[GRASS-SVN] r53783 - grass/trunk
Tue Nov 13 03:42:43 PST 2012
Author: martinl
Date: 2012-11-13 03:42:42 -0800 (Tue, 13 Nov 2012)
New Revision: 53783
   grass/trunk/SUBMITTING_PYTHON
note Python pep08
Modified: grass/trunk/SUBMITTING_PYTHON
--- grass/trunk/SUBMITTING_PYTHON	2012-11-13 08:40:14 UTC (rev 53782)
+++ grass/trunk/SUBMITTING_PYTHON	2012-11-13 11:42:42 UTC (rev 53783)
@@ -8,6 +8,7 @@
 [ see SUBMITTING      for C hints ]
 [ see SUBMITTING_DOCS for documentation ]
+See also http://www.python.org/dev/peps/pep-0008/
 0.  Indentation
@@ -19,10 +20,12 @@
     See also "Python Style Guide" by Guido van Rossum
     http://www.python.org/doc/essays/styleguide.html
 1.  Instructions for the GRASS script parser can be found in the g.parser
     module's help page.
     http://grass.osgeo.org/grass70/manuals/html70_user/g.parser.html
 2.  Use the directory structure to place your script appropriately into
     the source tree
     	- scripts go into scripts/
@@ -30,6 +33,7 @@
     Also add a Makefile and a <module>.html file into this directory.
     See existing Python scripts for examples.
 3.  Add a header section to the script you submit and make sure you
     include the copyright. The purpose section is meant to contain a
     general over view of the code in the file to assist other
@@ -64,9 +68,11 @@
     Just select an existing module which is close to your application to save
     efforts.
 4.  We don't want the $ ID $ in source code any more as it causes problems
     for the branches.
 5.  Create and use secure temporary files and directories. Use the
     grass.tempfile() or grass.tempdir() functions to do this. e.g.
@@ -75,6 +81,7 @@
 	if TMP is None:
 	    grass.fatal("Unable to create temporary files")
 6.  Use grass.findfile() when there is a need to test if a map exists.
 	# test for input raster map
@@ -111,6 +118,7 @@
     Try to omit any usage of the 'print' command for informational output.
 8.  PLEASE take the time to add comments throughout your code explaining what
     the code is doing. It will save a HUGE amount of time and frustration for
     other programmers that may have to change your code in the future.
