[GRASS-SVN] r53978 - in grass/trunk/lib/python/pygrass: . raster vector
Fri Nov 23 04:03:32 PST 2012
Author: lucadelu
Date: 2012-11-23 04:03:32 -0800 (Fri, 23 Nov 2012)
New Revision: 53978
Added:
   grass/trunk/lib/python/pygrass/functions.py
Removed:
   grass/trunk/lib/python/pygrass/env.py
   grass/trunk/lib/python/pygrass/__init__.py
   grass/trunk/lib/python/pygrass/raster/__init__.py
   grass/trunk/lib/python/pygrass/raster/abstract.py
   grass/trunk/lib/python/pygrass/vector/abstract.py
rename env.py to functions.py
Modified: grass/trunk/lib/python/pygrass/__init__.py
--- grass/trunk/lib/python/pygrass/__init__.py	2012-11-23 11:52:49 UTC (rev 53977)
+++ grass/trunk/lib/python/pygrass/__init__.py	2012-11-23 12:03:32 UTC (rev 53978)
@@ -9,13 +9,13 @@
 import os as _os
 import sys as _sys
-_pygrasspath = _os.path.dirname(_os.path.realpath( __file__ )).split(_os.sep)
+_pygrasspath = _os.path.dirname(_os.path.realpath(__file__)).split(_os.sep)
-_sys.path.append(_os.path.join(_os.sep,*_pygrasspath[:-1]))
+_sys.path.append(_os.path.join(_os.sep, *_pygrasspath[:-1]))
 import region
 import raster
 import vector
 import modules
 import errors
-import env
\ No newline at end of file
+import functions
Deleted: grass/trunk/lib/python/pygrass/env.py
--- grass/trunk/lib/python/pygrass/env.py	2012-11-23 11:52:49 UTC (rev 53977)
+++ grass/trunk/lib/python/pygrass/env.py	2012-11-23 12:03:32 UTC (rev 53978)
@@ -1,95 +0,0 @@
-# -*- coding: utf-8 -*-
-Created on Tue Jun 26 12:38:48 2012
- at author: pietro
-import fnmatch
-import grass.lib.gis as libgis
-import grass.lib.raster as libraster
-from grass.script import core as grasscore
-def looking(filter_string, obj):
-    >>> import grass.lib.vector as libvect
-    >>> sorted(looking('*by_box*', libvect))  # doctest: +NORMALIZE_WHITESPACE
-    ['Vect_select_areas_by_box', 'Vect_select_isles_by_box',
-     'Vect_select_lines_by_box', 'Vect_select_nodes_by_box']
-    word_list = [i for i in dir(obj)]
-    word_list.sort()
-    return fnmatch.filter(word_list, filter_string)
-def remove(**kargs):
-    grasscore.run_command('g.remove', **kargs)
-def rename(oldname, newname, maptype):
-    grasscore.run_command('g.rename',
-                          **{maptype: '{old},{new}'.format(old=oldname,
-                                                           new=newname), })
-def copy(existingmap, newmap, maptype):
-    grasscore.run_command('g.copy',
-                          **{maptype: '{old},{new}'.format(old=existingmap,
-                                                           new=newmap), })
-def get_mapset_raster(mapname, mapset=''):
-    return libgis.G_find_raster(mapname, '')
-def get_mapset_vector(mapname, mapset=''):
-    return libgis.G_find_vector(mapname, '')
-def exist(mapname, mapset=''):
-    mapset = get_mapset_raster(mapname, mapset)
-    if mapset != '':
-        return True
-    else:
-        mapset = get_mapset_vector(mapname, mapset)
-        if mapset:
-            return True
-    return False
-def clean_map_name(name):
-    name.strip()
-    for char in ' @#^?°,;%&/':
-        name = name.replace(char, '')
-    return name
-def coor2pixel((east, north), region):
-    """Convert coordinates into a pixel row and col ::
-        >>> from pygrass.region import Region
-        >>> reg = Region()
-        >>> coor2pixel((reg.west, reg.north), reg)
-        (0.0, 0.0)
-        >>> coor2pixel((reg.east, reg.south), reg) == (reg.cols, reg.rows)
-        True
-    return (libraster.Rast_northing_to_row(north, region.c_region),
-            libraster.Rast_easting_to_col(east, region.c_region))
-def pixel2coor((col, row), region):
-    """Convert row and col of a pixel into a coordinates ::
-        >>> pixel2coor((0, 0), reg) == (reg.north, reg.west)
-        True
-        >>> pixel2coor((reg.cols, reg.rows), reg) == (reg.east, reg.south)
-        True
-    return (libraster.Rast_row_to_northing(row, region.c_region),
-            libraster.Rast_col_to_easting(col, region.c_region))
Copied: grass/trunk/lib/python/pygrass/functions.py (from rev 53975, grass/trunk/lib/python/pygrass/env.py)
--- grass/trunk/lib/python/pygrass/functions.py	                        (rev 0)
+++ grass/trunk/lib/python/pygrass/functions.py	2012-11-23 12:03:32 UTC (rev 53978)
@@ -0,0 +1,95 @@
+# -*- coding: utf-8 -*-
+Created on Tue Jun 26 12:38:48 2012
+ at author: pietro
+import fnmatch
+import grass.lib.gis as libgis
+import grass.lib.raster as libraster
+from grass.script import core as grasscore
+def looking(filter_string, obj):
+    >>> import grass.lib.vector as libvect
+    >>> sorted(looking('*by_box*', libvect))  # doctest: +NORMALIZE_WHITESPACE
+    ['Vect_select_areas_by_box', 'Vect_select_isles_by_box',
+     'Vect_select_lines_by_box', 'Vect_select_nodes_by_box']
+    word_list = [i for i in dir(obj)]
+    word_list.sort()
+    return fnmatch.filter(word_list, filter_string)
+def remove(**kargs):
+    grasscore.run_command('g.remove', **kargs)
+def rename(oldname, newname, maptype):
+    grasscore.run_command('g.rename',
+                          **{maptype: '{old},{new}'.format(old=oldname,
+                                                           new=newname), })
+def copy(existingmap, newmap, maptype):
+    grasscore.run_command('g.copy',
+                          **{maptype: '{old},{new}'.format(old=existingmap,
+                                                           new=newmap), })
+def get_mapset_raster(mapname, mapset=''):
+    return libgis.G_find_raster(mapname, '')
+def get_mapset_vector(mapname, mapset=''):
+    return libgis.G_find_vector(mapname, '')
+def exist(mapname, mapset=''):
+    mapset = get_mapset_raster(mapname, mapset)
+    if mapset != '':
+        return True
+    else:
+        mapset = get_mapset_vector(mapname, mapset)
+        if mapset:
+            return True
+    return False
+def clean_map_name(name):
+    name.strip()
+    for char in ' @#^?°,;%&/':
+        name = name.replace(char, '')
+    return name
+def coor2pixel((east, north), region):
+    """Convert coordinates into a pixel row and col ::
+        >>> from pygrass.region import Region
+        >>> reg = Region()
+        >>> coor2pixel((reg.west, reg.north), reg)
+        (0.0, 0.0)
+        >>> coor2pixel((reg.east, reg.south), reg) == (reg.cols, reg.rows)
+        True
+    return (libraster.Rast_northing_to_row(north, region.c_region),
+            libraster.Rast_easting_to_col(east, region.c_region))
+def pixel2coor((col, row), region):
+    """Convert row and col of a pixel into a coordinates ::
+        >>> pixel2coor((0, 0), reg) == (reg.north, reg.west)
+        True
+        >>> pixel2coor((reg.cols, reg.rows), reg) == (reg.east, reg.south)
+        True
+    return (libraster.Rast_row_to_northing(row, region.c_region),
+            libraster.Rast_col_to_easting(col, region.c_region))
Modified: grass/trunk/lib/python/pygrass/raster/__init__.py
--- grass/trunk/lib/python/pygrass/raster/__init__.py	2012-11-23 11:52:49 UTC (rev 53977)
+++ grass/trunk/lib/python/pygrass/raster/__init__.py	2012-11-23 12:03:32 UTC (rev 53978)
@@ -24,7 +24,7 @@
 from pygrass.errors import OpenError, must_be_open
-import pygrass.env as env
+from pygrass import functions
 # import raster classes
@@ -661,7 +661,7 @@
         if not region:
             region = Region()
-        x, y = env.coor2pixel(point.coords(), region)
+        x, y = functions.coor2pixel(point.coords(), region)
         return self[x][y]
Modified: grass/trunk/lib/python/pygrass/raster/abstract.py
--- grass/trunk/lib/python/pygrass/raster/abstract.py	2012-11-23 11:52:49 UTC (rev 53977)
+++ grass/trunk/lib/python/pygrass/raster/abstract.py	2012-11-23 12:03:32 UTC (rev 53978)
@@ -21,7 +21,7 @@
 # import pygrass modules
+import pygrass as functions
 from pygrass.errors import must_be_open
@@ -122,7 +122,7 @@
     def _set_name(self, newname):
         """Private method to change the Raster name"""
         #import pdb; pdb.set_trace()
-        cleanname = env.clean_map_name(newname)
+        cleanname = functions.clean_map_name(newname)
         if self.exist():
             self.rename(cleanname)
         self._name = cleanname
@@ -212,7 +212,7 @@
         call the C function `G_find_raster`."""
         if self.name:
-            self.mapset = env.get_mapset_raster(self.name, self.mapset)
+            self.mapset = functions.get_mapset_raster(self.name, self.mapset)
         else:
             return False
         if self.mapset:
@@ -258,7 +258,7 @@
     def rename(self, newname):
         """Rename the map"""
         if self.exist():
-            env.rename(self.name, newname, 'rast')
+            functions.rename(self.name, newname, 'rast')
         self._name = newname
     def set_from_rast(self, rastname='', mapset=''):
@@ -292,7 +292,7 @@
         if not region:
             region = Region()
         line = self.get_row(int(x))
         return line[int(y)]
Modified: grass/trunk/lib/python/pygrass/vector/abstract.py
--- grass/trunk/lib/python/pygrass/vector/abstract.py	2012-11-23 11:52:49 UTC (rev 53977)
+++ grass/trunk/lib/python/pygrass/vector/abstract.py	2012-11-23 12:03:32 UTC (rev 53978)
@@ -9,16 +9,15 @@
 from vector_type import MAPTYPE
 from pygrass.errors import GrassError, OpenError, must_be_open
 from table import DBlinks
 # VECTOR ABSTRACT CLASS
 class Info(object):
     """Basic vector info.
     To get access to the vector info the map must be opened. ::
@@ -201,7 +200,7 @@
         if self.exist():
-            env.rename(self.name, newname, 'vect')
+            functions.rename(self.name, newname, 'vect')
     def is_3D(self):
@@ -209,7 +208,7 @@
     def exist(self):
         if self._name:
-            self.mapset = env.get_mapset_vector(self._name, self.mapset)
+            self.mapset = functions.get_mapset_vector(self._name, self.mapset)
         else:
             return False
         if self.mapset:
@@ -271,7 +270,7 @@
         """Remove vector map"""
         if self.is_open():
             self.close()
-        env.remove(vect=self.name)
+        functions.remove(vect=self.name)
     def build(self):
         """Close the vector map and build vector Topology"""
