[GRASS-SVN] r53896 - grass/trunk/vector/v.kernel
svn_grass at osgeo.org
Sun Nov 18 08:13:44 PST 2012
Author: mmetz
Date: 2012-11-18 08:13:44 -0800 (Sun, 18 Nov 2012)
New Revision: 53896
grass/trunk/vector/v.kernel/function.c
grass/trunk/vector/v.kernel/global.h
grass/trunk/vector/v.kernel/main.c
v.kernel optimization
Modified: grass/trunk/vector/v.kernel/function.c
--- grass/trunk/vector/v.kernel/function.c 2012-11-18 16:05:59 UTC (rev 53895)
+++ grass/trunk/vector/v.kernel/function.c 2012-11-18 16:13:44 UTC (rev 53896)
@@ -4,6 +4,8 @@
#include <grass/glocale.h>
#include "global.h"
+static double (*kernelfn)(int dimension, double bandwidth, double x);
/*********************** Gaussian ****************************/
/* probability for gaussian distribution */
double gaussian2dBySigma(double d, double sigma)
@@ -214,33 +216,36 @@
return k * (M_PI / 4. * cos(M_PI / 2. * x));
-double kernelFunction(int function, int dimension, double bandwidth, double x)
+double kernelFunction(int dimension, double bandwidth, double x)
- if (dimension > 2 && function != KERNEL_GAUSSIAN) {
- G_fatal_error(_("Dimension > 2 supported only by gaussian function"));
+ return kernelfn(dimension, bandwidth, x);
+void setKernelFunction(int function)
switch (function) {
case KERNEL_UNIFORM:
- return uniformKernel(dimension, bandwidth, x);
+ kernelfn = uniformKernel;
break;
case KERNEL_TRIANGULAR:
- return triangularKernel(dimension, bandwidth, x);
+ kernelfn = triangularKernel;
break;
case KERNEL_EPANECHNIKOV:
- return epanechnikovKernel(dimension, bandwidth, x);
+ kernelfn = epanechnikovKernel;
break;
case KERNEL_QUARTIC:
- return quarticKernel(dimension, bandwidth, x);
+ kernelfn = quarticKernel;
break;
case KERNEL_TRIWEIGHT:
- return triweightKernel(dimension, bandwidth, x);
+ kernelfn = triweightKernel;
break;
case KERNEL_GAUSSIAN:
- return gaussianKernel2(dimension, bandwidth, x);
+ kernelfn = gaussianKernel2;
break;
case KERNEL_COSINE:
- return cosineKernel(dimension, bandwidth, x);
+ kernelfn = cosineKernel;
break;
+ default:
+ G_fatal_error("Unknown kernel function");
- G_fatal_error("Unknown kernel function");
Modified: grass/trunk/vector/v.kernel/global.h
--- grass/trunk/vector/v.kernel/global.h 2012-11-18 16:05:59 UTC (rev 53895)
+++ grass/trunk/vector/v.kernel/global.h 2012-11-18 16:13:44 UTC (rev 53896)
@@ -15,7 +15,8 @@
#define KERNEL_COSINE 6
-double kernelFunction(int function, int dimension, double bandwidth, double x);
+void setKernelFunction(int function);
+double kernelFunction(int dimension, double bandwidth, double x);
double euclidean_distance(double *x, double *y, int n);
double gaussian2dBySigma(double d, double sigma);
@@ -29,13 +30,14 @@
double kernel1(double d, double rs, double lambda);
double segno(double x);
+/* main.c */
int read_points(struct Map_info *In, double ***coordinate, double dsize);
double compute_all_distances(double **coordinate, double **dists, int n,
double dmax);
double compute_all_net_distances(struct Map_info *In, struct Map_info *Net,
double netmax, double **dists, double dmax);
void compute_distance(double N, double E, struct Map_info *In, double sigma,
- double term, double *gaussian, double dmax, int kernel_function);
+ double *gaussian, double dmax);
void compute_net_distance(double x, double y, struct Map_info *In,
struct Map_info *Net, double netmax, double sigma,
- double term, double *gaussian, double dmax, int node_method, int kernel_function);
+ double *gaussian, double dmax, int node_method);
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c 2012-11-18 16:05:59 UTC (rev 53895)
+++ grass/trunk/vector/v.kernel/main.c 2012-11-18 16:13:44 UTC (rev 53896)
@@ -248,6 +248,8 @@
G_fatal_error(_("Optimal standard deviation calculation is supported only for kernel function 'gaussian'."));
+ setKernelFunction(kernel_function);
if (flag_q->answer) {
flag_o->answer = 1;
@@ -387,9 +389,9 @@
struct line_cats *SCats;
double total = 0.0;
- G_message(_("\nWriting output vector map using smooth parameter=%f."),
+ G_message(_("Writing output vector map using smooth parameter=%f."),
sigma);
- G_message(_("\nNormalising factor=%f."),
+ G_message(_("Normalising factor=%f."),
1. / gaussianFunction(sigma / 4., sigma, dimension));
/* Divide lines to segments and calculate gaussian for center of each segment */
@@ -424,9 +426,8 @@
G_debug(3, " segment = %d, offset = %f, xy = %f %f", seg,
offset1, x, y);
- compute_net_distance(x, y, &In, &Net, netmax, sigma, term,
- &gaussian, dmax, node_method,
- kernel_function);
+ compute_net_distance(x, y, &In, &Net, netmax, sigma,
+ &gaussian, dmax, node_method);
gaussian *= multip;
if (gaussian > gausmax)
gausmax = gaussian;
@@ -515,8 +516,7 @@
E = Rast_col_to_easting(col + 0.5, &window);
/* compute_distance(N, E, &In, sigma, term, &gaussian, dmax); */
- compute_distance(N, E, &In, sigma, term, &gaussian, dmax,
- kernel_function);
+ compute_distance(N, E, &In, sigma, &gaussian, dmax);
output_cell[col] = multip * gaussian;
@@ -697,22 +697,17 @@
/* Compute gausian for x, y along Net, using all points in In */
- int node_method, int kernel_function)
int i;
double dist, kernel;
- static struct line_pnts *Points = NULL;
static struct line_pnts *FPoints = NULL;
struct bound_box box;
static struct boxlist *PointsList = NULL;
static struct ilist *NodesList = NULL;
- if (!Points)
- Points = Vect_new_line_struct();
if (!PointsList)
- PointsList = Vect_new_boxlist(0);
+ PointsList = Vect_new_boxlist(1);
if (node_method == NODE_EQUAL_SPLIT) {
if (!NodesList)
@@ -741,15 +736,15 @@
int line, ret;
line = PointsList->id[i];
- Vect_read_line(In, Points, NULL, line);
- G_debug(3, " SP: %f %f -> %f %f", x, y, Points->x[0], Points->y[0]);
+ G_debug(3, " SP: %f %f -> %f %f", x, y, PointsList->box[i].E, PointsList->box[i].N);
/*ret = Vect_net_shortest_path_coor(Net, x, y, 0.0, Points->x[0], */
/*Points->y[0], 0.0, netmax, netmax, */
/*&dist, NULL, NULL, NULL, NULL, NULL, */
/*NULL); */
ret = Vect_net_shortest_path_coor2(Net,
- Points->x[0], Points->y[0], 0.0,
+ PointsList->box[i].E,
+ PointsList->box[i].N, 0.0,
x, y, 0.0, netmax, 1.0,
&dist, NULL,
NULL, NodesList, FPoints, NULL,
@@ -767,7 +762,7 @@
continue;
/* kernel = gaussianKernel(dist / sigma, term); */
- kernel = kernelFunction(kernel_function, 1, sigma, dist);
+ kernel = kernelFunction(1, sigma, dist);
int j, node;
@@ -795,8 +790,8 @@
- double sigma, double term, double *gaussian,
- double dmax, int kernel_function)
+ double sigma, double *gaussian,
+ double dmax)
int line, nlines;
double a[2], b[2];
@@ -805,16 +800,13 @@
/* spatial index handling, borrowed from lib/vector/Vlib/find.c */
static struct boxlist *NList = NULL;
a[0] = E;
a[1] = N;
if (!NList) {
- NList = Vect_new_boxlist(0);
+ NList = Vect_new_boxlist(1);
- if (!Points)
/* create bounding box 2x2*dmax size from the current cell center */
box.N = N + dmax;
@@ -831,17 +823,13 @@
for (line = 0; line < nlines; line++) {
- Vect_read_line(In, Points, NULL, NList->id[line]);
+ b[0] = NList->box[line].E;
+ b[1] = NList->box[line].N;
- b[0] = Points->x[0];
- b[1] = Points->y[0];
dist = euclidean_distance(a, b, 2);
if (dist <= dmax)
/* *gaussian += gaussianKernel(dist / sigma, term); */
- *gaussian += kernelFunction(kernel_function, 2, sigma, dist);
+ *gaussian += kernelFunction(2, sigma, dist);
