[GRASS-SVN] r53974 - grass/trunk/vector/v.out.postgis
Fri Nov 23 03:28:48 PST 2012
Author: martinl
Date: 2012-11-23 03:28:45 -0800 (Fri, 23 Nov 2012)
New Revision: 53974
   grass/trunk/vector/v.out.postgis/create.c
   grass/trunk/vector/v.out.postgis/main.c
v.out.postgis: bugfix (create_pgfile)
	       add error handler for map link
Modified: grass/trunk/vector/v.out.postgis/create.c
--- grass/trunk/vector/v.out.postgis/create.c	2012-11-23 09:59:50 UTC (rev 53973)
+++ grass/trunk/vector/v.out.postgis/create.c	2012-11-23 11:28:45 UTC (rev 53974)
@@ -53,7 +53,7 @@
         int length;
         length = strlen(dsn);
-        conninfo = (char *) G_malloc(length - 3);
+        conninfo = (char *) G_malloc(length - 2);
         for (i = 3; i < length; i++)
             conninfo[i-3] = dsn[i];
         conninfo[length-3] = '\0';
Modified: grass/trunk/vector/v.out.postgis/main.c
--- grass/trunk/vector/v.out.postgis/main.c	2012-11-23 09:59:50 UTC (rev 53973)
+++ grass/trunk/vector/v.out.postgis/main.c	2012-11-23 11:28:45 UTC (rev 53974)
@@ -21,6 +21,8 @@
 #include "local_proto.h"
+static void link_handler(void *);
 int main(int argc, char *argv[])
     struct GModule *module;
@@ -88,7 +90,10 @@
     if (ret == -1)
         G_fatal_error(_("Unable to open vector map <%s>"),
                       params.input->answer);
-    Vect_set_error_handler_io(&In, &Out);
+    Vect_set_error_handler_io(&In, NULL);
+    if (params.olink->answer)
+	G_add_error_handler(link_handler, params.olink->answer);
     if (ret < 2)
         G_warning(_("Unable to open vector map <%s> on topological level"),
@@ -132,3 +137,11 @@
     exit(EXIT_SUCCESS);
+void link_handler(void *p) {
+    const char *link = (const char *) p;
+    G_debug(1, "link_handler: %s", link);
+    if (G_find_vector2(link, G_mapset()))
+	Vect_delete(link);
