[GRASS-SVN] r53805 - grass/trunk/vector/v.distance
svn_grass at osgeo.org
Wed Nov 14 06:58:01 PST 2012
Author: mmetz
Date: 2012-11-14 06:58:01 -0800 (Wed, 14 Nov 2012)
New Revision: 53805
grass/trunk/vector/v.distance/main.c
v.distance: uniform category handling
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c 2012-11-14 14:48:16 UTC (rev 53804)
+++ grass/trunk/vector/v.distance/main.c 2012-11-14 14:58:01 UTC (rev 53805)
@@ -665,7 +665,6 @@
G_debug(3, " %d lines in box", lList->n_values);
for (i = 0; i < lList->n_values; i++) {
- tmp_tcat = -1;
ttype = Vect_read_line(&To, TPoints, TCats, lList->id[i]);
line2line(FPoints, ftype, TPoints, ttype,
@@ -676,8 +675,16 @@
if (tmp_dist > max || tmp_dist < min)
continue; /* not in threshold */
- /* TODO: more cats of the same field */
- Vect_cat_get(TCats, to_field, &tmp_tcat);
+ tmp_tcat = -1;
+ /* TODO: all cats of given field ? */
+ for (j = 0; j < TCats->n_cats; j++) {
+ if (TCats->field[j] == to_field) {
+ if (tmp_tcat >= 0)
+ G_warning(_("More cats found in to_layer (line=%d)"),
+ lList->id[i]);
+ tmp_tcat = TCats->cat[j];
G_debug(4, " tmp_dist = %f tmp_tcat = %d", tmp_dist,
tmp_tcat);
@@ -734,8 +741,6 @@
if (Vect_get_area_centroid(&To, aList->id[i]) == 0)
continue;
- tmp_tcat = -1;
line2area(&To, FPoints, ftype, aList->id[i], &aList->box[i],
&tmp_fx, &tmp_fy, &tmp_fz, &tmp_falong, &tmp_fangle,
&tmp_tx, &tmp_ty, &tmp_tz, &tmp_talong, &tmp_tangle,
@@ -746,8 +751,18 @@
Vect_get_area_cats(&To, aList->id[i], TCats);
+ tmp_tcat = -1;
+ G_warning(_("More cats found in to_layer (area=%d)"),
+ aList->id[i]);
tmp_tcat);
@@ -922,7 +937,6 @@
- tmp_tcat = -1;
/* area to line */
@@ -934,8 +948,16 @@
+ tmp_tcat = -1;
+ lList->id[i]);
tmp_tcat);
@@ -1079,7 +1101,7 @@
if (tmp_tcat >= 0)
- area);
+ tarea);
