[GRASS-SVN] r53915 - in grass-addons/grass6/raster: . r.mcda.electre
Mon Nov 19 05:38:52 PST 2012
Author: gianluca
Date: 2012-11-19 05:38:51 -0800 (Mon, 19 Nov 2012)
New Revision: 53915
Added:
   grass-addons/grass6/raster/r.mcda.electre/
   grass-addons/grass6/raster/r.mcda.electre/Makefile
   grass-addons/grass6/raster/r.mcda.electre/description.html
   grass-addons/grass6/raster/r.mcda.electre/dominance.c
   grass-addons/grass6/raster/r.mcda.electre/local_proto.h
   grass-addons/grass6/raster/r.mcda.electre/main.c
Added: grass-addons/grass6/raster/r.mcda.electre/Makefile
--- grass-addons/grass6/raster/r.mcda.electre/Makefile	                        (rev 0)
+++ grass-addons/grass6/raster/r.mcda.electre/Makefile	2012-11-19 13:38:51 UTC (rev 53915)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../../..
+PGM = r.mcda.electre
+LIBES= $(GISLIB) $(GMATHLIB)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass6/raster/r.mcda.electre/description.html
--- grass-addons/grass6/raster/r.mcda.electre/description.html	                        (rev 0)
+++ grass-addons/grass6/raster/r.mcda.electre/description.html	2012-11-19 13:38:51 UTC (rev 53915)
@@ -0,0 +1,40 @@
+<h2>DESCRIPTION</h2>
+<em>r.mcda.electre</em> is the implementation of the ELECTRE multicriteria
+algorithm in GRASS GIS environment. It is one of the available tools in the
+r.mcda suite. It requires as an input the list of raster representing the
+criteria to be assessed in the multicriteria evaluation and the vector of
+weights to be assigned. Every single cell of the GRASS region is considered
+as one of the possible alternatives to evaluate and it is described with
+the value assumed for the same cell by the raster used as criteria. There
+are two output files. One represents the spatial distribution of the
+concordance index, the other one of the discordance index. The optimal
+solution is the one presenting the maximum concordance value and the minimum
+discordance value at the same time.
+<h2>NOTES</h2>
+The module does not standardize the raster-criteria. Therefore, they must
+be prepared before by using, for example, r.mapcalc. The weights vector
+is always normalized so that the sum of the weights is 1.
+<h2>REFERENCE</h2>
+<p>Roy, B. (1971) Problem and methods with multiple objective functions
+ Mathematical programming 1, 239-266.</P>
+<p>Roy, B. (1990): The outranking approach and the foundations of Electre
+ methods , Document du LAMSADE, Paris.</P>
+<p>Janssen R. (1994) - Multiobjective decision support for environmental
+ management, Kluwer Academic Publishers.</P>
+<p>GRASS Development Team (2008)</P>
+<h2>SEE ALSO</h2>
+<em>r.mcda.fuzzy, r.mcda.electre, r.roughet, r.mapcalc</em>
+<h2>AUTHORS</h2>
+Antonio Boggia - Gianluca Massei<br>
+Department of Economics and Appraisal - University of Perugia - Italy
+<p>
+<i>Last changed: $Date: 2011-11-08 22:56:45 +0100 (mar, 08 nov 2011) $</i>
Added: grass-addons/grass6/raster/r.mcda.electre/dominance.c
--- grass-addons/grass6/raster/r.mcda.electre/dominance.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.mcda.electre/dominance.c	2012-11-19 13:38:51 UTC (rev 53915)
@@ -0,0 +1,116 @@
+#include "local_proto.h"
+ * global function declaration
+void build_weight_vect(int nrows, int ncols, int ncriteria,
+                       struct Option *weight, double *weight_vect);
+void build_dominance_matrix(int nrows, int ncols, int ncriteria,
+                            double *weight_vect, double ***decision_vol);
+ * function definitions
+    int i, nweight = 0;
+    double weight_sum = 0;
+    while (weight->answers[nweight] != NULL)
+        nweight++;
+    if (nweight != ncriteria)
+        G_fatal_error(_("criteria number  and weight number are different"));
+    for (i = 0; i < nweight; i++)
+        weight_vect[i] = (atof(weight->answers[i]));	/*transfer  weight value  in double  array */
+        weight_sum = weight_sum + weight_vect[i];	/*calculate sum weight */
+        weight_vect[i] = weight_vect[i] / weight_sum;	/*normalize vector weight */
+    int row1, col1, row2, col2;
+    int i, j, k, cont;
+	double *row_sum_conc;
+	double *col_sum_conc;
+	double *row_sum_disc;
+	double *col_sum_disc;
+	row_sum_conc=G_malloc(ncriteria * nrows * ncols * sizeof(double*));
+	col_sum_conc=G_malloc(ncriteria * nrows * ncols * sizeof(double*));
+	row_sum_disc=G_malloc(ncriteria * nrows * ncols * sizeof(double*));
+	col_sum_disc=G_malloc(ncriteria * nrows * ncols * sizeof(double*));
+    k = 0;			/* make pairwise comparation and build concordance/discordance matrix */
+    for (row1 = 0; row1 < nrows; row1++)
+        G_percent(row1, nrows, 2);
+        for (col1 = 0; col1 < ncols; col1++)
+            j = 0;
+            for (row2 = 0; row2 < nrows; row2++)
+                for (col2 = 0; col2 < ncols; col2++)
+                    double conc = 0, disc = 0;
+                    for (i = 0; i < ncriteria; i++)
+                        double d;
+			d = decision_vol[row1][col1][i] - decision_vol[row2][col2][i];
+                        if (d >= 0 )
+                            conc += weight_vect[i];
+                        if (d < disc)	/*WARNING: if(d>conc) */
+                            /**/ disc = -d;
+                    row_sum_conc[k] += conc;
+                    col_sum_conc[j] += conc;
+                    row_sum_disc[k] += disc;
+                    col_sum_disc[j] += disc;
+                    j++;	/* increase rows index up to nrows*ncols */
+            k++;		/* increase columns index up to nrows*ncols */;
+    /*calculate concordance and discordance index and storage in decision_vol */
+    cont = 0;			/*variabile progressiva per riga/colonna della concordance_map */
+            /*fill matrix with concordance index for each DCELL */
+            decision_vol[row1][col1][ncriteria] =
+                row_sum_conc[cont] - col_sum_conc[cont];
+            /*fill matrix with discordance index for each DCELL */
+            decision_vol[row1][col1][ncriteria + 1] =
+                row_sum_disc[cont] - col_sum_disc[cont];
+            cont++;
Added: grass-addons/grass6/raster/r.mcda.electre/local_proto.h
--- grass-addons/grass6/raster/r.mcda.electre/local_proto.h	                        (rev 0)
+++ grass-addons/grass6/raster/r.mcda.electre/local_proto.h	2012-11-19 13:38:51 UTC (rev 53915)
@@ -0,0 +1,15 @@
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include <grass/config.h>
+struct input
+    char *name, *mapset;	/* input raster name  and mapset name */
+    int infd;
+    void *inrast;		/* input buffer */
Added: grass-addons/grass6/raster/r.mcda.electre/main.c
--- grass-addons/grass6/raster/r.mcda.electre/main.c	                        (rev 0)
+++ grass-addons/grass6/raster/r.mcda.electre/main.c	2012-11-19 13:38:51 UTC (rev 53915)
@@ -0,0 +1,232 @@
+ * MODULE:	 r.mcda.electre
+ * AUTHORS:	 Gianluca Massei (g_massa at libero.it) - Antonio Boggia (boggia at unipg.it)
+ * PURPOSE:      Make a multicriterio decision  analysis based on ELECTRE algorthm
+ * COPYRIGHT:    (C) GRASS Development Team (2008)
+ *		        This program is free software under the GNU General Public
+ *   	    	License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	for details.
+ * main function
+int main(int argc, char *argv[])
+    struct Cell_head cellhd;	/* it stores region information,  and header information of rasters */
+    char *result_concordance, *result_discordance;		/* outputs raster name */
+    char *mapset;		/* mapset name */
+    unsigned char *outrast_concordance, *outrast_discordance;	/* output buffer */
+    char *message;
+    int i,j, ncriteria=0;	/* index and  files number*/
+    int nrows, ncols;
+    int row1, row2, col1, col2;
+    int outfd_concordance, outfd_discordance;		/* output file descriptor */
+    double *weight_vect, ***decision_vol;/* vector and matrix */
+    struct History history;	/* holds meta-data (title, comments,..) */
+    struct GModule *module;	/* GRASS module for parsing arguments */
+    struct Option *criteria, *weight, *discordance, *concordance;	/* options */
+    struct input *attributes; /*storage  alla input criteria GRID files and output concordance and discordance GRID files*/
+    /* initialize GIS environment */
+    G_gisinit(argv[0]);		/* reads grass env, stores program name to G_program_name() */
+    /* initialize module */
+    module = G_define_module();
+    module->keywords = _("raster,MCDA");
+    module->description = _("Multicirtieria decision analysis based on ELECTRE method");
+    /* Define the different options as defined in gis.h */
+    criteria  = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory*/
+    criteria->key        = "criteria";
+    criteria->type       = TYPE_STRING;
+    criteria->required   = YES;
+    criteria->multiple   = YES;
+    criteria->gisprompt  = "old,cell,raster" ;
+    criteria->description = "Input geographics criteria in information system";
+    weight = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory*/
+    weight->key        = "weight";
+    weight->type       = TYPE_DOUBLE;
+    weight->required   = YES;
+    weight->multiple   = YES;
+    weight->description = _("Criteria weight(s) (w1,w2,..)");
+    concordance = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
+    concordance->key = "concordance";
+    concordance->type = TYPE_STRING;
+    concordance->required = YES;
+    concordance->gisprompt = "new,cell,raster";
+    concordance->answer ="concordance";
+    concordance->description = "concordance output map";
+    discordance = G_define_option(); /* Allocates memory for the Option structure and returns a pointer to this memory */
+    discordance->key = "discordance";
+    discordance->type = TYPE_STRING;
+    discordance->required = YES;
+    discordance->gisprompt = "new,cell,raster";
+    discordance->answer ="discordance";
+    discordance->description = "discordance output map";
+    /* options and flags parser */
+    if (G_parser(argc, argv))
+        exit(EXIT_FAILURE);
+    G_message("Start: %s",G_date()); /*write calculation start time*/
+    /* number of file (=criteria) */
+    while (criteria->answers[ncriteria]!=NULL)
+        ncriteria++;
+    /* process the input maps:  stores options and flags to variables */
+    /* CRITERIA grid */
+    attributes = G_malloc(ncriteria * sizeof(struct input)); /*attributes is input struct defined in top file and store alla criteria files*/
+    weight_vect=G_malloc(ncriteria * sizeof(double)); /*allocate memory fron vector weight*/
+    build_weight_vect(nrows,ncols,ncriteria,weight,weight_vect); /*calcolate weight vector*/
+        struct input *p = &attributes[i];
+        p->name = criteria->answers[i];
+        p->mapset = G_find_cell2(p->name,""); /* G_find_cell: Looks for the raster map "name" in the database. */
+        if (p->mapset==NULL) /* returns NULL if the map was not found in any mapset,   mapset name otherwise */
+            G_fatal_error(_("Raster file <%s> not found"), p->name);
+        if ((p->infd = G_open_cell_old(p->name, p->mapset))<0) /* G_open_cell_old - returns file destriptor (>0) */
+            G_fatal_error(_("Unable to open input map <%s> in mapset <%s>"),p->name, p->mapset);
+        if (G_get_cellhd(p->name,p->mapset,&cellhd)<0)/* controlling, if we can open input raster */
+            G_fatal_error(_("Unable to read file header of <%s>"), p->name);
+        p->inrast = G_allocate_d_raster_buf(); /* Allocate an array of DCELL based on the number of columns in the current region. Return DCELL   */
+    result_concordance=concordance->answer; /* store outputn name in variables*/
+    result_discordance=discordance->answer;
+    if (G_legal_filename(result_concordance) < 0) /* check for legal database file names */
+        G_fatal_error(_("<%s> is an illegal file name"), result_concordance);
+    if (G_legal_filename(result_discordance) < 0) /* check for legal database file names */
+        G_fatal_error(_("<%s> is an illegal file name"), result_discordance);
+    /*values = G_malloc(ncriteria * sizeof(DCELL));*/
+    nrows = G_window_rows();
+    ncols = G_window_cols();
+    /*memory allocation for-three dimensional matrix*/
+    decision_vol=G_malloc(nrows * sizeof(double*));
+    for (i=0; i<nrows; ++i)
+        decision_vol[i]=G_malloc(ncols * sizeof(double*));
+        for (j=0; j<ncols; ++j)
+            decision_vol[i][j]=G_malloc((ncriteria+2) * sizeof(double)); /****NOTE: it's storage enven concordance and discordance index map****/
+    /* Allocate output buffer, use  DCELL_TYPE */
+    outrast_concordance = G_allocate_raster_buf(DCELL_TYPE); /* Allocate memory for a raster map of type DCELL_TYPE. */
+    outrast_discordance = G_allocate_raster_buf(DCELL_TYPE);
+    /* controlling, if we can write the raster */
+    if ((outfd_concordance = G_open_raster_new(result_concordance, DCELL_TYPE)) < 0)
+        G_fatal_error(_("Unable to create raster map <%s>"), result_concordance);
+    if ((outfd_discordance = G_open_raster_new(result_discordance, DCELL_TYPE)) < 0)
+        G_fatal_error(_("Unable to create raster map <%s>"), result_discordance);
+    /*build a three dimensional matrix for storage all critera maps*/
+    for (i=0;i<ncriteria;i++)
+        for (row1 = 0; row1 < nrows;row1++)
+            G_get_raster_row(attributes[i].infd, attributes[i].inrast, row1,DCELL_TYPE);/* Reads appropriate information into the buffer buf associated with the requested row*/
+            /*G_fatal_error(_("Unable to read raster map <%s> row %d"), criteria->answers[i], row);*/
+                /* viene letto il valore di cella e lo si attribuisce ad una variabile di tipo DCELL e poi ad un array*/
+                DCELL v1 = ((DCELL *)attributes[i].inrast)[col1];
+                decision_vol[row1][col1][i]=(double)(v1);
+    build_dominance_matrix(nrows,ncols,ncriteria,weight_vect,decision_vol); /*scan all DCELL, make a pairwise comparatione, buil concordance and discordance matrix and relative index*/
+            ((DCELL *) outrast_concordance)[col1] = (DCELL)decision_vol[row1][col1][ncriteria];/*write concordance map*/
+            ((DCELL *) outrast_discordance)[col1] = (DCELL)decision_vol[row1][col1][ncriteria+1];/*write discordance map*/
+        if (G_put_raster_row(outfd_concordance, outrast_concordance,  DCELL_TYPE) < 0)
+            G_fatal_error(_("Failed writing raster map <%s>"), result_concordance);
+        if (G_put_raster_row(outfd_discordance, outrast_discordance,  DCELL_TYPE) < 0)
+            G_fatal_error(_("Failed writing raster map <%s>"), result_discordance);
+    G_message("End: %s",G_date());
+    /* memory cleanup */
+    for (i = 0; i<ncriteria; i++)
+        G_free(attributes[i].inrast);
+    G_free(outrast_concordance);
+    G_free(outrast_discordance);
+    G_free(decision_vol);
+    /* closing raster maps */
+        G_close_cell(attributes[i].infd);
+    G_close_cell(outfd_concordance);
+    G_close_cell(outfd_discordance);
+    /* add command line incantation to history concordance file */
+    G_short_history(result_concordance, "raster", &history);
+    G_command_history(&history);
+    G_write_history(result_concordance, &history);
+    /* add command line incantation to history discordance file */
+    G_short_history(result_discordance, "raster", &history);
+    G_write_history(result_discordance, &history);
+    exit(EXIT_SUCCESS);
