[GRASS-SVN] r54053 - grass/trunk/db/db.copy
svn_grass at osgeo.org
Mon Nov 26 08:19:36 PST 2012
Author: neteler
Date: 2012-11-26 08:19:36 -0800 (Mon, 26 Nov 2012)
New Revision: 54053
grass/trunk/db/db.copy/db.copy.html
updated to reflect new behaviour of storing sqlite DB in subdir; modernized
Modified: grass/trunk/db/db.copy/db.copy.html
--- grass/trunk/db/db.copy/db.copy.html 2012-11-26 16:09:06 UTC (rev 54052)
+++ grass/trunk/db/db.copy/db.copy.html 2012-11-26 16:19:36 UTC (rev 54053)
@@ -13,59 +13,61 @@
<h3>DBF -> PG</h3>
-<em>Storing table 'markveggy.dbf' (in current directory) into PostgreSQL
+<em>Storing table 'geonames.dbf' (in current directory) into PostgreSQL
through ODBC:</em><br>
<div class="code"><pre>
-db.copy from_driver=dbf from_database=$HOME/grassdata/spearfish60/user1/dbf \
- from_table=markveggy to_driver=pg to_database="host=pgserver,dbname=grass6test" \
- to_table=markveggy
+db.copy from_driver=dbf from_database=$HOME/grassdata/nc_spm_08/user1/dbf \
+ from_table=geonames to_driver=pg to_database="host=pgserver,dbname=testdb" \
+ to_table=geonames
</pre></div>
<h3>PG -> DBF</h3>
-db.copy from_driver=pg from_database="host=pgserver.itc.it,dbname=testdb" \
+db.copy from_driver=pg from_database="host=pgserver.example.org,dbname=testdb" \
from_table=origtable to_driver=dbf \
- to_database=$HOME/grassdata/spearfish60/user1/dbf to_table=origtable
+ to_database=$HOME/grassdata/nc_spm_08/user1/dbf to_table=origtable
</pre></div>
<h3>PG -> PG with condition</h3>
-db.copy from_driver=pg from_database="host=localhost,dbname=meteo" \
- from_table=ukraine to_driver=pg to_database="host=localhost,dbname=meteo" \
- to_table=selection where="cat < 500"
+db.copy from_driver=pg from_database="host=localhost,dbname=testdb" \
+ from_table=geonames to_driver=pg to_database="host=localhost,dbname=testdb" \
+ to_table=selection where="cat < 500"
</pre></div>
<h3>DBF -> SQLite</h3>
- from_table=ammprv to_driver=sqlite \
- to_database=$HOME/grassdata/spearfish60/user1/sqlite.db to_table=ammprv
+db.copy from_driver=dbf from_database='$GISDBASE/$LOCATION_NAME/$MAPSET/PERMANENT/dbf \
+ from_table=geonames_features to_driver=sqlite \
+ to_database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db' to_table=geonames_features
# convenient viewer:
-sqlitebrowser $HOME/grassdata/spearfish60/user1/sqlite.db
+sqlitebrowser $HOME/grassdata/nc_spm_08/user1/sqlite/sqlite.db
</pre></div>
<h3>SQLite -> DBF</h3>
-db.copy from_driver=sqlite from_database=$HOME/grassdata/spearfish60/user1/sqlite.db \
- from_table=ammprv to_driver=dbf to_database=$HOME/grassdata/spearfish60/user1/dbf \
+db.copy from_driver=sqlite from_database=$HOME/grassdata/nc_spm_08/user1/sqlite.db \
+ from_table=ammprv to_driver=dbf to_database=$HOME/grassdata/nc_spm_08/user1/dbf \
to_table=ammprv
</pre></div>
<h2>SEE ALSO</h2>
-<em><a href="v.db.connect.html">v.db.connect</a>,
+<em>
+<a href="v.db.connect.html">v.db.connect</a>,
<a href="db.drivers.html">db.drivers</a>,
<a href="db.login.html">db.login</a>,
<a href="v.clean.html">v.clean</a>,
-<a href="sql.html">GRASS SQL interface</a></em>
+<a href="sql.html">GRASS SQL interface</a>
+</em>
<h2>AUTHOR</h2>
