[GRASS-SVN] r54078 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Tue Nov 27 05:53:36 PST 2012
Author: martinl
Date: 2012-11-27 05:53:35 -0800 (Tue, 27 Nov 2012)
New Revision: 54078
grass/trunk/lib/vector/Vlib/build_pg.c
grass/trunk/lib/vector/Vlib/copy.c
vlib (PostGIS Topo): update TopoGeometry data also for centroids
Modified: grass/trunk/lib/vector/Vlib/build_pg.c
--- grass/trunk/lib/vector/Vlib/build_pg.c 2012-11-27 13:24:56 UTC (rev 54077)
+++ grass/trunk/lib/vector/Vlib/build_pg.c 2012-11-27 13:53:35 UTC (rev 54078)
@@ -122,11 +122,13 @@
int build_topo(struct Map_info *Map, int build)
- int i, type;
+ int line, nlines, type;
char stmt[DB_SQL_MAX];
struct Plus_head *plus;
struct Format_info_pg *pg_info;
+ struct P_line *Line;
+ struct P_topo_c *topo;
plus = &(Map->plus);
pg_info = &(Map->fInfo.pg);
@@ -163,33 +165,31 @@
/* store map boundig box in DB */
save_map_bbox(pg_info, &(plus->box));
- i = 0;
- Vect_rewind(Map);
if (Vect__execute_pg(pg_info->conn, "BEGIN"))
return 0;
G_message(_("Updating TopoGeometry data..."));
- while (TRUE) {
- type = Vect_read_next_line(Map, NULL, NULL);
- if (type == -1) {
- G_warning(_("Unable to read vector map"));
- return 0;
- else if (type == -2) {
- break;
- G_progress(++i, 1e3);
+ nlines = Vect_get_num_lines(Map);
+ for(line = 1; line <= nlines; line++) {
+ type = Vect_read_line(Map, NULL, NULL, line);
+ G_percent(line, nlines, 3);
/* update topogeometry elements in feature table */
- if (type == GV_POINT || type == GV_LINE) {
- if (build_topogeom_stmt(pg_info, i, type, stmt) &&
+ if (type == GV_POINT || type == GV_LINE || type == GV_CENTROID) {
+ Line = Map->plus.Line[line];
+ if (!Line) {
+ G_warning(_("Inconsistency in topology detected. "
+ "Dead line found."));
+ topo = (struct P_topo_c *) Line->topo;
+ if (build_topogeom_stmt(pg_info, topo->area, type, stmt) &&
Vect__execute_pg(pg_info->conn, stmt) == -1) {
Vect__execute_pg(pg_info->conn, "ROLLBACK");
return 0;
- G_progress(1, 1);
if (Vect__execute_pg(pg_info->conn, "COMMIT") == -1)
return 0;
@@ -214,28 +214,23 @@
int topogeom_type;
- if (type == GV_POINT)
+ switch(type) {
+ case GV_POINT:
topogeom_type = 1;
- else if (type & GV_LINES)
+ break;
+ case GV_LINE:
+ case GV_BOUNDARY:
topogeom_type = 2;
- else {
+ break;
+ case GV_CENTROID:
+ topogeom_type = 3;
+ break;
+ default:
G_warning(_("Unsupported topo geometry type %d"), type);
return 0;
- /* it's quite slow...
sprintf(stmt, "UPDATE \"%s\".\"%s\" SET %s = "
- "topology.CreateTopoGeom('%s', %d, 1,"
- "'{{%d, %d}}'::topology.topoelementarray) "
- "WHERE %s = %d",
- pg_info->schema_name, pg_info->table_name,
- pg_info->topogeom_column, pg_info->toposchema_name,
- topogeom_type, id, topogeom_type,
- pg_info->fid_column, id);
- sprintf(stmt, "UPDATE \"%s\".\"%s\" SET %s = "
"'(%d, 1, %d, %d)'::topology.TopoGeometry "
"WHERE %s = %d",
Modified: grass/trunk/lib/vector/Vlib/copy.c
--- grass/trunk/lib/vector/Vlib/copy.c 2012-11-27 13:24:56 UTC (rev 54077)
+++ grass/trunk/lib/vector/Vlib/copy.c 2012-11-27 13:53:35 UTC (rev 54078)
@@ -291,7 +291,8 @@
with_z = Vect_is_3d(In);
nnodes = Vect_get_num_nodes(In);
- G_message(_("Exporting nodes..."));
+ if (nnodes > 0)
+ G_message(_("Exporting nodes..."));
Vect_append_point(Points, 0., 0., 0.);
for (node = 1; node <= nnodes; node++) {
G_debug(3, "Exporting GRASS node %d", node);
