[GRASS-SVN] r51896 - grass-addons/grass7/imagery/i.segment
svn_grass at osgeo.org
Wed May 30 14:49:45 PDT 2012
Author: momsen
Date: 2012-05-30 14:49:44 -0700 (Wed, 30 May 2012)
New Revision: 51896
Added:
grass-addons/grass7/imagery/i.segment/Makefile
grass-addons/grass7/imagery/i.segment/get_input.c
grass-addons/grass7/imagery/i.segment/i.segment.html
grass-addons/grass7/imagery/i.segment/main.c
grass-addons/grass7/imagery/i.segment/segment.h
File structure framework, step 1 to collect input.
Added: grass-addons/grass7/imagery/i.segment/Makefile
--- grass-addons/grass7/imagery/i.segment/Makefile (rev 0)
+++ grass-addons/grass7/imagery/i.segment/Makefile 2012-05-30 21:49:44 UTC (rev 51896)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = i.segment
+LIBES = $(GISLIB)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass7/imagery/i.segment/get_input.c
--- grass-addons/grass7/imagery/i.segment/get_input.c (rev 0)
+++ grass-addons/grass7/imagery/i.segment/get_input.c 2012-05-30 21:49:44 UTC (rev 51896)
@@ -0,0 +1,72 @@
+ * MODULE: i.segment
+ * AUTHOR(S): Eric Momsen <eric.momsen at gmail com>
+ * PURPOSE: Parse and validate the input
+ * COPYRIGHT: (C) 2012 by Eric Momsen, and the GRASS Development Team
+ * This program is free software under the GNU General Public
+ * License (>=v2). Read the COPYING file that comes with GRASS
+ * for details.
+//Should this type of comment block go at the beginning of all sub files?
+#include <stdlib.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include "segment.h"
+int get_input(int argc, char *argv[])
+ //reference: http://grass.osgeo.org/programming7/gislib.html#Command_Line_Parsing
+ input = G_define_standard_option(G_OPT_R_INPUT); /* Request a pointer to memory for each option */
+ input->key = "input"; /* TODO: update to allow groups. Maybe this needs a group/subgroup variables, or we can check if the input is group/subgroup/raster */
+ input->type = TYPE_STRING;
+ input->required = YES;
+ input->description = _("Raster map to be segmented.");
+ seeds = G_define_standard_option(G_OPT_V_INPUT);
+ seeds->key = "seeds";
+ seeds->type = TYPE_STRING;
+ seeds->required = NO;
+ seeds->description = _("Optional vector map with starting seeds.");
+ output = G_define_standard_option(G_OPT_R_OUTPUT);
+ output->key = "output";
+ output->type = TYPE_STRING;
+ output->required = YES;
+ output->description = _("Name of output raster map.");
+//TODO: when put in a new raster map, error message:
+//~ Command 'd.rast map=testing at samples' failed
+//~ Details: Raster map <testing at samples> not found
+//Also, that error seems to be accumulated, putting in a new output map names results in:
+//~ Command 'd.rast map=test2 at samples' failed
+//~ Details: Raster map <test2 at samples> not found
+ method = G_define_option();
+ method->key = "method";
+ method->type = TYPE_STRING;
+ method->required = NO;
+ method->answer = _("region growing");
+ method->options = "region growing, mean shift";
+ method->description = _("Segmentation method.");
+ threshold = G_define_option();
+ threshold->key = "threshold";
+ threshold->type = TYPE_DOUBLE;
+ threshold->required = YES;
+ threshold->description = _("Similarity threshold.");
+ //use checker for any of the data validation steps!?
+ if (G_parser(argc, argv))
+ exit (EXIT_FAILURE);
+ return 0;
Added: grass-addons/grass7/imagery/i.segment/i.segment.html
--- grass-addons/grass7/imagery/i.segment/i.segment.html (rev 0)
+++ grass-addons/grass7/imagery/i.segment/i.segment.html 2012-05-30 21:49:44 UTC (rev 51896)
@@ -0,0 +1,8 @@
+<h2>DESCRIPTION</h2>
+<H2>NOTES</h2>
+<H2>EXAMPLES</h2>
+<h2>TODO</h2>
+<h2>BUGS</h2>
+<H2>REFERENCES</h2>
+<h2>SEE ALSO</h2>
+<h2>AUTHORS</h2>
Added: grass-addons/grass7/imagery/i.segment/main.c
--- grass-addons/grass7/imagery/i.segment/main.c (rev 0)
+++ grass-addons/grass7/imagery/i.segment/main.c 2012-05-30 21:49:44 UTC (rev 51896)
@@ -0,0 +1,64 @@
+ * PURPOSE: Provide short description of module here...
+ * for details.
+// #include <grass/config.h>
+// #include <unistd.h>
+//#include <grass/imagery.h>
+#include <grass/glocale.h> //defines _() what exactly is that doing...(something about local language translation?) anything else in glocale.h that I should be aware of...
+//~ (for my reference, order for headers), adding them only as needed...
+//~ 1. Core system headers (stdio.h, ctype.h, ...)
+//~ 2. Headers for non-core system components (X11, libraries).
+//~ 3. Headers for core systems of the package being compiled (grass/gis.h, grass/glocale.h, ...)
+//~ 4. Headers for the specific library/program being compiled (geodesic.h, ...)
+struct GModule *module;
+struct Option *input, *seeds, *output, *method, *threshold; /* Establish an Option pointer for each option */
+// ? Any reasons not to use global variables for this application?
+int main(int argc, char *argv[])
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ G_add_keyword(_("imagery"));
+ G_add_keyword(_("segmentation"));
+ module->description = _("Segments an image.");
+ get_input(argc, argv);
+ //debug/testing stuff... delete when done.
+ G_message("For the option <%s> you chose: <%s>",
+ input->description, input->answer);
+ seeds->description, seeds->answer);
+ output->description, output->answer);
+ method->description, method->answer);
+ threshold->description, threshold->answer);
+ G_done_msg("Any other messages?");
+ exit(EXIT_SUCCESS);
Added: grass-addons/grass7/imagery/i.segment/segment.h
--- grass-addons/grass7/imagery/i.segment/segment.h (rev 0)
+++ grass-addons/grass7/imagery/i.segment/segment.h 2012-05-30 21:49:44 UTC (rev 51896)
@@ -0,0 +1,18 @@
+ * PURPOSE: global variable and function listing
+ * for details.
+extern struct GModule *module;
+extern struct Option *input, *seeds, *output, *method, *threshold;
+/* get_input.c */
+int get_input(int, char *[]);
