[GRASS-SVN] r53760 - grass/trunk/vector/v.buffer
svn_grass at osgeo.org
Fri Nov 9 13:19:36 PST 2012
Author: mmetz
Date: 2012-11-09 13:19:36 -0800 (Fri, 09 Nov 2012)
New Revision: 53760
grass/trunk/vector/v.buffer/main.c
v.buffer: add cats and where selection options
Modified: grass/trunk/vector/v.buffer/main.c
--- grass/trunk/vector/v.buffer/main.c 2012-11-09 21:18:10 UTC (rev 53759)
+++ grass/trunk/vector/v.buffer/main.c 2012-11-09 21:19:36 UTC (rev 53760)
@@ -180,6 +180,98 @@
return inside;
+static int cmp_int(const void *a, const void *b)
+ int ai = *(int *)a;
+ int bi = *(int *)b;
+ return (ai < bi ? -1 : (ai > bi));
+/* parse filter options */
+/* return cat list or NULL */
+struct cat_list *parse_filter_options(struct Map_info *Map, int layer,
+ char *where, char *cats)
+ struct cat_list *list = NULL;
+ if (where) {
+ struct field_info *Fi = NULL;
+ dbDriver *driver = NULL;
+ int ncats, *cats = NULL;
+ int i, j;
+ if (layer < 1)
+ G_fatal_error(_("'%s' must be > 0 for '%s'"), "layer", "where");
+ if (cats)
+ G_warning(_("'where' and 'cats' parameters were supplied, cat will be ignored"));
+ Fi = Vect_get_field(Map, layer);
+ if (!Fi) {
+ G_fatal_error(_("Database connection not defined for layer %d"),
+ layer);
+ G_verbose_message(_("Loading categories from table <%s>..."), Fi->table);
+ driver = db_start_driver_open_database(Fi->driver, Fi->database);
+ if (driver == NULL)
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+ Fi->database, Fi->driver);
+ ncats = db_select_int(driver, Fi->table, Fi->key, where,
+ &cats);
+ if (ncats == -1)
+ G_fatal_error(_("Unable select records from table <%s>"),
+ Fi->table);
+ G_verbose_message(_("%d categories loaded"), ncats);
+ db_close_database_shutdown_driver(driver);
+ /* sort */
+ qsort(cats, ncats, sizeof(int), cmp_int);
+ /* remove duplicates */
+ j = 1;
+ for (i = 1; i < ncats; i++) {
+ if (cats[i] != cats[j - 1]) {
+ cats[j] = cats[i];
+ j++;
+ ncats = j;
+ /* convert to cat list */
+ list = Vect_new_cat_list();
+ Vect_array_to_cat_list(cats, ncats, list);
+ if (cats)
+ G_free(cats);
+ else if (cats) {
+ if (layer < 1)
+ G_fatal_error(_("'%s' must be > 0 for '%s'"), "layer", GV_KEY_COLUMN);
+ if (Vect_str_to_cat_list(cats, list) > 0) {
+ G_warning(_("Problem loading category values"));
+ if (list) {
+ if (list->n_ranges < 1) {
+ Vect_destroy_cat_list(list);
+ list = NULL;
+ return list;
int main(int argc, char *argv[])
struct Map_info In, Out, Buf;
@@ -188,10 +280,12 @@
char bufname[GNAME_MAX];
struct GModule *module;
struct Option *in_opt, *out_opt, *type_opt, *dista_opt, *distb_opt,
- *angle_opt;
+ *angle_opt;
struct Flag *straight_flag, *nocaps_flag, *cats_flag;
- struct Option *tol_opt, *bufcol_opt, *scale_opt, *field_opt;
+ struct Option *tol_opt, *bufcol_opt, *scale_opt, *field_opt,
+ *where_opt, *cats_opt;
+ struct cat_list *cat_list = NULL;
int verbose;
double da, db, dalpha, tolerance, unit_tolerance;
int type;
@@ -228,6 +322,12 @@
field_opt = G_define_standard_option(G_OPT_V_FIELD_ALL);
field_opt->guisection = _("Selection");
+ cats_opt = G_define_standard_option(G_OPT_V_CATS);
+ cats_opt->guisection = _("Selection");
+ where_opt = G_define_standard_option(G_OPT_DB_WHERE);
+ where_opt->guisection = _("Selection");
type_opt = G_define_standard_option(G_OPT_V_TYPE);
type_opt->options = "point,line,boundary,centroid,area";
type_opt->answer = "point,line,area";
@@ -316,6 +416,9 @@
field = Vect_get_field_number(&In, field_opt->answer);
else
field = -1;
+ cat_list = parse_filter_options(&In, field, where_opt->answer,
+ cats_opt->answer);
if (bufcol_opt->answer && field == -1)
G_fatal_error(_("The bufcol option requires a valid layer."));
@@ -464,7 +567,22 @@
continue;
Vect_read_line(&In, NULL, Cats, centroid);
- if (field > 0 && !Vect_cat_get(Cats, field, &cat))
+ if (cat_list) {
+ int found = 0;
+ for (i = 0; i < Cats->n_cats; i++) {
+ if (Cats->field[i] == field &&
+ Vect_cat_in_cat_list(Cats->cat[i], cat_list)) {
+ found = 1;
+ break;
+ if (!found)
+ continue;
+ else if (field > 0 && !Vect_cat_get(Cats, field, &cat))
continue;
Vect_reset_cats(CCats);
@@ -568,7 +686,21 @@
if (!(ltype & type))
continue;
+ if (cat_list) {
+ int found = 0;
+ found = 1;
+ break;
+ if (!found)
+ continue;
continue;
