[GRASS-SVN] r53782 - grass/trunk/raster/r.colors
Tue Nov 13 00:40:15 PST 2012
Author: huhabla
Date: 2012-11-13 00:40:14 -0800 (Tue, 13 Nov 2012)
New Revision: 53782
   grass/trunk/raster/r.colors/edit_colors.c
Fixed wrong GUI section for map and file options.
Modified: grass/trunk/raster/r.colors/edit_colors.c
--- grass/trunk/raster/r.colors/edit_colors.c	2012-11-12 18:14:04 UTC (rev 53781)
+++ grass/trunk/raster/r.colors/edit_colors.c	2012-11-13 08:40:14 UTC (rev 53782)
@@ -68,12 +68,24 @@
     if (type == RASTER3D_TYPE) {
         opt.maps = G_define_standard_option(G_OPT_R3_MAPS);
-        opt.maps->required = NO;
     } else {
         opt.maps = G_define_standard_option(G_OPT_R_MAPS);
+    opt.maps->required = NO;
+    opt.maps->guisection = _("Define");
+    opt.file = G_define_standard_option(G_OPT_F_INPUT);
+    opt.file->key = "file";
+    opt.file->required = NO;
+    opt.file->label =
+        _("Input file with one map name per line");
+    opt.file->description =
+        _("Input map names can be defined in an input file in case a large"
+        		" amount of maps must be specified. This option is mutual"
+        		" exclusive to the map option.");
+    opt.file->guisection = _("Define");
     opt.colr = G_define_standard_option(G_OPT_M_COLR);
     opt.colr->guisection = _("Define");
@@ -84,12 +96,6 @@
         _("Raster map from which to copy color table");
     opt.rast->guisection = _("Define");
-    opt.file = G_define_standard_option(G_OPT_F_INPUT);
-    opt.file->key = "file";
-    opt.file->required = NO;
-    opt.file->description =
-        _("Input file with one map name per line");
     opt.volume = G_define_standard_option(G_OPT_R3_INPUT);
     opt.volume->key = "volume";
     opt.volume->required = NO;
