[GRASS-SVN] r53977 - grass/trunk/lib/python/pygrass/raster
svn_grass at osgeo.org
Fri Nov 23 03:52:49 PST 2012
Author: lucadelu
Date: 2012-11-23 03:52:49 -0800 (Fri, 23 Nov 2012)
New Revision: 53977
grass/trunk/lib/python/pygrass/raster/__init__.py
rewrite method to get pixel value from pair of coordinates for RasterNumpy
Modified: grass/trunk/lib/python/pygrass/raster/__init__.py
--- grass/trunk/lib/python/pygrass/raster/__init__.py 2012-11-23 11:49:14 UTC (rev 53976)
+++ grass/trunk/lib/python/pygrass/raster/__init__.py 2012-11-23 11:52:49 UTC (rev 53977)
@@ -24,6 +24,7 @@
from pygrass.errors import OpenError, must_be_open
from pygrass.region import Region
+import pygrass.env as env
# import raster classes
@@ -650,7 +651,20 @@
grasscore.try_remove(self.filename)
self._fd = None
+ def get_value(self, point, region=None):
+ """This method returns the pixel value of a given pair of coordinates:
+ Parameters
+ point = pair of coordinates in tuple object
+ if not region:
+ region = Region()
+ x, y = env.coor2pixel(point.coords(), region)
+ return self[x][y]
def random_map_only_columns(mapname, mtype, overwrite=True, factor=100):
region = Region()
random_map = RasterRow(mapname)
