[GRASS-SVN] r53779 - grass/branches/develbranch_6
svn_grass at osgeo.org
Mon Nov 12 08:58:12 PST 2012
Author: martinl
Date: 2012-11-12 08:58:11 -0800 (Mon, 12 Nov 2012)
New Revision: 53779
grass/branches/develbranch_6/configure
grass/branches/develbranch_6/configure.in
add xmu lib check - see r53778
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure 2012-11-12 16:33:53 UTC (rev 53778)
+++ grass/branches/develbranch_6/configure 2012-11-12 16:58:11 UTC (rev 53779)
@@ -10726,7 +10726,7 @@
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$OPENGLINC $X_CFLAGS $CPPFLAGS"
-for ac_hdr in GL/gl.h GL/glu.h X11/Xmu/Xmu.h
+for ac_hdr in GL/gl.h GL/glu.h
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
@@ -10768,11 +10768,56 @@
CPPFLAGS=$ac_save_cppflags
+ac_save_cppflags="$CPPFLAGS"
+CPPFLAGS="$OPENGLINC $X_CFLAGS $CPPFLAGS"
+for ac_hdr in X11/Xmu/Xmu.h
+do
+ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
+echo "configure:10779: checking for $ac_hdr" >&5
+cat > conftest.$ac_ext <<EOF
+#line 10782 "configure"
+#include "confdefs.h"
+#include <$ac_hdr>
+EOF
+ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
+{ (eval echo configure:10787: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
+if test -z "$ac_err"; then
+ rm -rf conftest*
+ eval "ac_cv_header_$ac_safe=yes"
+else
+ echo "$ac_err" >&5
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -rf conftest*
+ eval "ac_cv_header_$ac_safe=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
+ echo "$ac_t""yes" 1>&6
+ ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
+ cat >> confdefs.h <<EOF
+#define $ac_tr_hdr 1
+EOF
+else
+ echo "$ac_t""no" 1>&6
+{ echo "configure: error: *** Unable to locate Xmu includes." 1>&2; exit 1; }
+fi
+done
+CPPFLAGS=$ac_save_cppflags
# With OpenGL library directory
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10776: checking for location of OpenGL library" >&5
+echo "configure:10821: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10792,6 +10837,27 @@
+echo $ac_n "checking for location of Xmu library""... $ac_c" 1>&6
+echo "configure:10842: checking for location of Xmu library" >&5
+case "$with_Xmu_libs" in
+y | ye | yes | n | no)
+ { echo "configure: error: *** You must supply a directory to --with-Xmu-libs." 1>&2; exit 1; }
+esac
+echo "$ac_t""$with_Xmu_libs" 1>&6
+if test -n "$with_Xmu_libs"; then
+ for dir in $with_Xmu_libs; do
+ if test -d "$dir"; then
+ OPENGL_LIB_PATH="$OPENGL_LIB_PATH -L$dir"
+ else
+ { echo "configure: error: *** Xmu library directory $dir does not exist." 1>&2; exit 1; }
+ fi
+ done
+fi
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
@@ -10801,13 +10867,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10805: checking for glBegin in -lGL" >&5
+echo "configure:10871: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10811 "configure"
+#line 10877 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -10818,7 +10884,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -10837,13 +10903,13 @@
-echo "configure:10841: checking for glBegin in -lGL" >&5
+echo "configure:10907: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10847 "configure"
+#line 10913 "configure"
@@ -10854,7 +10920,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10873,13 +10939,13 @@
-echo "configure:10877: checking for glBegin in -lGL" >&5
+echo "configure:10943: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10883 "configure"
+#line 10949 "configure"
@@ -10890,7 +10956,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10909,13 +10975,13 @@
-echo "configure:10913: checking for glBegin in -lGL" >&5
+echo "configure:10979: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10919 "configure"
+#line 10985 "configure"
@@ -10926,7 +10992,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10988,13 +11054,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:10992: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11058: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10998 "configure"
+#line 11064 "configure"
@@ -11005,7 +11071,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11024,13 +11090,13 @@
-echo "configure:11028: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11094: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11034 "configure"
+#line 11100 "configure"
@@ -11041,7 +11107,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11085,10 +11151,10 @@
LDFLAGS="$LDFLAGS $OPENGLLIB"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11089: checking for glXCreatePbuffer" >&5
+echo "configure:11155: checking for glXCreatePbuffer" >&5
-#line 11092 "configure"
+#line 11158 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char glXCreatePbuffer(); below. */
@@ -11111,7 +11177,7 @@
; return 0; }
EOF
-if { (eval echo configure:11115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11133,10 +11199,10 @@
fi
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11137: checking for glXCreateGLXPixmap" >&5
+echo "configure:11203: checking for glXCreateGLXPixmap" >&5
-#line 11140 "configure"
+#line 11206 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11159,7 +11225,7 @@
; return 0; }
EOF
-if { (eval echo configure:11163: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11198,7 +11264,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:11202: checking for location of OpenGL includes" >&5
+echo "configure:11268: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -11224,15 +11290,15 @@
do
-echo "configure:11228: checking for $ac_hdr" >&5
+echo "configure:11294: checking for $ac_hdr" >&5
-#line 11231 "configure"
+#line 11297 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11236: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11302: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11267,10 +11333,10 @@
LDFLAGS="$with_opengl_libs $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11271: checking for glBegin" >&5
+echo "configure:11337: checking for glBegin" >&5
-#line 11274 "configure"
+#line 11340 "configure"
which can conflict with char glBegin(); below. */
@@ -11293,7 +11359,7 @@
; return 0; }
EOF
-if { (eval echo configure:11297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11308,10 +11374,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11312: checking for gluBeginCurve" >&5
+echo "configure:11378: checking for gluBeginCurve" >&5
-#line 11315 "configure"
+#line 11381 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11334,7 +11400,7 @@
; return 0; }
EOF
-if { (eval echo configure:11338: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11378,7 +11444,7 @@
-echo "configure:11382: checking for location of OpenGL includes" >&5
+echo "configure:11448: checking for location of OpenGL includes" >&5
@@ -11404,15 +11470,15 @@
do
-echo "configure:11408: checking for $ac_hdr" >&5
+echo "configure:11474: checking for $ac_hdr" >&5
-#line 11411 "configure"
+#line 11477 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11416: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11482: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11446,7 +11512,7 @@
-echo "configure:11450: checking for location of OpenGL library" >&5
+echo "configure:11516: checking for location of OpenGL library" >&5
@@ -11471,18 +11537,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11475: checking for OpenGL library" >&5
+echo "configure:11541: checking for OpenGL library" >&5
LIBS="-lopengl32 "
-#line 11479 "configure"
+#line 11545 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11552: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -11506,18 +11572,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11510: checking for GLU library" >&5
+echo "configure:11576: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 11514 "configure"
+#line 11580 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11566,7 +11632,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11570: checking whether to use Tcl/Tk" >&5
+echo "configure:11636: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -11586,7 +11652,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11590: checking for location of Tcl/Tk includes" >&5
+echo "configure:11656: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11612,15 +11678,15 @@
do
-echo "configure:11616: checking for $ac_hdr" >&5
+echo "configure:11682: checking for $ac_hdr" >&5
-#line 11619 "configure"
+#line 11685 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11624: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11690: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11657,15 +11723,15 @@
do
-echo "configure:11661: checking for $ac_hdr" >&5
+echo "configure:11727: checking for $ac_hdr" >&5
-#line 11664 "configure"
+#line 11730 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11669: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11735: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11698,7 +11764,7 @@
# Tcl/Tk version checks
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11702: checking Tcl version" >&5
+echo "configure:11768: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -11706,7 +11772,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 11710 "configure"
+#line 11776 "configure"
#include <stdio.h>
@@ -11718,7 +11784,7 @@
EOF
-if { (eval echo configure:11722: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -11736,7 +11802,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11740: checking Tk version" >&5
+echo "configure:11806: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11744,7 +11810,7 @@
else
-#line 11748 "configure"
+#line 11814 "configure"
#include <stdio.h>
@@ -11756,7 +11822,7 @@
EOF
-if { (eval echo configure:11760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -11787,7 +11853,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:11791: checking for location of Tcl/Tk library" >&5
+echo "configure:11857: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -11827,13 +11893,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:11831: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11897: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 11837 "configure"
+#line 11903 "configure"
@@ -11844,7 +11910,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11848: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11863,13 +11929,13 @@
-echo "configure:11867: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11933: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 11873 "configure"
+#line 11939 "configure"
@@ -11880,7 +11946,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11884: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11907,13 +11973,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11911: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11977: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 11917 "configure"
+#line 11983 "configure"
@@ -11924,7 +11990,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11943,13 +12009,13 @@
-echo "configure:11947: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:12013: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 11953 "configure"
+#line 12019 "configure"
@@ -11960,7 +12026,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11987,13 +12053,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:11991: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12057: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 11997 "configure"
+#line 12063 "configure"
@@ -12004,7 +12070,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12023,13 +12089,13 @@
-echo "configure:12027: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12093: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 12033 "configure"
+#line 12099 "configure"
@@ -12040,7 +12106,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12118,13 +12184,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:12122: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12188: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 12128 "configure"
+#line 12194 "configure"
@@ -12135,7 +12201,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12154,13 +12220,13 @@
-echo "configure:12158: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12224: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12164 "configure"
+#line 12230 "configure"
@@ -12171,7 +12237,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12241: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12198,13 +12264,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12202: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12268: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 12208 "configure"
+#line 12274 "configure"
@@ -12215,7 +12281,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12234,13 +12300,13 @@
-echo "configure:12238: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12304: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12244 "configure"
+#line 12310 "configure"
@@ -12251,7 +12317,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12278,13 +12344,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12282: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12348: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12288 "configure"
+#line 12354 "configure"
@@ -12295,7 +12361,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12299: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12314,13 +12380,13 @@
-echo "configure:12318: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12384: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12324 "configure"
+#line 12390 "configure"
@@ -12331,7 +12397,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12421,13 +12487,13 @@
do
# add only if in MACOSX_ARCHS
echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:12425: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:12491: checking for Tcl_Init in -l$tlib" >&5
ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 12431 "configure"
+#line 12497 "configure"
@@ -12438,7 +12504,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12442: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12487,7 +12553,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12491: checking whether to use ODBC" >&5
+echo "configure:12557: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -12506,7 +12572,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12510: checking for location of ODBC includes" >&5
+echo "configure:12576: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12532,15 +12598,15 @@
do
-echo "configure:12536: checking for $ac_hdr" >&5
+echo "configure:12602: checking for $ac_hdr" >&5
-#line 12539 "configure"
+#line 12605 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12544: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12610: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12574,7 +12640,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12578: checking for location of ODBC library" >&5
+echo "configure:12644: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12599,13 +12665,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12603: checking for SQLConnect in -lodbc" >&5
+echo "configure:12669: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 12609 "configure"
+#line 12675 "configure"
@@ -12616,7 +12682,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12686: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12641,13 +12707,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12645: checking for SQLConnect in -liodbc" >&5
+echo "configure:12711: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 12651 "configure"
+#line 12717 "configure"
@@ -12658,7 +12724,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12662: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12683,11 +12749,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12687: checking for ODBC library" >&5
+echo "configure:12753: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 12691 "configure"
+#line 12757 "configure"
#include <windows.h>
#include <sql.h>
@@ -12695,7 +12761,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:12699: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12765: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12744,7 +12810,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12748: checking whether to use FFTW" >&5
+echo "configure:12814: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12763,7 +12829,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12767: checking for location of FFTW includes" >&5
+echo "configure:12833: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12789,15 +12855,15 @@
do
-echo "configure:12793: checking for $ac_hdr" >&5
+echo "configure:12859: checking for $ac_hdr" >&5
-#line 12796 "configure"
+#line 12862 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12801: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12867: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12825,15 +12891,15 @@
do
-echo "configure:12829: checking for $ac_hdr" >&5
+echo "configure:12895: checking for $ac_hdr" >&5
-#line 12832 "configure"
+#line 12898 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12837: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12903: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12861,15 +12927,15 @@
do
-echo "configure:12865: checking for $ac_hdr" >&5
+echo "configure:12931: checking for $ac_hdr" >&5
-#line 12868 "configure"
+#line 12934 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12873: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12939: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12915,7 +12981,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12919: checking for location of FFTW library" >&5
+echo "configure:12985: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12940,13 +13006,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12944: checking for fftw_execute in -lfftw3" >&5
+echo "configure:13010: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12950 "configure"
+#line 13016 "configure"
@@ -12957,7 +13023,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:12961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13027: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12982,13 +13048,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12986: checking for fftwnd_one in -lfftw" >&5
+echo "configure:13052: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 12992 "configure"
+#line 13058 "configure"
@@ -12999,7 +13065,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13003: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13024,13 +13090,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:13028: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:13094: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 13034 "configure"
+#line 13100 "configure"
@@ -13041,7 +13107,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13111: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13098,7 +13164,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:13102: checking whether to use BLAS" >&5
+echo "configure:13168: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -13119,7 +13185,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:13123: checking for location of BLAS includes" >&5
+echo "configure:13189: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -13139,7 +13205,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:13143: checking for location of BLAS library" >&5
+echo "configure:13209: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -13165,15 +13231,15 @@
do
-echo "configure:13169: checking for $ac_hdr" >&5
+echo "configure:13235: checking for $ac_hdr" >&5
-#line 13172 "configure"
+#line 13238 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13177: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13243: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13208,13 +13274,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:13212: checking for dnrm2_ in -lblas" >&5
+echo "configure:13278: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 13218 "configure"
+#line 13284 "configure"
@@ -13225,7 +13291,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13295: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13244,13 +13310,13 @@
-echo "configure:13248: checking for dnrm2_ in -lblas" >&5
+echo "configure:13314: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13254 "configure"
+#line 13320 "configure"
@@ -13261,7 +13327,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13305,13 +13371,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13309: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13375: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 13315 "configure"
+#line 13381 "configure"
@@ -13322,7 +13388,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:13326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13337,13 +13403,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13341: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13407: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 13347 "configure"
+#line 13413 "configure"
@@ -13354,7 +13420,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13358: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13424: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13369,13 +13435,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13373: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13439: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13379 "configure"
+#line 13445 "configure"
@@ -13386,7 +13452,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:13390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13432,16 +13498,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13436: checking for sgemm in $vlib_flags" >&5
+echo "configure:13502: checking for sgemm in $vlib_flags" >&5
-#line 13438 "configure"
+#line 13504 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:13445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -13459,13 +13525,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13463: checking for sgemm_ in -lblas" >&5
+echo "configure:13529: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 13469 "configure"
+#line 13535 "configure"
@@ -13476,7 +13542,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13480: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13491,13 +13557,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13495: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13561: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 13501 "configure"
+#line 13567 "configure"
@@ -13508,7 +13574,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:13512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13578: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13523,13 +13589,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13527: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13593: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 13533 "configure"
+#line 13599 "configure"
@@ -13540,7 +13606,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13574,13 +13640,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13578: checking for acosp in -lsunmath" >&5
+echo "configure:13644: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 13584 "configure"
+#line 13650 "configure"
@@ -13591,7 +13657,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:13595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13661: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13606,13 +13672,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13610: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13676: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 13616 "configure"
+#line 13682 "configure"
@@ -13623,7 +13689,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13627: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13653,13 +13719,13 @@
# Generic BLAS library
-echo "configure:13657: checking for sgemm_ in -lblas" >&5
+echo "configure:13723: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 13663 "configure"
+#line 13729 "configure"
@@ -13670,7 +13736,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13674: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13740: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13709,7 +13775,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13713: checking whether to use LAPACK" >&5
+echo "configure:13779: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13734,7 +13800,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13738: checking for location of LAPACK includes" >&5
+echo "configure:13804: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13754,7 +13820,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13758: checking for location of LAPACK library" >&5
+echo "configure:13824: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13780,15 +13846,15 @@
do
-echo "configure:13784: checking for $ac_hdr" >&5
+echo "configure:13850: checking for $ac_hdr" >&5
-#line 13787 "configure"
+#line 13853 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13792: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13858: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13820,10 +13886,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13824: checking for dsegv_" >&5
+echo "configure:13890: checking for dsegv_" >&5
-#line 13827 "configure"
+#line 13893 "configure"
which can conflict with char dsegv_(); below. */
@@ -13846,7 +13912,7 @@
; return 0; }
EOF
-if { (eval echo configure:13850: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13873,13 +13939,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13877: checking for desgv_ in -llapack" >&5
+echo "configure:13943: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 13883 "configure"
+#line 13949 "configure"
@@ -13890,7 +13956,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13922,13 +13988,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13926: checking for dgesv_ in -llapack" >&5
+echo "configure:13992: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13932 "configure"
+#line 13998 "configure"
@@ -13939,7 +14005,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13943: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13958,13 +14024,13 @@
-echo "configure:13962: checking for dgesv_ in -llapack" >&5
+echo "configure:14028: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13968 "configure"
+#line 14034 "configure"
@@ -13975,7 +14041,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14031,7 +14097,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:14035: checking whether to use Motif" >&5
+echo "configure:14101: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -14050,7 +14116,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:14054: checking for location of Motif includes" >&5
+echo "configure:14120: checking for location of Motif includes" >&5
case "$with_motif_includes" in
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -14076,15 +14142,15 @@
do
-echo "configure:14080: checking for $ac_hdr" >&5
+echo "configure:14146: checking for $ac_hdr" >&5
-#line 14083 "configure"
+#line 14149 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14088: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14154: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14118,7 +14184,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:14122: checking for location of Motif library" >&5
+echo "configure:14188: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -14143,13 +14209,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:14147: checking for XmStringCreate in -lXm" >&5
+echo "configure:14213: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 14153 "configure"
+#line 14219 "configure"
@@ -14160,7 +14226,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:14164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14201,7 +14267,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:14205: checking whether to use Cairo" >&5
+echo "configure:14271: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -14233,7 +14299,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14237: checking for location of cairo includes" >&5
+echo "configure:14303: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14259,15 +14325,15 @@
do
-echo "configure:14263: checking for $ac_hdr" >&5
+echo "configure:14329: checking for $ac_hdr" >&5
-#line 14266 "configure"
+#line 14332 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14271: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14337: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14303,7 +14369,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14307: checking for location of cairo library" >&5
+echo "configure:14373: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14323,7 +14389,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14327: checking for cairo linking flags" >&5
+echo "configure:14393: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14339,10 +14405,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14343: checking for cairo_create" >&5
+echo "configure:14409: checking for cairo_create" >&5
-#line 14346 "configure"
+#line 14412 "configure"
which can conflict with char cairo_create(); below. */
@@ -14365,7 +14431,7 @@
; return 0; }
EOF
-if { (eval echo configure:14369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -14399,10 +14465,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14403: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14469: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14406 "configure"
+#line 14472 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -14425,7 +14491,7 @@
; return 0; }
EOF
-if { (eval echo configure:14429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -14458,10 +14524,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:14462: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:14528: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 14465 "configure"
+#line 14531 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -14484,7 +14550,7 @@
; return 0; }
EOF
-if { (eval echo configure:14488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -14526,7 +14592,7 @@
echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14530: checking whether to use GLw" >&5
+echo "configure:14596: checking whether to use GLw" >&5
echo "$ac_t"""$with_glw"" 1>&6
case "$with_glw" in
"no") USE_GLW= ;;
@@ -14545,7 +14611,7 @@
echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14549: checking for location of GLw includes" >&5
+echo "configure:14615: checking for location of GLw includes" >&5
case "$with_glw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14571,15 +14637,15 @@
do
-echo "configure:14575: checking for $ac_hdr" >&5
+echo "configure:14641: checking for $ac_hdr" >&5
-#line 14578 "configure"
+#line 14644 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14583: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14649: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14607,15 +14673,15 @@
do
-echo "configure:14611: checking for $ac_hdr" >&5
+echo "configure:14677: checking for $ac_hdr" >&5
-#line 14614 "configure"
+#line 14680 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14619: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14685: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14655,7 +14721,7 @@
echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14659: checking for location of GLw library" >&5
+echo "configure:14725: checking for location of GLw library" >&5
case "$with_glw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14680,13 +14746,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14684: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14750: checking for GLwCreateMDrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14690 "configure"
+#line 14756 "configure"
@@ -14697,7 +14763,7 @@
GLwCreateMDrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14722,13 +14788,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14726: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14792: checking for GLwCreateM1DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14732 "configure"
+#line 14798 "configure"
@@ -14739,7 +14805,7 @@
GLwCreateM1DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14764,13 +14830,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14768: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14834: checking for GLwCreateM2DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14774 "configure"
+#line 14840 "configure"
@@ -14781,7 +14847,7 @@
GLwCreateM2DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14851: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14806,13 +14872,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14810: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14876: checking for GLwCreateMDrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14816 "configure"
+#line 14882 "configure"
@@ -14823,7 +14889,7 @@
; return 0; }
EOF
-if { (eval echo configure:14827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14848,13 +14914,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14852: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14918: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14858 "configure"
+#line 14924 "configure"
@@ -14865,7 +14931,7 @@
; return 0; }
EOF
-if { (eval echo configure:14869: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14890,13 +14956,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14894: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14960: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14900 "configure"
+#line 14966 "configure"
@@ -14907,7 +14973,7 @@
; return 0; }
EOF
-if { (eval echo configure:14911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14934,13 +15000,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14938: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:15004: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14944 "configure"
+#line 15010 "configure"
@@ -14951,7 +15017,7 @@
; return 0; }
EOF
-if { (eval echo configure:14955: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14970,13 +15036,13 @@
-echo "configure:14974: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:15040: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14980 "configure"
+#line 15046 "configure"
@@ -14987,7 +15053,7 @@
; return 0; }
EOF
-if { (eval echo configure:14991: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15014,13 +15080,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:15018: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15084: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 15024 "configure"
+#line 15090 "configure"
@@ -15031,7 +15097,7 @@
; return 0; }
EOF
-if { (eval echo configure:15035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15050,13 +15116,13 @@
-echo "configure:15054: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15120: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15060 "configure"
+#line 15126 "configure"
@@ -15067,7 +15133,7 @@
; return 0; }
EOF
-if { (eval echo configure:15071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15180,7 +15246,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:15184: checking whether to use FreeType" >&5
+echo "configure:15250: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -15199,7 +15265,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:15203: checking for location of FreeType includes" >&5
+echo "configure:15269: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -15225,15 +15291,15 @@
do
-echo "configure:15229: checking for $ac_hdr" >&5
+echo "configure:15295: checking for $ac_hdr" >&5
-#line 15232 "configure"
+#line 15298 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15237: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15303: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15267,7 +15333,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15271: checking for location of FreeType library" >&5
+echo "configure:15337: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15292,13 +15358,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15296: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15362: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 15302 "configure"
+#line 15368 "configure"
@@ -15309,7 +15375,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:15313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15350,7 +15416,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15354: checking whether to use NLS" >&5
+echo "configure:15420: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -15370,10 +15436,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15374: checking for gettext" >&5
+echo "configure:15440: checking for gettext" >&5
cat > conftest.$ac_ext <<EOF
-#line 15377 "configure"
+#line 15443 "configure"
#include "confdefs.h"
which can conflict with char gettext(); below. */
@@ -15396,7 +15462,7 @@
; return 0; }
EOF
-if { (eval echo configure:15400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15466: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -15414,13 +15480,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15418: checking for gettext in -lintl" >&5
+echo "configure:15484: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 15424 "configure"
+#line 15490 "configure"
@@ -15431,7 +15497,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:15435: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15466,7 +15532,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15470: checking whether to use C++" >&5
+echo "configure:15536: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -15482,7 +15548,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15486: checking for $ac_word" >&5
+echo "configure:15552: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15511,7 +15577,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15515: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15581: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15522,12 +15588,12 @@
cat > conftest.$ac_ext << EOF
-#line 15526 "configure"
+#line 15592 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:15531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -15553,19 +15619,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15557: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15623: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15562: checking whether we are using GNU C++" >&5
+echo "configure:15628: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15569: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15635: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -15583,7 +15649,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15587: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15653: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15624,7 +15690,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15628: checking whether to use openDWG" >&5
+echo "configure:15694: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -15644,7 +15710,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15648: checking for location of openDGW includes" >&5
+echo "configure:15714: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15670,15 +15736,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:15674: checking for $ac_hdr" >&5
+echo "configure:15740: checking for $ac_hdr" >&5
-#line 15677 "configure"
+#line 15743 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:15682: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15748: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -15712,7 +15778,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15716: checking for location of openDWG library" >&5
+echo "configure:15782: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15759,7 +15825,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15763: checking for special C compiler options needed for large files" >&5
+echo "configure:15829: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -15767,7 +15833,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 15771 "configure"
+#line 15837 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -15783,7 +15849,7 @@
; return 0; }
EOF
-if { (eval echo configure:15787: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15853: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -15792,7 +15858,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 15796 "configure"
+#line 15862 "configure"
@@ -15808,7 +15874,7 @@
; return 0; }
EOF
-if { (eval echo configure:15812: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15878: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -15828,11 +15894,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15832: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15898: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 15836 "configure"
+#line 15902 "configure"
@@ -15848,14 +15914,14 @@
; return 0; }
EOF
-if { (eval echo configure:15852: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15918: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 15859 "configure"
+#line 15925 "configure"
#define _FILE_OFFSET_BITS 64
@@ -15873,7 +15939,7 @@
; return 0; }
EOF
-if { (eval echo configure:15877: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15943: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -15892,11 +15958,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15896: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15962: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 15900 "configure"
+#line 15966 "configure"
@@ -15912,14 +15978,14 @@
; return 0; }
EOF
-if { (eval echo configure:15916: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15982: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15923 "configure"
+#line 15989 "configure"
#define _LARGE_FILES 1
@@ -15937,7 +16003,7 @@
; return 0; }
EOF
-if { (eval echo configure:15941: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16007: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -15956,25 +16022,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15960: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:16026: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 15964 "configure"
+#line 16030 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15971: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16037: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15978 "configure"
+#line 16044 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -15983,7 +16049,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15987: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16053: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -16004,10 +16070,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:16008: checking if system supports Large Files at all" >&5
+echo "configure:16074: checking if system supports Large Files at all" >&5
-#line 16011 "configure"
+#line 16077 "configure"
#include <stdio.h>
@@ -16039,7 +16105,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:16043: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16109: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -16068,7 +16134,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16072: checking whether to use Python" >&5
+echo "configure:16138: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -16088,7 +16154,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:16092: checking for $ac_word" >&5
+echo "configure:16158: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -16130,15 +16196,15 @@
do
-echo "configure:16134: checking for $ac_hdr" >&5
+echo "configure:16200: checking for $ac_hdr" >&5
-#line 16137 "configure"
+#line 16203 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16142: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16208: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -16208,7 +16274,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16212: checking whether to use wxWidgets" >&5
+echo "configure:16278: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -16229,7 +16295,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:16233: checking for $ac_word" >&5
+echo "configure:16299: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -16277,7 +16343,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16281: checking wxWidgets version" >&5
+echo "configure:16347: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -16300,15 +16366,15 @@
do
-echo "configure:16304: checking for $ac_hdr" >&5
+echo "configure:16370: checking for $ac_hdr" >&5
-#line 16307 "configure"
+#line 16373 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16312: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16378: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
Modified: grass/branches/develbranch_6/configure.in
--- grass/branches/develbranch_6/configure.in 2012-11-12 16:33:53 UTC (rev 53778)
+++ grass/branches/develbranch_6/configure.in 2012-11-12 16:58:11 UTC (rev 53779)
@@ -1147,12 +1147,16 @@
LOC_CHECK_INC_PATH(opengl,OpenGL,OPENGLINC)
-LOC_CHECK_INCLUDES(GL/gl.h GL/glu.h X11/Xmu/Xmu.h,OpenGL,$OPENGLINC $X_CFLAGS)
+LOC_CHECK_INCLUDES(GL/gl.h GL/glu.h,OpenGL,$OPENGLINC $X_CFLAGS)
+LOC_CHECK_INCLUDES(X11/Xmu/Xmu.h,Xmu,$OPENGLINC $X_CFLAGS)
# With OpenGL library directory
LOC_CHECK_LIB_PATH(opengl,OpenGL,OPENGL_LIB_PATH)
+LOC_CHECK_LIB_PATH(Xmu,Xmu,OPENGL_LIB_PATH)
LOC_CHECK_LIBS(GL,glBegin,OpenGL,$OPENGL_LIB_PATH,OPENGLLIB,$X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB,,,-lpthread,-lXext)
LOC_CHECK_LIBS(GLU,gluBeginCurve,GLU,$OPENGL_LIB_PATH,OPENGLULIB,$OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB,,,-lstdc++)
