[GRASS-SVN] r53806 - in grass/trunk/raster3d: . r3.in.bin r3.in.bin/test_suite r3.out.bin
svn_grass at osgeo.org
Wed Nov 14 07:09:32 PST 2012
Author: huhabla
Date: 2012-11-14 07:09:32 -0800 (Wed, 14 Nov 2012)
New Revision: 53806
Added:
grass/trunk/raster3d/r3.in.bin/
grass/trunk/raster3d/r3.in.bin/Makefile
grass/trunk/raster3d/r3.in.bin/main.c
grass/trunk/raster3d/r3.in.bin/r3.in.bin.html
grass/trunk/raster3d/r3.in.bin/test_suite/
grass/trunk/raster3d/r3.in.bin/test_suite/test.r3.in.bin.sh
grass/trunk/raster3d/r3.in.bin/test_suite/test_out_bin_double.ref
grass/trunk/raster3d/r3.in.bin/test_suite/test_out_bin_float.ref
grass/trunk/raster3d/Makefile
grass/trunk/raster3d/r3.out.bin/main.c
New module to import 3D raster binary data as 3D raster maps.
Modified: grass/trunk/raster3d/Makefile
--- grass/trunk/raster3d/Makefile 2012-11-14 14:58:01 UTC (rev 53805)
+++ grass/trunk/raster3d/Makefile 2012-11-14 15:09:32 UTC (rev 53806)
@@ -4,6 +4,7 @@
r3.cross.rast \
r3.gwflow \
r3.in.ascii \
+ r3.in.bin \
r3.in.v5d \
r3.info \
r3.mask \
Added: grass/trunk/raster3d/r3.in.bin/Makefile
--- grass/trunk/raster3d/r3.in.bin/Makefile (rev 0)
+++ grass/trunk/raster3d/r3.in.bin/Makefile 2012-11-14 15:09:32 UTC (rev 53806)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = r3.in.bin
+LIBES = $(RASTERLIB) $(RASTER3DLIB) $(GISLIB)
+DEPENDENCIES = $(RASTERDEP) $(RASTER3DDEP) $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass/trunk/raster3d/r3.in.bin/main.c
--- grass/trunk/raster3d/r3.in.bin/main.c (rev 0)
+++ grass/trunk/raster3d/r3.in.bin/main.c 2012-11-14 15:09:32 UTC (rev 53806)
@@ -0,0 +1,491 @@
+ * r.in.bin
+ * Copyright (C) 2000 by the GRASS Development Team
+ * Author: Bob Covill <bcovill tekmap.ns.ca>
+ * This program is free software under the GPL (>=v2)
+ * Read the file COPYING coming with GRASS for details.
+#include <stdlib.h>
+#include <string.h>
+#include <unistd.h>
+#include <sys/stat.h>
+#include <grass/gis.h>
+#include <grass/raster.h>
+#include <grass/raster3d.h>
+#include <grass/glocale.h>
+/* Some global variables */
+RASTER3D_Map *map;
+RASTER3D_Region region;
+FILE *fp;
+unsigned char *in_cell;
+static void swap_2(void *p) {
+ unsigned char *q = p;
+ unsigned char t;
+ t = q[0];
+ q[0] = q[1];
+ q[1] = t;
+static void swap_4(void *p) {
+ unsigned char t;
+ t = q[0];
+ q[0] = q[3];
+ q[3] = t;
+ t = q[1];
+ q[1] = q[2];
+ q[2] = t;
+static void swap_8(void *p) {
+ unsigned char t;
+ t = q[0];
+ q[0] = q[7];
+ q[7] = t;
+ t = q[1];
+ q[1] = q[6];
+ q[6] = t;
+ t = q[2];
+ q[2] = q[5];
+ q[5] = t;
+ t = q[3];
+ q[3] = q[4];
+ q[4] = t;
+static void read_cell(DCELL *out_cell, int is_integer, int is_signed, int bytes,
+ int byte_swap) {
+ if (fread(in_cell, bytes, 1, fp) != 1)
+ G_fatal_error(_("Error reading binary data"));
+ if (byte_swap) {
+ switch (bytes) {
+ case 1:
+ break;
+ case 2:
+ swap_2(in_cell);
+ break;
+ case 4:
+ swap_4(in_cell);
+ break;
+ case 8:
+ swap_8(in_cell);
+ break;
+ if (!is_integer) {
+ switch (bytes) {
+ case 4:
+ *out_cell = (DCELL) *(float *) in_cell;
+ break;
+ case 8:
+ *out_cell = (DCELL) *(double *) in_cell;
+ break;
+ } else if (is_signed) {
+ switch (bytes) {
+ case 1:
+ *out_cell = (DCELL) *(signed char *) in_cell;
+ break;
+ case 2:
+ *out_cell = (DCELL) *(short *) in_cell;
+ break;
+ case 4:
+ *out_cell = (DCELL) *(int *) in_cell;
+ break;
+#ifdef HAVE_LONG_LONG_INT
+ case 8:
+ *out_cell = (DCELL) *(long long *) in_cell;
+ break;
+#endif
+ } else {
+ switch (bytes) {
+ case 1:
+ *out_cell = (DCELL) *(unsigned char *) in_cell;
+ break;
+ case 2:
+ *out_cell = (DCELL) *(unsigned short *) in_cell;
+ break;
+ case 4:
+ *out_cell = (DCELL) *(unsigned int *) in_cell;
+ break;
+ case 8:
+ *out_cell = (DCELL) *(unsigned long long *) in_cell;
+ break;
+#endif
+static void bin_to_raster3d(char *null, int map_type, int is_integer,
+ int is_signed, int bytes, int byte_swap, int row_swap, int depth_swap) {
+ int x, y, z;
+ int col, row, depth;
+ DCELL value;
+ FCELL fvalue;
+ DCELL null_value;
+ int tileX, tileY, tileZ;
+ if (null)
+ null_value = atof(null);
+ Rast3d_get_tile_dimensions_map(map, &tileX, &tileY, &tileZ);
+ Rast3d_min_unlocked(map, RASTER3D_USE_CACHE_X);
+ Rast3d_autolock_on(map);
+ Rast3d_unlock_all(map);
+ G_message(_("Loading %s data with %i bytes ... (%dx%dx%d)"),
+ (is_integer? "integer":"floating point "), bytes, region.cols,
+ region.rows, region.depths);
+ for (z = 0; z < region.depths; z++) {
+ G_percent(z, region.depths, 1);
+ if ((z % tileZ) == 0)
+ for (y = 0; y < region.rows; y++) {/* go south to north */
+ for (x = 0; x < region.cols; x++) {
+ /* From west to east */
+ col = x;
+ /* The default is to read rows from north to south */
+ row = y;
+ /* From bottom to the top */
+ depth = z;
+ /* Read rows as from south to north */
+ if (row_swap)
+ row = region.rows - y - 1;
+ /* Read XY layer from top to bottom */
+ if (depth_swap)
+ depth = region.depths - z - 1;
+ /* Read value from binary file */
+ read_cell(&value, is_integer, is_signed, bytes, byte_swap);
+ /* Write value to the 3D raster map */
+ if (map_type == DCELL_TYPE) {
+ if (null && value == null_value)
+ Rast3d_set_null_value(&value, 1, DCELL_TYPE);
+ Rast3d_put_double(map, col, row, depth, value);
+ } else {
+ fvalue = (FCELL) value;
+ Rast3d_set_null_value(&fvalue, 1, FCELL_TYPE);
+ Rast3d_put_double(map, col, row, depth, fvalue);
+ if (!Rast3d_flush_all_tiles(map))
+ G_fatal_error(_("Error flushing tiles"));
+ Rast3d_autolock_off(map);
+ G_percent(1, 1, 1);
+int main(int argc, char *argv[]) {
+ struct GModule *module;
+ struct {
+ struct Option *input;
+ struct Option *output;
+ struct Option *null;
+ struct Option *bytes;
+ struct Option *order;
+ struct Option *north;
+ struct Option *south;
+ struct Option *top;
+ struct Option *bottom;
+ struct Option *east;
+ struct Option *west;
+ struct Option *rows;
+ struct Option *cols;
+ struct Option *depths;
+ } parm;
+ struct {
+ struct Flag *integer_in;
+ struct Flag *sign;
+ struct Flag *swap;
+ struct Flag *depth;
+ struct Flag *row;
+ } flag;
+ const char *input;
+ const char *output;
+ int is_integer;
+ int is_signed;
+ int bytes;
+ int order;
+ int byte_swap;
+ RASTER_MAP_TYPE map_type;
+ off_t file_size;
+ struct History history;
+ off_t expected;
+ /* Need to be allocated later */
+ in_cell = NULL;
+ G_gisinit(argv[0]);
+ /* Set description */
+ module = G_define_module();
+ G_add_keyword(_("raster"));
+ G_add_keyword(_("import"));
+ module->description =
+ _("Import a binary raster file into a GRASS 3D raster map layer.");
+ parm.input = G_define_standard_option(G_OPT_F_INPUT);
+ parm.input->description = _("Binary 3D raster file to be imported");
+ parm.output = G_define_standard_option(G_OPT_R3_OUTPUT);
+ parm.bytes = G_define_option();
+ parm.bytes->key = "bytes";
+ parm.bytes->type = TYPE_INTEGER;
+ parm.bytes->required = YES;
+ parm.bytes->options = "1,2,4,8";
+ parm.bytes->description = _("Number of bytes per cell in binary file");
+ parm.bytes->guisection = _("Settings");
+ parm.order = G_define_option();
+ parm.order->key = "order";
+ parm.order->type = TYPE_STRING;
+ parm.order->required = NO;
+ parm.order->options = "big,little,native,swap";
+ parm.order->description = _("Byte order in binary file");
+ parm.order->answer = "native";
+ parm.north = G_define_option();
+ parm.north->key = "north";
+ parm.north->type = TYPE_DOUBLE;
+ parm.north->required = YES;
+ parm.north->description =
+ _("Northern limit of geographic region (outer edge)");
+ parm.north->guisection = _("Bounds");
+ parm.south = G_define_option();
+ parm.south->key = "south";
+ parm.south->type = TYPE_DOUBLE;
+ parm.south->required = YES;
+ parm.south->description =
+ _("Southern limit of geographic region (outer edge)");
+ parm.south->guisection = _("Bounds");
+ parm.east = G_define_option();
+ parm.east->key = "east";
+ parm.east->type = TYPE_DOUBLE;
+ parm.east->required = YES;
+ parm.east->description =
+ _("Eastern limit of geographic region (outer edge)");
+ parm.east->guisection = _("Bounds");
+ parm.west = G_define_option();
+ parm.west->key = "west";
+ parm.west->type = TYPE_DOUBLE;
+ parm.west->required = YES;
+ parm.west->description =
+ _("Western limit of geographic region (outer edge)");
+ parm.west->guisection = _("Bounds");
+ parm.bottom = G_define_option();
+ parm.bottom->key = "bottom";
+ parm.bottom->type = TYPE_DOUBLE;
+ parm.bottom->required = YES;
+ parm.bottom->description =
+ _("Bottom limit of geographic region (outer edge)");
+ parm.bottom->guisection = _("Bounds");
+ parm.top = G_define_option();
+ parm.top->key = "top";
+ parm.top->type = TYPE_DOUBLE;
+ parm.top->required = YES;
+ parm.top->description = _("Top limit of geographic region (outer edge)");
+ parm.top->guisection = _("Bounds");
+ parm.rows = G_define_option();
+ parm.rows->key = "rows";
+ parm.rows->type = TYPE_INTEGER;
+ parm.rows->required = YES;
+ parm.rows->description = _("Number of rows");
+ parm.rows->guisection = _("Bounds");
+ parm.cols = G_define_option();
+ parm.cols->key = "cols";
+ parm.cols->type = TYPE_INTEGER;
+ parm.cols->required = YES;
+ parm.cols->description = _("Number of columns");
+ parm.cols->guisection = _("Bounds");
+ parm.depths = G_define_option();
+ parm.depths->key = "depths";
+ parm.depths->type = TYPE_INTEGER;
+ parm.depths->required = YES;
+ parm.depths->description = _("Number of depths");
+ parm.depths->guisection = _("Bounds");
+ parm.null = G_define_option();
+ parm.null->key = "null";
+ parm.null->type = TYPE_DOUBLE;
+ parm.null->required = NO;
+ parm.null->description = _("Set Value to NULL");
+ parm.null->guisection = _("Settings");
+ flag.row = G_define_flag();
+ flag.row->key = 'r';
+ flag.row->description = _("Switch the row order in output from "
+ "north->south to south->north");
+ flag.depth = G_define_flag();
+ flag.depth->key = 'd';
+ flag.depth->description = _("Switch the depth order in output "
+ "from bottom->top to top->bottom");
+ flag.integer_in = G_define_flag();
+ flag.integer_in->key = 'i';
+ flag.integer_in->description =
+ _("Binary data is of type integer");
+ flag.sign = G_define_flag();
+ flag.sign->key = 's';
+ flag.sign->description = _("Signed data (two's complement)");
+ flag.sign->guisection = _("Settings");
+ flag.swap = G_define_flag();
+ flag.swap->key = 'b';
+ flag.swap->description = _("Byte Swap the Data During Import");
+ flag.swap->guisection = _("Settings");
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ input = parm.input->answer;
+ output = parm.output->answer;
+ if (G_strcasecmp(parm.order->answer, "big") == 0)
+ order = 0;
+ else if (G_strcasecmp(parm.order->answer, "little") == 0)
+ order = 1;
+ else if (G_strcasecmp(parm.order->answer, "native") == 0)
+ order = G_is_little_endian() ? 1 : 0;
+ else if (G_strcasecmp(parm.order->answer, "swap") == 0)
+ order = G_is_little_endian() ? 0 : 1;
+ if (flag.swap->answer) {
+ if (strcmp(parm.order->answer, "native") != 0)
+ G_fatal_error(_("order= and -b are mutually exclusive"));
+ byte_swap = order == (G_is_little_endian() ? 0 : 1);
+ is_signed = !!flag.sign->answer;
+ is_integer = 0;
+ bytes = 8;
+ if (parm.bytes->answer)
+ bytes = atoi(parm.bytes->answer);
+ if (!flag.integer_in->answer) {
+ if (bytes && bytes < 4)
+ G_fatal_error(
+ _("bytes=%d; must be 4 or 8 in case of floating point input"),
+ bytes);
+ if (!bytes)
+ bytes = 4;
+ } else {
+ is_integer = 1;
+#ifndef HAVE_LONG_LONG_INT
+ if (is_integer && bytes > 4)
+ G_fatal_error(_("Integer input doesn't support size=8 in this build"));
+#endif
+ if (bytes != 1 && bytes != 2 && bytes != 4 && bytes != 8)
+ G_fatal_error(_("bytes= must be 1, 2, 4 or 8"));
+ region.zone = G_zone();
+ region.proj = G_projection();
+ region.rows = atoi(parm.rows->answer);
+ region.cols = atoi(parm.cols->answer);
+ region.depths = atoi(parm.depths->answer);
+ region.top = atof(parm.top->answer);
+ region.bottom = atof(parm.bottom->answer);
+ if (!G_scan_northing(parm.north->answer, ®ion.north, region.proj))
+ G_fatal_error(_("Illegal north coordinate <%s>"), parm.north->answer);
+ if (!G_scan_northing(parm.south->answer, ®ion.south, region.proj))
+ G_fatal_error(_("Illegal south coordinate <%s>"), parm.south->answer);
+ if (!G_scan_easting(parm.east->answer, ®ion.east, region.proj))
+ G_fatal_error(_("Illegal east coordinate <%s>"), parm.east->answer);
+ if (!G_scan_easting(parm.west->answer, ®ion.west, region.proj))
+ G_fatal_error(_("Illegal west coordinate <%s>"), parm.west->answer);
+ Rast3d_adjust_region(®ion);
+ expected = (off_t) region.rows * region.cols * region.depths * bytes;
+ fp = fopen(input, "rb");
+ if (!fp)
+ G_fatal_error(_("Unable to open <%s>"), input);
+ /* Find File Size in Byte and Check against byte size */
+ G_fseek(fp, 0, SEEK_END);
+ file_size = G_ftell(fp);
+ G_fseek(fp, 0, SEEK_SET);
+ if (file_size != expected) {
+ G_warning(_("File Size %lld ... Total Bytes %lld"),
+ (long long int) file_size, (long long int) expected);
+ G_fatal_error(_("Bytes do not match file size"));
+ map_type = (bytes > 4 ? DCELL_TYPE : FCELL_TYPE);
+ if(is_integer && bytes >= 4)
+ map_type = DCELL_TYPE;
+ Rast3d_init_defaults();
+ /*Open the new 3D raster map */
+ map = Rast3d_open_new_opt_tile_size(output, RASTER3D_USE_CACHE_DEFAULT,
+ ®ion, map_type, 32);
+ if (map == NULL)
+ G_fatal_error(_("Unable to open 3D raster map"));
+ in_cell = G_malloc(bytes);
+ bin_to_raster3d(parm.null->answer, map_type, is_integer, is_signed, bytes,
+ byte_swap, flag.row->answer, flag.depth->answer);
+ if (!Rast3d_close(map))
+ G_fatal_error(_("Unable to close 3D raster map"));
+ /* write input name to map history */
+ Rast3d_read_history(output, G_mapset(), &history);
+ Rast_set_history(&history, HIST_DATSRC_1, input);
+ Rast3d_write_history(output, &history);
+ fclose(fp);
+ if (in_cell)
+ G_free(in_cell);
+ return EXIT_SUCCESS;
Added: grass/trunk/raster3d/r3.in.bin/r3.in.bin.html
--- grass/trunk/raster3d/r3.in.bin/r3.in.bin.html (rev 0)
+++ grass/trunk/raster3d/r3.in.bin/r3.in.bin.html 2012-11-14 15:09:32 UTC (rev 53806)
@@ -0,0 +1,23 @@
+<h2>DESCRIPTION</h2>
+<em>r3.in.bin</em> allows a user to create a GRASS 3D raster map
+from a variety of binary 3D raster data formats.
+<p>The top, bottom, north, south, east, and west field values entered
+are the coordinates of the edges of the geographic region.
+The depths, rows and cols field values entered describe the dimensions
+of the matrix of data to follow.
+If the bytes field is entered incorrectly an error will be generated
+suggesting a closer bytes value.
+<h2>SEE ALSO</h2>
+<em>
+<a href="r3.out.bin.html">r3.out.bin</a>,
+<a href="r3.in.ascii.html">r3.in.ascii</a>,
+<a href="r3.out.ascii.html">r3.out.ascii</a>
+</em>
+<h2>AUTHORS</h2>
+Soren Gebbert, based on r.in.bin from Jacques Bouchard and Bob Covill
\ No newline at end of file
Added: grass/trunk/raster3d/r3.in.bin/test_suite/test.r3.in.bin.sh
--- grass/trunk/raster3d/r3.in.bin/test_suite/test.r3.in.bin.sh (rev 0)
+++ grass/trunk/raster3d/r3.in.bin/test_suite/test.r3.in.bin.sh 2012-11-14 15:09:32 UTC (rev 53806)
@@ -0,0 +1,123 @@
+#!/bin/sh
+g.region w=0 e=180 s=0 n=90 b=0 t=100 res3=10
+r3.mapcalc --o expr="test_out_bin_float = float(if(row() == 2, null(), row()))"
+r3.mapcalc --o expr="test_out_bin_double = double(if(row() == 2, null(), row()))"
+r3.out.ascii --o dp=0 input=test_out_bin_float output=test_out_bin_float.ref;
+r3.out.ascii --o dp=0 input=test_out_bin_double output=test_out_bin_double.ref;
+# @test
+r3.out.bin --o input=test_out_bin_float byte=4 null=-9999 \
+ output=test_out_bin_float_native_b4.bin order=native
+r3.out.bin --o input=test_out_bin_float byte=8 null=-9999 \
+ output=test_out_bin_float_native_b8.bin order=native
+r3.out.bin --o -s input=test_out_bin_float byte=4 null=-9999 \
+ output=test_out_bin_float_native_s_b4.bin order=native
+r3.out.bin --o -r input=test_out_bin_float byte=4 null=-9999 \
+ output=test_out_bin_float_native_r_b4.bin order=native
+r3.out.bin --o -d input=test_out_bin_float byte=4 null=-9999 \
+ output=test_out_bin_float_native_d_b4.bin order=native
+r3.out.bin --o -rd input=test_out_bin_float byte=4 null=-9999 \
+ output=test_out_bin_float_native_rd_b4.bin order=native
+# Test little and big endian
+ output=test_out_bin_float_little_b4.bin order=little
+ output=test_out_bin_float_big_b4.bin order=big
+# Write float map as integer array
+r3.out.bin --o -i input=test_out_bin_float byte=1 null=-9999 \
+ output=test_out_bin_float_native_b1_as_integer.bin order=native
+r3.out.bin --o -i input=test_out_bin_float byte=2 null=-9999 \
+ output=test_out_bin_float_native_b2_as_integer.bin order=native
+r3.out.bin --o -i input=test_out_bin_float byte=4 null=-9999 \
+ output=test_out_bin_float_native_b4_as_integer.bin order=native
+r3.out.bin --o -i input=test_out_bin_float byte=8 null=-9999 \
+ output=test_out_bin_float_native_b8_as_integer.bin order=native
+# Double precision
+r3.out.bin --o input=test_out_bin_double byte=4 null=-9999 \
+ output=test_out_bin_double_native_b4.bin order=native
+r3.out.bin --o input=test_out_bin_double byte=8 null=-9999 \
+ output=test_out_bin_double_native_b8.bin order=native
+# Import test floating point
+r3.in.bin --o output=test_in_bin_float_1 byte=4 null=-9999 \
+ input=test_out_bin_float_native_b4.bin order=native \
+ bottom=0 top=100 west=0 east=180 south=0 north=90 \
+ cols=18 rows=9 depths=10
+r3.in.bin --o output=test_in_bin_float_2 byte=8 null=-9999 \
+ input=test_out_bin_float_native_b8.bin order=native \
+#r3.in.bin --o output=test_in_bin_float_3 byte=4 null=-9999 \
+# input=test_out_bin_float_native_s_b4.bin order=native \
+# bottom=0 top=100 west=0 east=180 south=0 north=90 \
+# cols=18 rows=9 depths=10 -s
+r3.in.bin --o output=test_in_bin_float_4 byte=4 null=-9999 \
+ input=test_out_bin_float_native_d_b4.bin order=native \
+ cols=18 rows=9 depths=10 -d
+r3.in.bin --o output=test_in_bin_float_5 byte=4 null=-9999 \
+ input=test_out_bin_float_native_r_b4.bin order=native \
+ cols=18 rows=9 depths=10 -r
+r3.in.bin --o output=test_in_bin_float_6 byte=4 null=-9999 \
+ input=test_out_bin_float_native_rd_b4.bin order=native \
+ cols=18 rows=9 depths=10 -rd
+r3.in.bin --o output=test_in_bin_float_7 byte=1 null=-9999 \
+ input=test_out_bin_float_native_b1_as_integer.bin order=native \
+ cols=18 rows=9 depths=10 -i
+r3.in.bin --o output=test_in_bin_float_8 byte=2 null=-9999 \
+ input=test_out_bin_float_native_b2_as_integer.bin order=native \
+r3.in.bin --o output=test_in_bin_float_9 byte=4 null=-9999 \
+ input=test_out_bin_float_native_b4_as_integer.bin order=native \
+r3.in.bin --o output=test_in_bin_float_10 byte=8 null=-9999 \
+ input=test_out_bin_float_native_b8_as_integer.bin order=native \
+for map in `g.mlist type=rast3d pattern=test_in_bin_float*` ; do
+ r3.out.ascii input=${map} output=${map}.txt dp=0
+done
+for i in `ls test_in_bin_float_*.txt` ; do
+ diff $i test_out_bin_float.ref
+done
+g.mremove -f rast3d=*
+rm *.txt
+rm *.bin
Added: grass/trunk/raster3d/r3.in.bin/test_suite/test_out_bin_double.ref
--- grass/trunk/raster3d/r3.in.bin/test_suite/test_out_bin_double.ref (rev 0)
+++ grass/trunk/raster3d/r3.in.bin/test_suite/test_out_bin_double.ref 2012-11-14 15:09:32 UTC (rev 53806)
@@ -0,0 +1,101 @@
+version: grass7
+order: nsbt
+north: 90.000000
+south: 0.000000
+east: 180.000000
+west: 0.000000
+top: 100.000000
+bottom: 0.000000
+rows: 9
+cols: 18
+levels: 10
+1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
+3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3 3
+4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
+5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5
+6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6
+7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7
+8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8
+9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9 9
Added: grass/trunk/raster3d/r3.in.bin/test_suite/test_out_bin_float.ref
--- grass/trunk/raster3d/r3.in.bin/test_suite/test_out_bin_float.ref (rev 0)
+++ grass/trunk/raster3d/r3.in.bin/test_suite/test_out_bin_float.ref 2012-11-14 15:09:32 UTC (rev 53806)
@@ -0,0 +1,101 @@
+version: grass7
+order: nsbt
+north: 90.000000
+south: 0.000000
+east: 180.000000
+west: 0.000000
+top: 100.000000
+bottom: 0.000000
+rows: 9
+cols: 18
+levels: 10
Modified: grass/trunk/raster3d/r3.out.bin/main.c
--- grass/trunk/raster3d/r3.out.bin/main.c 2012-11-14 14:58:01 UTC (rev 53805)
+++ grass/trunk/raster3d/r3.out.bin/main.c 2012-11-14 15:09:32 UTC (rev 53806)
@@ -1,4 +1,3 @@
* MODULE: r3.out.bin
@@ -24,10 +23,18 @@
RASTER3D_Map *map;
+unsigned char *out_cell;
+ unsigned char t;
+ t = q[0];
+ q[0] = q[1];
+ q[1] = t;
unsigned char t;
@@ -56,24 +63,58 @@
q[4] = t;
-static void write_float(FILE *fp, int swap_flag, float x) {
- if (swap_flag)
- swap_4(&x);
+static void write_cell(FILE *fp, const DCELL in_cell, int as_integer, int bytes,
+ int swap_flag) {
+ if (!as_integer) {
+ switch (bytes) {
+ case 4:
+ *(float *) out_cell = (float) in_cell;
+ break;
+ case 8:
+ *(double *) out_cell = (double) in_cell;
+ break;
+ } else {
+ switch (bytes) {
+ case 1:
+ *(unsigned char *) out_cell = (unsigned char) in_cell;
+ break;
+ case 2:
+ *(short *) out_cell = (short) in_cell;
+ break;
+ case 4:
+ *(int *) out_cell = (int) in_cell;
+ break;
+ case 8:
+ *(long long *) out_cell = (long long) in_cell;
+ break;
+#endif
- if (fwrite(&x, 4, 1, fp) != 1)
- G_fatal_error(_("Error writing data"));
+ if (swap_flag) {
+ switch (bytes) {
+ case 1:
+ break;
+ case 2:
+ swap_2(out_cell);
+ break;
+ case 4:
+ swap_4(out_cell);
+ break;
+ case 8:
+ swap_8(out_cell);
+ break;
-static void write_double(FILE *fp, int swap_flag, double x) {
- if (swap_flag)
- swap_8(&x);
- if (fwrite(&x, 8, 1, fp) != 1)
+ if (fwrite(out_cell, bytes, 1, fp) != 1)
-void raster3d_to_bin(FILE * fp, DCELL null_value, int byte_swap, int row_swap,
- int depth_swap) {
+static void raster3d_to_bin(FILE * fp, DCELL null_value, int as_integer,
+ int bytes, int byte_swap, int row_swap, int depth_swap) {
DCELL dvalue;
FCELL fvalue;
int x, y, z;
@@ -88,13 +129,12 @@
for (z = 0; z < depths; z++) {
G_percent(z, depths, 1);
- for (y = 0; y < rows; y++) { /* g3d rows count from south to north */
+ for (y = 0; y < rows; y++) {
for (x = 0; x < cols; x++) {
col = x;
/* The default is to write rows from north to south
- to be r.in.ascii compatible
row = y;
@@ -113,17 +153,20 @@
Rast3d_get_value(map, col, row, depth, &fvalue, FCELL_TYPE);
if (Rast3d_is_null_value_num(&fvalue, FCELL_TYPE))
- write_float(fp, byte_swap, (float)null_value);
+ write_cell(fp, null_value, as_integer, bytes,
+ byte_swap);
else
- write_float(fp, byte_swap, fvalue);
+ write_cell(fp, (DCELL) fvalue, as_integer, bytes,
+ byte_swap);
} else {
Rast3d_get_value(map, col, row, depth, &dvalue, DCELL_TYPE);
if (Rast3d_is_null_value_num(&dvalue, DCELL_TYPE))
- write_double(fp, byte_swap, null_value);
+ byte_swap);
else
- write_double(fp, byte_swap, dvalue);
+ write_cell(fp, dvalue, as_integer, bytes, byte_swap);
@@ -139,9 +182,10 @@
} parm;
struct {
- struct Flag *swap, *row, *depth;
+ struct Flag *swap, *row, *depth, *integer;
} flag;
char *name;
char *outfile;
@@ -149,8 +193,12 @@
int do_stdout;
int order;
int swap_flag;
+ int bytes;
+ int as_integer = 0;
FILE *fp;
+ out_cell = NULL;
G_gisinit(argv[0]);
@@ -171,6 +219,14 @@
parm.null->answer = "0";
parm.null->description = _("Value to write out for null");
@@ -193,14 +249,34 @@
+ flag.integer = G_define_flag();
+ flag.integer->key = 'i';
+ flag.integer->description = _("Write data as integer");
exit(EXIT_FAILURE);
if (sscanf(parm.null->answer, "%lf", &null_val) != 1)
G_fatal_error(_("Invalid value for null (integers only)"));
+ as_integer = flag.integer->answer;
name = parm.input->answer;
+ else if (as_integer)
+ bytes = 4;
+ else
+ bytes = 8;
+ if (!as_integer && bytes < 4)
+ G_fatal_error(_("Floating-point output requires bytes=4 or bytes=8"));
+ if (as_integer && bytes > 4)
+ G_fatal_error(_("Integer output doesn't support bytes=8 in this build"));
+#endif
if (parm.output->answer)
outfile = parm.output->answer;
else {
@@ -227,6 +303,8 @@
do_stdout = strcmp("-", outfile) == 0;
+ out_cell = G_malloc(bytes);
if (NULL == G_find_raster3d(parm.input->answer, ""))
Rast3d_fatal_error(_("3D raster map <%s> not found"),
parm.input->answer);
@@ -263,13 +341,16 @@
G_verbose_message(_("cols=%d"), region.cols);
G_verbose_message(_("depths=%d"), region.depths);
- raster3d_to_bin(fp, null_val, swap_flag, flag.row->answer,
- flag.depth->answer);
+ raster3d_to_bin(fp, null_val, as_integer, bytes, swap_flag,
+ flag.row->answer, flag.depth->answer);
Rast3d_close(map);
fclose(fp);
+ if(out_cell)
+ G_free(out_cell);
