create a 3D raster map without the specification of a vertical unit</p>
+<div class="code"><pre>
+g.region s=-90 n=90 w=-180 e=180 b=0 t=50 res=10 res3=2 -p3
+r3.mapcalc expr="volume_double = double(col() + row() + depth())"
+r3.info
+ | Layer: volume_double Date: Wed May 16 20:08:22 2012 |
+ | Mapset: PERMANENT Login of Creator: soeren |
+ | Location: TestLL |
+ | DataBase: /1/soeren/grassdata |
+ | Title: volume_double |
+ | Units: none |
+ | Vertical unit: units |
+ | Timestamp: none |
+ | Type of Map: 3d cell Number of Categories: 0 |
+ | Data Type: DCELL |
+ | Rows: 90 |
+ | Columns: 180 |
+ | Depths: 25 |
+ | Total Cells: 405000 |
+ | Total size: 2835864 Bytes |
+ | Number of tiles: 108 |
+ | Mean tile size: 26258 Bytes |
+ | Tile size in memory: 32400 Bytes |
+ | Number of tiles in x, y and z: 6, 6, 3 |
+ | Dimension of a tile in x, y, z: 30, 15, 9 |
+ | Projection: Latitude-Longitude (zone 0) |
+ | N: 90N S: 90S Res: 2 |
+ | E: 180E W: 180W Res: 2 |
+ | T: 50 B: 0 Res: 2 |
+ | Range of data: min = 3 max = 295 |
+ | Data Source: |
+ | Data Description: |
+ | generated by r3.mapcalc |
+ | Comments: |
+ | r3.mapcalc expression="volume_double = double(col() + row() + depth(\ |
+</pre></div>
+<p>Export the map and show the NetCDF header</P>
+r3.out.netcdf input=volume_double output=test_double.nc
+ncdump -h test_double.nc
+netcdf test_double {
+dimensions:
+ longitude = 180 ;
+ latitude = 90 ;
+ z = 25 ;
+variables:
+ char crs ;
+ crs:crs_wkt = "GEOGCS[\"wgs84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS_1984\",6378137,298.257223563]],PRIMEM[\"Greenwich\",0],UNIT[\"degree\",0.0174532925199433]]" ;
+ crs:spatial_ref = "GEOGCS[\"wgs84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS_1984\",6378137,298.257223563]],PRIMEM[\"Greenwich\",0],UNIT[\"degree\",0.0174532925199433]]" ;
+ crs:crs_proj4 = " +proj=longlat +no_defs +a=6378137 +rf=298.257223563 +towgs84=0.000,0.000,0.000" ;
+ float longitude(longitude) ;
+ longitude:units = "degrees_east" ;
+ longitude:long_name = "Longitude values" ;
+ longitude:standard_name = "longitude" ;
+ longitude:axis = "X" ;
+ float latitude(latitude) ;
+ latitude:units = "degrees_north" ;
+ latitude:long_name = "Latitude values" ;
+ latitude:standard_name = "latitude" ;
+ latitude:axis = "Y" ;
+ float z(z) ;
+ z:units = "meter" ;
+ z:long_name = "z coordinate of projection" ;
+ z:standard_name = "projection_z_coordinate" ;
+ z:positive = "up" ;
+ z:axis = "Z" ;
+ double volume_double(z, latitude, longitude) ;
+ volume_double:grid_mapping = "crs" ;
+// global attributes:
+ :Conventions = "CF-1.5" ;
+ :history = "GRASS GIS 7 NetCDF export of r3.out.netcdf" ;
+</pre></div>
+<p>Now we create a 3D raster map with a temporal vertical unit</p>
+r3.timestamp map=volume_time_double date='1 Jan 2001'
+r3.support map=volume_time_double vunit="days"
+r3.info
+ | Layer: volume_time_double Date: Wed May 16 20:26:28 2012 |
+ | Title: volume_time_double |
+ | Units: none |
+ | Vertical unit: days |
+ | Timestamp: 1 Jan 2001 |
+ | Rows: 90 |
+ | Columns: 180 |
+ | Depths: 25 |
+ | Data Source: |
+ | Comments: |
+ | r3.mapcalc expression="volume_time_double = double(col() + row() + d\ |
+ | epth())" |
+</pre></div>
+<p>NetCDF header of an exported 3D raster map with vertical temporal unit in a Lat/Lon projection:</P>
+r3.out.netcdf --o input=volume_time_double output=test_time_double.nc
+ncdump -h test_time_double.nc
+netcdf test_time_double {
+dimensions:
+ longitude = 180 ;
+ latitude = 90 ;
+ time = 25 ;
+variables:
+ char crs ;
+ int time(time) ;
+ time:units = "days since 2001-01-01 00:00:00" ;
+ time:long_name = "Time in days" ;
+ time:calendar = "gregorian" ;
+ time:positive = "up" ;
+ time:axis = "T" ;
+ double volume_time_double(time, latitude, longitude) ;
+ volume_time_double:grid_mapping = "crs" ;
+</pre></div>
<h2>SEE ALSO</h2>
<em>
+<a href="t.rast.to.rast3.html">t.rast.to.rast3</a>,
<a href="r3.out.ascii.html">r3.in.ascii</a>,
<a href="g.region.html">g.region</a>
</em>
<h2>AUTHORS</h2>
-Sören Gebbert
-<p><i>Last changed: $Date: 2011-11-08 22:24:20 +0100 (Di, 08 Nov 2011) $</i>
+Sören Gebbert
\ No newline at end of file
