[GRASS-SVN] r54077 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Tue Nov 27 05:24:56 PST 2012
Author: martinl
Date: 2012-11-27 05:24:56 -0800 (Tue, 27 Nov 2012)
New Revision: 54077
grass/trunk/lib/vector/Vlib/write_pg.c
vlib/PostGIS Topo: fix update_topo_edge() - next left/right edge
Modified: grass/trunk/lib/vector/Vlib/write_pg.c
--- grass/trunk/lib/vector/Vlib/write_pg.c 2012-11-27 12:41:14 UTC (rev 54076)
+++ grass/trunk/lib/vector/Vlib/write_pg.c 2012-11-27 13:24:56 UTC (rev 54077)
@@ -56,7 +56,7 @@
static char *build_insert_stmt(const struct Format_info_pg *, const char *,
int, const struct field_info *);
static int insert_topo_element(struct Map_info *, int, int, const char *);
-static int update_next_edge(struct Map_info*, int, int, int*, int *);
+static int update_next_edge(struct Map_info*, int, int);
static int insert_face(struct Map_info *, int);
static int update_topo_edge(struct Map_info *, int);
static int update_topo_face(struct Map_info *, int);
@@ -1260,13 +1260,12 @@
\param[out] left left line
\param[out] right right line
- \return 0 on success
- \return -1 on failure
+ \return left (line < 0) or right (line > 0) next edge
+ \return 0 on failure
-int update_next_edge(struct Map_info* Map, int nlines, int line,
- int *left, int *right)
+int update_next_edge(struct Map_info* Map, int nlines, int line)
- int next_line, edge;
+ int ret, next_line, edge;
char stmt[DB_SQL_MAX];
const struct Format_info_pg *pg_info;
@@ -1284,30 +1283,30 @@
G_debug(3, "line=%d next_line=%d", line, next_line);
if (next_line == 0) {
G_warning(_("Invalid topology"));
- return -1;
+ return 0;
Line = Map->plus.Line[abs(line)];
Line_next = Map->plus.Line[abs(next_line)];
if (!Line || !Line_next) {
- return -1;
+ return 0;
if (line > 0) {
edge = Line->offset;
- *right = next_line > 0 ? Line_next->offset : -Line_next->offset;
+ ret = next_line > 0 ? Line_next->offset : -Line_next->offset;
else {
edge = -Line->offset;
- *left = next_line > 0 ? Line_next->offset : -Line_next->offset;
if (next_line < 0) {
sprintf(stmt, "UPDATE \"%s\".edge_data SET next_left_edge = %d, "
- "abs_next_left_edge = %d WHERE edge_id = %lu",
- pg_info->toposchema_name, edge, abs(edge), Line_next->offset);
- G_debug(3, "update edge=%lu next_left_edge=%d", Line_next->offset, edge);
+ "abs_next_left_edge = %d WHERE edge_id = %lu AND abs_next_left_edge = %lu",
+ pg_info->toposchema_name, edge, abs(edge), Line_next->offset, Line_next->offset);
+ G_debug(3, "update edge=%lu next_left_edge=%d (?)", Line_next->offset, edge);
else {
sprintf(stmt, "UPDATE \"%s\".edge_data SET next_right_edge = %d, "
@@ -1318,7 +1317,7 @@
if(Vect__execute_pg(pg_info->conn, stmt) == -1) {
Vect__execute_pg(pg_info->conn, "ROLLBACK");
- return -1;
+ return 0;
if (nlines > 2) {
@@ -1338,18 +1337,18 @@
else {
- "abs_next_right_edge = %d WHERE edge_id = %lu AND abs_next_right_edge = %lu",
- pg_info->toposchema_name, edge, abs(edge), Line_next->offset, Line_next->offset);
- G_debug(3, "update edge=%lu next_right_edge=%d (?)", Line_next->offset, edge);
+ "abs_next_right_edge = %d WHERE edge_id = %lu",
+ pg_info->toposchema_name, edge, abs(edge), Line_next->offset);
+ G_debug(3, "update edge=%lu next_right_edge=%d", Line_next->offset, edge);
- return -1;
+ return 0;
- return 0;
+ return ret;
@@ -1415,8 +1414,8 @@
int update_topo_edge(struct Map_info *Map, int line)
- int n1, n2;
- int nle, nre;
+ int i, n;
+ int nle, nre, next_edge;
@@ -1436,28 +1435,57 @@
struct P_topo_l *topo = (struct P_topo_l *) Line->topo;
- /* get number of lines for each node */
- n1 = Vect_get_node_n_lines(Map, topo->N1);
- n2 = Vect_get_node_n_lines(Map, topo->N2);
+ nre = nle = 0; /* edge = 0 is an illegal value */
- nre = nle = 0;
/* check for line connection */
- if (n1 > 1) {
- update_next_edge(Map, n1, line, &nle, &nre);
+ for (i = 0; i < 2; i++) {
+ /* first check start node then end node */
+ n = i == 0 ? Vect_get_node_n_lines(Map, topo->N1)
+ : Vect_get_node_n_lines(Map, topo->N2);
+ if (n < 2) /* no connection */
+ continue;
+ next_edge = update_next_edge(Map, n,
+ i == 0 ? line : -line);
+ if (next_edge != 0) {
+ if (i == 0)
+ nre = next_edge; /* update next right edge for start node */
+ else
+ nle = next_edge; /* update next left edge for end node */
+ else {
+ G_warning(_("Inconsistency in topology detected. "
+ "Unable to determine next left/right edge."));
+ return -1;
- if (n2 > 1) {
- update_next_edge(Map, n2, -line, &nle, &nre);
if (nle == 0 && nre == 0) /* nothing changed */
return 0;
- sprintf(stmt, "UPDATE \"%s\".edge_data SET "
- "next_left_edge = %d, abs_next_left_edge = %d, "
- "next_right_edge = %d, abs_next_right_edge = %d "
- "WHERE edge_id = %lu", pg_info->toposchema_name,
- nle, abs(nle), nre, abs(nre), Line->offset);
+ if (nle != 0 && nre != 0) {
+ /* update both next left and right edge */
+ sprintf(stmt, "UPDATE \"%s\".edge_data SET "
+ "next_left_edge = %d, abs_next_left_edge = %d, "
+ "next_right_edge = %d, abs_next_right_edge = %d "
+ "WHERE edge_id = %lu", pg_info->toposchema_name,
+ nle, abs(nle), nre, abs(nre), Line->offset);
+ else if (nle != 0) {
+ /* update next left edge only */
+ "next_left_edge = %d, abs_next_left_edge = %d "
+ nle, abs(nle), Line->offset);
+ else {
+ /* update next right edge only */
+ nre, abs(nre), Line->offset);
G_debug(3, "update edge=%lu next_left_edge=%d next_right_edge=%d",
Line->offset, nle, nre);
