[GRASS-SVN] r53863 - in grass-addons/grass7/raster: . r.mcda.input
Sat Nov 17 15:38:49 PST 2012
Author: gianluca
Date: 2012-11-17 15:38:48 -0800 (Sat, 17 Nov 2012)
New Revision: 53863
Added:
   grass-addons/grass7/raster/r.mcda.input/
   grass-addons/grass7/raster/r.mcda.input/Makefile
   grass-addons/grass7/raster/r.mcda.input/description.html
   grass-addons/grass7/raster/r.mcda.input/r.mcda.input.py
convert old r.in.drsa to r.mcda.input
Added: grass-addons/grass7/raster/r.mcda.input/Makefile
--- grass-addons/grass7/raster/r.mcda.input/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.mcda.input/Makefile	2012-11-17 23:38:48 UTC (rev 53863)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.in.drsa
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/raster/r.mcda.input/Makefile
___________________________________________________________________
Added: svn:executable
Added: grass-addons/grass7/raster/r.mcda.input/description.html
--- grass-addons/grass7/raster/r.mcda.input/description.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.mcda.input/description.html	2012-11-17 23:38:48 UTC (rev 53863)
@@ -0,0 +1,33 @@
+<h2>DESCRIPTION</h2>
+<p>The <em>r.in.drsa</em> module will read a  *rls file output from
+jMAF, JAMM or 4eMka2 sofware <a href="http://idss.cs.put.poznan.pl/">
+Laboratory of Intelligent Decision Support Systems - Poznan University.</a>
+and returns maps of the rules </p>
+<em>(GRASS python Script)</em>
+<h2>NOTES</h2>
+<h2>TODO</h2>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.roughset.html">r.roughset</a>,
+<a href="r.mcda.regime.html">r.mcda.regime</a>,
+<a href="r.mcda.fuzzy.html">r.mcda.fuzzy</a>
+<a href="r.mcda.electre.html">r.mcda.electre</a>,
+<a href="r.mcda.ahp.html">r.mcda.ahp</a>
+<a href="r.mcda.roughset.html">r.mcda.roughset</a>
+<a href="r.in.drsa.html">r.in.drsa</a>
+<a href="r.to.drsa.html">r.to.drsa</a>
+</em>
+<h2>AUTHORS</h2>
+Antonio Boggia - Gianluca Massei<br>
+Department of Economics and Appraisal - University of Perugia - Italy
+<p>
+<i>Last changed: $Date: 2012-09-12 22:32:08 +0200 (mer, 12 set 2012) $</i>
Added: grass-addons/grass7/raster/r.mcda.input/r.mcda.input.py
--- grass-addons/grass7/raster/r.mcda.input/r.mcda.input.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.mcda.input/r.mcda.input.py	2012-11-17 23:38:48 UTC (rev 53863)
@@ -0,0 +1,179 @@
+#!/usr/bin/env python
+# MODULE:	   r.in.drsa
+# AUTHOR:	   Gianluca Massei - Antonio Boggia
+# PURPOSE:	  Import roles from *.rls file and apply those condition
+#			   at geographics information system for generate a raster
+#			   map classified under Dominance Rough Set Approach
+# COPYRIGHT:	c) 2010 Gianluca Massei, Antonio Boggia  and the GRASS
+#			   Development Team. This program is free software under the
+#			   GNU General PublicLicense (>=v2). Read the file COPYING
+#			   that comes with GRASS for details.
+#%Module
+#% description: Generate a raster map classified with Dominance Rough Set Approach. Use *.rls file from JAMM, 4eMka2 etc.
+#% keywords: raster, Dominance Rough Set Approach
+#% keywords: Multi Criteria Decision Analysis (MCDA)
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,file,input
+#% description: File name with rules (*.rls)
+#% required: yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new_file,cell,output
+#% description: output classified raster map
+#% required: yes
+#%end
+#%flag
+#% key:k
+#% description:file *.rls from software 4eMka2
+#% answer:true
+#%end
+#%flag
+#% key:j
+#% description:file *.rls from software jMAF (NOT YET IMPLEMENTED)
+#%end
+#%flag
+#% key: l
+#% description: do not remove single rules in vector format
+#% answer:false
+#%end
+import sys
+import grass.script as grass
+import pdb
+import string
+def parser_4eMka2_rule(tags):
+	"parser file *.rls from 4eMka2 software and extract information for make new classified raster"
+	rule=dict()
+	rules=[]
+	for t in tags:
+		condition=[]
+		decision=[]
+		row=t.split()
+		if(len(row)>0 and row[0]=="Rule"):
+			#rules_list.append(row)
+			i=row.index("=>")
+			for j in range(2,i):
+				 if( row[j]!="&"):
+					 condition.append(row[j].strip('[,;]'))
+			for j in range(i+1,len(row)-2):
+					 decision.append(row[j].strip('([,;])'))
+			rule={'id_rule':row[1].strip('[.;]'),
+				  'condition':condition,
+				  'decision':(decision[0]),
+				  'class':"_".join(decision[1:]),
+				  'support':int(row[-2].strip('[.,;]')),
+				  'strength':row[-1].strip('[,:]')}
+			rules.append(rule)
+	rls = open('rules',"w")
+	for l in rules:
+		factor=l['decision'].strip('()').split(' ')
+		rls.write('id_rule:%s - condition:%s - decision: %s - class:%s \n' % (l['id_rule'],l['condition'], l['decision'],l['class']))
+	rls.close
+	return rules
+def parser_JAMM_rule(tags):
+	"parser file *.rls from JAMM software and extract information for make new classified raster"
+def parser_mapcalc(rules,i):
+	"parser to build a formula to be included  in mapcalc command"
+	mapalgebra="if("
+	for j in rules[i]['condition'][:-1]:
+		mapalgebra+= j + " && "
+	mapalgebra+=rules[i]['condition'][-1]+","+rules[i]['id_rule']+",null())"
+	return mapalgebra
+def clean_rules(rules):
+	"cleans rules to no processed vaue from rules (eg = -> ==) "
+	for i in range(len(rules)):
+		for j in rules[i]['condition']:
+			if (j.find("<=")!=-1):
+				return 1
+			elif (j.find("<=")!=-1):
+				return 1
+			elif (j.find("=")!=-1):
+				j=j.replace("=","==")
+				return 0
+			else:
+				return -1
+def patch_georules(maps,outputMap):
+	labels=["_".join(m.split('_')[1:]) for m in maps]
+	labels=list(set(labels))
+	for l in labels:
+		print "mapping %s rule" % str(l)
+		map_synth=[]
+		for m in maps:
+			if l == "_".join(m.split('_')[1:]):
+				map_synth.append(m)
+		if len(map_synth)>1:
+			grass.run_command("r.patch", overwrite='True', input=(",".join(map_synth)), output=l )
+		else:
+			grass.run_command("g.copy",rast=(str(map_synth),l))
+		grass.run_command("r.to.vect", overwrite='True', flags='s', input=l, output=l, feature='area')
+		grass.run_command("v.db.addcol", map=l, columns='rule varchar(25)')
+		grass.run_command("v.db.update", map=l, column='rule', value=l)
+		grass.run_command("v.db.update", map=l, column='label', value=l)
+	mapstring=",".join(labels)
+	if len(maps)>1:
+		grass.run_command("v.patch", overwrite='True', flags='e', input=mapstring, output=outputMap)
+	else:
+		grass.run_command("g.copy",vect=(mapstring,outputMap))
+def main():
+	input_rules = options['input']
+	outputMap = options['output']
+	gregion = grass.region()
+	nrows = gregion['rows']
+	ncols = gregion['cols']
+	ewres=int(gregion['ewres'])
+	nsres=int(gregion['nsres'])
+	input_rules=open(input_rules,"r")
+	tags=input_rules.readlines()
+	rules=[]  #single rule (dictionary) in array
+	maps=[]
+	rules=parser_4eMka2_rule(tags)
+##	clean_rules(rules)
+		mappa="r"+rules[i]['id_rule']+"_"+rules[i]['class']
+		formula=parser_mapcalc(rules,i)
+		grass.mapcalc(mappa +"=" +formula)
+		maps.append(mappa)
+	maplist=",".join(maps)
+	print maplist
+	patch_georules(maps,outputMap)
+	if not flags['l']:
+		grass.run_command("g.remove",flags="quiet", rast=maplist)
+		grass.run_command("g.remove",flags="quiet", vect=maplist)
+	input_rules.close()
+	return 0
+if __name__ == "__main__":
+	options, flags = grass.parser()
+	sys.exit(main())
Property changes on: grass-addons/grass7/raster/r.mcda.input/r.mcda.input.py
