[GRASS-SVN] r53973 - in grass/trunk/lib/python/pygrass: . vector
svn_grass at osgeo.org
Fri Nov 23 01:59:50 PST 2012
Author: lucadelu
Date: 2012-11-23 01:59:50 -0800 (Fri, 23 Nov 2012)
New Revision: 53973
grass/trunk/lib/python/pygrass/errors.py
grass/trunk/lib/python/pygrass/vector/abstract.py
Moved must_bo_open decorator to errors
Modified: grass/trunk/lib/python/pygrass/errors.py
--- grass/trunk/lib/python/pygrass/errors.py 2012-11-22 12:26:11 UTC (rev 53972)
+++ grass/trunk/lib/python/pygrass/errors.py 2012-11-23 09:59:50 UTC (rev 53973)
@@ -5,6 +5,7 @@
@author: pietro
+from grass.script import warning
class GrassError(Exception):
def __init__(self, value):
@@ -19,4 +20,12 @@
self.value = value
def __str__(self):
- return repr(self.value)
\ No newline at end of file
+ return repr(self.value)
+def must_be_open(method):
+ def wrapper(self):
+ if self.is_open():
+ return method(self)
+ else:
+ warning(_("The map is close!"))
+ return wrapper
Modified: grass/trunk/lib/python/pygrass/vector/abstract.py
--- grass/trunk/lib/python/pygrass/vector/abstract.py 2012-11-22 12:26:11 UTC (rev 53972)
+++ grass/trunk/lib/python/pygrass/vector/abstract.py 2012-11-23 09:59:50 UTC (rev 53973)
@@ -10,19 +10,11 @@
from vector_type import MAPTYPE
import pygrass.env as env
-from pygrass.errors import GrassError, OpenError
+from pygrass.errors import GrassError, OpenError, must_be_open
from table import DBlinks
-def must_be_open(method):
- def wrapper(self):
- if self.is_open():
- return method(self)
- else:
- print "You must open the map."
- return wrapper
# VECTOR ABSTRACT CLASS
