[GRASS-SVN] r51798 - in grass/branches/develbranch_6/gui/wxpython:
gui_core lmgr
svn_grass at osgeo.org
Sat May 26 11:14:37 EDT 2012
Author: martinl
Date: 2012-05-26 08:14:37 -0700 (Sat, 26 May 2012)
New Revision: 51798
grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py
grass/branches/develbranch_6/gui/wxpython/gui_core/prompt.py
grass/branches/develbranch_6/gui/wxpython/lmgr/frame.py
wxGUI: implement cmd protocol functionality
fix GPrompt.OnRunCmd() to be called correctly
(merge r51789 & r51795 & r51797 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py 2012-05-26 15:10:49 UTC (rev 51797)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py 2012-05-26 15:14:37 UTC (rev 51798)
@@ -263,16 +263,20 @@
self.btnCmdClear.Hide()
self.btnOutputSave = wx.Button(parent = self.panelOutput, id = wx.ID_SAVE)
self.btnOutputSave.SetToolTipString(_("Save output window content to the file"))
- # abort
self.btnCmdAbort = wx.Button(parent = self.panelOutput, id = wx.ID_STOP)
self.btnCmdAbort.SetToolTipString(_("Abort running command"))
self.btnCmdAbort.Enable(False)
+ self.btnCmdProtocol = wx.ToggleButton(parent = self.panelOutput, id = wx.ID_ANY,
+ label = _("&Protocol"))
+ self.btnCmdProtocol.SetToolTipString(_("Toggle to save list of executed commands into file; "
+ "content saved when switching off."))
self.btnCmdClear.Bind(wx.EVT_BUTTON, self.cmdPrompt.OnCmdErase)
- self.btnOutputClear.Bind(wx.EVT_BUTTON, self.ClearHistory)
- self.btnOutputSave.Bind(wx.EVT_BUTTON, self.SaveHistory)
+ self.btnOutputClear.Bind(wx.EVT_BUTTON, self.OnOutputClear)
+ self.btnOutputSave.Bind(wx.EVT_BUTTON, self.OnOutputSave)
self.btnCmdAbort.Bind(wx.EVT_BUTTON, self.OnCmdAbort)
self.btnCmdAbort.Bind(EVT_CMD_ABORT, self.OnCmdAbort)
+ self.btnCmdProtocol.Bind(wx.EVT_TOGGLEBUTTON, self.OnCmdProtocol)
self._layout()
@@ -300,14 +304,16 @@
outBtnSizer.Add(item = self.btnOutputSave, proportion = 1,
flag = wx.ALIGN_RIGHT | wx.RIGHT, border = 5)
+ cmdBtnSizer.Add(item = self.btnCmdProtocol, proportion = 1,
+ flag = wx.ALIGN_CENTER | wx.ALIGN_CENTER_VERTICAL | wx.LEFT | wx.RIGHT, border = 5)
cmdBtnSizer.Add(item = self.btnCmdClear, proportion = 1,
- flag = wx.ALIGN_CENTER | wx.LEFT | wx.RIGHT, border = 5)
+ flag = wx.ALIGN_CENTER | wx.RIGHT, border = 5)
cmdBtnSizer.Add(item = self.btnCmdAbort, proportion = 1,
- btnSizer.Add(item = outBtnSizer, proportion = 1,
+ btnSizer.Add(item = outBtnSizer, proportion = 2,
flag = wx.ALL | wx.ALIGN_CENTER, border = 5)
- btnSizer.Add(item = cmdBtnSizer, proportion = 1,
+ btnSizer.Add(item = cmdBtnSizer, proportion = 3,
flag = wx.ALIGN_CENTER | wx.TOP | wx.BOTTOM | wx.RIGHT, border = 5)
outputSizer.Add(item = btnSizer, proportion = 0,
flag = wx.EXPAND)
@@ -469,7 +475,8 @@
'.bash_history'),
encoding = 'utf-8', mode = 'a')
except IOError, e:
- self.WriteError(e)
+ GError(_("Unable to write file '%s'.\n\nDetails: %s") % (path, e),
+ parent = self.parent)
fileHistory = None
if fileHistory:
@@ -605,8 +612,8 @@
onDone = onDone, onPrepare = onPrepare, userData = userData)
self.cmdOutputTimer.Start(50)
- def ClearHistory(self, event):
- """!Clear history of commands"""
+ def OnOutputClear(self, event):
+ """!Clear content of output window"""
self.cmdOutput.SetReadOnly(False)
self.cmdOutput.ClearAll()
self.cmdOutput.SetReadOnly(True)
@@ -626,30 +633,35 @@
return self.cmdStdOut
- def SaveHistory(self, event):
- """!Save history of commands"""
- self.history = self.cmdOutput.GetSelectedText()
- if self.history == '':
- self.history = self.cmdOutput.GetText()
+ def OnOutputSave(self, event):
+ """!Save (selected) text from output window to the file"""
+ text = self.cmdOutput.GetSelectedText()
+ if not text:
+ text = self.cmdOutput.GetText()
# add newline if needed
- if len(self.history) > 0 and self.history[-1] != '\n':
- self.history += '\n'
- wildcard = "Text file (*.txt)|*.txt"
- dlg = wx.FileDialog(self, message = _("Save file as..."), defaultDir = os.getcwd(),
- defaultFile = "grass_cmd_history.txt", wildcard = wildcard,
+ if len(text) > 0 and text[-1] != '\n':
+ text += '\n'
+ dlg = wx.FileDialog(self, message = _("Save file as..."),
+ defaultFile = "grass_cmd_output.txt",
+ wildcard = _("%s (*.txt)|*.txt|%s (*)|*") % (_("Text files"), _("Files")),
style = wx.SAVE | wx.FD_OVERWRITE_PROMPT)
# Show the dialog and retrieve the user response. If it is the OK response,
# process the data.
if dlg.ShowModal() == wx.ID_OK:
path = dlg.GetPath()
- output = open(path, "w")
- output.write(self.history)
- output.close()
+ try:
+ output = open(path, "w")
+ output.write(text)
+ except IOError, e:
+ GError(_("Unable to write file '%s'.\n\nDetails: %s") % (path, e))
+ finally:
+ output.close()
+ self.parent.SetStatusText(_("Commands output saved into '%s'") % path)
dlg.Destroy()
def GetCmd(self):
@@ -746,6 +758,43 @@
"""!Update progress message info"""
self.progressbar.SetValue(event.value)
+ def CmdProtocolSave(self):
+ """Save commands protocol into the file"""
+ if not hasattr(self, 'cmdFileProtocol'):
+ return # it should not happen
+ try:
+ output = open(self.cmdFileProtocol, "w")
+ cmds = self.cmdPrompt.GetCommands()
+ output.write('\n'.join(cmds))
+ if len(cmds) > 0:
+ output.write('\n')
+ finally:
+ output.close()
+ self.parent.SetStatusText(_("Commands protocol saved into '%s'") % self.cmdFileProtocol)
+ del self.cmdFileProtocol
+ def OnCmdProtocol(self, event = None):
+ """!Save commands into file"""
+ if not event.IsChecked():
+ # stop capturing commands, save list of commands to the
+ # protocol file
+ self.CmdProtocolSave()
+ else:
+ # start capturing commands
+ self.cmdPrompt.ClearCommands()
+ # ask for the file
+ defaultFile = "grass_cmd_protocol.txt",
+ style = wx.SAVE | wx.FD_OVERWRITE_PROMPT)
+ if dlg.ShowModal() == wx.ID_OK:
+ self.cmdFileProtocol = dlg.GetPath()
+ dlg.Destroy()
def OnCmdAbort(self, event):
"""!Abort running command"""
self.cmdThread.abort()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/prompt.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/prompt.py 2012-05-26 15:10:49 UTC (rev 51797)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/prompt.py 2012-05-26 15:14:37 UTC (rev 51798)
@@ -486,7 +486,7 @@
else:
self.moduleDesc = parent.parent.menubar.GetData().GetModules()
self.moduleList = self._getListOfModules()
- self.mapList = self._getListOfMaps()
+ self.mapList = self._getListOfMaps()
self.mapsetList = utils.ListOfMapsets()
else:
self.moduleDesc = self.moduleList = self.mapList = None
@@ -496,10 +496,13 @@
self.autoCompFilter = None
# command description (gtask.grassTask)
- self.cmdDesc = None
+ self.cmdDesc = None
self.cmdbuffer = self._readHistory()
- self.cmdindex = len(self.cmdbuffer)
+ self.cmdindex = len(self.cmdbuffer)
+ # list of traced commands
+ self.commands = list()
def _readHistory(self):
"""!Get list of commands from history file"""
hist = list()
@@ -588,25 +591,42 @@
result['vector'] = grass.list_strings('vect')
return result
- def OnRunCmd(self, event):
- """!Run command"""
- cmdString = event.GetString()
+ def _runCmd(self, cmdString):
+ """!Run command
- if self.standAlone:
+ @param cmdString command to run (given as a string)
+ if self.parent.GetName() == "ModelerDialog":
+ self.parent.OnOk(None)
return
+ if not cmdString or self.standAlone:
+ return
if cmdString[:2] == 'd.' and not self.parent.curr_page:
- self.parent.NewDisplay(show=True)
+ self.parent.NewDisplay(show = True)
+ self.commands.append(cmdString) # trace commands
+ # parse command into list
+ try:
+ cmd = utils.split(str(cmdString))
+ except UnicodeError:
+ cmd = utils.split(EncodeString((cmdString)))
+ cmd = map(DecodeString, cmd)
- cmd = utils.split(cmdString)
- if len(cmd) > 1:
- self.parent.RunCmd(cmd, switchPage = True)
+ # send the command list to the processor
+ if cmd[0] in ('r.mapcalc', 'r3.mapcalc') and len(cmd) == 1:
+ self.parent.parent.OnMapCalculator(event = None, cmd = cmd)
else:
- self.parent.RunCmd(cmd, switchPage = False)
+ self.parent.RunCmd(cmd)
+ # add command to history & clean prompt
+ self.UpdateCmdHistory(cmd)
+ self.OnCmdErase(None)
+ self.parent.parent.statusbar.SetStatusText('')
- self.OnUpdateStatusBar(None)
def OnUpdateStatusBar(self, event):
"""!Update Layer Manager status bar"""
if self.standAlone:
@@ -643,6 +663,14 @@
else:
self.dataList = self._getListOfMaps()
+ def GetCommands(self):
+ """!Get list of launched commands"""
+ return self.commands
+ def ClearCommands(self):
+ """!Clear list of commands"""
+ del self.commands[:]
class GPromptPopUp(GPrompt, TextCtrlAutoComplete):
"""!Interactive wxGUI prompt - popup version"""
def __init__(self, parent):
@@ -678,6 +706,10 @@
"""!Erase command prompt"""
self.input.SetValue('')
+ def OnRunCmd(self, event):
+ """!Run command"""
+ self._runCmd(event.GetString())
class GPromptSTC(GPrompt, wx.stc.StyledTextCtrl):
"""!Styled wxGUI prompt with autocomplete and calltips"""
def __init__(self, parent, id = wx.ID_ANY, margin = False):
@@ -1083,34 +1115,8 @@
elif event.GetKeyCode() in [wx.WXK_RETURN, wx.WXK_NUMPAD_ENTER] and \
self.AutoCompActive() == False:
# run command on line when <return> is pressed
- if self.parent.GetName() == "ModelerDialog":
- self.parent.OnOk(None)
- return
- # find the command to run
- line = self.GetCurLine()[0].strip()
- if len(line) == 0:
- return
- # parse command into list
- try:
- cmd = utils.split(str(line))
- except UnicodeError:
- cmd = utils.split(EncodeString((line)))
- cmd = map(DecodeString, cmd)
- # send the command list to the processor
- if cmd[0] in ('r.mapcalc', 'r3.mapcalc') and len(cmd) == 1:
- self.parent.parent.OnMapCalculator(event = None, cmd = cmd)
- else:
- self.parent.RunCmd(cmd)
- # add command to history & clean prompt
- self.UpdateCmdHistory(cmd)
- self.OnCmdErase(None)
- self.parent.parent.statusbar.SetStatusText('')
+ self._runCmd(self.GetCurLine()[0].strip())
elif event.GetKeyCode() == wx.WXK_SPACE:
items = self.GetTextLeft().split()
if len(items) == 1:
Modified: grass/branches/develbranch_6/gui/wxpython/lmgr/frame.py
--- grass/branches/develbranch_6/gui/wxpython/lmgr/frame.py 2012-05-26 15:10:49 UTC (rev 51797)
+++ grass/branches/develbranch_6/gui/wxpython/lmgr/frame.py 2012-05-26 15:14:37 UTC (rev 51798)
@@ -7,7 +7,7 @@
Classes:
- frame::GMFrame
-(C) 2006-2011 by the GRASS Development Team
+(C) 2006-2012 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -1692,11 +1692,16 @@
def OnCloseWindow(self, event):
"""!Cleanup when wxGUI is quitted"""
+ # save command protocol if actived
+ if self.goutput.btnCmdProtocol.GetValue():
+ self.goutput.CmdProtocolSave()
if not self.curr_page:
self._auimgr.UnInit()
self.Destroy()
return
+ # save changes in the workspace
maptree = self.curr_page.maptree
if self.workspaceChanged and \
UserSettings.Get(group = 'manager', key = 'askOnQuit', subkey = 'enabled'):
