[GRASS-SVN] r53907 - grass/trunk/lib/python/pygrass/modules
svn_grass at osgeo.org
Mon Nov 19 02:39:01 PST 2012
Author: zarch
Date: 2012-11-19 02:39:01 -0800 (Mon, 19 Nov 2012)
New Revision: 53907
grass/trunk/lib/python/pygrass/modules/__init__.py
Fix default value in Parameter class and rephrase the string error
Modified: grass/trunk/lib/python/pygrass/modules/__init__.py
--- grass/trunk/lib/python/pygrass/modules/__init__.py 2012-11-19 10:20:54 UTC (rev 53906)
+++ grass/trunk/lib/python/pygrass/modules/__init__.py 2012-11-19 10:39:01 UTC (rev 53907)
@@ -149,6 +149,8 @@
i) for i in diz['values']] if 'values' in diz else None
self.default = self._type(
diz['default']) if 'default' in diz else None
+ if self.default is not None:
+ self._value = self.default
self.guisection = diz.get('guisection', None)
if 'gisprompt' in diz:
self.type = diz['gisprompt']['prompt']
@@ -166,7 +168,7 @@
self._value = [
val for val in value if isinstance(value, self._type)]
else:
- str_err = 'The Parameter <%s>, not support multiple inputs'
+ str_err = 'The Parameter <%s> does not accept multiple inputs'
raise TypeError(str_err % self.name)
elif isinstance(value, self._type):
if self.values:
