[GRASS-SVN] r54054 - grass/trunk/vector/v.db.connect
Mon Nov 26 08:21:38 PST 2012
Author: neteler
Date: 2012-11-26 08:21:38 -0800 (Mon, 26 Nov 2012)
New Revision: 54054
   grass/trunk/vector/v.db.connect/v.db.connect.html
updated to reflect new behaviour of storing sqlite DB in subdir
Modified: grass/trunk/vector/v.db.connect/v.db.connect.html
--- grass/trunk/vector/v.db.connect/v.db.connect.html	2012-11-26 16:19:36 UTC (rev 54053)
+++ grass/trunk/vector/v.db.connect/v.db.connect.html	2012-11-26 16:21:38 UTC (rev 54054)
@@ -71,10 +71,10 @@
 Very similar to DBF driver example above.
 <div class="code"><pre>
-db.connect driver=sqlite database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db'
+db.connect driver=sqlite database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
 db.tables -p
 v.db.connect map=vectormap table=table driver=sqlite \
-             database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db'
+             database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
 v.db.connect -p map=vectormap
 </pre></div>
