[GRASS-SVN] r53880 - grass/trunk/lib/ogsf
svn_grass at osgeo.org
Sun Nov 18 02:24:41 PST 2012
Author: martinl
Date: 2012-11-18 02:24:41 -0800 (Sun, 18 Nov 2012)
New Revision: 53880
grass/trunk/lib/ogsf/gsd_img_mpeg.c
ogsf: support also older FFMPEG API (see r53854)
Modified: grass/trunk/lib/ogsf/gsd_img_mpeg.c
--- grass/trunk/lib/ogsf/gsd_img_mpeg.c 2012-11-18 10:14:43 UTC (rev 53879)
+++ grass/trunk/lib/ogsf/gsd_img_mpeg.c 2012-11-18 10:24:41 UTC (rev 53880)
@@ -5,15 +5,14 @@
GRASS OpenGL gsurf OGSF Library
- (C) 1999-2008 by the GRASS Development Team
+ (C) 1999-2008, 2012 by the GRASS Development Team
- This program is free software under the
- GNU General Public License (>=v2).
- Read the file COPYING that comes with GRASS
- for details.
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
\author Bill Brown USACERL, GMSL/University of Illinois
- \author Doxygenized by Martin Landa <landa.martin gmail.com> (May 2008)
+ \author Doxygenized (May 2008) and update for FFMPEG >= 0.7
+ (November 2012) by Martin Landa <landa.martin gmail.com>
#include <stdlib.h>
@@ -58,7 +57,11 @@
AVCodecContext *c;
AVStream *st;
+#if LIBAVFORMAT_VERSION_INT < AV_VERSION_INT(52, 100, 0)
+ st = av_new_stream(oc, 0);
+#else
st = avformat_new_stream(oc, NULL);
+#endif
if (!st) {
G_warning(_("Unable to allocate stream"));
return NULL;
@@ -97,12 +100,13 @@
c->flags |= CODEC_FLAG_GLOBAL_HEADER;
c->flags |= CODEC_FLAG_QSCALE;
- /* Quality, as it has been removed from AVCodecContext and put in AVVideoFrame.
- \todo use AVVideoFrame
- c->global_quality = st->quality = FF_QP2LAMBDA * 10;
+ /* Quality, as it has been removed from AVCodecContext and put in AVVideoFrame. */
+ c->global_quality = st->quality = FF_QP2LAMBDA * 10;
+#else
c->global_quality = FF_QP2LAMBDA * 10;
+#endif
return st;
@@ -163,7 +167,11 @@
/* open the codec */
+ if (avcodec_open(c, codec) < 0) {
+#else
if (avcodec_open2(c, codec, NULL) < 0) {
+#endif
G_warning(_("Unable to open codec"));
return;
@@ -338,12 +346,20 @@
/* set the output parameters (must be done even if no parameters). */
+ if (av_set_parameters(oc, NULL) < 0) {
+#else
if (avformat_write_header(oc, NULL) < 0) {
+#endif
G_warning(_("Invalid output format parameters"));
- return (-1);
+ return -1;
+ dump_format(oc, 0, filename, 1);
+#else
av_dump_format(oc, 0, filename, 1);
+#endif
/* now that all the parameters are set, we can open the audio and
video codecs and allocate the necessary encode buffers */
@@ -352,21 +368,28 @@
/* open the output file, if needed */
if (!(fmt->flags & AVFMT_NOFILE)) {
+ if (url_fopen(&oc->pb, filename, URL_WRONLY) < 0) {
+#else
if (avio_open(&oc->pb, filename, AVIO_FLAG_WRITE) < 0) {
+#endif
G_warning(_("Unable to open <%s>"), filename);
return (-1);
/* write the stream header, if any */
+ av_write_header(oc);
+#else
avformat_write_header(oc, NULL);
+#endif
#else
- G_warning(_("NVIZ has not been built with MPEG output support"));
- return (-1);
+ G_warning(_("OGSF library has not been built with MPEG output support"));
+ return -1;
#endif
- return (0);
+ return 0;
@@ -441,7 +464,13 @@
/* close the output file */
- avio_close(oc->pb);
+#if (LIBAVFORMAT_VERSION_INT>>16) < 52
+ url_fclose(&oc->pb);
+#elif LIBAVFORMAT_VERSION_INT < AV_VERSION_INT(52, 100, 0)
+ url_fclose(oc->pb);
+#else
+ avio_close(oc->pb);
+#endif
/* free the stream */
@@ -451,5 +480,5 @@
G_debug(3, "Closed MPEG stream");
#endif
- return (0);
+ return 0;
