[GRASS-SVN] r53976 - grass/trunk/lib/python/pygrass/raster
svn_grass at osgeo.org
Fri Nov 23 03:49:15 PST 2012
Author: lucadelu
Date: 2012-11-23 03:49:14 -0800 (Fri, 23 Nov 2012)
New Revision: 53976
grass/trunk/lib/python/pygrass/raster/abstract.py
add method to get pixel value from pair of coordinates
Modified: grass/trunk/lib/python/pygrass/raster/abstract.py
--- grass/trunk/lib/python/pygrass/raster/abstract.py 2012-11-23 11:45:23 UTC (rev 53975)
+++ grass/trunk/lib/python/pygrass/raster/abstract.py 2012-11-23 11:49:14 UTC (rev 53976)
@@ -23,6 +23,7 @@
import pygrass.env as env
from pygrass.region import Region
+from pygrass.errors import must_be_open
# import raster classes
@@ -280,6 +281,21 @@
self._rows = libraster.Rast_window_rows()
self._cols = libraster.Rast_window_cols()
+ @must_be_open
+ def get_value(self, point, region=None):
+ """This method returns the pixel value of a given pair of coordinates:
+ Parameters
+ point = pair of coordinates in tuple object
+ if not region:
+ region = Region()
+ x, y = env.coor2pixel(point.coords(), region)
+ line = self.get_row(int(x))
+ return line[int(y)]
def has_cats(self):
"""Return True if the raster map has categories"""
if self.exist():
