[GRASS-SVN] r53860 - in grass/trunk/gui/wxpython: gui_core lmgr
Sat Nov 17 11:14:19 PST 2012
Author: wenzeslaus
Date: 2012-11-17 11:14:18 -0800 (Sat, 17 Nov 2012)
New Revision: 53860
   grass/trunk/gui/wxpython/gui_core/goutput.py
   grass/trunk/gui/wxpython/lmgr/frame.py
wxGUI/goutput: GConsole styles (co-author: annakrat)
Modified: grass/trunk/gui/wxpython/gui_core/goutput.py
--- grass/trunk/gui/wxpython/gui_core/goutput.py	2012-11-17 17:17:23 UTC (rev 53859)
+++ grass/trunk/gui/wxpython/gui_core/goutput.py	2012-11-17 19:14:18 UTC (rev 53860)
@@ -52,6 +52,12 @@
 wxCmdAbort,    EVT_CMD_ABORT    = NewEvent()
 wxCmdPrepare,  EVT_CMD_PREPARE  = NewEvent()
+GC_EMPTY = 0
+GC_SEARCH = 1
+GC_PROMPT = 2
 def GrassCmd(cmd, env = None, stdout = None, stderr = None):
     """!Return GRASS command thread"""
     return CommandThread(cmd, env = env,
@@ -199,6 +205,7 @@
     def __init__(self, parent, id = wx.ID_ANY, margin = False,
                  frame = None, notebook = None,
                  style = wx.TAB_TRAVERSAL | wx.FULL_REPAINT_ON_RESIZE,
+                 gcstyle = GC_EMPTY,
                  **kwargs):
         wx.SplitterWindow.__init__(self, parent, id, style = style, *kwargs)
         self.SetName("GConsole")
@@ -217,6 +224,8 @@
             self._notebook = notebook
         else:
             self._notebook = self.parent.notebook
+        self._gcstyle = gcstyle
         self.lineWidth       = 80
         # remember position of line begining (used for '\r')
@@ -241,14 +250,16 @@
         self.Bind(EVT_CMD_RUN,     self.OnCmdRun)
         self.Bind(EVT_CMD_DONE,    self.OnCmdDone)
         self.Bind(EVT_CMD_PREPARE, self.OnCmdPrepare)
         # search & command prompt
+        # move to the if below
+        # search depends on cmd prompt
         self.cmdPrompt = GPromptSTC(parent = self)
-        if self.parent.GetName() != 'LayerManager':
-            self.search = None
+        if not self._gcstyle & GC_PROMPT:
             self.cmdPrompt.Hide()
-        else:
+        if self._gcstyle & GC_SEARCH:
             self.infoCollapseLabelExp = _("Click here to show search module engine")
             self.infoCollapseLabelCol = _("Click here to hide search module engine")
             self.searchPane = wx.CollapsiblePane(parent = self.panelOutput,
@@ -259,7 +270,9 @@
             self.searchPane.Collapse(True)
             self.Bind(wx.EVT_COLLAPSIBLEPANE_CHANGED, self.OnSearchPaneChanged, self.searchPane)
             self.search.Bind(wx.EVT_TEXT,             self.OnUpdateStatusBar)
+        else:
+            self.search = None
         # stream redirection
         self.cmdStdOut = GStdout(self)
         self.cmdStdErr = GStderr(self)
@@ -269,9 +282,14 @@
         self.outputBox = wx.StaticBox(parent = self.panelOutput, id = wx.ID_ANY,
                                       label = " %s " % _("Output window"))
+        if self._gcstyle & GC_PROMPT:
+            cmdLabel = _("Command prompt")
+        else:
+            cmdLabel = _("Command")
         self.cmdBox = wx.StaticBox(parent = self.panelOutput, id = wx.ID_ANY,
-                                   label = " %s " % _("Command prompt"))
+                                   label = " %s " % cmdLabel)
         # buttons
         self.btnOutputClear = wx.Button(parent = self.panelOutput, id = wx.ID_CLEAR)
         self.btnOutputClear.SetToolTipString(_("Clear output window content"))
@@ -288,7 +306,7 @@
         self.btnCmdProtocol.SetToolTipString(_("Toggle to save list of executed commands into file; "
                                                "content saved when switching off."))
-        if self.frame.GetName() != 'LayerManager':
             self.btnCmdClear.Hide()
             self.btnCmdProtocol.Hide()
@@ -308,12 +326,12 @@
         outBtnSizer = wx.StaticBoxSizer(self.outputBox, wx.HORIZONTAL)
         cmdBtnSizer = wx.StaticBoxSizer(self.cmdBox, wx.HORIZONTAL)
-        if self.cmdPrompt.IsShown():
             promptSizer = wx.BoxSizer(wx.VERTICAL)
             promptSizer.Add(item = self.cmdPrompt, proportion = 1,
                         flag = wx.EXPAND | wx.LEFT | wx.RIGHT | wx.TOP, border = 3)
-        if self.search and self.search.IsShown():
             outputSizer.Add(item = self.searchPane, proportion = 0,
                             flag = wx.EXPAND | wx.ALL, border = 3)
         outputSizer.Add(item = self.cmdOutput, proportion = 1,
@@ -332,10 +350,10 @@
         cmdBtnSizer.Add(item = self.btnCmdAbort, proportion = 1,
                         flag = wx.ALIGN_CENTER | wx.RIGHT, border = 5)
+            proportion = (2, 3)
+        else:
             proportion = (1, 1)
-        else:
-            proportion = (2, 3)
         btnSizer.Add(item = outBtnSizer, proportion = proportion[0],
                      flag = wx.ALL | wx.ALIGN_CENTER, border = 5)
@@ -350,13 +368,13 @@
         # eliminate gtk_widget_size_allocate() warnings
         outputSizer.SetVirtualSizeHints(self.panelOutput)
             promptSizer.Fit(self)
             promptSizer.SetSizeHints(self)
             self.panelPrompt.SetSizer(promptSizer)
         # split window
             self.SplitHorizontally(self.panelOutput, self.panelPrompt, -50)
         else:
             self.SplitHorizontally(self.panelOutput, self.panelPrompt, -45)
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py	2012-11-17 17:17:23 UTC (rev 53859)
+++ grass/trunk/gui/wxpython/lmgr/frame.py	2012-11-17 19:14:18 UTC (rev 53860)
@@ -49,7 +49,7 @@
 from modules.mcalc_builder import MapCalcFrame
 from dbmgr.manager         import AttributeManager
 from core.workspace        import ProcessWorkspaceFile, ProcessGrcFile, WriteWorkspaceFile
-from gui_core.goutput      import GConsole
+from gui_core.goutput      import GConsole, GC_SEARCH, GC_PROMPT
 from gui_core.dialogs      import GdalOutputDialog, DxfImportDialog, GdalImportDialog, MapLayersDialog
 from gui_core.dialogs      import EVT_APPLY_MAP_LAYERS
 from gui_core.dialogs      import LocationDialog, MapsetDialog, CreateNewVector, GroupDialog
@@ -255,7 +255,8 @@
         self.notebook.AddPage(page = self.notebookLayers, text = _("Map layers"), name = 'layers')
         # create 'command output' text area
-        self.goutput = GConsole(self, frame = self)
+        self.goutput = GConsole(self, frame = self,
+                                gcstyle = GC_SEARCH | GC_PROMPT)
         self.notebook.AddPage(page = self.goutput, text = _("Command console"), name = 'output')
         self._setCopyingOfSelectedText()
