[GRASS-SVN] r53881 - grass/trunk
svn_grass at osgeo.org
Sun Nov 18 02:25:47 PST 2012
Author: martinl
Date: 2012-11-18 02:25:46 -0800 (Sun, 18 Nov 2012)
New Revision: 53881
grass/trunk/configure
grass/trunk/configure.in
configure: ffmpeg don't use new and deprecated fns for LOC_CHECK_LIB
Modified: grass/trunk/configure
--- grass/trunk/configure 2012-11-18 10:24:41 UTC (rev 53880)
+++ grass/trunk/configure 2012-11-18 10:25:46 UTC (rev 53881)
@@ -8948,9 +8948,9 @@
-echo $ac_n "checking for avformat_write_header in -lavformat""... $ac_c" 1>&6
-echo "configure:8953: checking for avformat_write_header in -lavformat" >&5
-ac_lib_var=`echo avformat'_'avformat_write_header | sed 'y%./+-%__p_%'`
+echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
+echo "configure:8953: checking for avformat_alloc_context in -lavformat" >&5
+ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lavformat $FFMPEGLIB $LIBS"
@@ -8960,10 +8960,10 @@
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
-char avformat_write_header();
+char avformat_alloc_context();
int main() {
-avformat_write_header()
+avformat_alloc_context()
; return 0; }
EOF
if { (eval echo configure:8970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
@@ -8984,9 +8984,9 @@
else
echo "$ac_t""no" 1>&6
-echo "configure:8989: checking for avformat_write_header in -lavformat" >&5
+echo "configure:8989: checking for avformat_alloc_context in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
@@ -8996,10 +8996,10 @@
int main() {
; return 0; }
EOF
if { (eval echo configure:9006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2012-11-18 10:24:41 UTC (rev 53880)
+++ grass/trunk/configure.in 2012-11-18 10:25:46 UTC (rev 53881)
@@ -1140,7 +1140,7 @@
LOC_CHECK_LIBS(avutil, av_free, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB,,,,$MATHLIB)
LOC_CHECK_LIBS(avcodec, avcodec_register, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB, $FFMPEGLIB,,,$MATHLIB)
-LOC_CHECK_LIBS(avformat, avformat_write_header, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB, $FFMPEGLIB,,,$MATHLIB)
+LOC_CHECK_LIBS(avformat, avformat_alloc_context, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB, $FFMPEGLIB,,,$MATHLIB)
fi # $USE_FFMPEG
