[GRASS-SVN] r51651 - grass-addons/grass6/vector/v.trimesh
Fri May 18 06:22:49 EDT 2012
Author: neteler
Date: 2012-05-18 03:22:48 -0700 (Fri, 18 May 2012)
New Revision: 51651
   grass-addons/grass6/vector/v.trimesh/v.trimesh.c
proper source code indentation
Modified: grass-addons/grass6/vector/v.trimesh/v.trimesh.c
--- grass-addons/grass6/vector/v.trimesh/v.trimesh.c	2012-05-18 10:21:12 UTC (rev 51650)
+++ grass-addons/grass6/vector/v.trimesh/v.trimesh.c	2012-05-18 10:22:48 UTC (rev 51651)
@@ -1,13 +1,15 @@
-/*  MODULE: v.trimesh							     */
+/*  MODULE: v.trimesh                                                        */
 /*  AUTHOR: Jaime Carrera-Hernandez, University of Alberta, Edmonton Canada  */
-/*		jaime.carrera-AT-ualberta.ca                                 */
+/*              jaime.carrera-AT-ualberta.ca                                 */
 /*              jaime.carrerah-AT-gmail.com                                  */
 /*  PURPOSE: v.trimesh creates a triangular mesh                              */
 /*         using Triangle (by Jonathan Richard Shewchunk)                    */
-/* COPYRIGHT: (C) 2008 by the GRASS development team			     */
+/* COPYRIGHT: (C) 2008 by the GRASS development team                         */
@@ -43,158 +45,170 @@
     int type, ctype, i, cat, j, firstnode, segments, h;
     int numberofregions, c, nnodes, nlines;
     int count, more, of;
-    /* val is used for area constraints... currently set to int values*/
+    /* val is used for area constraints... currently set to int values */
     double *xptr, *yptr, *zptr, x, y, areaconst;
     struct triangulateio in, out;
     /* I need dynamic allocation */
     double pointlist[10000];
     /* regionlist is used for centroids         */
     /* val is for area constraints centroids    */
     double regionlist[40];
     int val[40];
-    int segmentlist[10000];
-    /*    int holelist[30];*/
+    int segmentlist[10000];
+    /*    int holelist[30]; */
     struct line_pnts *Points;
     struct line_cats *Cats;
     struct Option *column;
-    /*To determine centroids*/
-    int left,center,right;
-    double xleft,yleft,xcenter,ycenter,xright,yright;
-    double xm1,xm2,ym,m1,m2,b1,b2;
-    int area,areas,centroid;
+    /*To determine centroids */
+    int left, center, right;
+    double xleft, yleft, xcenter, ycenter, xright, yright;
+    double xm1, xm2, ym, m1, m2, b1, b2;
+    int area, areas, centroid;
     G_gisinit(argv[0]);
     module = G_define_module();
     module->keywords = _("vector");
-    module->description =
-	_("Create a triangular mesh from a vector map");
+    module->description = _("Create a triangular mesh from a vector map");
     input = G_define_standard_option(G_OPT_V_INPUT);
     column = G_define_option();
     column->key = "column";
-    column->type= TYPE_STRING;
-    column->required= YES;
-    column->multiple=NO;
-    column->description=_("Column name with area constraints/centroid attributes");
+    column->type = TYPE_STRING;
+    column->required = YES;
+    column->multiple = NO;
+    column->description =
+	_("Column name with area constraints/centroid attributes");
     output = G_define_standard_option(G_OPT_V_OUTPUT);
     nomaxarea = G_define_flag();
-    nomaxarea->key='a';
-    nomaxarea->description=_("Do not use areal constraint");
-    /* The vector map is opened*/
-    if(G_parser(argc,argv))
-      exit(EXIT_FAILURE);
+    nomaxarea->key = 'a';
+    nomaxarea->description = _("Do not use areal constraint");
+    /* The vector map is opened */
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
     Vect_set_open_level(2);
     Vect_open_old(&Map, input->answer, "");
-    /* The vector map is now read (boundaries and centroids)*/
+    /* The vector map is now read (boundaries and centroids) */
     Points = Vect_new_line_struct();
     Cats = Vect_new_cats_struct();
-    areas=Vect_get_num_areas(&Map);
-    printf("areas=%i\n",areas);
+    areas = Vect_get_num_areas(&Map);
+    printf("areas=%i\n", areas);
-    /* Verifying if data were input properly*/
-    if(!column->answer)
-      G_fatal_error ("Please assign a column with areal constraints");
+    /* Verifying if data were input properly */
+    if (!column->answer)
+	G_fatal_error("Please assign a column with areal constraints");
-    h=0;
-    c=0;
-    j=0;
-    segments=0;
+    h = 0;
+    c = 0;
+    j = 0;
+    segments = 0;
-    for(area=1;area<=areas;area++){
-      centroid=Vect_get_area_centroid(&Map,area);
-      firstnode=j;
+    for (area = 1; area <= areas; area++) {
+	centroid = Vect_get_area_centroid(&Map, area);
+	firstnode = j;
-      Vect_get_area_points(&Map,area,Points);
-      printf("Reading boundaries for area %i\n",area);
-      xptr=Points->x;
-      yptr=Points->y;
+	Vect_get_area_points(&Map, area, Points);
+	printf("Reading boundaries for area %i\n", area);
+	xptr = Points->x;
+	yptr = Points->y;
-      while(Points->n_points--){
-	pointlist[j*2]=*xptr++;
-	pointlist[j*2+1]=*yptr++;
-	j++;
-      j--;
-      printf("before reading nodes from boundary\n");
-      for(i=firstnode;i<j;i++){
-	if(i<j-1){
-	  segmentlist[i*2]=i;
-	  segmentlist[i*2+1]=i+1;
-	else{
-	  segmentlist[i*2+1]=firstnode;
+	while (Points->n_points--) {
+	    pointlist[j * 2] = *xptr++;
+	    pointlist[j * 2 + 1] = *yptr++;
+	    j++;
-	segments++;
+	j--;
+	printf("before reading nodes from boundary\n");
+	for (i = firstnode; i < j; i++) {
+	    if (i < j - 1) {
+		segmentlist[i * 2] = i;
+		segmentlist[i * 2 + 1] = i + 1;
+	    else {
+		segmentlist[i * 2 + 1] = firstnode;
+	    segments++;
     /*                Get area constraints                          */
-    c=0;
-    while((type=Vect_read_next_line(&Map,Points,Cats))>0)
-	if(type == GV_CENTROID && Cats->cat[0] > 0){
-	  xptr=Points->x;
-	  yptr=Points->y;
-	  regionlist[c*2]=*xptr;
-	  regionlist[c*2+1]=*yptr;
-	  for(i=0;i < Cats->n_cats; i++){
-	    Fi= Vect_get_field(&Map,Cats->field[i]);
-	    driver = db_start_driver_open_database ( Fi->driver, Fi->database );
-	    printf("select %s from %s where %s=%-10d\n",column->answer,Fi->table,Fi->key,Cats->cat[i]);
-	    sprintf(buf,"select %s from %s where %s=%-10d\n",column->answer,Fi->table,Fi->key,Cats->cat[i]);
-	    db_init_string(&stmt);
-	    db_append_string(&stmt,buf);
-	    if(db_open_select_cursor(driver, &stmt, &cursor, DB_SEQUENTIAL) != DB_OK)
-	      G_fatal_error ( "Cannot open select cursor: '%s'", db_get_string(&stmt));
-	    table=db_get_cursor_table(&cursor);
-	    col=db_get_table_column(table,0); /* first column	*/
-	    ctype= db_sqltype_to_Ctype(db_get_column_sqltype (col));
-	    if ( ctype != DB_C_TYPE_INT )
-	      G_fatal_error ( "area constraint must be integer");
+    c = 0;
+    while ((type = Vect_read_next_line(&Map, Points, Cats)) > 0) {
+	if (type == GV_CENTROID && Cats->cat[0] > 0) {
+	    xptr = Points->x;
+	    yptr = Points->y;
+	    regionlist[c * 2] = *xptr;
+	    regionlist[c * 2 + 1] = *yptr;
+	    for (i = 0; i < Cats->n_cats; i++) {
+		Fi = Vect_get_field(&Map, Cats->field[i]);
+		driver =
+		    db_start_driver_open_database(Fi->driver, Fi->database);
+		printf("select %s from %s where %s=%-10d\n", column->answer,
+		       Fi->table, Fi->key, Cats->cat[i]);
-	    dbvalue=db_get_column_value(col);
-	    /* fetch the data*/
-	    count=0;
-	    while(1){
-	      if(db_fetch(&cursor, DB_NEXT, &more) != DB_OK)
-		return (-1);
-	      if (!more) break;
-	      /* somehow it didn't work with double val[c], so only int values are used*/
-	      if( count == 0 )
-		val[c] =  db_get_value_int ( dbvalue );
-	      count ++;
-	    db_close_cursor(&cursor);
-	    db_free_string(&stmt);
-	    printf("c=%i, val[%i]=%i\n",c,c,val[c]);
-	    c++;
+		sprintf(buf, "select %s from %s where %s=%-10d\n",
+			column->answer, Fi->table, Fi->key, Cats->cat[i]);
+		db_init_string(&stmt);
+		db_append_string(&stmt, buf);
+		if (db_open_select_cursor
+		    (driver, &stmt, &cursor, DB_SEQUENTIAL) != DB_OK)
+		    G_fatal_error("Cannot open select cursor: '%s'",
+				  db_get_string(&stmt));
+		table = db_get_cursor_table(&cursor);
+		col = db_get_table_column(table, 0);	/* first column   */
+		ctype = db_sqltype_to_Ctype(db_get_column_sqltype(col));
+		if (ctype != DB_C_TYPE_INT)
+		    G_fatal_error("area constraint must be integer");
+		dbvalue = db_get_column_value(col);
+		/* fetch the data */
+		count = 0;
+		while (1) {
+		    if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK)
+			return (-1);
+		    if (!more)
+			break;
+		    /* somehow it didn't work with double val[c], so only int values are used */
+		    if (count == 0)
+			val[c] = db_get_value_int(dbvalue);
+		    count++;
+		db_close_cursor(&cursor);
+		db_free_string(&stmt);
+		printf("c=%i, val[%i]=%i\n", c, c, val[c]);
+		c++;
     Vect_close(&Map);
-    /*printf("ocas 4\n");*/
+    /*printf("ocas 4\n"); */
     /* Creating Triangle's data input : */
     in.numberofpoints = j;
@@ -202,202 +216,213 @@
     in.pointlist = (REAL *) malloc(in.numberofpoints * 2 * sizeof(REAL));
     /* This is a really dirty way to do it */
-    for(i=0;i<j;i++){
-      for(of=0;of<2;of++){
-	in.pointlist[i*2+of]=pointlist[i*2+of];
+    for (i = 0; i < j; i++) {
+	for (of = 0; of < 2; of++) {
+	    in.pointlist[i * 2 + of] = pointlist[i * 2 + of];
-    in.numberofsegments=segments;
-    in.segmentlist = (int *) malloc(in.numberofsegments * 2 * sizeof(int));
-    for(i=0;i<segments;i++){
-	in.segmentlist[i*2+of]=segmentlist[i*2+of];
-/*	printf("segmentlist[%i]=%i in.segmentlist[%i]=%i\n",i*2+of,segmentlist[i*2+of],i*2+of,in.segmentlist[i*2+of]);
-      printf("segment %i= %i--%i\n",i,in.segmentlist[i*2],in.segmentlist[i*2+1]);
+    in.numberofsegments = segments;
+    in.segmentlist = (int *)malloc(in.numberofsegments * 2 * sizeof(int));
+    for (i = 0; i < segments; i++) {
+	    in.segmentlist[i * 2 + of] = segmentlist[i * 2 + of];
+	    /*      printf("segmentlist[%i]=%i in.segmentlist[%i]=%i\n",i*2+of,segmentlist[i*2+of],i*2+of,in.segmentlist[i*2+of]);
+	       printf("segment %i= %i--%i\n",i,in.segmentlist[i*2],in.segmentlist[i*2+1]);
     in.numberofregions = c;
     in.regionlist = (REAL *) malloc(in.numberofregions * 4 * sizeof(REAL));
-    for(i=0;i<in.numberofregions;i++){
-      in.regionlist[i*4]=regionlist[i*2];
-      in.regionlist[i*4+1]=regionlist[i*2+1];
-      in.regionlist[i*4+2]=0;
-      in.regionlist[i*4+3]=val[i];
-      /*printf("val[%i]=%i\n",i,val[i]);*/
+    for (i = 0; i < in.numberofregions; i++) {
+	in.regionlist[i * 4] = regionlist[i * 2];
+	in.regionlist[i * 4 + 1] = regionlist[i * 2 + 1];
+	in.regionlist[i * 4 + 2] = 0;
+	in.regionlist[i * 4 + 3] = val[i];
+	/*printf("val[%i]=%i\n",i,val[i]); */
     /* For some reason Triangle doesn't like these lines */
     /* In case holes are present; so no holes!) */
-/* Tabernacle!
-    if(h>0){
-      in.numberofholes=h;
-      printf("shouldn't be in...\n");
-      in.holelist=(REAL *) malloc(in.numberofholes * 2 * sizeof(REAL));
-      out.holelist= (int *) NULL;
-      for(i=0;i<in.numberofholes;i++){
-	  in.holelist[i*2+of]=holelist[i*2+of];
+    /* Tabernacle!
+       if(h>0){
+       in.numberofholes=h;
+       printf("shouldn't be in...\n");
+       in.holelist=(REAL *) malloc(in.numberofholes * 2 * sizeof(REAL));
+       out.holelist= (int *) NULL;
+       for(i=0;i<in.numberofholes;i++){
+       for(of=0;of<2;of++){
+       in.holelist[i*2+of]=holelist[i*2+of];
     /* variables need to be initialized for Triangle */
-    in.numberofholes=0;
-    in.segmentmarkerlist = (int *) NULL;
+    in.numberofholes = 0;
+    in.segmentmarkerlist = (int *)NULL;
     in.holelist = (REAL *) NULL;
     out.pointlist = (REAL *) NULL;
-    out.trianglelist = (int *) NULL;
-    out.segmentlist = (int *) NULL;
-    out.edgelist= (int *) NULL;
+    out.trianglelist = (int *)NULL;
+    out.segmentlist = (int *)NULL;
+    out.edgelist = (int *)NULL;
     /* Triangulate the points: read and write a PSLG (p), number everything */
-    /* from zero (z), create a quality mesh (q) and use area constraints (a)*/
-    /* voronoi polygons not needed, thus vorout== NULL*/
+    /* from zero (z), create a quality mesh (q) and use area constraints (a) */
+    /* voronoi polygons not needed, thus vorout== NULL */
-    /* Use FLAGS for either constrained Delaunay, area constraints*/
-    printf("number of regions = %i\n",c);
+    /* Use FLAGS for either constrained Delaunay, area constraints */
+    printf("number of regions = %i\n", c);
     printf("calling triangle \n");
     /* 10/7/2009 Paolo Zatelli: avoids segmentation fault at lines 14133-14136 of triangle.c */
     /* due to non-null pointer; in.pointmarkerlist is never used in v.trivertex */
-    in.pointmarkerlist = (int *) NULL;
+    in.pointmarkerlist = (int *)NULL;
-    if(nomaxarea->answer)
-      triangulate("pzqDBeQj", &in, &out, (struct triangulateio *) NULL);
+    if (nomaxarea->answer)
+	triangulate("pzqDBeQj", &in, &out, (struct triangulateio *)NULL);
     else
-      triangulate("pzqDaBeQj", &in, &out, (struct triangulateio *) NULL);
+	triangulate("pzqDaBeQj", &in, &out, (struct triangulateio *)NULL);
-    if (0>Vect_open_new (&Map, output->answer, 0))
-      G_fatal_error(_("Unable to create vector map %s"),output->answer);
-    driver=db_start_driver_open_database(Fi->driver,Vect_subst_var(Fi->database,&Map));
+    if (0 > Vect_open_new(&Map, output->answer, 0))
+	G_fatal_error(_("Unable to create vector map %s"), output->answer);
-    if(driver==NULL)
-      G_fatal_error(_("Cannot open database %s by driver %s"),Vect_subst_var(Fi->database,&Map),Fi->driver);
-    printf("driver= %s\n",Fi->driver);
+    driver =
+				      Vect_subst_var(Fi->database, &Map));
+    if (driver == NULL)
+	G_fatal_error(_("Cannot open database %s by driver %s"),
+		      Vect_subst_var(Fi->database, &Map), Fi->driver);
+    printf("driver= %s\n", Fi->driver);
     db_begin_transaction(driver);
-    sprintf(buf,"create table %snodes (cat int)",output->answer);
+    sprintf(buf, "create table %snodes (cat int)", output->answer);
     printf("buf=%s\n", buf);
-    if(db_execute_immediate(driver,&stmt) != DB_OK)
-      G_fatal_error(_("Cannot create table %s"),db_get_string(&stmt));
-    sprintf(buf,"%snodes",output->answer);
-    Vect_map_add_dblink(&Map, 1, NULL, buf,"cat",Fi->database,Fi->driver);
+    if (db_execute_immediate(driver, &stmt) != DB_OK)
+	G_fatal_error(_("Cannot create table %s"), db_get_string(&stmt));
+    sprintf(buf, "%snodes", output->answer);
+    Vect_map_add_dblink(&Map, 1, NULL, buf, "cat", Fi->database, Fi->driver);
     /* Writing the output to GRASS */
     /* Writing NODES     */
-    for(i=0;i<out.numberofpoints;i++){
-      Vect_reset_line (Points);
-      Vect_reset_cats (Cats);
-      x=out.pointlist[i*2];
-      y=out.pointlist[i*2+1];
-      Vect_append_point (Points,x,y,0);
-      Vect_cat_set (Cats, 1, i+1);
-      Vect_write_line(&Map, GV_POINT, Points, Cats);
-      sprintf(buf,"insert into %snodes values(%i)",output->answer,i+1);
-	G_fatal_error(_("Cannot add values to table %snodes"),output->answer);
+    for (i = 0; i < out.numberofpoints; i++) {
+	Vect_reset_line(Points);
+	Vect_reset_cats(Cats);
+	x = out.pointlist[i * 2];
+	y = out.pointlist[i * 2 + 1];
+	Vect_append_point(Points, x, y, 0);
+	Vect_cat_set(Cats, 1, i + 1);
+	Vect_write_line(&Map, GV_POINT, Points, Cats);
+	sprintf(buf, "insert into %snodes values(%i)", output->answer, i + 1);
+	    G_fatal_error(_("Cannot add values to table %snodes"),
+			  output->answer);
     /* Writing BOUNDARIES */
-    for(i=0;i<out.numberofedges;i++){
-	j=out.edgelist[i*2+of];
-	x=out.pointlist[j*2];
-	y=out.pointlist[j*2+1];
-	Vect_write_line(&Map, GV_BOUNDARY, Points, Cats);
+    for (i = 0; i < out.numberofedges; i++) {
+	    j = out.edgelist[i * 2 + of];
+	    x = out.pointlist[j * 2];
+	    y = out.pointlist[j * 2 + 1];
+	    Vect_write_line(&Map, GV_BOUNDARY, Points, Cats);
     /* Writing CENTROIDS */
-    sprintf(buf,"create table %stricentr (cat int)",output->answer);
+    sprintf(buf, "create table %stricentr (cat int)", output->answer);
-    sprintf(buf,"%stricentr",output->answer);
-    Vect_map_add_dblink(&Map, 2, NULL, buf,"cat",Fi->database,Fi->driver);
+    sprintf(buf, "%stricentr", output->answer);
+    Vect_map_add_dblink(&Map, 2, NULL, buf, "cat", Fi->database, Fi->driver);
-    for(i=0;i<out.numberoftriangles;i++){
-      left=out.trianglelist[i*3];
-      center=out.trianglelist[i*3+1];
-      right=out.trianglelist[i*3+2];
+    for (i = 0; i < out.numberoftriangles; i++) {
+	left = out.trianglelist[i * 3];
+	center = out.trianglelist[i * 3 + 1];
+	right = out.trianglelist[i * 3 + 2];
-      xleft=out.pointlist[left*2];
-      yleft=out.pointlist[left*2+1];
-      xcenter=out.pointlist[center*2];
-      ycenter=out.pointlist[center*2+1];
-      xright=out.pointlist[right*2];
-      yright=out.pointlist[right*2+1];
+	xleft = out.pointlist[left * 2];
+	yleft = out.pointlist[left * 2 + 1];
+	xcenter = out.pointlist[center * 2];
+	ycenter = out.pointlist[center * 2 + 1];
+	xright = out.pointlist[right * 2];
+	yright = out.pointlist[right * 2 + 1];
-      xm1=xleft+((xcenter-xleft)/2);
-      ym=yleft+((ycenter-yleft)/2);
-      m1=(yright-ym)/(xright-xm1);
-      b1=yright-(m1*xright);
+	xm1 = xleft + ((xcenter - xleft) / 2);
+	ym = yleft + ((ycenter - yleft) / 2);
+	m1 = (yright - ym) / (xright - xm1);
+	b1 = yright - (m1 * xright);
-      xm2=xcenter+((xright-xcenter)/2);
-      ym=ycenter+((yright-ycenter)/2);
-      m2=(yleft-ym)/(xleft-xm2);
-      b2=yleft-(m2*xleft);
-      /* in case a median is a vertical line */
-	if((xright-xm1)==0 || (xleft-xm2)==0 ){
-	  if((xright-xm1)==0){
-	    x=xm1;
-	    y=(m2*x)+b2;
-	  else{
-	    x=xm2;
-	    y=(m1*x)+b1;
+	xm2 = xcenter + ((xright - xcenter) / 2);
+	ym = ycenter + ((yright - ycenter) / 2);
+	m2 = (yleft - ym) / (xleft - xm2);
+	b2 = yleft - (m2 * xleft);
+	/* in case a median is a vertical line */
+	if ((xright - xm1) == 0 || (xleft - xm2) == 0) {
+	    if ((xright - xm1) == 0) {
+		x = xm1;
+		y = (m2 * x) + b2;
+	    else {
+		x = xm2;
+		y = (m1 * x) + b1;
-	else{
-	  x=(b2-b1)/(m1-m2);
-	  y=(m1*x)+b1;
+	else {
+	    x = (b2 - b1) / (m1 - m2);
-	Vect_cat_set (Cats, 2, i+1);
+	Vect_cat_set(Cats, 2, i + 1);
 	Vect_write_line(&Map, GV_CENTROID, Points, Cats);
-	sprintf(buf,"insert into %stricentr values(%i)",output->answer,i+1);
+	sprintf(buf, "insert into %stricentr values(%i)", output->answer,
+		i + 1);
-	if(db_execute_immediate(driver,&stmt) != DB_OK){
-	  G_fatal_error(_("Cannot add values to table %stricentr"),output->answer);
+	if (db_execute_immediate(driver, &stmt) != DB_OK) {
+	    G_fatal_error(_("Cannot add values to table %stricentr"),
+			  output->answer);
     db_close_database(driver);
     db_shutdown_driver(driver);
-    Vect_build_partial(&Map,GV_BUILD_NONE);
+    Vect_build_partial(&Map, GV_BUILD_NONE);
     Vect_build(&Map);
     Vect_close(&Map);
-    return(EXIT_SUCCESS);
+    return (EXIT_SUCCESS);
