[GRASS-SVN] r53897 - in grass/trunk/gui/wxpython: . gmodeler gui_core lmgr modules
Sun Nov 18 08:32:37 PST 2012
Author: annakrat
Date: 2012-11-18 08:32:36 -0800 (Sun, 18 Nov 2012)
New Revision: 53897
   grass/trunk/gui/wxpython/gmodeler/dialogs.py
   grass/trunk/gui/wxpython/gui_core/goutput.py
   grass/trunk/gui/wxpython/gui_core/menu.py
   grass/trunk/gui/wxpython/gui_core/widgets.py
   grass/trunk/gui/wxpython/lmgr/frame.py
   grass/trunk/gui/wxpython/modules/extensions.py
   grass/trunk/gui/wxpython/wxpythonlib.dox
wxGUI/SearchModule: rename classes
Modified: grass/trunk/gui/wxpython/gmodeler/dialogs.py
--- grass/trunk/gui/wxpython/gmodeler/dialogs.py	2012-11-18 16:13:44 UTC (rev 53896)
+++ grass/trunk/gui/wxpython/gmodeler/dialogs.py	2012-11-18 16:32:36 UTC (rev 53897)
@@ -32,7 +32,7 @@
 from core                 import globalvar
 from core                 import utils
 from core.modulesdata     import ModulesData
-from gui_core.widgets     import SearchModuleWindow, EVT_MODULE_SELECTED
+from gui_core.widgets     import SearchModuleWidget, EVT_MODULE_SELECTED
 from core.gcmd            import GError, EncodeString
 from gui_core.dialogs     import ElementDialog, MapLayersDialogForModeler
 from gui_core.prompt      import GPromptSTC
@@ -137,7 +137,7 @@
         modulesData = ModulesData()
         self.cmd_prompt = GPromptSTC(parent = self, modulesData = modulesData)
-        self.search = SearchModuleWindow(parent = self.panel,
+        self.search = SearchModuleWidget(parent = self.panel,
                                          modulesData = modulesData,
                                          showTip = True)
         self.search.Bind(EVT_MODULE_SELECTED,
Modified: grass/trunk/gui/wxpython/gui_core/goutput.py
--- grass/trunk/gui/wxpython/gui_core/goutput.py	2012-11-18 16:13:44 UTC (rev 53896)
+++ grass/trunk/gui/wxpython/gui_core/goutput.py	2012-11-18 16:32:36 UTC (rev 53897)
@@ -43,7 +43,7 @@
 from core.debug      import Debug
 from core.settings   import UserSettings, GetDisplayVectSettings
 wxCmdOutput,   EVT_CMD_OUTPUT   = NewEvent()
@@ -398,7 +398,7 @@
         """!Create search pane"""
         border = wx.BoxSizer(wx.VERTICAL)
-        self.search = SearchModuleWindow(parent = pane,
+        self.search = SearchModuleWidget(parent = pane,
         border.Add(item = self.search, proportion = 0,
Modified: grass/trunk/gui/wxpython/gui_core/menu.py
--- grass/trunk/gui/wxpython/gui_core/menu.py	2012-11-18 16:13:44 UTC (rev 53896)
+++ grass/trunk/gui/wxpython/gui_core/menu.py	2012-11-18 16:32:36 UTC (rev 53897)
@@ -5,7 +5,7 @@
 Classes:
  - menu::Menu
- - menu::MenuTreeWindow
+ - menu::SearchModuleWindow
  - menu::MenuTree
 (C) 2010-2012 by the GRASS Development Team
@@ -27,7 +27,7 @@
 from core.gcmd         import EncodeString
-from gui_core.widgets  import ItemTree, SearchModuleWindow
+from gui_core.widgets  import ItemTree, SearchModuleWidget
 from lmgr.menudata     import LayerManagerMenuData
 class Menu(wx.MenuBar):
@@ -124,7 +124,7 @@
         # but in this case just call Skip so the default is done
         event.Skip()
-class MenuTreeWindow(wx.Panel):
+class SearchModuleWindow(wx.Panel):
     """!Show menu tree"""
     def __init__(self, parent, id = wx.ID_ANY, **kwargs):
         self.parent = parent # LayerManager
@@ -139,7 +139,7 @@
         self.tree.Load()
         # search widget
-        self.search = SearchModuleWindow(parent = self,
+        self.search = SearchModuleWidget(parent = self,
                                          modulesData = ModulesData(menuData.GetModules()),
                                          showChoice = False)
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py	2012-11-18 16:13:44 UTC (rev 53896)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py	2012-11-18 16:32:36 UTC (rev 53897)
@@ -15,7 +15,7 @@
  - widgets::FloatValidator
  - widgets::ItemTree
  - widgets::GListCtrl
- - widgets::SearchModuleWindow
+ - widgets::SearchModuleWidget
 (C) 2008-2012 by the GRASS Development Team
@@ -712,8 +712,8 @@
 gModuleSelected, EVT_MODULE_SELECTED = NewEvent()
-class SearchModuleWindow(wx.Panel):
-    """!Search module window (used in MenuTreeWindow)"""
+class SearchModuleWidget(wx.Panel):
+    """!Search module widget (used in SearchModuleWindow)"""
     def __init__(self, parent, modulesData, id = wx.ID_ANY,
                  showChoice = True, showTip = False, **kwargs):
         self.showTip = showTip
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py	2012-11-18 16:13:44 UTC (rev 53896)
+++ grass/trunk/gui/wxpython/lmgr/frame.py	2012-11-18 16:32:36 UTC (rev 53897)
@@ -54,7 +54,7 @@
 from gui_core.dialogs      import EVT_APPLY_MAP_LAYERS
 from gui_core.dialogs      import LocationDialog, MapsetDialog, CreateNewVector, GroupDialog
 from modules.colorrules    import RasterColorTable, VectorColorTable
-from gui_core.menu         import Menu, MenuTreeWindow
+from gui_core.menu         import Menu, SearchModuleWindow
 from gmodeler.model        import Model
 from gmodeler.frame        import ModelFrame
 from psmap.frame           import PsMapFrame
@@ -262,7 +262,7 @@
         # create 'search module' notebook page
         if not UserSettings.Get(group = 'manager', key = 'hideTabs', subkey = 'search'):
-            self.search = MenuTreeWindow(parent = self)
+            self.search = SearchModuleWindow(parent = self)
             self.notebook.AddPage(page = self.search, text = _("Search module"), name = 'search')
         else:
             self.search = None
Modified: grass/trunk/gui/wxpython/modules/extensions.py
--- grass/trunk/gui/wxpython/modules/extensions.py	2012-11-18 16:13:44 UTC (rev 53896)
+++ grass/trunk/gui/wxpython/modules/extensions.py	2012-11-18 16:32:36 UTC (rev 53897)
@@ -34,7 +34,7 @@
 from core.gcmd        import GError, RunCommand
 from core.utils       import SetAddOnPath
 from gui_core.forms   import GUI
-from gui_core.widgets import ItemTree, GListCtrl, SearchModuleWindow
+from gui_core.widgets import ItemTree, GListCtrl, SearchModuleWidget
 class InstallExtensionWindow(wx.Frame):
@@ -58,7 +58,7 @@
                                     label = _("Fetch full info including description and keywords"))
         self.fullDesc.SetValue(True)
-        self.search = SearchModuleWindow(parent = self.panel, modulesData = None)
+        self.search = SearchModuleWidget(parent = self.panel, modulesData = None)
         self.search.SetSelection(0)
         self.tree   = ExtensionTree(parent = self.panel, log = parent.GetLogWindow())
Modified: grass/trunk/gui/wxpython/wxpythonlib.dox
--- grass/trunk/gui/wxpython/wxpythonlib.dox	2012-11-18 16:13:44 UTC (rev 53896)
+++ grass/trunk/gui/wxpython/wxpythonlib.dox	2012-11-18 16:32:36 UTC (rev 53897)
@@ -149,7 +149,7 @@
  - mapwindow::MapWindow
 - gui_core::menu
  - menu::Menu
  - menu::MenuTree
 - gui_core::preferences
  - preferences::PreferencesBaseDialog
@@ -176,7 +176,7 @@
  - widgets::NTCValidator
  - widgets::ItemTree
 \subsection lmgr Layer Manager
