[GRASS-SVN] r53771 - in grass/trunk: gui/wxpython/gui_core lib/python/temporal
svn_grass at osgeo.org
Sun Nov 11 12:12:42 PST 2012
Author: annakrat
Date: 2012-11-11 12:12:41 -0800 (Sun, 11 Nov 2012)
New Revision: 53771
grass/trunk/gui/wxpython/gui_core/gselect.py
grass/trunk/lib/python/temporal/space_time_datasets_tools.py
wxGUI: distinguish dataset types (strds, stvds, ...) in gselect
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py 2012-11-11 18:45:36 UTC (rev 53770)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py 2012-11-11 20:12:41 UTC (rev 53771)
@@ -329,11 +329,11 @@
'stvds':'stvds'}
if element not in elementdict:
- self.AddItem(_('Not selectable element'))
+ self.AddItem(_('Not selectable element'), node = False)
return
if element in ('stds', 'strds', 'str3ds', 'stvds'):
- filesdict = tgis.tlist_grouped(elementdict[element])
+ filesdict = tgis.tlist_grouped(elementdict[element], element == 'stds')
else:
if globalvar.have_mlist:
filesdict = grass.mlist_grouped(elementdict[element],
@@ -353,7 +353,8 @@
first_mapset = None
for mapset in mapsets:
- mapset_node = self.AddItem(_('Mapset') + ': ' + mapset)
+ mapset_node = self.AddItem(_('Mapset') + ': ' + mapset, node = True, mapset = mapset)
+ node = mapset_node
if not first_mapset:
first_mapset = mapset_node
@@ -361,21 +362,18 @@
if mapset not in filesdict:
continue
try:
- elem_list = filesdict[mapset]
- elem_list.sort()
- for elem in elem_list:
- if elem != '':
- fullqElem = elem + '@' + mapset
- if elements is not None:
- if (exclude and fullqElem in elements) or \
- (not exclude and fullqElem not in elements):
- continue
- if self.filterElements:
- if self.filterElements(fullqElem):
- self.AddItem(elem, parent = mapset_node)
- else:
+ if type(filesdict[mapset]) == dict:
+ for elementType in filesdict[mapset].keys():
+ node = self.AddItem(_('Type: ') + elementType, mapset = mapset,
+ node = True, parent = mapset_node)
+ self.seltree.SetItemTextColour(node, wx.Colour(50, 50, 200))
+ elem_list = filesdict[mapset][elementType]
+ self._addItems(elist = elem_list, elements = elements,
+ mapset = mapset, exclude = exclude, node = node)
+ else:
except StandardError, e:
sys.stderr.write(_("GSelect: invalid item: %s") % e)
continue
@@ -400,15 +398,39 @@
collapse = False
if collapse:
- self.seltree.Collapse(mapset_node)
+ self.seltree.CollapseAllChildren(mapset_node)
else:
- self.seltree.Expand(mapset_node)
+ self.seltree.ExpandAllChildren(mapset_node)
if first_mapset:
# select first mapset (MSW hack)
self.seltree.SelectItem(first_mapset)
# helpers
+ def _addItems(self, elist, elements, mapset, exclude, node):
+ """!Helper function for adding multiple items (maps, stds).
+ @param elist list of map/stds names
+ @param elements list of forced elements
+ @param mapset mapset name
+ @param exclude True to exclude, False for forcing the list
+ @param node parent node
+ elist.sort()
+ for elem in elist:
+ if elem != '':
+ fullqElem = elem + '@' + mapset
+ if elements is not None:
+ if (exclude and fullqElem in elements) or \
+ (not exclude and fullqElem not in elements):
+ continue
+ if self.filterElements:
+ if self.filterElements(fullqElem):
+ self.AddItem(elem, mapset = mapset, node = False, parent = node)
+ else:
def FindItem(self, parentItem, text, startLetters = False):
"""!Finds item with given name or starting with given text"""
startletters = startLetters
@@ -425,14 +447,15 @@
item, cookie = self.seltree.GetNextChild(parentItem, cookie)
return wx.TreeItemId()
- def AddItem(self, value, parent=None):
+ def AddItem(self, value, mapset = None, node = True, parent = None):
if not parent:
root = self.seltree.GetRootItem()
if not root:
root = self.seltree.AddRoot("<hidden root>")
parent = root
- item = self.seltree.AppendItem(parent, text=value)
+ data = {'node': node, 'mapset': mapset}
+ item = self.seltree.AppendItem(parent, text = value, data = wx.TreeItemData(data))
return item
# able to recieve only wx.EVT_KEY_UP
@@ -482,13 +505,12 @@
self.Dismiss()
elif event.GetKeyCode() == wx.WXK_RETURN:
- if self.seltree.GetRootItem() == self.seltree.GetItemParent(item):
- self.value = []
+ if self.seltree.GetPyData(item)['node']:
+ self.value = []
else:
- mapsetItem = self.seltree.GetItemParent(item)
fullName = self.seltree.GetItemText(item)
if self.fullyQualified:
- fullName += '@' + self.seltree.GetItemText(mapsetItem).split(':', -1)[1].strip()
+ fullName += '@' + self.seltree.GetPyData(item)['mapset']
if self.multiple:
self.value.append(fullName)
@@ -519,14 +541,13 @@
if item and flags & wx.TREE_HITTEST_ONITEMLABEL:
self.curitem = item
evt.Skip()
return
if self.multiple:
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-11-11 18:45:36 UTC (rev 53770)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-11-11 20:12:41 UTC (rev 53771)
@@ -729,7 +729,7 @@
-def tlist_grouped(type):
+def tlist_grouped(type, group_type = False):
"""!List of temporal elements grouped by mapsets.
Returns a dictionary where the keys are mapset
@@ -765,11 +765,20 @@
except ValueError:
warning(_("Invalid element '%s'") % line)
continue
- if mapset in result:
+ if mapset not in result:
+ if group_type:
+ result[mapset] = {}
+ else:
+ result[mapset] = []
+ if group_type:
+ if type in result[mapset]:
+ result[mapset][type].append(name)
+ else:
+ result[mapset][type] = [name, ]
+ else:
result[mapset].append(name)
- else:
- result[mapset] = [name, ]
return result
