[GRASS-SVN] r53906 - grass/trunk/lib/vector/rtree
svn_grass at osgeo.org
Mon Nov 19 02:20:54 PST 2012
Author: mmetz
Date: 2012-11-19 02:20:54 -0800 (Mon, 19 Nov 2012)
New Revision: 53906
grass/trunk/lib/vector/rtree/index.c
grass/trunk/lib/vector/rtree/index.h
grass/trunk/lib/vector/rtree/indexf.c
grass/trunk/lib/vector/rtree/io.c
grass/trunk/lib/vector/rtree/rtree.h
rtree: spatial index with buffered external memory, work in progress
Modified: grass/trunk/lib/vector/rtree/index.c
--- grass/trunk/lib/vector/rtree/index.c 2012-11-19 09:54:19 UTC (rev 53905)
+++ grass/trunk/lib/vector/rtree/index.c 2012-11-19 10:20:54 UTC (rev 53906)
@@ -112,9 +112,11 @@
for (i = 0; i < MAXLEVEL; i++) {
for (j = 0; j < MAXCARD; j++) {
new_rtree->fs[i].sn.branch[j].rect.boundary = RTreeAllocBoundary(new_rtree);
for (j = 0; j < NODE_BUFFER_SIZE; j++) {
new_rtree->nb[i][j].dirty = 0;
new_rtree->nb[i][j].pos = -1;
Modified: grass/trunk/lib/vector/rtree/index.h
--- grass/trunk/lib/vector/rtree/index.h 2012-11-19 09:54:19 UTC (rev 53905)
+++ grass/trunk/lib/vector/rtree/index.h 2012-11-19 10:20:54 UTC (rev 53906)
@@ -109,7 +109,7 @@
int RTreeGetLeafMax(struct RTree *);
/* io.c */
-void RTreeGetNode(struct RTree_Node *n, off_t, int, struct RTree *);
+struct RTree_Node *RTreeGetNode(off_t, int, struct RTree *);
void RTreeNodeChanged(struct RTree_Node *, off_t , struct RTree *);
void RTreePutNode(struct RTree_Node *, off_t, struct RTree *);
size_t RTreeRewriteNode(struct RTree_Node *, off_t, struct RTree *);
Modified: grass/trunk/lib/vector/rtree/indexf.c
--- grass/trunk/lib/vector/rtree/indexf.c 2012-11-19 09:54:19 UTC (rev 53905)
+++ grass/trunk/lib/vector/rtree/indexf.c 2012-11-19 10:20:54 UTC (rev 53906)
@@ -50,23 +50,23 @@
/* add root node position to stack */
currlevel = t->rootlevel;
s[top].pos = t->rootpos;
- /* s[top].sn = RTreeGetNode(s[top].pos, currlevel, t); */
- RTreeGetNode(&(s[top].sn), s[top].pos, currlevel, t);
+ s[top].sn = RTreeGetNode(s[top].pos, currlevel, t);
+ /* RTreeGetNode(&(s[top].sn), s[top].pos, currlevel, t); */
s[top].branch_id = i = 0;
while (top >= 0) {
- n = &(s[top].sn);
- if (s[top].sn.level > 0) { /* this is an internal node in the tree */
+ n = s[top].sn;
+ if (s[top].sn->level > 0) { /* this is an internal node in the tree */
notfound = 1;
- currlevel = s[top].sn.level - 1;
+ currlevel = s[top].sn->level - 1;
for (i = s[top].branch_id; i < t->nodecard; i++) {
- if (s[top].sn.branch[i].child.pos > -1 &&
- RTreeOverlap(r, &(s[top].sn.branch[i].rect), t)) {
+ if (s[top].sn->branch[i].child.pos > -1 &&
+ RTreeOverlap(r, &(s[top].sn->branch[i].rect), t)) {
s[top++].branch_id = i + 1;
/* add next node to stack */
s[top].pos = n->branch[i].child.pos;
s[top].branch_id = 0;
notfound = 0;
break;
@@ -80,12 +80,12 @@
else { /* this is a leaf node */
for (i = 0; i < t->leafcard; i++) {
- if (s[top].sn.branch[i].child.id &&
+ if (s[top].sn->branch[i].child.id &&
hitCount++;
if (shcb) { /* call the user-provided callback */
- if (!shcb(s[top].sn.branch[i].child.id,
- &s[top].sn.branch[i].rect, cbarg)) {
+ if (!shcb(s[top].sn->branch[i].child.id,
+ &(s[top].sn->branch[i].rect), cbarg)) {
/* callback wants to terminate search early */
return hitCount;
@@ -139,22 +139,22 @@
/* go down to level of insertion */
- while (s[top].sn.level > level) {
- n = &(s[top].sn);
+ while (s[top].sn->level > level) {
+ n = s[top].sn;
i = RTreePickBranch(r, n, t);
s[top++].branch_id = i;
- assert(s[top].sn.level == currlevel);
+ assert(s[top].sn->level == currlevel);
- assert(s[top].sn.level == level);
+ assert(s[top].sn->level == level);
/* Have reached level for insertion. Add rect, split if necessary */
RTreeCopyRect(&(b->rect), r, t);
@@ -163,11 +163,11 @@
/* add branch, may split node or remove branches */
cover = NULL;
if (top)
- cover = &(s[top - 1].sn.branch[s[top - 1].branch_id].rect);
- result = RTreeAddBranch(b, &(s[top].sn), &n2, ee, cover, overflow, t);
+ cover = &(s[top - 1].sn->branch[s[top - 1].branch_id].rect);
+ result = RTreeAddBranch(b, s[top].sn, &n2, ee, cover, overflow, t);
/* update node */
- RTreePutNode(&(s[top].sn), s[top].pos, t);
- /* RTreeNodeChanged(s[top].sn, s[top].pos, t); */
+ /* RTreePutNode(&(s[top].sn), s[top].pos, t); */
+ RTreeNodeChanged(s[top].sn, s[top].pos, t);
/* write out new node if node was split */
if (result == 1) {
*newnode_pos = RTreeGetNodePos(t);
@@ -180,32 +180,30 @@
down = top--;
if (result == 0) { /* branch was added */
- RTreeCombineRect(&(s[top].sn.branch[i].rect), r, &nr, t);
+ RTreeCombineRect(&(s[top].sn->branch[i].rect), r, &nr, t);
/* rewrite rect */
if (!RTreeCompareRect(&nr, &(s[top].sn.branch[i].rect), t)) {
RTreeUpdateRect(&nr, &(s[top].sn), s[top].pos, i, t);
if (RTreeExpandRect(&(s[top].sn->branch[i].rect), r, t)) {
else if (result == 2) { /* branches were removed */
/* get node cover of previous node */
- RTreeNodeCover(&(s[down].sn), &nr, t);
+ RTreeNodeCover(s[down].sn, &nr, t);
/* rewrite rect */
- if (!RTreeCompareRect(&nr, &(s[top].sn.branch[i].rect), t)) {
- RTreeUpdateRect(&nr, &(s[top].sn), s[top].pos, i, t);
+ if (!RTreeCompareRect(&nr, &(s[top].sn->branch[i].rect), t)) {
+ /* RTreeUpdateRect(&nr, &(s[top].sn), s[top].pos, i, t); */
RTreeCopyRect(&(s[top].sn->branch[i].rect), &nr, t);
else if (result == 1) { /* node was split */
- RTreeNodeCover(&(s[down].sn), &(s[top].sn.branch[i].rect), t);
+ RTreeNodeCover(s[down].sn, &(s[top].sn->branch[i].rect), t);
/* add new branch for new node previously added by RTreeAddBranch() */
b->child.pos = *newnode_pos;
RTreeNodeCover(n2, &(b->rect), t);
@@ -213,13 +211,13 @@
cover = NULL;
if (top)
result =
- RTreeAddBranch(b, &(s[top].sn), &n2, ee, cover, overflow, t);
+ RTreeAddBranch(b, s[top].sn, &n2, ee, cover, overflow, t);
/* update node */
if (result == 1) {
@@ -254,13 +252,13 @@
struct RTree_Branch *b = &(t->tmpb1);
off_t newnode_pos = -1;
- static struct RTree_Node oldroot;
+ struct RTree_Node *oldroot;
static struct RTree_Node newroot, newnode;
static int rect_init = 0;
if (!rect_init) {
for (i = 0; i < MAXCARD; i++) {
- oldroot.branch[i].rect.boundary = RTreeAllocBoundary(t);
+ /* oldroot.branch[i].rect.boundary = RTreeAllocBoundary(t); */
newroot.branch[i].rect.boundary = RTreeAllocBoundary(t);
newnode.branch[i].rect.boundary = RTreeAllocBoundary(t);
@@ -274,14 +272,14 @@
t, &reInsertList, overflow);
if (result == 1) { /* root split */
- /* oldroot = RTreeGetNode(t->rootpos, t->rootlevel, t); */
- RTreeGetNode(&oldroot, t->rootpos, t->rootlevel, t);
+ oldroot = RTreeGetNode(t->rootpos, t->rootlevel, t);
+ /* RTreeGetNode(&oldroot, t->rootpos, t->rootlevel, t); */
/* grow a new root, & tree taller */
t->rootlevel++;
RTreeInitNode(t, &newroot, NODETYPE(t->rootlevel, t->fd));
newroot.level = t->rootlevel;
/* branch for old root */
- RTreeNodeCover(&oldroot, &(b->rect), t);
+ RTreeNodeCover(oldroot, &(b->rect), t);
b->child.pos = t->rootpos;
RTreeAddBranch(b, &newroot, NULL, NULL, NULL, NULL, t);
/* branch for new node created by RTreeInsertRect2() */
@@ -310,14 +308,14 @@
t->rootlevel++;
@@ -364,23 +362,23 @@
while (notfound && top >= 0) {
/* go down to level 0, remember path */
- n = &(s[top].sn);
+ n = s[top].sn;
if (n->branch[i].child.pos > -1 &&
RTreeOverlap(r, &(n->branch[i].rect), t)) {
notfound = 0;
@@ -397,11 +395,11 @@
else {
- s[top].sn.branch[i].child.id == child.id) { /* found item */
- RTreeDisconnectBranch(&(s[top].sn), i, t);
+ s[top].sn->branch[i].child.id == child.id) { /* found item */
+ RTreeDisconnectBranch(s[top].sn, i, t);
t->n_leafs--;
notfound = 0;
break;
@@ -421,33 +419,31 @@
down = top;
top--;
i = s[top].branch_id - 1;
- assert(s[down].sn.level == s[top].sn.level - 1);
+ assert(s[down].sn->level == s[top].sn->level - 1);
- minfill = (s[down].sn.level ? t->min_node_fill : t->min_leaf_fill);
- if (s[down].sn.count >= minfill) {
+ minfill = (s[down].sn->level ? t->min_node_fill : t->min_leaf_fill);
+ if (s[down].sn->count >= minfill) {
/* just update node cover */
/* rewrite rect */
else {
/* not enough entries in child, eliminate child node */
- assert(s[top].sn.branch[i].child.pos == s[down].pos);
- n = RTreeAllocNode(t, s[down].sn.level);
+ assert(s[top].sn->branch[i].child.pos == s[down].pos);
+ n = RTreeAllocNode(t, s[down].sn->level);
/* copy node */
- RTreeCopyNode(n, &(s[down].sn), t);
- RTreeAddNodePos(s[down].pos, s[down].sn.level, t);
+ RTreeCopyNode(n, s[down].sn, t);
+ RTreeAddNodePos(s[down].pos, s[down].sn->level, t);
RTreeReInsertNode(n, ee);
@@ -508,9 +504,11 @@
/* check for redundant root (not leaf, 1 child) and eliminate */
- /* n = RTreeGetNode(t->rootpos, t->rootlevel, t); */
+ n = RTreeGetNode(t->rootpos, t->rootlevel, t);
RTreeGetNode(&rn, t->rootpos, t->rootlevel, t);
n = &rn;
if (n->count == 1 && n->level > 0) {
for (i = 0; i < t->nodecard; i++) {
Modified: grass/trunk/lib/vector/rtree/io.c
--- grass/trunk/lib/vector/rtree/io.c 2012-11-19 09:54:19 UTC (rev 53905)
+++ grass/trunk/lib/vector/rtree/io.c 2012-11-19 10:20:54 UTC (rev 53906)
@@ -47,6 +47,7 @@
i < NODE_BUFFER_SIZE)
i++;
+ /* is it possible that this node is not in the buffer? */
assert(i < NODE_BUFFER_SIZE);
which = t->used[level][i];
assert(t->nb[level][which].n.level == level);
@@ -55,16 +56,14 @@
/* make it lru */
if (i < NODE_BUFFER_SIZE - 1) { /* which != t->used[level][NODE_BUFFER_SIZE - 1] */
-#ifdef USAGE_SWAP
- t->used[level][i] = t->used[level][NODE_BUFFER_SIZE - 1];
- t->used[level][NODE_BUFFER_SIZE - 1] = which;
-#else
- while (i < NODE_BUFFER_SIZE - 1) {
+ /* simple swap does not work here */
+ while (i < NODE_BUFFER_SIZE - 1 &&
+ t->nb[level][t->used[level][i + 1]].pos != -1) {
t->used[level][i] = t->used[level][i + 1];
i++;
-#endif
+ assert(i < NODE_BUFFER_SIZE);
+ t->used[level][i] = which;
@@ -109,7 +108,7 @@
/* get node from buffer or file */
-void RTreeGetNode(struct RTree_Node *n, off_t nodepos, int level, struct RTree *t)
+struct RTree_Node *RTreeGetNode(off_t nodepos, int level, struct RTree *t)
int which, i = 0;
@@ -122,9 +121,6 @@
if (t->nb[level][which].pos != nodepos) {
- if (t->nb[level][which].pos >= 0) {
- assert(i == NODE_BUFFER_SIZE - 1);
/* rewrite node in buffer */
if (t->nb[level][which].dirty) {
assert(t->nb[level][which].pos >= 0);
@@ -151,9 +147,9 @@
#endif
- RTreeCopyNode(n, &(t->nb[level][which].n), t);
+ /* RTreeCopyNode(n, &(t->nb[level][which].n), t); */
- /* return &(t->nb[level][which].n); */
+ return &(t->nb[level][which].n);
/* write branch to file */
Modified: grass/trunk/lib/vector/rtree/rtree.h
--- grass/trunk/lib/vector/rtree/rtree.h 2012-11-19 09:54:19 UTC (rev 53905)
+++ grass/trunk/lib/vector/rtree/rtree.h 2012-11-19 10:20:54 UTC (rev 53906)
@@ -52,7 +52,7 @@
#define MAXLEVEL 20 /* 8^MAXLEVEL items are guaranteed to fit into the tree */
/* number of nodes buffered per level */
-#define NODE_BUFFER_SIZE 4
+#define NODE_BUFFER_SIZE 8
struct RTree_Rect
@@ -103,7 +103,7 @@
/* stack for file-based index */
struct fstack
- struct RTree_Node sn; /* stack node */
+ struct RTree_Node *sn; /* stack node */
int branch_id; /* branch number to follow down */
off_t pos; /* file position of stack node */
