[GRASS-SVN] r53761 - grass/trunk/vector/v.distance
Fri Nov 9 13:44:31 PST 2012
Author: mmetz
Date: 2012-11-09 13:44:31 -0800 (Fri, 09 Nov 2012)
New Revision: 53761
   grass/trunk/vector/v.distance/main.c
v.distance: fix to_column bug
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c	2012-11-09 21:19:36 UTC (rev 53760)
+++ grass/trunk/vector/v.distance/main.c	2012-11-09 21:44:31 UTC (rev 53761)
@@ -438,6 +438,7 @@
     to_driver = NULL;
     toFi = NULL;
     if (opt.to_column->answer) {
 	toFi = Vect_get_field(&To, to_field);
 	if (toFi == NULL)
 	    G_fatal_error(_("Database connection not defined for layer %d"),
@@ -484,6 +485,17 @@
 	    if (fcname) {
+		Fi = Vect_get_field(&From, from_field);
+		if (Fi == NULL)
+		    G_fatal_error(_("Database connection not defined for layer <%s>"),
+				  opt.from_field->answer);
+		driver = db_start_driver_open_database(Fi->driver, Fi->database);
+		if (driver == NULL)
+		    G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+				  Fi->database, Fi->driver);
 		fctype = db_column_Ctype(driver, Fi->table, fcname);
 		tctype =
 		    db_column_Ctype(to_driver, toFi->table,
@@ -499,8 +511,12 @@
 		    G_fatal_error(_("Incompatible column types"));
+		/* close db connection */
+		db_close_database_shutdown_driver(driver);
+		driver = NULL;
 	db_close_database_shutdown_driver(to_driver);
 	to_driver = NULL;
