[GRASS-SVN] r51804 - in grass/trunk/gui/wxpython: core mapdisp
svn_grass at osgeo.org
Sat May 26 12:38:56 EDT 2012
Author: annakrat
Date: 2012-05-26 09:38:55 -0700 (Sat, 26 May 2012)
New Revision: 51804
grass/trunk/gui/wxpython/core/render.py
grass/trunk/gui/wxpython/mapdisp/main.py
wxGUI: fix bug introduced in r51758 (author Vaclav Petras)
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py 2012-05-26 15:46:05 UTC (rev 51803)
+++ grass/trunk/gui/wxpython/core/render.py 2012-05-26 16:38:55 UTC (rev 51804)
@@ -361,10 +361,21 @@
# setting some initial env. variables
self._initGisEnv() # g.gisenv
self.GetWindow()
+ # GRASS environment variable (for rendering)
+ self.env = {"GRASS_BACKGROUNDCOLOR" : "FFFFFF",
+ "GRASS_COMPRESSION" : "0",
+ "GRASS_TRUECOLOR" : "TRUE",
+ "GRASS_TRANSPARENT" : "TRUE",
+ "GRASS_PNG_READ" : "FALSE",
+ for k, v in self.env.iteritems():
+ os.environ[k] = v
# projection info
self.projinfo = self._projInfo()
def _runCommand(self, cmd, **kwargs):
"""!Run command in environment defined by self.gisrc if
defined"""
Modified: grass/trunk/gui/wxpython/mapdisp/main.py
--- grass/trunk/gui/wxpython/mapdisp/main.py 2012-05-26 15:46:05 UTC (rev 51803)
+++ grass/trunk/gui/wxpython/mapdisp/main.py 2012-05-26 16:38:55 UTC (rev 51804)
@@ -51,42 +51,31 @@
def __init__(self, gisrc = None, cmdfile = None, mapfile = None, envfile = None, monitor = None):
"""!Map composition (stack of map layers and overlays)
@param cmdline full path to the cmd file (defined by d.mon)
@param mapfile full path to the map file (defined by d.mon)
@param envfile full path to the env file (defined by d.mon)
@param monitor name of monitor (defined by d.mon)
Map.__init__(self)
# environment settings
self.env = dict()
self.cmdfile = cmdfile
self.envfile = envfile
self.monitor = monitor
if mapfile:
self.mapfileCmd = mapfile
self.maskfileCmd = os.path.splitext(mapfile)[0] + '.pgm'
# generated file for g.pnmcomp output for rendering the map
self.mapfile = grass.tempfile(create = False) + '.ppm'
- # GRASS environment variable (for rendering)
- env = {"GRASS_BACKGROUNDCOLOR" : "FFFFFF",
- "GRASS_COMPRESSION" : "0",
- "GRASS_TRUECOLOR" : "TRUE",
- "GRASS_TRANSPARENT" : "TRUE",
- "GRASS_PNG_READ" : "FALSE",
- self._writeEnvFile(env)
+ self._writeEnvFile(self.env) # self.env is expected to be defined in parent class
self._writeEnvFile({"GRASS_PNG_READ" : "TRUE"})
- for k, v in env.iteritems():
- os.environ[k] = v
def GetLayersFromCmdFile(self):
"""!Get list of map layers from cmdfile
