[GRASS-SVN] r53759 - grass/trunk/vector/v.hull
svn_grass at osgeo.org
Fri Nov 9 13:18:11 PST 2012
Author: mmetz
Date: 2012-11-09 13:18:10 -0800 (Fri, 09 Nov 2012)
New Revision: 53759
grass/trunk/vector/v.hull/Makefile
grass/trunk/vector/v.hull/hull.h
grass/trunk/vector/v.hull/main.c
grass/trunk/vector/v.hull/read.c
v.hull: remove -a flag, add -r flag and cats and where options
Modified: grass/trunk/vector/v.hull/Makefile
--- grass/trunk/vector/v.hull/Makefile 2012-11-09 18:51:23 UTC (rev 53758)
+++ grass/trunk/vector/v.hull/Makefile 2012-11-09 21:18:10 UTC (rev 53759)
@@ -2,8 +2,8 @@
PGM = v.hull
-LIBES = $(VECTORLIB) $(GISLIB)
-DEPENDENCIES = $(VECTORDEP) $(GISDEP)
+LIBES = $(VECTORLIB) $(DBMILIB) $(GISLIB)
+DEPENDENCIES = $(VECTORDEP) $(DBMIDEP) $(GISDEP)
EXTRA_INC = $(VECT_INC)
EXTRA_CFLAGS = $(VECT_CFLAGS)
Modified: grass/trunk/vector/v.hull/hull.h
--- grass/trunk/vector/v.hull/hull.h 2012-11-09 18:51:23 UTC (rev 53758)
+++ grass/trunk/vector/v.hull/hull.h 2012-11-09 21:18:10 UTC (rev 53759)
@@ -9,8 +9,11 @@
#define ALLOC_CHUNK 256
+struct cat_list *parse_filter_options(struct Map_info *, int , char *,
+ char *);
int loadSiteCoordinates(struct Map_info *, struct Point **, int,
- struct Cell_head *, int);
+ struct Cell_head *, int, struct cat_list *);
int convexHull(struct Point *, int, int **);
Modified: grass/trunk/vector/v.hull/main.c
--- grass/trunk/vector/v.hull/main.c 2012-11-09 18:51:23 UTC (rev 53758)
+++ grass/trunk/vector/v.hull/main.c 2012-11-09 21:18:10 UTC (rev 53759)
@@ -31,9 +31,11 @@
int main(int argc, char **argv)
struct GModule *module;
- struct Option *input, *output, *field;
- struct Flag *all, *flat;
+ struct Option *input, *output, *field, *cats_opt, *where_opt;
+ struct Flag *region_flag, *flat;
struct Cell_head window;
+ int layer;
+ struct cat_list *cat_list = NULL;
char *sitefile;
@@ -58,11 +60,14 @@
output = G_define_standard_option(G_OPT_V_OUTPUT);
- all = G_define_flag();
- all->key = 'a';
- all->description =
- _("Use all vector points (do not limit to current region)");
+ cats_opt = G_define_standard_option(G_OPT_V_CATS);
+ where_opt = G_define_standard_option(G_OPT_DB_WHERE);
+ region_flag = G_define_flag();
+ region_flag->key = 'r';
+ region_flag->description = _("Limit to current region");
flat = G_define_flag();
flat->key = 'f';
flat->description =
@@ -80,17 +85,21 @@
if (Vect_open_old2(&Map, sitefile, "", field->answer) < 0)
G_fatal_error(_("Unable to open vector map <%s>"), sitefile);
+ layer = Vect_get_field_number(&Map, field->answer);
+ cat_list = parse_filter_options(&Map, layer, where_opt->answer,
+ cats_opt->answer);
/* load site coordinates */
G_get_window(&window);
- numSitePoints = loadSiteCoordinates(&Map, &points, all->answer, &window,
- Vect_get_field_number(&Map, field->answer));
+ numSitePoints = loadSiteCoordinates(&Map, &points, region_flag->answer, &window,
+ layer, cat_list);
if (numSitePoints < 0)
G_fatal_error(_("Error loading vector points from <%s>"), sitefile);
if (numSitePoints < 3)
G_fatal_error(_("Convex hull calculation requires at least three points (%d found)"), numSitePoints);
- G_verbose_message(_("%d points read from vector map <%s>"), sitefile);
+ G_verbose_message(_("%d points read from vector map <%s>"), numSitePoints, sitefile);
/* create a 2D or a 3D hull? */
MODE2D = 1;
@@ -101,7 +110,10 @@
MODE2D = 1;
- /* create vector map */
+ /* close input vector */
+ Vect_close(&Map);
+ /* create output vector map */
if (0 > Vect_open_new(&Map, output->answer, MODE2D ? WITHOUT_Z : WITH_Z)) {
G_fatal_error(_("Unable to create vector map <%s>"), output->answer);
Modified: grass/trunk/vector/v.hull/read.c
--- grass/trunk/vector/v.hull/read.c 2012-11-09 18:51:23 UTC (rev 53758)
+++ grass/trunk/vector/v.hull/read.c 2012-11-09 21:18:10 UTC (rev 53759)
@@ -1,9 +1,11 @@
#include <grass/gis.h>
+#include <grass/dbmi.h>
+#include <grass/glocale.h>
#include "hull.h"
-int loadSiteCoordinates(struct Map_info *Map, struct Point **points, int all,
- struct Cell_head *window, int field)
+int loadSiteCoordinates(struct Map_info *Map, struct Point **points, int region,
+ struct Cell_head *window, int field, struct cat_list *cat_list)
int i, pointIdx;
struct line_pnts *sites;
@@ -25,14 +27,28 @@
if (type != GV_POINT && !(type & GV_LINES))
continue;
- if (field != -1 && Vect_cat_get(cats, field, &cat) == 0)
+ if (cat_list) {
+ int found = 0;
+ for (i = 0; i < cats->n_cats; i++) {
+ if (cats->field[i] == field &&
+ Vect_cat_in_cat_list(cats->cat[i], cat_list)) {
+ found = 1;
+ break;
+ if (!found)
+ continue;
+ else if (field > 0 && Vect_cat_get(cats, field, &cat) == 0)
continue;
for (i = 0; i < sites->n_points; i++) {
G_debug(4, "Point: %f|%f|%f|#%d", sites->x[i], sites->y[i],
sites->z[i], cat);
- if (!all && !Vect_point_in_box(sites->x[i], sites->y[i], sites->z[i], &box))
+ if (region && !Vect_point_in_box(sites->x[i], sites->y[i], sites->z[i], &box))
continue;
G_debug(4, "Point in the box");
@@ -54,3 +70,94 @@
return pointIdx;
+static int cmp_int(const void *a, const void *b)
+ int ai = *(int *)a;
+ int bi = *(int *)b;
+ return (ai < bi ? -1 : (ai > bi));
+/* parse filter options */
+/* return cat list or NULL */
+struct cat_list *parse_filter_options(struct Map_info *Map, int layer,
+ char *where, char *cats)
+ struct cat_list *list = NULL;
+ if (where) {
+ struct field_info *Fi = NULL;
+ dbDriver *driver = NULL;
+ int ncats, *cats = NULL;
+ int i, j;
+ if (layer < 1)
+ G_fatal_error(_("'%s' must be > 0 for '%s'"), "layer", "where");
+ if (cats)
+ G_warning(_("'where' and 'cats' parameters were supplied, cat will be ignored"));
+ Fi = Vect_get_field(Map, layer);
+ if (!Fi) {
+ G_fatal_error(_("Database connection not defined for layer %d"),
+ layer);
+ G_verbose_message(_("Loading categories from table <%s>..."), Fi->table);
+ driver = db_start_driver_open_database(Fi->driver, Fi->database);
+ if (driver == NULL)
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+ Fi->database, Fi->driver);
+ ncats = db_select_int(driver, Fi->table, Fi->key, where,
+ &cats);
+ if (ncats == -1)
+ G_fatal_error(_("Unable select records from table <%s>"),
+ Fi->table);
+ G_verbose_message(_("%d categories loaded"), ncats);
+ db_close_database_shutdown_driver(driver);
+ /* sort */
+ qsort(cats, ncats, sizeof(int), cmp_int);
+ /* remove duplicates */
+ j = 1;
+ for (i = 1; i < ncats; i++) {
+ if (cats[i] != cats[j - 1]) {
+ cats[j] = cats[i];
+ j++;
+ ncats = j;
+ /* convert to cat list */
+ list = Vect_new_cat_list();
+ Vect_array_to_cat_list(cats, ncats, list);
+ if (cats)
+ G_free(cats);
+ else if (cats) {
+ if (layer < 1)
+ G_fatal_error(_("'%s' must be > 0 for '%s'"), "layer", GV_KEY_COLUMN);
+ if (Vect_str_to_cat_list(cats, list) > 0) {
+ G_warning(_("Problem loading category values"));
+ if (list) {
+ if (list->n_ranges < 1) {
+ Vect_destroy_cat_list(list);
+ list = NULL;
+ return list;
