[GRASS-SVN] r54076 - grass/trunk/gui/wxpython/xml
svn_grass at osgeo.org
Tue Nov 27 04:41:16 PST 2012
Author: martinl
Date: 2012-11-27 04:41:14 -0800 (Tue, 27 Nov 2012)
New Revision: 54076
grass/trunk/gui/wxpython/xml/menudata.xml
wxGUI: add v.out.postgis to the menu
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml 2012-11-27 11:29:13 UTC (rev 54075)
+++ grass/trunk/gui/wxpython/xml/menudata.xml 2012-11-27 12:41:14 UTC (rev 54076)
@@ -311,7 +311,7 @@
</menuitem>
<menuitem>
<label>Raw binary array 3D import</label>
- <help>Import a binary raster file into a GRASS 3D raster map.</help>
+ <help>Imports a binary raster file into a GRASS 3D raster map.</help>
<keywords>raster3d,import</keywords>
<handler>OnMenuCmd</handler>
<command>r3.in.bin</command>
@@ -492,6 +492,13 @@
<command>v.out.gps</command>
</menuitem>
<menuitem>
+ <label>PostGIS export</label>
+ <help>Exports a vector map layer to PostGIS feature table.</help>
+ <keywords>vector,export,PostGIS,simple features,topology</keywords>
+ <handler>OnMenuCmd</handler>
+ <command>v.out.postgis</command>
+ </menuitem>
+ <menuitem>
<label>POV-Ray export</label>
<help>Converts GRASS x,y,z points to POV-Ray x,z,y format.</help>
<keywords>vector,export</keywords>
