[GRASS-SVN] r53914 - in grass-addons/grass6/raster: . r.mcda.ahp
Mon Nov 19 05:38:35 PST 2012
Author: gianluca
Date: 2012-11-19 05:38:34 -0800 (Mon, 19 Nov 2012)
New Revision: 53914
Added:
   grass-addons/grass6/raster/r.mcda.ahp/
   grass-addons/grass6/raster/r.mcda.ahp/Makefile
   grass-addons/grass6/raster/r.mcda.ahp/description.html
   grass-addons/grass6/raster/r.mcda.ahp/r.mcda.ahp.py
Added: grass-addons/grass6/raster/r.mcda.ahp/Makefile
--- grass-addons/grass6/raster/r.mcda.ahp/Makefile	                        (rev 0)
+++ grass-addons/grass6/raster/r.mcda.ahp/Makefile	2012-11-19 13:38:34 UTC (rev 53914)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = r.mcda.ahp
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Added: grass-addons/grass6/raster/r.mcda.ahp/description.html
--- grass-addons/grass6/raster/r.mcda.ahp/description.html	                        (rev 0)
+++ grass-addons/grass6/raster/r.mcda.ahp/description.html	2012-11-19 13:38:34 UTC (rev 53914)
@@ -0,0 +1,33 @@
+<h2>DESCRIPTION</h2>
+<p>The <em>r.mcda.ahp</em> Generate a raster map classified with analytic hierarchy process (AHP) [Saaty, 1977 and Saaty & Vargas, 1991]</p>
+<em>(GRASS python Script)</em>
+<p></p>
+<h2>NOTES</h2>
+<p>It is mandatory to build a pairwise comparation table with the same order of input of criteria maps in the criteria field.</p>
+<p>Example: r.mcda.ahp criteria=reclass_slope,reclass_sand,reclass_elev pairwise=pairwise output=outputMap</p>
+<p>The file "pairwise" has to have a structure like this:</p>
+<p>#start file</p>
+<p>1.0, 0.2, 3.0</p>
+<p>5.0, 1.0, 5.0</p>
+<p>0.3, 0.2, 1.0</p>
+<p>#comment: order: reclass_slope,reclass_sand,reclass_</p>
+<p>#end file</p>
+The first row and first column are related to the first criteria (reclass_slope in our case); the second row and second column are related to the second criteria (reclass_sand in our case) and the third row and third column are related to the third criteria
+ ( reclass_elev in our cas), and so on.
+<p>In the work directory should be generated a log.txt file were you can find additional information like: eigenvectors, eigenvalues, weights</p>
+<h2>TODO</h2>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.roughset.html">r.roughset</a>,
+<a href="r.mcda.regime.html">r.mcda.regime</a>,
+<a href="r.mcda.fuzzy.html">r.mcda.fuzzy</a>
+<a href="r.mcda.electre.html">r.mcda.electre</a>,
+<a href="r.mcda.roughset.html">r.mcda.roughset</a>
+<a href="r.in.drsa.html">r.in.drsa</a>
+<a href="r.to.drsa.html">r.to.drsa</a>
+</em>
+<h2>AUTHORS</h2>
+Antonio Boggia - Gianluca Massei<br>
+Department of Economics and Appraisal - University of Perugia - Italy
+<p><i>Last changed: $Date: 2012-09-12 22:32:08 +0200 (mer, 12 set 2012) $</i>
Added: grass-addons/grass6/raster/r.mcda.ahp/r.mcda.ahp.py
--- grass-addons/grass6/raster/r.mcda.ahp/r.mcda.ahp.py	                        (rev 0)
+++ grass-addons/grass6/raster/r.mcda.ahp/r.mcda.ahp.py	2012-11-19 13:38:34 UTC (rev 53914)
@@ -0,0 +1,111 @@
+#!/usr/bin/env python
+# MODULE:       r.mcda.ahp
+# AUTHOR:       Gianluca Massei - Antonio Boggia
+# PURPOSE:      Generate a raster map classified with  analytic hierarchy process (AHP) [Saaty, 1977 and Saaty & Vargas, 1991]
+# COPYRIGHT:    c) 2010 Gianluca Massei, Antonio Boggia  and the GRASS
+#                       Development Team. This program is free software under the
+#                       GNU General PublicLicense (>=v2). Read the file COPYING
+#                       that comes with GRASS for details.
+#%Module
+#% description: Generate a raster map classified with analytic hierarchy process (AHP).
+#% keywords: raster, analytic hierarchy process (AHP), Multi Criteria Decision Analysis (MCDA)
+#%End
+#%option
+#% key: criteria
+#% type: string
+#% multiple: yes
+#% gisprompt: old,cell,raster
+#% key_desc: name
+#% description: Name of criteria raster maps
+#% required: yes
+#%end
+#%option
+#% key: pairwise
+#% type: string
+#% gisprompt: old,file,input
+#% description: Pairwise comparison matrix
+#% required: yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new_file,cell,output
+#% description: output classified raster map
+#% required: yes
+#%end
+#%flag
+#% key:k
+#% description:build a void pairwise comparison matrix and exit (no yet implemented)
+#%end
+import sys
+import grass.script as grass
+import numpy as np
+import warnings
+def calculateWeight(pairwise):
+    "Define vector of weight based on eigenvector and eigenvalues"
+    pairwise=np.genfromtxt(pairwise, delimiter=",")
+    warnings.simplefilter("ignore", np.ComplexWarning)
+    eigenvalues, eigenvector=np.linalg.eig(pairwise)
+    maxindex=np.argmax(eigenvalues)
+    eigenvalues=np.float32(eigenvalues)
+    eigenvector=np.float32(eigenvector)
+    weight=eigenvector[:, maxindex] #extract vector from eigenvector with max vaue in eigenvalues
+    weight.tolist() #convert array(numpy)  to vector
+    weight=[ w/sum(weight) for w in weight ]
+    return weight, eigenvalues,  eigenvector
+def calculateMap(criteria, weight, outputMap):
+    "Parser a formula for mapcalc and run grass.mapcalc"
+    formula=''
+    for i in range(len(criteria)-1):
+        formula += "%s*%s + " % (criteria[i], weight[i])
+    formula +="%s*%s " % (criteria[len(criteria)-1], weight[len(criteria)-1])
+    grass.mapcalc(outputMap +"=" +formula)
+    return 0
+def Consistency(weight,eigenvalues):
+    "Calculete Consistency index in accord with Saaty (1977)"
+    RI=[0.00, 0.00, 0.00,0.52,0.90,1.12,1.24,1.32,1.41]     #order of matrix: 0,1,2,3,4,5,6,7,8
+    order=len(weight)
+    CI= (np.max(eigenvalues)-order)/(order-1)
+    return CI/RI[order-1]
+def ReportLog(eigenvalues,eigenvector, weight, consistency):
+    "Make a log file"
+    log=open("log.txt", "w")
+    log.write("eigenvalues:\n%s" % eigenvalues)
+    log.write("\neigenvector:\n%s" % eigenvector)
+    log.write("\nweight:\n%s" % weight)
+    log.write("\nconsistency:\n%s" % consistency)
+    log.close()
+    return 0
+def main():
+    "main"
+    criteria = options['criteria'].split(',')
+    pairwise = options['pairwise']
+    outputMap = options['output']
+    gregion = grass.region()
+    nrows = gregion['rows']
+    ncols = gregion['cols']
+    ewres=int(gregion['ewres'])
+    nsres=int(gregion['nsres'])
+    weight, eigenvalues,  eigenvector = calculateWeight(pairwise)
+    calculateMap(criteria, weight, outputMap)
+    consistency=Consistency(weight,eigenvalues)
+    ReportLog(eigenvalues,eigenvector, weight, consistency)
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
