[GRASS-SVN] r53864 - in grass-addons/grass7/raster: . r.mcda.output
Sat Nov 17 15:54:06 PST 2012
Author: gianluca
Date: 2012-11-17 15:54:06 -0800 (Sat, 17 Nov 2012)
New Revision: 53864
Added:
   grass-addons/grass7/raster/r.mcda.output/
   grass-addons/grass7/raster/r.mcda.output/Makefile
   grass-addons/grass7/raster/r.mcda.output/description.html
   grass-addons/grass7/raster/r.mcda.output/r.mcda.output.py
convert old r.to.drsa to r.mcda.output
Added: grass-addons/grass7/raster/r.mcda.output/Makefile
--- grass-addons/grass7/raster/r.mcda.output/Makefile	                        (rev 0)
+++ grass-addons/grass7/raster/r.mcda.output/Makefile	2012-11-17 23:54:06 UTC (rev 53864)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.to.drsa
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/raster/r.mcda.output/Makefile
___________________________________________________________________
Added: svn:executable
Added: grass-addons/grass7/raster/r.mcda.output/description.html
--- grass-addons/grass7/raster/r.mcda.output/description.html	                        (rev 0)
+++ grass-addons/grass7/raster/r.mcda.output/description.html	2012-11-17 23:54:06 UTC (rev 53864)
@@ -0,0 +1,35 @@
+<h2>DESCRIPTION</h2>
+The <em>r.ro.drsa</em> module will export raster maps as a *isf file
+readable in jMAF, JAMM or 4eMka2 sofware <a href="http://idss.cs.put.poznan.pl/">Laboratory of Intelligent Decision Support Systems - Poznan University.</a>
+<p>
+<em>(GRASS python Script)</em>
+<h2>NOTES</h2>
+<p>
+This module, as all GRASS raster modules, will export cells based on the
+current region settings. See the <em>g.region</em> module for details.
+<h2>TODO</h2>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.roughset.html">r.roughset</a>,
+<a href="r.mcda.regime.html">r.mcda.regime</a>,
+<a href="r.mcda.fuzzy.html">r.mcda.fuzzy</a>
+<a href="r.mcda.electre.html">r.mcda.electre</a>,
+<a href="r.in.drsa.html">r.in.drsa</a>
+</em>
+<h2>AUTHORS</h2>
+Antonio Boggia - Gianluca Massei<br>
+Department of Economics and Appraisal - University of Perugia - Italy
+<p>
+<i>Last changed: $Date: 2012-09-12 22:32:08 +0200 (mer, 12 set 2012) $</i>
Added: grass-addons/grass7/raster/r.mcda.output/r.mcda.output.py
--- grass-addons/grass7/raster/r.mcda.output/r.mcda.output.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.mcda.output/r.mcda.output.py	2012-11-17 23:54:06 UTC (rev 53864)
@@ -0,0 +1,127 @@
+#!/usr/bin/env python
+# MODULE:       r.to.drsa
+# AUTHOR:       Gianluca Massei - Antonio Boggia
+# PURPOSE:      Export criteria raster maps and decision raster map in a *.isf
+#               file for dominance rough set approach analysis (DRSA)
+#               Dominance Rough Set Analysis (e.g. 4eMka2,JAMM, jMAF).
+# COPYRIGHT:    c) 2010 Gianluca Massei, Antonio Boggia  and the GRASS
+#               Development Team. This program is free software under the
+#               GNU General PublicLicense (>=v2). Read the file COPYING
+#               that comes with GRASS for details.
+#%Module
+#% description: Export criteria raster maps and decision raster map in a *.isf file (e.g. 4eMka2, jMAF) for dominance rough set approach analysis
+#% keywords: raster, Dominance Rough Set Approach
+#% keywords: Multi Criteria Decision Analysis (MCDA)
+#%End
+#%option
+#% key: attributes
+#% type: string
+#% multiple: yes
+#% gisprompt: old,cell,raster
+#% key_desc: name
+#% description: Name of criteria raster maps
+#% required: yes
+#%end
+#%option
+#% key: preferences
+#% type: string
+#% key_desc: character
+#% description: gain,cost,none
+#% required: yes
+#%end
+#%option
+#% key: decision
+#% type: string
+#% key_desc: name
+#% description: Name of decision raster map
+#% required: yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new_file,file,output
+#% key_desc: name
+#% description: Name for output file (*.isf file, Information System)
+#% answer:infosys.isf
+#% required: yes
+#%end
+import sys
+##from grass.script import core as grass
+import grass.script as grass
+def main():
+    attributes = options['attributes'].split(',')
+    preferences=options['preferences'].split(',')
+    decision=options['decision']
+    output = options['output']
+    gregion = grass.region()
+    nrows = gregion['rows']
+    ncols = gregion['cols']
+    ewres=int(gregion['ewres'])
+    nsres=int(gregion['nsres'])
+    print nrows, ncols, ewres,nsres
+    outf = file(output,"w")
+    outf.write("**ATTRIBUTES\n")
+    for i in range(len(attributes)):
+        outf.write("+ %s: (continuous)\n" % attributes[i])
+    outf.write("+ %s: [" % decision)
+    value=[]
+    value=grass.read_command("r.describe", flags = "1n", map = decision)
+    v=value.split()
+    for i in range(len(v)-1):
+        outf.write("%s, " % str(v[i]))
+    outf.write("%s]\n" % str(v[len(v)-1]))
+    outf.write("decision: %s\n" % decision)
+    outf.write("\n**PREFERENCES\n")
+        if(preferences[i]==""):
+            preferences[i]="none"
+        outf.write("%s: %s\n" % (attributes[i], preferences[i]))
+    outf.write("%s: gain\n" % decision)
+    outf.write("\n**EXAMPLES\n")
+    examples=[]
+    MATRIX=[]
+        grass.mapcalc("rast=if(isnull(${decision})==0,${attribute},null())",
+                         rast="rast",
+                         decision=decision,
+                         attribute=attributes[i])
+        tmp=grass.read_command("r.stats", flags = "1n", nv="?", input = "rast")
+        example=tmp.split()
+        examples.append(example)
+    tmp=grass.read_command("r.stats", flags = "1n", nv="?", input = decision)
+    MATRIX=map(list,zip(*examples))
+    MATRIX=[r for r in MATRIX if not '?' in r] #remove all rows with almost one "?"
+    MATRIX=[list(i) for i in set(tuple(j) for j in MATRIX)] #remove duplicate example
+    print "rows:%d - col:%d" %(len(MATRIX),len(MATRIX[0]))
+    for r in range(len(MATRIX)):
+        for c in range(len(MATRIX[0])):
+            outf.write("%s " %  str(MATRIX[r][c]))
+        outf.write("\n")
+    outf.write("**END")
+    outf.close()
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
Property changes on: grass-addons/grass7/raster/r.mcda.output/r.mcda.output.py
