[GRASS-SVN] r51897 - in grass-addons/grass7/vector: . v.external.all
Thu May 31 03:36:10 PDT 2012
Author: martinl
Date: 2012-05-31 03:36:09 -0700 (Thu, 31 May 2012)
New Revision: 51897
Added:
   grass-addons/grass7/vector/v.external.all/
   grass-addons/grass7/vector/v.external.all/Makefile
   grass-addons/grass7/vector/v.external.all/v.external.all.html
   grass-addons/grass7/vector/v.external.all/v.external.all.py
new module v.external.all
Added: grass-addons/grass7/vector/v.external.all/Makefile
--- grass-addons/grass7/vector/v.external.all/Makefile	                        (rev 0)
+++ grass-addons/grass7/vector/v.external.all/Makefile	2012-05-31 10:36:09 UTC (rev 51897)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.external.all
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/vector/v.external.all/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Added: grass-addons/grass7/vector/v.external.all/v.external.all.html
--- grass-addons/grass7/vector/v.external.all/v.external.all.html	                        (rev 0)
+++ grass-addons/grass7/vector/v.external.all/v.external.all.html	2012-05-31 10:36:09 UTC (rev 51897)
@@ -0,0 +1,65 @@
+<h2>DESCRIPTION</h2>
+<em>v.external.all</em> creates
+(using <em><a href="v.external.html">v.external</a></em>) in the
+current mapset new pseudo-vector maps for all OGR layers from given
+OGR datasource (<b>dsn</b> option).
+<h2>EXAMPLES</h2>
+<h3>PostGIS</h3>
+List available feature tables in given PostGIS database
+<div class="code"><pre>
+v.external.all -l dsn=PG:dbname=pgis_nc
+PostGIS database <pgis_nc> contains 55 feature table(s):
+boundary_county
+boundary_municp
+bridges
+busroute1
+busroute11
+busroute6
+busroute_a
+busroutesall
+busstopsall
+censusblk_swwake
+census_wake2000
+</pre></div>
+Create links (ie. pseudo-vector maps) in the current mapset for all
+PostGIS feature tables
+v.external.all dsn=PG:dbname=pgis_nc
+</pre></div>
+<h3>Esri Shapefile</h3>
+v.external.all -l dsn=~/geodata/ncshape/
+Data source </home/martin/geodata/ncshape/> (format 'ESRI Shapefile')
+contains 44 layers:
+poi_names_wake
+schools_wake
+urbanarea
+geodetic_swwake_pts
+usgsgages
+busroute_a
+busroute6
+hospitals
+</pre></div>
+</pre></div>
+<h2>AUTHOR</h2>
+Martin Landa, Czech Technical University in Prague
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/vector/v.external.all/v.external.all.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Added: grass-addons/grass7/vector/v.external.all/v.external.all.py
--- grass-addons/grass7/vector/v.external.all/v.external.all.py	                        (rev 0)
+++ grass-addons/grass7/vector/v.external.all/v.external.all.py	2012-05-31 10:36:09 UTC (rev 51897)
@@ -0,0 +1,68 @@
+#!/usr/bin/env python
+# MODULE:	v.external.all
+# AUTHOR(S):	Martin Landa
+# PURPOSE:	Links all OGR layers available in given OGR datasource.
+# COPYRIGHT:	(C) 2012 by Martin Landa, and the GRASS Development Team
+#		This program is free software under the GNU General
+#		Public License (>=v2). Read the file COPYING that
+#		comes with GRASS for details.
+#%module
+#% description: Links all OGR layers available in given OGR datasource.
+#% keywords: vector
+#% keywords: external
+#%end
+#%flag
+#% key: l
+#% description: List available layers in data source and exit
+#%end
+#%option
+#% key: dsn
+#% type: string
+#% description: Name of input OGR or PostGIS data source
+#% required: yes
+#%end
+import os
+import sys
+from grass.script import core as grass
+def list_layers(dsn):
+    ret = grass.read_command('v.external',
+                             flags = 'l',
+                             dsn = dsn)
+    if not ret:
+        sys.exit(1)
+    return ret.splitlines()
+def make_links(dsn):
+    layers = list_layers(dsn)
+    for layer in layers:
+        oname = layer.replace('.', '_')
+        grass.message(_("%s\nCreating link for OGR layer <%s> as <%s>...\n%s") % \
+                          ('-' * 80, layer, oname, '-' * 80))
+        if 0 != grass.run_command('v.external',
+                                  dsn = dsn, layer = layer, output = oname):
+            grass.warning(_("Unable to create link for OGR layer <%s>") % layer)
+def main():
+    if flags['l']:
+        ret = list_layers(options['dsn'])
+        sys.stdout.write(os.linesep.join(ret))
+        sys.stdout.write(os.linesep)
+    else:
+        make_links(options['dsn'])
+    return 0
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
Property changes on: grass-addons/grass7/vector/v.external.all/v.external.all.py
Added: svn:executable
   + text/x-python
   + native
