[GRASS-SVN] r53861 - grass/trunk/lib/python
Sat Nov 17 12:18:17 PST 2012
Author: huhabla
Date: 2012-11-17 12:18:16 -0800 (Sat, 17 Nov 2012)
New Revision: 53861
   grass/trunk/lib/python/array.py
Small bugfix and some example code
Modified: grass/trunk/lib/python/array.py
--- grass/trunk/lib/python/array.py	2012-11-17 19:14:18 UTC (rev 53860)
+++ grass/trunk/lib/python/array.py	2012-11-17 20:18:16 UTC (rev 53861)
@@ -2,22 +2,124 @@
 @brief GRASS Python scripting module (2D and 3D raster with numpy)
-Functions to use GRASS rasters with NumPy.
+Functions to use GRASS 2D and 3D rasters with NumPy.
 Usage:
 @code
-from grass.script import array as garray
-    map = 'elevation'
-    x = garray.array()
-    x.read(map)
-    # calculate something on array
-    x[...] = x / 50.
-    x.write(map + ".new")
+>>> import grass.script as grass
+>>> from grass.script import array as garray
+>>> # We create a temporary region that is only valid in this python session
+... grass.use_temp_region()
+>>> grass.run_command("g.region", n=80, e=120, t=60, s=0, w=0, b=0, res=20, res3=20)
+0
+>>> # Lets create a raster map numpy array
+... # based at the current region settings
+... map2d_1 = garray.array()
+>>> # Write some data
+... for y in range(map2d_1.shape[0]):
+...     for x in range(map2d_1.shape[1]):
+...         map2d_1[y][x] = y + x
+>>> # Lets have a look at the array
+... print map2d_1
+[[ 0.  1.  2.  3.  4.  5.]
+ [ 1.  2.  3.  4.  5.  6.]
+ [ 2.  3.  4.  5.  6.  7.]
+ [ 3.  4.  5.  6.  7.  8.]]
+>>> # This will write the numpy array as GRASS raster map
+... # with name map2d_1
+... map2d_1.write(mapname="map2d_1", overwrite=True)
+ 100%
+0
+>>> # We create a new array and read map2d_1 to modify it
+... map2d_2 = garray.array()
+>>> # Don't do map2d_2 = map2d_1 % 3
+... # because: this will overwrite the internal temporary filename
+... map2d_2.read("map2d_1")
+0
+>>> map2d_2 %= 3
+>>> # Show the result
+... print map2d_2
+[[ 0.  1.  2.  0.  1.  2.]
+ [ 1.  2.  0.  1.  2.  0.]
+ [ 2.  0.  1.  2.  0.  1.]
+ [ 0.  1.  2.  0.  1.  2.]]
+>>> # Write the result as new raster map with name map2d_2
+... map2d_2.write(mapname="map2d_2", overwrite=True)
+ 100%
+0
+>>> # Here we create a 3D raster map numpy array
+... # based in the current region settings
+... map3d_1 = garray.array3d()
+... # Note: the 3D array has map[depth][row][column] order
+... for z in range(map3d_1.shape[0]):
+...     for y in range(map3d_1.shape[1]):
+...         for x in range(map3d_1.shape[2]):
+...             map3d_1[z][y][x] = z + y + x
+>>> # Lets have a look at the 3D array
+... print map3d_1
+[[[  0.   1.   2.   3.   4.   5.]
+ [[  1.   2.   3.   4.   5.   6.]
+  [  4.   5.   6.   7.   8.   9.]]
+ [[  2.   3.   4.   5.   6.   7.]
+  [  5.   6.   7.   8.   9.  10.]]]
+>>> # This will write the numpy array as GRASS 3D raster map
+... # with name map3d_1
+... map3d_1.write(mapname="map3d_1", overwrite=True)
+Loading floating point data with 8 bytes ... (6x4x3)
+ 100%
+0
+>>> # We create a new 3D array and read map3d_1 to modify it
+... map3d_2 = garray.array3d()
+>>> # Don't do map3d_2 = map3d_1 % 3
+... map3d_2.read("map3d_1")
+0
+>>> map3d_2 %= 3
+... print map3d_2
+[[[ 0.  1.  2.  0.  1.  2.]
+ [[ 1.  2.  0.  1.  2.  0.]
+  [ 1.  2.  0.  1.  2.  0.]]
+ [[ 2.  0.  1.  2.  0.  1.]
+  [ 2.  0.  1.  2.  0.  1.]]]
+>>> # Write the result as new 3D raster map with name map3d_2
+... map3d_2.write(mapname="map3d_2", overwrite=True)
+ 100%
+0
 @endcode
-(C) 2010-2011 by Glynn Clements and the GRASS Development Team
+(C) 2010-2012 by Glynn Clements and the GRASS Development Team
 This program is free software under the GNU General Public
 License (>=v2). Read the file COPYING that comes with GRASS
 for details.
@@ -30,6 +132,7 @@
 import core as grass
 class array(numpy.memmap):
     def __new__(cls, dtype=numpy.double):
@@ -89,7 +192,8 @@
             output=self.filename,
             bytes=size,
             null=null,
-            quiet=True)
+            quiet=True,
+            overwrite=True)
     def write(self, mapname, title=None, null=None, overwrite=None):
         """!Write array into raster map
@@ -139,6 +243,7 @@
             rows=reg['rows'],
             cols=reg['cols'])
 class array3d(numpy.memmap):
@@ -163,9 +268,11 @@
             shape=shape)
         self.filename = filename
         return self
     def _close(self):
         numpy.memmap._close(self)
         if isinstance(self, array):
             grass.try_remove(self.filename)
@@ -199,7 +306,8 @@
             bytes=size,
             null=null,
-            quiet=True)
+            quiet=True,
+            overwrite=True)
     def write(self, mapname, null=None, overwrite=None):
         """!Write array into 3D raster map
@@ -213,6 +321,7 @@
         kind = self.dtype.kind
         size = self.dtype.itemsize
+        flags = None
         if kind == 'f':
             if size != 4 and size != 8:
@@ -244,3 +353,4 @@
             depths=reg['depths'],
             rows=reg['rows3'],
             cols=reg['cols3'])
