[GRASS-SVN] r54052 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Mon Nov 26 08:09:07 PST 2012
Author: zarch
Date: 2012-11-26 08:09:06 -0800 (Mon, 26 Nov 2012)
New Revision: 54052
grass/trunk/lib/python/pygrass/vector/__init__.py
grass/trunk/lib/python/pygrass/vector/abstract.py
grass/trunk/lib/python/pygrass/vector/geometry.py
Fix, before to modify the attribute table check if we are in the current mapset.
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py 2012-11-26 16:08:51 UTC (rev 54051)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py 2012-11-26 16:09:06 UTC (rev 54052)
@@ -13,6 +13,7 @@
# import pygrass modules
from pygrass.errors import GrassError
+from pygrass.functions import getenv
import geometry
from abstract import Info
@@ -296,7 +297,8 @@
if vtype in _GEOOBJ.keys():
if _GEOOBJ[vtype] is not None:
return (_GEOOBJ[vtype](v_id=indx, c_mapinfo=self.c_mapinfo,
- table=self.table)
+ table=self.table,
+ write=self.write)
for indx in xrange(1, self.number_of(vtype) + 1))
else:
keys = "', '".join(sorted(_GEOOBJ.keys()))
@@ -364,7 +366,8 @@
c_points=c_points,
c_cats=c_cats,
- table=self.table)
+ table=self.table,
+ write=self.write)
else:
raise ValueError('The index must be >0, %r given.' % feature_id)
Modified: grass/trunk/lib/python/pygrass/vector/abstract.py
--- grass/trunk/lib/python/pygrass/vector/abstract.py 2012-11-26 16:08:51 UTC (rev 54051)
+++ grass/trunk/lib/python/pygrass/vector/abstract.py 2012-11-26 16:09:06 UTC (rev 54052)
@@ -262,6 +262,7 @@
raise OpenError(str_err % openvect)
# istantiate the table
self.table = self.get_table(link_id=self.link_id)
+ self.write = self.mapset == functions.getenv("MAPSET")
def get_table(self, link_id=None, link_name=None,):
if link_id is None and link_name is None and len(self.dblinks) == 0:
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py 2012-11-26 16:08:51 UTC (rev 54051)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py 2012-11-26 16:09:06 UTC (rev 54052)
@@ -13,6 +13,8 @@
import grass.lib.gis as libgis
import grass.lib.vector as libvect
+from pygrass.errors import GrassError
from basic import Ilist, Bbox, Cats
import sql
@@ -110,10 +112,11 @@
class Attrs(object):
- def __init__(self, v_id, table):
+ def __init__(self, v_id, table, write=False):
self.id = v_id
self.table = table
self.cond = "%s=%d" % (self.table.key, self.id)
+ self.write = write
def __getitem__(self, key):
"""Return the value stored in the attribute table. ::
@@ -136,12 +139,17 @@
>>> attrs['LABEL'] = 'New Label'
- #UPDATE {tname} SET {new_col} = {old_col} WHERE {condition}
- self.table.execute(sql.UPDATE_WHERE.format(tname=self.table.name,
- new_col=key,
- old_col=repr(value),
- condition=self.cond))
- #self.table.conn.commit()
+ if self.write:
+ #UPDATE {tname} SET {new_col} = {old_col} WHERE {condition}
+ self.table.execute(sql.UPDATE_WHERE.format(tname=self.table.name,
+ new_col=key,
+ old_col=repr(value),
+ condition=self.cond))
+ #self.table.conn.commit()
+ else:
+ str_err = "You can only read the attributes if the map is \
+in another mapset"
+ raise GrassError(str_err)
def __dict__(self):
"""Reurn a dict of the attribute table row."""
@@ -175,7 +183,7 @@
>>> geo1 = Geo(c_points=points, c_cats=cats)
def __init__(self, v_id=None, c_mapinfo=None, c_points=None, c_cats=None,
- table=None):
+ table=None, write=False):
self.id = v_id # vector id
self.c_mapinfo = c_mapinfo
@@ -193,7 +201,7 @@
# set the attributes
if table:
- self.attrs = Attrs(self.id, table)
+ self.attrs = Attrs(self.id, table, write)
def is_with_topology(self):
if self.c_mapinfo is not None:
