[GRASS-SVN] r53770 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sun Nov 11 10:45:37 PST 2012
Author: mmetz
Date: 2012-11-11 10:45:36 -0800 (Sun, 11 Nov 2012)
New Revision: 53770
grass/trunk/lib/vector/Vlib/intersect.c
Vlib: optimization
Modified: grass/trunk/lib/vector/Vlib/intersect.c
--- grass/trunk/lib/vector/Vlib/intersect.c 2012-11-11 18:43:43 UTC (rev 53769)
+++ grass/trunk/lib/vector/Vlib/intersect.c 2012-11-11 18:45:36 UTC (rev 53770)
@@ -83,7 +83,7 @@
#if 0
static int ident(double x1, double y1, double x2, double y2, double thresh);
#endif
-static int cross_seg(int id, struct RTree_Rect rect, int *arg);
+static int cross_seg(int id, const struct RTree_Rect *rect, int *arg);
static int find_cross(int id, const struct RTree_Rect *rect, int *arg);
#define D ((ax2-ax1)*(by1-by2) - (ay2-ay1)*(bx1-bx2))
@@ -182,8 +182,8 @@
* Can it be a problem to set the tolerance to 0.0 ? */
dtol = 0.0;
if (fabs(d) > dtol) {
- r1 = D1 / d;
- r2 = D2 / d;
+ r1 = d1 / d;
+ r2 = d2 / d;
G_debug(2, " -> not parallel/collinear: r1 = %f, r2 = %f", r1, r2);
@@ -203,7 +203,7 @@
/* segments are parallel or collinear */
G_debug(3, " -> parallel/collinear");
- if (D1 || D2) { /* lines are parallel */
+ if (d1 || d2) { /* lines are parallel */
G_debug(2, " -> parallel");
return 0;
@@ -542,7 +542,7 @@
static struct line_pnts *APnts, *BPnts;
/* break segments (called by rtree search) */
double x1, y1, z1, x2, y2, z2;
int i, j, ret;
@@ -693,6 +693,7 @@
/* Create rtree for B line */
MyRTree = RTreeCreateTree(-1, 0, 2);
+ RTreeSetOverflow(MyRTree, 0);
for (i = 0; i < BPoints->n_points - 1; i++) {
if (BPoints->x[i] <= BPoints->x[i + 1]) {
rect.boundary[0] = BPoints->x[i];
@@ -767,6 +768,7 @@
/* Snap breaks to nearest vertices within RE threshold */
+ /* Calculate distances along segments */
for (i = 0; i < n_cross; i++) {
/* 1. of A seg */
seg = cross[i].segment[0];
@@ -775,6 +777,8 @@
x = APoints->x[seg];
y = APoints->y[seg];
+ cross[i].distance[0] = curdist;
/* 2. of A seg */
dist =
dist2(cross[i].x, cross[i].y, APoints->x[seg + 1],
@@ -789,12 +793,15 @@
seg = cross[i].segment[1];
dist =
dist2(cross[i].x, cross[i].y, BPoints->x[seg], BPoints->y[seg]);
+ cross[i].distance[1] = dist;
if (dist < curdist) {
curdist = dist;
x = BPoints->x[seg];
y = BPoints->y[seg];
- dist = dist2(cross[i].x, cross[i].y, BPoints->x[seg + 1], BPoints->y[seg + 1]); /* 2. of B seg */
+ /* 2. of B seg */
+ dist = dist2(cross[i].x, cross[i].y, BPoints->x[seg + 1], BPoints->y[seg + 1]);
curdist = dist;
x = BPoints->x[seg + 1];
@@ -803,19 +810,17 @@
if (curdist < rethresh * rethresh) {
cross[i].x = x;
cross[i].y = y;
+ /* Update distances along segments */
+ seg = cross[i].segment[0];
+ dist2(APoints->x[seg], APoints->y[seg], cross[i].x, cross[i].y);
+ seg = cross[i].segment[1];
+ dist2(BPoints->x[seg], BPoints->y[seg], cross[i].x, cross[i].y);
- /* Calculate distances along segments */
- for (i = 0; i < n_cross; i++) {
- seg = cross[i].segment[0];
- cross[i].distance[0] =
- dist2(APoints->x[seg], APoints->y[seg], cross[i].x, cross[i].y);
- seg = cross[i].segment[1];
- cross[i].distance[1] =
- dist2(BPoints->x[seg], BPoints->y[seg], cross[i].x, cross[i].y);
/* l = 1 ~ line A, l = 2 ~ line B */
for (l = 1; l < 3; l++) {
@@ -1240,6 +1245,7 @@
