[GRASS-SVN] r53916 - in grass/trunk/gui/wxpython: core gui_core lmgr modules
Mon Nov 19 06:55:37 PST 2012
Author: wenzeslaus
Date: 2012-11-19 06:55:36 -0800 (Mon, 19 Nov 2012)
New Revision: 53916
Added:
   grass/trunk/gui/wxpython/core/events.py
   grass/trunk/gui/wxpython/core/modulesdata.py
   grass/trunk/gui/wxpython/gui_core/goutput.py
   grass/trunk/gui/wxpython/gui_core/menu.py
   grass/trunk/gui/wxpython/gui_core/widgets.py
   grass/trunk/gui/wxpython/lmgr/frame.py
   grass/trunk/gui/wxpython/modules/extensions.py
wxGUI/SearchModuleWidget: general notification event, removing GConsole-statusbar dependency (co-author: annakrat)
Added: grass/trunk/gui/wxpython/core/events.py
--- grass/trunk/gui/wxpython/core/events.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/core/events.py	2012-11-19 14:55:36 UTC (rev 53916)
@@ -0,0 +1,24 @@
+ at package core.events
+ at brief General events
+Put here only truly general events. Once you find that your event can be
+generated in more than one class, put your event here. Otherwise,
+leave it in your class file.
+(C) 2012 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Vaclav Petras <wenzeslaus gmail.com>
+from wx.lib.newevent import NewCommandEvent
+# Notification event intended to update statusbar.
+gShowNotification, EVT_SHOW_NOTIFICATION = NewCommandEvent()
Property changes on: grass/trunk/gui/wxpython/core/events.py
___________________________________________________________________
Added: svn:mime-type
   + text/x-python
Added: svn:eol-style
   + native
Modified: grass/trunk/gui/wxpython/core/modulesdata.py
--- grass/trunk/gui/wxpython/core/modulesdata.py	2012-11-19 13:38:51 UTC (rev 53915)
+++ grass/trunk/gui/wxpython/core/modulesdata.py	2012-11-19 14:55:36 UTC (rev 53916)
@@ -30,6 +30,10 @@
     """!Holds information about modules.
     @todo add doctest
+    @todo analyze what exactly this class is doing
+    @todo split this class into two classes
+    @see modules::extensions::ExtensionModulesData
     def __init__(self, modulesDesc = None):
Modified: grass/trunk/gui/wxpython/gui_core/goutput.py
--- grass/trunk/gui/wxpython/gui_core/goutput.py	2012-11-19 13:38:51 UTC (rev 53915)
+++ grass/trunk/gui/wxpython/gui_core/goutput.py	2012-11-19 14:55:36 UTC (rev 53916)
@@ -273,7 +273,6 @@
             self.MakeSearchPaneContent(self.searchPane.GetPane(), modulesData)
             self.searchPane.Collapse(True)
             self.Bind(wx.EVT_COLLAPSIBLEPANE_CHANGED, self.OnSearchPaneChanged, self.searchPane)
-            self.search.Bind(wx.EVT_TEXT,             self.OnUpdateStatusBar)
             self.search.Bind(EVT_MODULE_SELECTED,
                              lambda event:
                                  self.cmdPrompt.SetTextAndFocus(event.name + ' '))
@@ -738,16 +737,6 @@
         else:
             self.cmdPrompt.Unbind(stc.EVT_STC_PAINTED)
             self.cmdOutput.Unbind(stc.EVT_STC_PAINTED)
-    def OnUpdateStatusBar(self, event):
-        """!Update statusbar text"""
-        if event.GetString():
-            nItems = len(self.cmdPrompt.GetCommandItems())
-            self.frame.SetStatusText(_('%d modules match') % nItems, 0)
-        else:
-            self.frame.SetStatusText('', 0)
-        event.Skip()
     def OnCmdOutput(self, event):
         """!Print command output"""
Modified: grass/trunk/gui/wxpython/gui_core/menu.py
--- grass/trunk/gui/wxpython/gui_core/menu.py	2012-11-19 13:38:51 UTC (rev 53915)
+++ grass/trunk/gui/wxpython/gui_core/menu.py	2012-11-19 14:55:36 UTC (rev 53916)
@@ -27,6 +27,7 @@
 from core.modulesdata  import ModulesData
 from core.gcmd         import EncodeString
 from core.settings     import UserSettings
+from core.events       import EVT_SHOW_NOTIFICATION
 from gui_core.widgets  import ItemTree, SearchModuleWidget
 from lmgr.menudata     import LayerManagerMenuData
@@ -155,6 +156,13 @@
         self.search.GetCtrl().Bind(wx.EVT_TEXT,    self.OnUpdateStatusBar)
         self.search.GetCtrl().Bind(wx.EVT_KEY_UP,  self.OnKeyUp)
+        # stop propagation of event
+        # because number of matched items differs
+        # from number of matched items in tree
+        # TODO: find the reason for this difference
+        # TODO: use this event for updating statusbar (i.e., don't do this bind)
+        self.Bind(EVT_SHOW_NOTIFICATION, lambda event: None)
         self._layout()
         self.search.SetFocus()
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py	2012-11-19 13:38:51 UTC (rev 53915)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py	2012-11-19 14:55:36 UTC (rev 53916)
@@ -49,6 +49,7 @@
 from core        import globalvar
 from core.debug  import Debug
+from core.events import gShowNotification
 from wx.lib.newevent import NewEvent
 wxSymbolSelectionChanged, EVT_SYMBOL_SELECTION_CHANGED  = NewEvent()
@@ -800,20 +801,22 @@
             mList = self.modulesData.GetCommandItems()
             if self.showChoice:
                 self.searchChoice.SetItems(mList)
-            if self.showTip:
-                self.searchTip.SetLabel(_("%d modules found") % len(mList))
-            event.Skip()
-            return
+            label = _("%d modules found") % len(mList)
+        else:
+            findIn = self.searchBy.GetClientData(self.searchBy.GetSelection())
+            modules, nFound = self.modulesData.FindModules(text = text, findIn = findIn)
+            self.modulesData.SetFilter(modules)
+            if self.showChoice:
+                self.searchChoice.SetItems(self.modulesData.GetCommandItems())
+                self.searchChoice.SetSelection(0)
+            label = _("%d modules match") % nFound
-        findIn = self.searchBy.GetClientData(self.searchBy.GetSelection())
-        modules, nFound = self.modulesData.FindModules(text = text, findIn = findIn)
-        self.modulesData.SetFilter(modules)
-        if self.showChoice:
-            self.searchChoice.SetItems(self.modulesData.GetCommandItems())
-            self.searchChoice.SetSelection(0)
         if self.showTip:
-            self.searchTip.SetLabel(_("%d modules match") % nFound)
+            self.searchTip.SetLabel(label)
+        newEvent = gShowNotification(self.GetId(), message = label)
+        wx.PostEvent(self, newEvent)
         event.Skip()
     def OnSelectModule(self, event):
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py	2012-11-19 13:38:51 UTC (rev 53915)
+++ grass/trunk/gui/wxpython/lmgr/frame.py	2012-11-19 14:55:36 UTC (rev 53916)
@@ -42,6 +42,7 @@
 from core.gcmd             import RunCommand, GError, GMessage
 from core.settings         import UserSettings, GetDisplayVectSettings
 from core.utils            import SetAddOnPath
 from gui_core.preferences  import MapsetAccess, PreferencesDialog, EVT_SETTINGS_CHANGED
 from lmgr.layertree        import LayerTree, LMIcons
@@ -154,6 +155,8 @@
         # bindings
         self.Bind(wx.EVT_CLOSE,    self.OnCloseWindow)
         self.Bind(wx.EVT_KEY_DOWN, self.OnKeyDown)
+                  lambda event: self.SetStatusText(event.message))
         # minimal frame size
         self.SetMinSize((globalvar.GM_WINDOW_SIZE[0], 400))
Modified: grass/trunk/gui/wxpython/modules/extensions.py
--- grass/trunk/gui/wxpython/modules/extensions.py	2012-11-19 13:38:51 UTC (rev 53915)
+++ grass/trunk/gui/wxpython/modules/extensions.py	2012-11-19 14:55:36 UTC (rev 53916)
@@ -40,7 +40,8 @@
 class ExtensionModulesData(object):
-    @todo add doctest
+    @todo add some test
+    @todo this class has some common methods with core::modulesdata::ModulesData
     def __init__(self, modulesDesc):
