[GRASS-SVN] r53686 - in grass/trunk: include/defs lib/vector/Vlib
svn_grass at osgeo.org
Mon Nov 5 01:34:48 PST 2012
Author: martinl
Date: 2012-11-05 01:34:48 -0800 (Mon, 05 Nov 2012)
New Revision: 53686
Added:
grass/trunk/lib/vector/Vlib/local_proto.h
grass/trunk/include/defs/vector.h
grass/trunk/lib/vector/Vlib/build_nat.c
grass/trunk/lib/vector/Vlib/build_pg.c
grass/trunk/lib/vector/Vlib/build_sfa.c
grass/trunk/lib/vector/Vlib/close_pg.c
grass/trunk/lib/vector/Vlib/copy.c
grass/trunk/lib/vector/Vlib/e_intersect.c
grass/trunk/lib/vector/Vlib/open_pg.c
grass/trunk/lib/vector/Vlib/pg_local_proto.h
grass/trunk/lib/vector/Vlib/read_pg.c
grass/trunk/lib/vector/Vlib/rewind_pg.c
grass/trunk/lib/vector/Vlib/write.c
grass/trunk/lib/vector/Vlib/write_nat.c
grass/trunk/lib/vector/Vlib/write_pg.c
PG topo support major update
V2__write_line_pg() and V2__write_node_pg() implemented
internal subroutines renamed (use Vect__ prefix)
move some internal subroutines to local_proto.h
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h 2012-11-04 21:34:20 UTC (rev 53685)
+++ grass/trunk/include/defs/vector.h 2012-11-05 09:34:48 UTC (rev 53686)
@@ -541,6 +541,8 @@
const struct line_cats *);
off_t V2_write_line_sfa(struct Map_info *, int, const struct line_pnts *,
+off_t V2_write_line_pg(struct Map_info *, int, const struct line_pnts *,
+ const struct line_cats *);
off_t V1_rewrite_line_nat(struct Map_info *, int, int, off_t,
const struct line_pnts *, const struct line_cats *);
off_t V1_rewrite_line_ogr(struct Map_info *, int, int, off_t,
@@ -551,9 +553,6 @@
off_t V2_rewrite_line_sfa(struct Map_info *, int, int, off_t,
-off_t V2_write_area_pg(struct Map_info *, const struct line_pnts *,
- const struct line_cats *,
- const struct line_pnts **, int);
/* Build topology */
int Vect_build_nat(struct Map_info *, int);
Modified: grass/trunk/lib/vector/Vlib/build_nat.c
--- grass/trunk/lib/vector/Vlib/build_nat.c 2012-11-04 21:34:20 UTC (rev 53685)
+++ grass/trunk/lib/vector/Vlib/build_nat.c 2012-11-05 09:34:48 UTC (rev 53686)
@@ -61,7 +61,7 @@
Cats = Vect_new_cats_struct();
if (plus->built < GV_BUILD_BASE) {
- register int npoints, c;
+ int npoints, c;
* We shall go through all primitives in coor file and add
@@ -78,7 +78,8 @@
/* register line */
type = Vect_read_next_line(Map, Points, Cats);
- /* Note: check for dead lines is not needed, because they are skipped by V1_read_next_line_nat() */
+ /* Note: check for dead lines is not needed, because they
+ are skipped by V1_read_next_line() */
if (type == -1) {
G_warning(_("Unable to read vector map"));
return 0;
Modified: grass/trunk/lib/vector/Vlib/build_pg.c
--- grass/trunk/lib/vector/Vlib/build_pg.c 2012-11-04 21:34:20 UTC (rev 53685)
+++ grass/trunk/lib/vector/Vlib/build_pg.c 2012-11-05 09:34:48 UTC (rev 53686)
@@ -78,8 +78,8 @@
/* commit transaction block (update mode only) */
- if (pg_info->inTransaction && execute(pg_info->conn, "COMMIT") == -1)
- return -1;
+ if (pg_info->inTransaction && Vect__execute_pg(pg_info->conn, "COMMIT") == -1)
+ return 0;
pg_info->inTransaction = FALSE;
@@ -135,13 +135,19 @@
return 0;
+ /* read topology from PostGIS ???
if (load_plus(Map, FALSE) != 0)
return 0;
+ /* build GRASS-like topology from PostGIS topological
+ primitives */
+ if (Vect_build_nat(Map, build) != 1)
+ return 0;
- plus->built = build;
+ /* update PostGIS topology based on GRASS-like topology */
return 1;
#endif
Modified: grass/trunk/lib/vector/Vlib/build_sfa.c
--- grass/trunk/lib/vector/Vlib/build_sfa.c 2012-11-04 21:34:20 UTC (rev 53685)
+++ grass/trunk/lib/vector/Vlib/build_sfa.c 2012-11-05 09:34:48 UTC (rev 53686)
@@ -329,7 +329,7 @@
G_zero(&fparts, sizeof(struct feat_parts));
/* get all features */
- if (set_initial_query(pg_info, TRUE) != 0)
+ if (Vect__set_initial_query_pg(pg_info, TRUE) != 0)
return;
/* scan records */
@@ -345,8 +345,8 @@
G_progress(iFeature + 1, 1e4);
/* cache feature (lines) */
- if (SF_NONE == cache_feature(wkb_data, FALSE, FALSE,
- &(pg_info->cache), &fparts)) {
+ if (SF_NONE == Vect__cache_feature_pg(wkb_data, FALSE, FALSE,
+ &(pg_info->cache), &fparts)) {
G_warning(_("Feature %d without geometry skipped"),
iFeature + 1);
continue;
Modified: grass/trunk/lib/vector/Vlib/close_pg.c
--- grass/trunk/lib/vector/Vlib/close_pg.c 2012-11-04 21:34:20 UTC (rev 53685)
+++ grass/trunk/lib/vector/Vlib/close_pg.c 2012-11-05 09:34:48 UTC (rev 53686)
@@ -61,11 +61,11 @@
sprintf(stmt, "CLOSE %s_%s%p",
pg_info->schema_name, pg_info->table_name, pg_info->conn);
- if (execute(pg_info->conn, stmt) == -1) {
+ if (Vect__execute_pg(pg_info->conn, stmt) == -1) {
G_warning(_("Unable to close cursor"));
return -1;
- execute(pg_info->conn, "COMMIT");
+ Vect__execute_pg(pg_info->conn, "COMMIT");
PQfinish(pg_info->conn);
Modified: grass/trunk/lib/vector/Vlib/copy.c
--- grass/trunk/lib/vector/Vlib/copy.c 2012-11-04 21:34:20 UTC (rev 53685)
+++ grass/trunk/lib/vector/Vlib/copy.c 2012-11-05 09:34:48 UTC (rev 53686)
@@ -18,6 +18,10 @@
#include <grass/vector.h>
#include <grass/glocale.h>
+#ifdef HAVE_POSTGRES
+#include "pg_local_proto.h"
+#endif
static int copy_lines_1(struct Map_info *, int, struct Map_info *);
static int copy_lines_2(struct Map_info *, int, int, struct Map_info *);
static int copy_nodes(const struct Map_info *, struct Map_info *);
@@ -44,7 +48,7 @@
Note: Try to copy on level 2 otherwise level 1 is used.
- \todo Implement V2_write_area_ogr()
+ \todo Implement V2__write_area_ogr()
\param In input vector map
\param field layer number (-1 for all layers)
@@ -283,13 +287,15 @@
if (with_z)
Points->z[0] = z;
- if (-1 == Vect_write_line(Out, GV_POINT, Points, NULL))
- G_fatal_error(_("Unable to export node %d. Exiting."), node);
+ if (-1 == V2__write_node_pg(Out, Points)) {
+ G_warning(_("Writing node %d failed"), node);
+ return 1;
Vect_destroy_line_struct(Points);
- return nnodes;
+ return 0;
@@ -357,9 +363,17 @@
if (ogr)
Vect_write_line(Out, GV_BOUNDARY, Points, Cats);
- else
- V2_write_area_pg(Out, Points, Cats,
- (const struct line_pnts **) IPoints, nisles);
+ else {
+#if HAVE_POSTGRES
+ if (-1 == V2__write_area_pg(Out, Points, Cats,
+ (const struct line_pnts **) IPoints, nisles)) {
+ G_warning(_("Writing area %d failed"), area);
+ return 1;
+#else
+ G_fatal_error(_("GRASS is not compiled with PostgreSQL support"));
+#endif
/* free allocated space for isles */
@@ -369,7 +383,7 @@
Vect_destroy_cats_struct(Cats);
- return nareas;
+ return 0;
Modified: grass/trunk/lib/vector/Vlib/e_intersect.c
--- grass/trunk/lib/vector/Vlib/e_intersect.c 2012-11-04 21:34:20 UTC (rev 53685)
+++ grass/trunk/lib/vector/Vlib/e_intersect.c 2012-11-05 09:34:48 UTC (rev 53686)
@@ -15,7 +15,9 @@
#include <stdlib.h>
#include <math.h>
#include <grass/gis.h>
#include "e_intersect.h"
#define SWAP(a,b) {double t = a; a = b; b = t;}
Added: grass/trunk/lib/vector/Vlib/local_proto.h
--- grass/trunk/lib/vector/Vlib/local_proto.h (rev 0)
+++ grass/trunk/lib/vector/Vlib/local_proto.h 2012-11-05 09:34:48 UTC (rev 53686)
@@ -0,0 +1,9 @@
+#ifndef __LOCAL_PROTO_H__
+#define __LOCAL_PROTO_H__
+#include <grass/vector.h>
+void V2__add_line_to_topo_nat(struct Map_info *, int ,
+ const struct line_pnts *, const struct line_cats *);
+#endif /* PG_LOCAL_PROTO_H__ */
Property changes on: grass/trunk/lib/vector/Vlib/local_proto.h
___________________________________________________________________
Added: svn:mime-type
+ text/x-chdr
Added: svn:eol-style
+ native
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c 2012-11-04 21:34:20 UTC (rev 53685)
+++ grass/trunk/lib/vector/Vlib/open_pg.c 2012-11-05 09:34:48 UTC (rev 53686)
@@ -429,7 +429,7 @@
/* free and init plus structure */
dig_init_plus(plus);
- return load_plus(Map, head_only);
+ return Vect__load_plus_pg(Map, head_only);
#else
return -1;
@@ -566,7 +566,7 @@
pg_info->schema_name, pg_info->table_name);
G_debug(2, "SQL: %s", stmt);
return -1;
@@ -595,7 +595,7 @@
if (!result || PQresultStatus(result) != PGRES_TUPLES_OK) {
PQclear(result);
- execute(pg_info->conn, "ROLLBACK");
+ Vect__execute_pg(pg_info->conn, "ROLLBACK");
return -1;
@@ -610,8 +610,8 @@
if (!found) {
sprintf(stmt, "CREATE SCHEMA %s", pg_info->schema_name);
return -1;
G_warning(_("Schema <%s> doesn't exist, created"),
@@ -768,14 +768,14 @@
strcat(stmt, ")"); /* close CREATE TABLE statement */
/* begin transaction (create table) */
- if (execute(pg_info->conn, "BEGIN") == -1) {
+ if (Vect__execute_pg(pg_info->conn, "BEGIN") == -1) {
return -1;
/* create table */
return -1;
@@ -785,8 +785,8 @@
pg_info->fid_column);
return -1;
@@ -804,7 +804,7 @@
break;
default:
G_warning(_("Unsupported feature type %d"), pg_info->feature_type);
return -1;
@@ -819,7 +819,7 @@
PQclear(result);
return -1;
@@ -834,14 +834,14 @@
pg_info->geom_column);
return -1;
/* close transaction (create table) */
- if (execute(pg_info->conn, "COMMIT") == -1) {
+ if (Vect__execute_pg(pg_info->conn, "COMMIT") == -1) {
return -1;
@@ -899,7 +899,7 @@
/* begin transaction (create topo schema) */
return -1;
@@ -916,7 +916,7 @@
result = PQexec(pg_info->conn, stmt);
G_warning(_("Execution failed: %s"), PQerrorMessage(pg_info->conn));
return -1;
@@ -932,12 +932,12 @@
return -1;
/* close transaction (create topo schema) */
return -1;
@@ -1191,8 +1191,8 @@
PQclear(res);
/* get node coordinates */
- if (SF_POINT != cache_feature(wkb_data, FALSE, FALSE,
- &(pg_info->cache), NULL))
+ if (SF_POINT != Vect__cache_feature_pg(wkb_data, FALSE, FALSE,
+ &(pg_info->cache), NULL))
G_warning(_("Node %d: unexpected feature type %d"),
n, pg_info->cache.sf_type);
@@ -1300,7 +1300,7 @@
/* update spatial index */
- cache_feature(data->wkb_geom, FALSE, FALSE, cache, NULL);
+ Vect__cache_feature_pg(data->wkb_geom, FALSE, FALSE, cache, NULL);
itype = cache->lines_types[0];
if ((line->type & GV_POINTS && itype != GV_POINT) ||
(line->type & GV_LINES && itype != GV_LINE))
@@ -1427,7 +1427,7 @@
\return 0 on success
\return -1 on error
-int load_plus(struct Map_info *Map, int head_only)
+int Vect__load_plus_pg(struct Map_info *Map, int head_only)
int i, id, ntuples;
char stmt[DB_SQL_MAX];
Modified: grass/trunk/lib/vector/Vlib/pg_local_proto.h
--- grass/trunk/lib/vector/Vlib/pg_local_proto.h 2012-11-04 21:34:20 UTC (rev 53685)
+++ grass/trunk/lib/vector/Vlib/pg_local_proto.h 2012-11-05 09:34:48 UTC (rev 53686)
@@ -51,13 +51,18 @@
/* functions used in *_pg.c files */
-int execute(PGconn *, const char *);
-SF_FeatureType cache_feature(const char *, int, int,
- struct Format_info_cache *,
- struct feat_parts *);
-int set_initial_query(struct Format_info_pg *, int);
-int load_plus(struct Map_info *, int);
+int Vect__execute_pg(PGconn *, const char *);
+SF_FeatureType Vect__cache_feature_pg(const char *, int, int,
+ struct Format_info_cache *,
+ struct feat_parts *);
+int Vect__set_initial_query_pg(struct Format_info_pg *, int);
+int Vect__load_plus_pg(struct Map_info *, int);
+off_t V2__write_node_pg(struct Map_info *, const struct line_pnts *);
+off_t V2__write_area_pg(struct Map_info *, const struct line_pnts *,
+ const struct line_cats *,
+ const struct line_pnts **, int);
#endif /* HAVE_POSTGRES */
#endif /* __PG_LOCAL_PROTO_H__ */
Modified: grass/trunk/lib/vector/Vlib/read_pg.c
--- grass/trunk/lib/vector/Vlib/read_pg.c 2012-11-04 21:34:20 UTC (rev 53685)
+++ grass/trunk/lib/vector/Vlib/read_pg.c 2012-11-05 09:34:48 UTC (rev 53686)
@@ -476,7 +476,7 @@
if (fid < 1) {
/* next (read n features) */
if (!pg_info->res) {
- if (set_initial_query(pg_info, FALSE) == -1)
+ if (Vect__set_initial_query_pg(pg_info, FALSE) == -1)
return -1;
@@ -487,7 +487,7 @@
return -1;
return -1;
if (!pg_info->toposchema_name) {
@@ -508,7 +508,7 @@
topotable_name = "edge";
else {
G_warning(_("Unsupported feature type %d"), type);
return -1;
@@ -520,7 +520,7 @@
topotable_name, topotable_name, fid);
return -1;
sprintf(stmt, "FETCH ALL in %s_%s%p",
@@ -547,7 +547,7 @@
pg_info->res = PQexec(pg_info->conn, stmt);
return -1;
pg_info->next_line = 0;
@@ -561,12 +561,12 @@
return -1;
return -2;
@@ -583,9 +583,9 @@
pg_info->cache.sf_type =
- cache_feature(data, FALSE,
- left_face != 0 || right_face != 0 ? TRUE : FALSE,
- &(pg_info->cache), NULL);
+ Vect__cache_feature_pg(data, FALSE,
+ left_face != 0 || right_face != 0 ? TRUE : FALSE,
+ &(pg_info->cache), NULL);
if (fid < 0) {
pg_info->cache.fid =
atoi(PQgetvalue(pg_info->res, pg_info->next_line, 1));
@@ -599,12 +599,12 @@
return -1;
return -1;
@@ -666,10 +666,10 @@
\return simple feature type
\return SF_UNKNOWN on error
-SF_FeatureType cache_feature(const char *data, int skip_polygon,
- int force_boundary,
- struct Format_info_cache *cache,
- struct feat_parts * fparts)
+SF_FeatureType Vect__cache_feature_pg(const char *data, int skip_polygon,
+ int force_boundary,
+ struct Format_info_cache *cache,
+ struct feat_parts * fparts)
int ret, byte_order, nbytes, is3D;
unsigned char *wkb_data;
@@ -691,12 +691,12 @@
if (nbytes < 5) {
/* G_free(wkb_data); */
if (nbytes > 0) {
- G_debug(3, "cache_feature(): invalid geometry");
+ G_debug(3, "Vect__cache_feature_pg(): invalid geometry");
G_warning(_("Invalid WKB content: %d bytes"), nbytes);
return SF_UNKNOWN;
else {
- G_debug(3, "cache_feature(): no geometry");
+ G_debug(3, "Vect__cache_feature_pg(): no geometry");
return SF_NONE;
@@ -745,7 +745,7 @@
ftype = (SF_FeatureType) wkb_data[4];
is3D = wkb_data[1] & 0x80 || wkb_data[3] & 0x80;
- G_debug(3, "cache_feature(): sf_type = %d", ftype);
+ G_debug(3, "Vect__cache_feature_pg(): sf_type = %d", ftype);
/* allocate space in lines cache - be minimalistic
@@ -1130,11 +1130,11 @@
\return -1 on error
-int set_initial_query(struct Format_info_pg *pg_info, int fetch_all)
+int Vect__set_initial_query_pg(struct Format_info_pg *pg_info, int fetch_all)
return -1;
@@ -1164,8 +1164,8 @@
return -1;
@@ -1177,7 +1177,7 @@
G_warning(_("Unable to get features"));
return -1;
@@ -1197,13 +1197,13 @@
\return -1 on error
-int execute(PGconn * conn, const char *stmt)
+int Vect__execute_pg(PGconn * conn, const char *stmt)
PGresult *result;
result = NULL;
- G_debug(3, "execute(): %s", stmt);
+ G_debug(3, "Vect__execute_pg(): %s", stmt);
result = PQexec(conn, stmt);
if (!result || PQresultStatus(result) != PGRES_COMMAND_OK) {
PQclear(result);
@@ -1315,7 +1315,7 @@
data = (char *)PQgetvalue(res, 0, 0);
PQclear(res);
- if (GV_POINT != cache_feature(data, FALSE, FALSE, &(pg_info->cache), NULL))
+ if (GV_POINT != Vect__cache_feature_pg(data, FALSE, FALSE, &(pg_info->cache), NULL))
return -1;
Vect_append_points(line_p, pg_info->cache.lines[0], GV_FORWARD);
Modified: grass/trunk/lib/vector/Vlib/rewind_pg.c
--- grass/trunk/lib/vector/Vlib/rewind_pg.c 2012-11-04 21:34:20 UTC (rev 53685)
+++ grass/trunk/lib/vector/Vlib/rewind_pg.c 2012-11-05 09:34:48 UTC (rev 53686)
@@ -54,11 +54,11 @@
return -1;
return 0;
Modified: grass/trunk/lib/vector/Vlib/write.c
--- grass/trunk/lib/vector/Vlib/write.c 2012-11-04 21:34:20 UTC (rev 53685)
+++ grass/trunk/lib/vector/Vlib/write.c 2012-11-05 09:34:48 UTC (rev 53686)
@@ -81,7 +81,7 @@
#endif
- write_dummy, V1_write_line_pg, V2_write_line_sfa}
+ write_dummy, V1_write_line_pg, V2_write_line_pg}
#else
write_dummy, format_l, format_l}
Modified: grass/trunk/lib/vector/Vlib/write_nat.c
--- grass/trunk/lib/vector/Vlib/write_nat.c 2012-11-04 21:34:20 UTC (rev 53685)
+++ grass/trunk/lib/vector/Vlib/write_nat.c 2012-11-05 09:34:48 UTC (rev 53686)
@@ -22,6 +22,8 @@
+#include "local_proto.h"
static off_t V1__rewrite_line_nat(struct Map_info *, off_t, int,
@@ -133,8 +135,8 @@
\param points pointer to line_pnts structure (feature's geometry)
\param cats pointer to line_cats structure (feature's categories)
-static void V2__add_line_to_topo_nat(struct Map_info *Map, int line,
- const struct line_pnts *points, const struct line_cats *cats)
+void V2__add_line_to_topo_nat(struct Map_info *Map, int line,
+ const struct line_pnts *points, const struct line_cats *cats)
int first, s, n, i;
int type, node, next_line, area, side, sel_area, new_area[2];
@@ -297,11 +299,13 @@
/* Add category index */
- for (i = 0; i < cats->n_cats; i++) {
- dig_cidx_add_cat_sorted(plus, cats->field[i], cats->cat[i], line,
- type);
+ if (cats) {
+ for (i = 0; i < cats->n_cats; i++) {
+ dig_cidx_add_cat_sorted(plus, cats->field[i], cats->cat[i], line,
+ type);
return;
Modified: grass/trunk/lib/vector/Vlib/write_pg.c
--- grass/trunk/lib/vector/Vlib/write_pg.c 2012-11-04 21:34:20 UTC (rev 53685)
+++ grass/trunk/lib/vector/Vlib/write_pg.c 2012-11-05 09:34:48 UTC (rev 53686)
@@ -26,6 +26,8 @@
@@ -34,7 +36,7 @@
static off_t write_line_sf(struct Map_info *, int,
const struct line_pnts **, int,
-static off_t write_line_tp(struct Map_info *, int,
+static off_t write_line_tp(struct Map_info *, int, int,
static char *binary_to_hex(int, const unsigned char *);
static unsigned char *point_to_wkb(int, const struct line_pnts *, int, int *);
@@ -44,10 +46,11 @@
int, int *);
static int write_feature(struct Format_info_pg *,
int, const struct line_pnts **, int, int,
+ const struct P_line *,
int, const struct field_info *);
static char *build_insert_stmt(const struct Format_info_pg *, const char *,
-static char *build_topo_stmt(const struct Format_info_pg *, int,
+static char *build_topo_stmt(struct Format_info_pg *, int,
const struct P_line *, const char *);
static char *build_topogeom_stmt(const struct Format_info_pg *, int, int, int);
static int execute_topo(PGconn *, const char *);
@@ -75,10 +78,22 @@
- if (!Map->fInfo.pg.toposchema_name)
- return write_line_sf(Map, type, &points, 1, cats);
- else
- return write_line_tp(Map, type, points);
+ struct Format_info_pg *pg_info;
+ pg_info = &(Map->fInfo.pg);
+ if (pg_info->feature_type == SF_UNKNOWN) {
+ /* create PostGIS table if doesn't exist */
+ if (V2_open_new_pg(Map, type) < 0)
+ return -1;
+ if (pg_info->toposchema_name) {
+ G_warning(_("PostGIS topology not supported on level 1"));
+ return -1;
+ return write_line_sf(Map, type, &points, 1, cats);
#else
return -1;
@@ -86,6 +101,36 @@
+ \brief Writes feature on level 2 (PostGIS interface)
+ \param Map pointer to Map_info structure
+ \param type feature type (GV_POINT, GV_LINE, ...)
+ \param points pointer to line_pnts structure (feature geometry)
+ \param cats pointer to line_cats structure (feature categories)
+ \return feature offset into file
+ \return -1 on error
+off_t V2_write_line_pg(struct Map_info *Map, int type,
+ const struct line_cats *cats)
+ if (!pg_info->toposchema_name) /* pseudo-topology */
+ return V2_write_line_sfa(Map, type, points, cats);
+ else /* PostGIS topology */
+ return write_line_tp(Map, type, FALSE, points);
+#else
+ return -1;
+#endif
\brief Rewrites feature at the given offset (level 1) (PostGIS interface)
@@ -157,7 +202,7 @@
if (!pg_info->inTransaction) {
/* start transaction */
pg_info->inTransaction = TRUE;
return -1;
@@ -165,9 +210,9 @@
pg_info->table_name, pg_info->fid_column, fid);
G_warning(_("Unable to delete feature"));
return -1;
@@ -179,9 +224,35 @@
- \brief Writes area on level 2 (PostGIS interface)
+ \brief Writes node on level 2 (PostGIS Topology interface) - internal use only
+ \return 0 on success
+off_t V2__write_node_pg(struct Map_info *Map, const struct line_pnts *points)
+ return -1; /* PostGIS Topology required */
+ return write_line_tp(Map, GV_POINT, TRUE, points);
+#else
+ return -1;
+#endif
+ \brief Writes area on level 2 (PostGIS Simple Features interface) - internal use only
\param points pointer to line_pnts structure (boundary geometry)
@@ -190,11 +261,11 @@
\return -1 on error
-off_t V2_write_area_pg(struct Map_info *Map,
- const struct line_pnts *bpoints,
- const struct line_cats *cats,
- const struct line_pnts **ipoints, int nisles)
+off_t V2__write_area_pg(struct Map_info *Map,
+ const struct line_pnts *bpoints,
+ const struct line_cats *cats,
+ const struct line_pnts **ipoints, int nisles)
int i;
@@ -224,6 +295,12 @@
+ \brief Write vector features as PostGIS simple feature element
off_t write_line_sf(struct Map_info *Map, int type,
const struct line_pnts **points, int nparts,
@@ -240,22 +317,22 @@
offset_info = &(pg_info->offset);
+ /* check required PG settings */
if (!pg_info->conn) {
G_warning(_("No connection defined"));
return -1;
if (!pg_info->table_name) {
G_warning(_("PostGIS feature table not defined"));
return -1;
- /* create PostGIS table if doesn't exist */
return -1;
Fi = NULL; /* no attributes to be written */
cat = -1;
if (cats->n_cats > 0 && Vect_get_num_dblinks(Map) > 0) {
@@ -324,8 +401,8 @@
/* write feature's geometry and fid */
if (-1 == write_feature(pg_info, type, points, nparts,
- Vect_is_3d(Map) ? WITH_Z : WITHOUT_Z, cat, Fi)) {
+ Vect_is_3d(Map) ? WITH_Z : WITHOUT_Z, NULL, cat, Fi)) {
return -1;
@@ -336,7 +413,6 @@
offset_info->array_alloc *
sizeof(int));
offset = offset_info->array_num;
offset_info->array[offset_info->array_num++] = cat;
@@ -350,25 +426,50 @@
return offset;
-off_t write_line_tp(struct Map_info *Map, int type,
+ \brief Write vector feature in PostGIS topology schema and
+ updates internal topology structures
+ \param Map vector map
+ \param type feature type to be written
+ \param points feature geometry
+ \param is_node TRUE for nodes (written as points)
+off_t write_line_tp(struct Map_info *Map, int type, int is_node,
+ struct Plus_head *plus;
+ struct P_line *Line;
+ plus = &(Map->plus);
+ /* check type for nodes */
+ if (is_node && type != GV_POINT) {
+ G_warning(_("Invalid type (%d) for nodes"), type);
+ return -1;
return -1;
return -1;
+ if (!pg_info->toposchema_name) {
+ G_warning(_("PostGIS topology schema not defined"));
+ return -1;
return -1;
@@ -376,10 +477,32 @@
G_debug(3, "write_line_pg(): type = %d n_points = %d",
type, points->n_points);
- /* write feature's geometry and fid */
+ /* update topology before writing feature */
+ Line = NULL;
+ if (is_node) {
+ dig_add_node(plus, points->x[0], points->y[0], points->z[0]);
+ else {
+ int line;
+ struct bound_box box;
+ dig_line_box(points, &box);
+ line = dig_add_line(plus, type, points, &box, 0); /* offset ? */
+ G_debug(3, " line added to topo with id = %d", line);
+ if (line == 1)
+ Vect_box_copy(&(plus->box), &box);
+ else
+ Vect_box_extend(&(plus->box), &box);
+ V2__add_line_to_topo_nat(Map, line, points, NULL); /* cats ? */
+ Line = plus->Line[line];
+ /* write feature geometry and fid */
if (-1 == write_feature(pg_info, type, &points, 1,
- Vect_is_3d(Map) ? WITH_Z : WITHOUT_Z, -1, NULL)) {
+ Vect_is_3d(Map) ? WITH_Z : WITHOUT_Z, Line,
+ -1, NULL)) {
return -1;
@@ -673,8 +796,9 @@
\retirn 0 on success
int write_feature(struct Format_info_pg *pg_info, int type,
- const struct line_pnts **points, int nparts,
- int with_z, int cat, const struct field_info *Fi)
+ const struct line_pnts **points, int nparts, int with_z,
+ const struct P_line *Line,
+ int cat, const struct field_info *Fi)
int byte_order, nbytes, nsize;
unsigned int sf_type;
@@ -776,43 +900,38 @@
return -1;
/* stmt can NULL when writing PostGIS topology with no attributes
* attached */
- if (stmt && execute(pg_info->conn, stmt) == -1) {
+ if (stmt && Vect__execute_pg(pg_info->conn, stmt) == -1) {
/* rollback transaction */
return -1;
G_free(stmt);
/* write feature in PostGIS topology schema if enabled */
- int id, do_update;
- do_update = stmt ? TRUE : FALSE; /* update or insert new record
- to the feature table */
/* insert feature into topology schema (node or edge) */
- stmt = build_topo_stmt(pg_info, type, NULL, text_data);
- id = execute_topo(pg_info->conn, stmt);
- if (id == -1) {
+ stmt = build_topo_stmt(pg_info, type, Line, text_data);
return -1;
G_free(stmt);
- /* insert topoelement into feature table) */
+ /* insert topoelement into feature table
stmt = build_topogeom_stmt(pg_info, id, type, do_update);
return -1;
G_free(stmt);
G_free(wkb_data);
@@ -981,7 +1100,7 @@
\return pointer to allocated string buffer with SQL statement
\return NULL on error
-char *build_topo_stmt(const struct Format_info_pg *pg_info, int type,
+char *build_topo_stmt(struct Format_info_pg *pg_info, int type,
const struct P_line *Line, const char *geom_data)
char *stmt;
@@ -989,7 +1108,7 @@
stmt = NULL;
switch(type) {
case GV_POINT: {
-#if 0
+#if 1
G_asprintf(&stmt, "INSERT INTO \"%s\".node (geom) VALUES ('%s'::GEOMETRY)",
pg_info->toposchema_name, geom_data);
#else
@@ -999,17 +1118,19 @@
break;
case GV_LINE: {
- struct P_topo_l *topo;
+ if (!Line) {
+ G_warning(_("Topology not available. Unable to insert new edge."));
+ return NULL;
- topo = (struct P_topo_l *) Line->topo;
- G_asprintf(&stmt, "INSERT INTO \"%s\".edge_data (geom,"
- "start_node,end_node,"
- "next_left_edge,abs_next_left_edge,"
- "next_right_edge,abs_next_right_edge,"
- "left_face,right_face) "
- "VALUES ('%s'::GEOMETRY,%d,%d,0,0,0,0,0,0)",
- pg_info->toposchema_name, geom_data,
- topo->N1, topo->N2);
+ struct P_topo_l *topo = (struct P_topo_l *) Line->topo;
+ G_asprintf(&stmt, "INSERT INTO \"%s\".edge_data (geom, start_node, end_node, "
+ "next_left_edge, next_right_edge, abs_next_left_edge, abs_next_right_edge, "
+ "left_face, right_face) "
+ "VALUES ('%s'::GEOMETRY, %d, %d, %d, %d, %d, %d, %d, %d)",
+ pg_info->toposchema_name, geom_data, topo->N1, topo->N2, 0, 0, 0, 0, 0, 0);
break;
case GV_CENTROID: {
@@ -1025,7 +1146,7 @@
break;
default:
- G_warning(_("Unsupported feature type %d"), Line->type);
+ G_warning(_("Unsupported feature type %d"), type);
break;
