[GRASS-SVN] r53895 - in grass/trunk/gui/wxpython: . gmodeler gui_core modules
svn_grass at osgeo.org
Sun Nov 18 08:06:00 PST 2012
Author: wenzeslaus
Date: 2012-11-18 08:05:59 -0800 (Sun, 18 Nov 2012)
New Revision: 53895
grass/trunk/gui/wxpython/gmodeler/dialogs.py
grass/trunk/gui/wxpython/gui_core/ghelp.py
grass/trunk/gui/wxpython/gui_core/goutput.py
grass/trunk/gui/wxpython/gui_core/menu.py
grass/trunk/gui/wxpython/gui_core/widgets.py
grass/trunk/gui/wxpython/modules/extensions.py
grass/trunk/gui/wxpython/wxpythonlib.dox
wxGUI/SearchModuleWindow: move from ghelp to widgets
Modified: grass/trunk/gui/wxpython/gmodeler/dialogs.py
--- grass/trunk/gui/wxpython/gmodeler/dialogs.py 2012-11-18 13:43:05 UTC (rev 53894)
+++ grass/trunk/gui/wxpython/gmodeler/dialogs.py 2012-11-18 16:05:59 UTC (rev 53895)
@@ -32,10 +32,9 @@
from core import globalvar
from core import utils
from core.modulesdata import ModulesData
-from gui_core.widgets import GNotebook
+from gui_core.widgets import SearchModuleWindow, EVT_MODULE_SELECTED
from core.gcmd import GError, EncodeString
from gui_core.dialogs import ElementDialog, MapLayersDialogForModeler
-from gui_core.ghelp import SearchModuleWindow, EVT_MODULE_SELECTED
from gui_core.prompt import GPromptSTC
from gui_core.forms import CmdPanel
from gui_core.gselect import Select
Modified: grass/trunk/gui/wxpython/gui_core/ghelp.py
--- grass/trunk/gui/wxpython/gui_core/ghelp.py 2012-11-18 13:43:05 UTC (rev 53894)
+++ grass/trunk/gui/wxpython/gui_core/ghelp.py 2012-11-18 16:05:59 UTC (rev 53895)
@@ -4,7 +4,6 @@
@brief Help/about window, menu tree, search module tree
Classes:
- - ghelp::SearchModuleWindow
- ghelp::AboutWindow
- ghelp::HelpFrame
- ghelp::HelpWindow
@@ -19,155 +18,24 @@
import os
-import sys
import codecs
import platform
import wx
from wx.html import HtmlWindow
try:
- import wx.lib.agw.customtreectrl as CT
from wx.lib.agw.hyperlink import HyperLinkCtrl
except ImportError:
- import wx.lib.customtreectrl as CT
from wx.lib.hyperlink import HyperLinkCtrl
-import wx.lib.flatnotebook as FN
-from wx.lib.newevent import NewEvent
import grass.script as grass
-from core import utils
from core.gcmd import GError, DecodeString
-from gui_core.widgets import FormListbook, StaticWrapText, ScrolledPanel
+from gui_core.widgets import FormListbook, ScrolledPanel
from core.debug import Debug
-from core.settings import UserSettings
-gModuleSelected, EVT_MODULE_SELECTED = NewEvent()
-class SearchModuleWindow(wx.Panel):
- """!Search module window (used in MenuTreeWindow)"""
- def __init__(self, parent, modulesData, id = wx.ID_ANY,
- showChoice = True, showTip = False, **kwargs):
- self.showTip = showTip
- self.showChoice = showChoice
- self.modulesData = modulesData
- wx.Panel.__init__(self, parent = parent, id = id, **kwargs)
- self._searchDict = { _('description') : 'description',
- _('command') : 'command',
- _('keywords') : 'keywords' }
- self.box = wx.StaticBox(parent = self, id = wx.ID_ANY,
- label = " %s " % _("Find module - (press Enter for next match)"))
- self.searchBy = wx.Choice(parent = self, id = wx.ID_ANY)
- items = [_('description'), _('keywords'), _('command')]
- datas = ['description', 'keywords', 'command']
- for item, data in zip(items, datas):
- self.searchBy.Append(item = item, clientData = data)
- self.searchBy.SetSelection(0)
- self.search = wx.SearchCtrl(parent = self, id = wx.ID_ANY,
- size = (-1, 25), style = wx.TE_PROCESS_ENTER)
- self.search.Bind(wx.EVT_TEXT, self.OnSearchModule)
- if self.showTip:
- self.searchTip = StaticWrapText(parent = self, id = wx.ID_ANY,
- size = (-1, 35))
- if self.showChoice:
- self.searchChoice = wx.Choice(parent = self, id = wx.ID_ANY)
- self.searchChoice.SetItems(self.modulesData.GetCommandItems())
- self.searchChoice.Bind(wx.EVT_CHOICE, self.OnSelectModule)
- self._layout()
- def _layout(self):
- """!Do layout"""
- sizer = wx.StaticBoxSizer(self.box, wx.HORIZONTAL)
- gridSizer = wx.GridBagSizer(hgap = 3, vgap = 3)
- gridSizer.Add(item = self.searchBy,
- flag = wx.ALIGN_CENTER_VERTICAL, pos = (0, 0))
- gridSizer.Add(item = self.search,
- flag = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND, pos = (0, 1))
- row = 1
- gridSizer.Add(item = self.searchChoice,
- flag = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND, pos = (row, 0), span = (1, 2))
- row += 1
- if self.showTip:
- gridSizer.Add(item = self.searchTip,
- row += 1
- gridSizer.AddGrowableCol(1)
- sizer.Add(item = gridSizer, proportion = 1)
- self.SetSizer(sizer)
- sizer.Fit(self)
- def GetCtrl(self):
- """!Get SearchCtrl widget"""
- return self.search
- def GetSelection(self):
- """!Get selected element"""
- selection = self.searchBy.GetStringSelection()
- return self._searchDict[selection]
- def SetSelection(self, i):
- """!Set selection element"""
- self.searchBy.SetSelection(i)
- def OnSearchModule(self, event):
- """!Search module by keywords or description"""
- text = event.GetEventObject().GetValue()
- if not text:
- self.modulesData.SetFilter()
- mList = self.modulesData.GetCommandItems()
- self.searchChoice.SetItems(mList)
- if self.showTip:
- self.searchTip.SetLabel(_("%d modules found") % len(mList))
- event.Skip()
- return
- findIn = self.searchBy.GetClientData(self.searchBy.GetSelection())
- modules, nFound = self.modulesData.FindModules(text = text, findIn = findIn)
- self.modulesData.SetFilter(modules)
- self.searchChoice.SetSelection(0)
- if self.showTip:
- self.searchTip.SetLabel(_("%d modules match") % nFound)
- event.Skip()
- def OnSelectModule(self, event):
- """!Module selected from choice, update command prompt"""
- cmd = event.GetString().split(' ', 1)[0]
- moduleEvent = gModuleSelected(name = cmd)
- wx.PostEvent(self, moduleEvent)
- desc = self.modulesData.GetCommandDesc(cmd)
- if self.showTip:
- self.searchTip.SetLabel(desc)
- def Reset(self):
- """!Reset widget"""
- self.search.SetValue('')
- if self.showTip:
- self.searchTip.SetLabel('')
class AboutWindow(wx.Frame):
"""!Create custom About Window
Modified: grass/trunk/gui/wxpython/gui_core/goutput.py
--- grass/trunk/gui/wxpython/gui_core/goutput.py 2012-11-18 13:43:05 UTC (rev 53894)
+++ grass/trunk/gui/wxpython/gui_core/goutput.py 2012-11-18 16:05:59 UTC (rev 53895)
@@ -43,7 +43,7 @@
from core.settings import UserSettings, GetDisplayVectSettings
wxCmdOutput, EVT_CMD_OUTPUT = NewEvent()
Modified: grass/trunk/gui/wxpython/gui_core/menu.py
--- grass/trunk/gui/wxpython/gui_core/menu.py 2012-11-18 13:43:05 UTC (rev 53894)
+++ grass/trunk/gui/wxpython/gui_core/menu.py 2012-11-18 16:05:59 UTC (rev 53895)
@@ -27,9 +27,8 @@
from core.gcmd import EncodeString
-from gui_core.widgets import ItemTree
+from gui_core.widgets import ItemTree, SearchModuleWindow
from lmgr.menudata import LayerManagerMenuData
class Menu(wx.MenuBar):
def __init__(self, parent, data):
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py 2012-11-18 13:43:05 UTC (rev 53894)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py 2012-11-18 16:05:59 UTC (rev 53895)
@@ -15,6 +15,7 @@
- widgets::FloatValidator
- widgets::ItemTree
- widgets::GListCtrl
+ - widgets::SearchModuleWindow
(C) 2008-2012 by the GRASS Development Team
@@ -706,3 +707,129 @@
self.CheckItem(item, False)
event.Skip()
+gModuleSelected, EVT_MODULE_SELECTED = NewEvent()
+class SearchModuleWindow(wx.Panel):
+ """!Search module window (used in MenuTreeWindow)"""
+ def __init__(self, parent, modulesData, id = wx.ID_ANY,
+ showChoice = True, showTip = False, **kwargs):
+ self.showTip = showTip
+ self.showChoice = showChoice
+ self.modulesData = modulesData
+ wx.Panel.__init__(self, parent = parent, id = id, **kwargs)
+ self._searchDict = { _('description') : 'description',
+ _('command') : 'command',
+ _('keywords') : 'keywords' }
+ self.box = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label = " %s " % _("Find module - (press Enter for next match)"))
+ self.searchBy = wx.Choice(parent = self, id = wx.ID_ANY)
+ items = [_('description'), _('keywords'), _('command')]
+ datas = ['description', 'keywords', 'command']
+ for item, data in zip(items, datas):
+ self.searchBy.Append(item = item, clientData = data)
+ self.searchBy.SetSelection(0)
+ self.search = wx.SearchCtrl(parent = self, id = wx.ID_ANY,
+ size = (-1, 25), style = wx.TE_PROCESS_ENTER)
+ self.search.Bind(wx.EVT_TEXT, self.OnSearchModule)
+ if self.showTip:
+ self.searchTip = StaticWrapText(parent = self, id = wx.ID_ANY,
+ size = (-1, 35))
+ if self.showChoice:
+ self.searchChoice = wx.Choice(parent = self, id = wx.ID_ANY)
+ self.searchChoice.SetItems(self.modulesData.GetCommandItems())
+ self.searchChoice.Bind(wx.EVT_CHOICE, self.OnSelectModule)
+ self._layout()
+ def _layout(self):
+ """!Do layout"""
+ sizer = wx.StaticBoxSizer(self.box, wx.HORIZONTAL)
+ gridSizer = wx.GridBagSizer(hgap = 3, vgap = 3)
+ gridSizer.Add(item = self.searchBy,
+ flag = wx.ALIGN_CENTER_VERTICAL, pos = (0, 0))
+ gridSizer.Add(item = self.search,
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND, pos = (0, 1))
+ row = 1
+ gridSizer.Add(item = self.searchChoice,
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND, pos = (row, 0), span = (1, 2))
+ row += 1
+ if self.showTip:
+ gridSizer.Add(item = self.searchTip,
+ row += 1
+ gridSizer.AddGrowableCol(1)
+ sizer.Add(item = gridSizer, proportion = 1)
+ self.SetSizer(sizer)
+ sizer.Fit(self)
+ def GetCtrl(self):
+ """!Get SearchCtrl widget"""
+ return self.search
+ def GetSelection(self):
+ """!Get selected element"""
+ selection = self.searchBy.GetStringSelection()
+ return self._searchDict[selection]
+ def SetSelection(self, i):
+ """!Set selection element"""
+ self.searchBy.SetSelection(i)
+ def OnSearchModule(self, event):
+ """!Search module by keywords or description"""
+ text = event.GetEventObject().GetValue()
+ if not text:
+ self.modulesData.SetFilter()
+ mList = self.modulesData.GetCommandItems()
+ self.searchChoice.SetItems(mList)
+ if self.showTip:
+ self.searchTip.SetLabel(_("%d modules found") % len(mList))
+ event.Skip()
+ return
+ findIn = self.searchBy.GetClientData(self.searchBy.GetSelection())
+ modules, nFound = self.modulesData.FindModules(text = text, findIn = findIn)
+ self.modulesData.SetFilter(modules)
+ self.searchChoice.SetSelection(0)
+ if self.showTip:
+ self.searchTip.SetLabel(_("%d modules match") % nFound)
+ event.Skip()
+ def OnSelectModule(self, event):
+ """!Module selected from choice, update command prompt"""
+ cmd = event.GetString().split(' ', 1)[0]
+ moduleEvent = gModuleSelected(name = cmd)
+ wx.PostEvent(self, moduleEvent)
+ desc = self.modulesData.GetCommandDesc(cmd)
+ if self.showTip:
+ self.searchTip.SetLabel(desc)
+ def Reset(self):
+ """!Reset widget"""
+ self.search.SetValue('')
+ if self.showTip:
+ self.searchTip.SetLabel('')
Modified: grass/trunk/gui/wxpython/modules/extensions.py
--- grass/trunk/gui/wxpython/modules/extensions.py 2012-11-18 13:43:05 UTC (rev 53894)
+++ grass/trunk/gui/wxpython/modules/extensions.py 2012-11-18 16:05:59 UTC (rev 53895)
@@ -34,9 +34,9 @@
from core.gcmd import GError, RunCommand
from core.utils import SetAddOnPath
from gui_core.forms import GUI
-from gui_core.widgets import ItemTree, GListCtrl
+from gui_core.widgets import ItemTree, GListCtrl, SearchModuleWindow
class InstallExtensionWindow(wx.Frame):
def __init__(self, parent, id = wx.ID_ANY,
title = _("Fetch & install extension from GRASS Addons"), **kwargs):
Modified: grass/trunk/gui/wxpython/wxpythonlib.dox
--- grass/trunk/gui/wxpython/wxpythonlib.dox 2012-11-18 13:43:05 UTC (rev 53894)
+++ grass/trunk/gui/wxpython/wxpythonlib.dox 2012-11-18 16:05:59 UTC (rev 53895)
@@ -113,7 +113,6 @@
- forms::CmdPanel
- forms::GrassGUIApp
- gui_core::ghelp
- ghelp::HelpFrame
- ghelp::HelpWindow
@@ -177,6 +176,7 @@
- widgets::NTCValidator
- widgets::ItemTree
\subsection lmgr Layer Manager
