[GRASS-SVN] r51650 - grass-addons/grass6/vector/v.trimesh
svn_grass at osgeo.org
Fri May 18 06:21:12 EDT 2012
Author: neteler
Date: 2012-05-18 03:21:12 -0700 (Fri, 18 May 2012)
New Revision: 51650
grass-addons/grass6/vector/v.trimesh/v.trimesh.c
Bugfixes from Paolo Zatelli and Carlo Cormio
Modified: grass-addons/grass6/vector/v.trimesh/v.trimesh.c
--- grass-addons/grass6/vector/v.trimesh/v.trimesh.c 2012-05-18 08:44:01 UTC (rev 51649)
+++ grass-addons/grass6/vector/v.trimesh/v.trimesh.c 2012-05-18 10:21:12 UTC (rev 51650)
@@ -40,7 +40,7 @@
dbColumn *col;
dbTable *table;
char buf[2000];
- int type, ctype, i, cat, j, firstnode, segments,h;
+ int type, ctype, i, cat, j, firstnode, segments, h;
int numberofregions, c, nnodes, nlines;
int count, more, of;
/* val is used for area constraints... currently set to int values*/
@@ -213,9 +213,10 @@
for(i=0;i<segments;i++){
for(of=0;of<2;of++){
in.segmentlist[i*2+of]=segmentlist[i*2+of];
- /* printf("segmentlist[%i]=%i in.segmentlist[%i]=%i\n",i*2+of,segmentlist[i*2+of],i*2+of,in.segmentlist[i*2+of]);
+/* printf("segmentlist[%i]=%i in.segmentlist[%i]=%i\n",i*2+of,segmentlist[i*2+of],i*2+of,in.segmentlist[i*2+of]);
- printf("segment %i= %i--%i\n",i,in.segmentlist[i*2],in.segmentlist[i*2+1]);*/
+ printf("segment %i= %i--%i\n",i,in.segmentlist[i*2],in.segmentlist[i*2+1]);
in.numberofregions = c;
@@ -226,11 +227,11 @@
in.regionlist[i*4+1]=regionlist[i*2+1];
in.regionlist[i*4+2]=0;
in.regionlist[i*4+3]=val[i];
- /*printf("val[%i]=%i",i,val[i]);*/
+ /*printf("val[%i]=%i\n",i,val[i]);*/
/* For some reason Triangle doesn't like these lines */
/* In case holes are present; so no holes!) */
- /* Tabernacle!
+/* Tabernacle!
if(h>0){
in.numberofholes=h;
printf("shouldn't be in...\n");
@@ -242,9 +243,12 @@
/* variables need to be initialized for Triangle */
in.numberofholes=0;
+ in.segmentmarkerlist = (int *) NULL;
+ in.holelist = (REAL *) NULL;
out.pointlist = (REAL *) NULL;
out.trianglelist = (int *) NULL;
@@ -258,6 +262,11 @@
/* Use FLAGS for either constrained Delaunay, area constraints*/
printf("number of regions = %i\n",c);
printf("calling triangle \n");
+ /* 10/7/2009 Paolo Zatelli: avoids segmentation fault at lines 14133-14136 of triangle.c */
+ /* due to non-null pointer; in.pointmarkerlist is never used in v.trivertex */
+ in.pointmarkerlist = (int *) NULL;
if(nomaxarea->answer)
triangulate("pzqDBeQj", &in, &out, (struct triangulateio *) NULL);
else
@@ -271,7 +280,8 @@
if(driver==NULL)
G_fatal_error(_("Cannot open database %s by driver %s"),Vect_subst_var(Fi->database,&Map),Fi->driver);
- printf("driver= %s\n",driver);
+ printf("driver= %s\n",Fi->driver);
db_begin_transaction(driver);
sprintf(buf,"create table %snodes (cat int)",output->answer);
@@ -284,12 +294,10 @@
sprintf(buf,"%snodes",output->answer);
- table=buf;
+ Vect_map_add_dblink(&Map, 1, NULL, buf,"cat",Fi->database,Fi->driver);
- Vect_map_add_dblink(&Map, 1, NULL, table,"cat",Fi->database,Fi->driver);
+ /* Writing the output to GRASS */
- /* Writing the output to GRASS*/
/* Writing NODES */
@@ -333,10 +341,8 @@
G_fatal_error(_("Cannot create table %s"),db_get_string(&stmt));
sprintf(buf,"%stricentr",output->answer);
- table=buf;
+ Vect_map_add_dblink(&Map, 2, NULL, buf,"cat",Fi->database,Fi->driver);
- Vect_map_add_dblink(&Map, 2, NULL, table,"cat",Fi->database,Fi->driver);
for(i=0;i<out.numberoftriangles;i++){
Vect_reset_line (Points);
Vect_reset_cats (Cats);
@@ -388,12 +394,10 @@
db_close_database(driver);
db_shutdown_driver(driver);
- /* Vect_build_partial(&Map,GV_BUILD_NONE,NULL); */
- /* Vect_build(&Map,stderr); */
Vect_build_partial(&Map,GV_BUILD_NONE);
Vect_build(&Map);
Vect_close(&Map);
+ return(EXIT_SUCCESS);
