[GRASS-SVN] r53859 - in grass/trunk/gui/wxpython: . gmodeler gui_core lmgr scripts
svn_grass at osgeo.org
Sat Nov 17 09:17:24 PST 2012
Author: wenzeslaus
Date: 2012-11-17 09:17:23 -0800 (Sat, 17 Nov 2012)
New Revision: 53859
grass/trunk/gui/wxpython/gmodeler/frame.py
grass/trunk/gui/wxpython/gmodeler/model.py
grass/trunk/gui/wxpython/gui_core/forms.py
grass/trunk/gui/wxpython/gui_core/goutput.py
grass/trunk/gui/wxpython/gui_core/prompt.py
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/scripts/vkrige.py
grass/trunk/gui/wxpython/wxpythonlib.dox
wxGUI/goutput: rename GM (gis manager) classes to G (grass) classes (limited to goutput classes)
Modified: grass/trunk/gui/wxpython/gmodeler/frame.py
--- grass/trunk/gui/wxpython/gmodeler/frame.py 2012-11-17 16:46:32 UTC (rev 53858)
+++ grass/trunk/gui/wxpython/gmodeler/frame.py 2012-11-17 17:17:23 UTC (rev 53859)
@@ -34,7 +34,7 @@
from core import globalvar
from gui_core.widgets import GNotebook
-from gui_core.goutput import GMConsole
+from gui_core.goutput import GConsole
from core.debug import Debug
from core.gcmd import GMessage, GException, GWarning, GError, RunCommand
from gui_core.dialogs import GetImageHandlers
@@ -104,7 +104,7 @@
self.pythonPanel = PythonPanel(parent = self)
- self.goutput = GMConsole(parent = self, frame = self, notebook = self.notebook)
+ self.goutput = GConsole(parent = self, frame = self, notebook = self.notebook)
self.notebook.AddPage(page = self.canvas, text=_('Model'), name = 'model')
self.notebook.AddPage(page = self.itemPanel, text=_('Items'), name = 'items')
Modified: grass/trunk/gui/wxpython/gmodeler/model.py
--- grass/trunk/gui/wxpython/gmodeler/model.py 2012-11-17 16:46:32 UTC (rev 53858)
+++ grass/trunk/gui/wxpython/gmodeler/model.py 2012-11-17 17:17:23 UTC (rev 53859)
@@ -493,7 +493,7 @@
def Run(self, log, onDone, parent = None):
"""!Run model
- @param log logging window (see goutput.GMConsole)
+ @param log logging window (see goutput.GConsole)
@param onDone on-done method
@param parent window for messages or None
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py 2012-11-17 16:46:32 UTC (rev 53858)
+++ grass/trunk/gui/wxpython/gui_core/forms.py 2012-11-17 17:17:23 UTC (rev 53859)
@@ -1617,8 +1617,8 @@
# are we running from command line?
### add 'command output' tab regardless standalone dialog
if self.parent.GetName() == "MainFrame" and self.parent.get_dcmd is None:
- from gui_core.goutput import GMConsole
- self.goutput = GMConsole(parent = self.notebook, frame = self.parent, margin = False, notebook = self.notebook)
+ from gui_core.goutput import GConsole
+ self.goutput = GConsole(parent = self.notebook, frame = self.parent, margin = False, notebook = self.notebook)
self.outpage = self.notebook.AddPage(page = self.goutput, text = _("Command output"), name = 'output')
index = self.AddBitmapToImageList(section = 'output', imageList = imageList)
if index >= 0:
Modified: grass/trunk/gui/wxpython/gui_core/goutput.py
--- grass/trunk/gui/wxpython/gui_core/goutput.py 2012-11-17 16:46:32 UTC (rev 53858)
+++ grass/trunk/gui/wxpython/gui_core/goutput.py 2012-11-17 17:17:23 UTC (rev 53859)
@@ -5,10 +5,10 @@
Classes:
- goutput::CmdThread
- - goutput::GMConsole
- - goutput::GMStdout
- - goutput::GMStderr
- - goutput::GMStc
+ - goutput::GConsole
+ - goutput::GStdout
+ - goutput::GStderr
+ - goutput::GStc
(C) 2007-2012 by the GRASS Development Team
@@ -75,7 +75,7 @@
self.setDaemon(True)
- self.parent = parent # GMConsole
+ self.parent = parent # GConsole
self._want_abort_all = False
self.start()
@@ -193,7 +193,7 @@
if self.requestQ.empty():
-class GMConsole(wx.SplitterWindow):
+class GConsole(wx.SplitterWindow):
"""!Create and manage output console for commands run by GUI.
def __init__(self, parent, id = wx.ID_ANY, margin = False,
@@ -201,7 +201,7 @@
style = wx.TAB_TRAVERSAL | wx.FULL_REPAINT_ON_RESIZE,
**kwargs):
wx.SplitterWindow.__init__(self, parent, id, style = style, *kwargs)
- self.SetName("GMConsole")
+ self.SetName("GConsole")
self.panelOutput = wx.Panel(parent = self, id = wx.ID_ANY)
self.panelPrompt = wx.Panel(parent = self, id = wx.ID_ANY)
@@ -233,7 +233,7 @@
self.progressbar.Bind(EVT_CMD_PROGRESS, self.OnCmdProgress)
# text control for command output
- self.cmdOutput = GMStc(parent = self.panelOutput, id = wx.ID_ANY, margin = margin,
+ self.cmdOutput = GStc(parent = self.panelOutput, id = wx.ID_ANY, margin = margin,
wrap = None)
self.cmdOutputTimer = wx.Timer(self.cmdOutput, id = wx.ID_ANY)
self.cmdOutput.Bind(EVT_CMD_OUTPUT, self.OnCmdOutput)
@@ -261,8 +261,8 @@
self.search.Bind(wx.EVT_TEXT, self.OnUpdateStatusBar)
# stream redirection
- self.cmdStdOut = GMStdout(self)
- self.cmdStdErr = GMStderr(self)
+ self.cmdStdOut = GStdout(self)
+ self.cmdStdErr = GStderr(self)
# thread
self.cmdThread = CmdThread(self, self.requestQ, self.resultQ)
@@ -425,7 +425,7 @@
given style
@param line text line
- @param style text style (see GMStc)
+ @param style text style (see GStc)
@param stdout write to stdout or stderr
@@ -954,7 +954,7 @@
mapTree = self.frame.parent.GetLayerTree()
elif winName == 'LayerTree':
- elif winName: # GMConsole
+ elif winName: # GConsole
mapTree = self.frame.parent.parent.GetLayerTree()
else:
mapTree = None
@@ -1010,8 +1010,8 @@
"""!Get prompt"""
return self.cmdPrompt
-class GMStdout:
- """!GMConsole standard output
+class GStdout:
+ """!GConsole standard output
Based on FrameOutErr.py
@@ -1022,7 +1022,7 @@
Licence: GPL
def __init__(self, parent):
def write(self, s):
if len(s) == 0 or s == '\n':
@@ -1036,8 +1036,8 @@
type = '')
wx.PostEvent(self.parent.cmdOutput, evt)
-class GMStderr:
- """!GMConsole standard error output
+class GStderr:
+ """!GConsole standard error output
@@ -1048,7 +1048,7 @@
Licence: GPL
self.type = ''
self.message = ''
@@ -1109,8 +1109,8 @@
evt = wxCmdProgress(value = progressValue)
wx.PostEvent(self.parent.progressbar, evt)
-class GMStc(stc.StyledTextCtrl):
- """!Styled GMConsole
+class GStc(stc.StyledTextCtrl):
+ """!Styled text control for GRASS stdout and stderr.
Modified: grass/trunk/gui/wxpython/gui_core/prompt.py
--- grass/trunk/gui/wxpython/gui_core/prompt.py 2012-11-17 16:46:32 UTC (rev 53858)
+++ grass/trunk/gui/wxpython/gui_core/prompt.py 2012-11-17 17:17:23 UTC (rev 53859)
@@ -471,7 +471,7 @@
See subclass GPromptPopUp and GPromptSTC.
self.panel = self.parent.GetPanel()
if self.parent.parent.GetName() not in ("LayerManager", "Modeler"):
@@ -758,7 +758,7 @@
def OnTextSelectionChanged(self, event):
"""!Copy selected text to clipboard and skip event.
- The same function is in GMStc class (goutput.py).
+ The same function is in GStc class (goutput.py).
wx.CallAfter(self.Copy)
event.Skip()
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2012-11-17 16:46:32 UTC (rev 53858)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2012-11-17 17:17:23 UTC (rev 53859)
@@ -49,7 +49,7 @@
from modules.mcalc_builder import MapCalcFrame
from dbmgr.manager import AttributeManager
from core.workspace import ProcessWorkspaceFile, ProcessGrcFile, WriteWorkspaceFile
from gui_core.dialogs import GdalOutputDialog, DxfImportDialog, GdalImportDialog, MapLayersDialog
from gui_core.dialogs import EVT_APPLY_MAP_LAYERS
from gui_core.dialogs import LocationDialog, MapsetDialog, CreateNewVector, GroupDialog
@@ -255,7 +255,7 @@
self.notebook.AddPage(page = self.notebookLayers, text = _("Map layers"), name = 'layers')
# create 'command output' text area
- self.goutput = GMConsole(self, frame = self)
+ self.goutput = GConsole(self, frame = self)
self.notebook.AddPage(page = self.goutput, text = _("Command console"), name = 'output')
self._setCopyingOfSelectedText()
Modified: grass/trunk/gui/wxpython/scripts/vkrige.py
--- grass/trunk/gui/wxpython/scripts/vkrige.py 2012-11-17 16:46:32 UTC (rev 53858)
+++ grass/trunk/gui/wxpython/scripts/vkrige.py 2012-11-17 17:17:23 UTC (rev 53859)
@@ -98,7 +98,7 @@
self.CreatePage(package = Rpackage, Rinstance = Rinstance, controller = controller)
## Command output. From menuform module, cmdPanel class
- self.goutput = goutput.GMConsole(parent = self, frame = self.parent, margin = False,
+ self.goutput = goutput.GConsole(parent = self, frame = self.parent, margin = False,
notebook = self.RPackagesBook)
self.goutputId = self.RPackagesBook.GetPageCount()
self.outpage = self.RPackagesBook.AddPage(page = self.goutput, text = _("Command output"), name = 'output')
Modified: grass/trunk/gui/wxpython/wxpythonlib.dox
--- grass/trunk/gui/wxpython/wxpythonlib.dox 2012-11-17 16:46:32 UTC (rev 53858)
+++ grass/trunk/gui/wxpython/wxpythonlib.dox 2012-11-17 17:17:23 UTC (rev 53859)
@@ -118,10 +118,10 @@
- ghelp::HelpPanel
- gui_core::goutput
- - goutput::GMStc
+ - goutput::GStc
- gui_core::gselect
- gselect::Select
- gselect::VectorSelect
