[GRASS-SVN] r53778 - grass/branches/develbranch_6
svn_grass at osgeo.org
Mon Nov 12 08:33:54 PST 2012
Author: martinl
Date: 2012-11-12 08:33:53 -0800 (Mon, 12 Nov 2012)
New Revision: 53778
grass/branches/develbranch_6/configure
grass/branches/develbranch_6/configure.in
X11/Xmu/Xmu.h is required by Nviz
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure 2012-11-12 16:17:36 UTC (rev 53777)
+++ grass/branches/develbranch_6/configure 2012-11-12 16:33:53 UTC (rev 53778)
@@ -10726,7 +10726,7 @@
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$OPENGLINC $X_CFLAGS $CPPFLAGS"
-for ac_hdr in GL/gl.h GL/glu.h
+for ac_hdr in GL/gl.h GL/glu.h X11/Xmu/Xmu.h
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
@@ -15611,58 +15611,7 @@
fi
fi
-for ac_declaration in \
- '#include <stdlib.h>' \
- 'extern "C" void std::exit (int) throw (); using std::exit;' \
- 'extern "C" void std::exit (int); using std::exit;' \
- 'extern "C" void exit (int) throw ();' \
- 'extern "C" void exit (int);' \
- 'void exit (int);'
-do
- cat > conftest.$ac_ext <<EOF
-#line 15625 "configure"
-#include "confdefs.h"
-#include <stdlib.h>
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:15633: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -rf conftest*
- continue
-fi
-rm -f conftest*
-#line 15643 "configure"
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:15650: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
- rm -rf conftest*
- break
-else
-fi
-rm -f conftest*
-done
-if test -n "$ac_declaration"; then
- echo '#ifdef __cplusplus' >>confdefs.h
- echo $ac_declaration >>confdefs.h
- echo '#endif' >>confdefs.h
-fi
-else
CXX=
CXXFLAGS=
@@ -15675,7 +15624,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15679: checking whether to use openDWG" >&5
+echo "configure:15628: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -15695,7 +15644,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15699: checking for location of openDGW includes" >&5
+echo "configure:15648: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15721,15 +15670,15 @@
do
-echo "configure:15725: checking for $ac_hdr" >&5
+echo "configure:15674: checking for $ac_hdr" >&5
-#line 15728 "configure"
+#line 15677 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:15733: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15682: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -15763,7 +15712,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15767: checking for location of openDWG library" >&5
+echo "configure:15716: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15810,7 +15759,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15814: checking for special C compiler options needed for large files" >&5
+echo "configure:15763: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -15818,7 +15767,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 15822 "configure"
+#line 15771 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -15834,7 +15783,7 @@
; return 0; }
EOF
-if { (eval echo configure:15838: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15787: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -15843,7 +15792,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 15847 "configure"
+#line 15796 "configure"
@@ -15859,7 +15808,7 @@
; return 0; }
EOF
-if { (eval echo configure:15863: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15812: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -15879,11 +15828,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15883: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15832: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 15887 "configure"
+#line 15836 "configure"
@@ -15899,14 +15848,14 @@
; return 0; }
EOF
-if { (eval echo configure:15903: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15852: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15910 "configure"
+#line 15859 "configure"
#define _FILE_OFFSET_BITS 64
@@ -15924,7 +15873,7 @@
; return 0; }
EOF
-if { (eval echo configure:15928: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15877: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -15943,11 +15892,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15947: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15896: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 15951 "configure"
+#line 15900 "configure"
@@ -15963,14 +15912,14 @@
; return 0; }
EOF
-if { (eval echo configure:15967: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15916: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15974 "configure"
+#line 15923 "configure"
#define _LARGE_FILES 1
@@ -15988,7 +15937,7 @@
; return 0; }
EOF
-if { (eval echo configure:15992: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15941: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -16007,25 +15956,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:16011: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15960: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 16015 "configure"
+#line 15964 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:16022: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15971: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 16029 "configure"
+#line 15978 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -16034,7 +15983,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:16038: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15987: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -16055,10 +16004,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:16059: checking if system supports Large Files at all" >&5
+echo "configure:16008: checking if system supports Large Files at all" >&5
-#line 16062 "configure"
+#line 16011 "configure"
#include <stdio.h>
@@ -16090,7 +16039,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:16094: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16043: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -16119,7 +16068,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16123: checking whether to use Python" >&5
+echo "configure:16072: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -16139,7 +16088,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:16143: checking for $ac_word" >&5
+echo "configure:16092: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -16181,15 +16130,15 @@
do
-echo "configure:16185: checking for $ac_hdr" >&5
+echo "configure:16134: checking for $ac_hdr" >&5
-#line 16188 "configure"
+#line 16137 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16193: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16142: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -16259,7 +16208,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16263: checking whether to use wxWidgets" >&5
+echo "configure:16212: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -16280,7 +16229,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:16284: checking for $ac_word" >&5
+echo "configure:16233: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -16328,7 +16277,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16332: checking wxWidgets version" >&5
+echo "configure:16281: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -16351,15 +16300,15 @@
do
-echo "configure:16355: checking for $ac_hdr" >&5
+echo "configure:16304: checking for $ac_hdr" >&5
-#line 16358 "configure"
+#line 16307 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16363: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16312: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
Modified: grass/branches/develbranch_6/configure.in
--- grass/branches/develbranch_6/configure.in 2012-11-12 16:17:36 UTC (rev 53777)
+++ grass/branches/develbranch_6/configure.in 2012-11-12 16:33:53 UTC (rev 53778)
@@ -1147,7 +1147,7 @@
LOC_CHECK_INC_PATH(opengl,OpenGL,OPENGLINC)
-LOC_CHECK_INCLUDES(GL/gl.h GL/glu.h,OpenGL,$OPENGLINC $X_CFLAGS)
+LOC_CHECK_INCLUDES(GL/gl.h GL/glu.h X11/Xmu/Xmu.h,OpenGL,$OPENGLINC $X_CFLAGS)
# With OpenGL library directory
