[GRASS-SVN] r51797 - in grass/trunk/gui/wxpython: gui_core lmgr
svn_grass at osgeo.org
Sat May 26 11:10:49 EDT 2012
Author: martinl
Date: 2012-05-26 08:10:49 -0700 (Sat, 26 May 2012)
New Revision: 51797
grass/trunk/gui/wxpython/gui_core/goutput.py
grass/trunk/gui/wxpython/lmgr/frame.py
wxGUI: save commands protocol when exiting wxGUI (if protocol is activated)
Modified: grass/trunk/gui/wxpython/gui_core/goutput.py
--- grass/trunk/gui/wxpython/gui_core/goutput.py 2012-05-26 14:55:37 UTC (rev 51796)
+++ grass/trunk/gui/wxpython/gui_core/goutput.py 2012-05-26 15:10:49 UTC (rev 51797)
@@ -761,25 +761,31 @@
"""!Update progress message info"""
self.progressbar.SetValue(event.value)
- def OnCmdProtocol(self, event):
+ def CmdProtocolSave(self):
+ """Save commands protocol into the file"""
+ if not hasattr(self, 'cmdFileProtocol'):
+ return # it should not happen
+ try:
+ output = open(self.cmdFileProtocol, "w")
+ cmds = self.cmdPrompt.GetCommands()
+ output.write('\n'.join(cmds))
+ if len(cmds) > 0:
+ output.write('\n')
+ except IOError, e:
+ GError(_("Unable to write file '%s'.\n\nDetails: %s") % (path, e))
+ finally:
+ output.close()
+ self.parent.SetStatusText(_("Commands protocol saved into '%s'") % self.cmdFileProtocol)
+ del self.cmdFileProtocol
+ def OnCmdProtocol(self, event = None):
"""!Save commands into file"""
- if not self.btnCmdProtocol.GetValue():
+ if not event.IsChecked():
# stop capturing commands, save list of commands to the
# protocol file
- if hasattr(self, 'cmdFileProtocol'):
- try:
- output = open(self.cmdFileProtocol, "w")
- cmds = self.cmdPrompt.GetCommands()
- output.write('\n'.join(cmds))
- if len(cmds) > 0:
- output.write('\n')
- except IOError, e:
- GError(_("Unable to write file '%s'.\n\nDetails: %s") % (path, e))
- finally:
- output.close()
- self.parent.SetStatusText(_("Commands protocol saved into '%s'") % self.cmdFileProtocol)
- del self.cmdFileProtocol
+ self.CmdProtocolSave()
else:
# start capturing commands
self.cmdPrompt.ClearCommands()
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2012-05-26 14:55:37 UTC (rev 51796)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2012-05-26 15:10:49 UTC (rev 51797)
@@ -7,7 +7,7 @@
Classes:
- frame::GMFrame
-(C) 2006-2011 by the GRASS Development Team
+(C) 2006-2012 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -1674,11 +1674,16 @@
def OnCloseWindow(self, event):
"""!Cleanup when wxGUI is quitted"""
+ # save command protocol if actived
+ if self.goutput.btnCmdProtocol.GetValue():
+ self.goutput.CmdProtocolSave()
if not self.curr_page:
self._auimgr.UnInit()
self.Destroy()
return
+ # save changes in the workspace
maptree = self.curr_page.maptree
if self.workspaceChanged and \
UserSettings.Get(group = 'manager', key = 'askOnQuit', subkey = 'enabled'):
